Adding factory keyless entry to your 1st gen S-Series - S-10 Forum
post #1 of 3 Old 07-26-2009, 12:54 AM Thread Starter
It's a drag being me
AustinBlazer's Avatar
User is: AustinBlazer is offline
Cool Adding factory keyless entry to your 1st gen S-Series
This is an ongoing project in my how-to series on adding factory options my truck that it either didn't come with or never had. This is mostly for guys like Golana and myself. LOL! As well as Syclone owners that want to use stock parts.
Difficulty: 5/10 (10 hardest)
This is a how-to on installing FACTORY keyless entry in your 1st gen S-series that has power locks.
Install at your own risk as this involves a little wiring work.
Hate having aftermarket keyless remotes? Truck never came with factory keyless and you want to keep stock appearances? This is for you! I will install a GM Goodwrench alarm system next.
What you will need:
1. factory keyless remote module with some wiring and connector (located under center console usually) and remote(s). Or you can use the module from many GM cars of the '90s, I know W bodies (Grand Prix, Cutlass, Regal, Lumina) from 1990-1996 use the same module.
2: length of wire. 18 gauge will be fine.
3. phillips screwdriver.
4. largish flat blade screwdriver
5. T15 Torx
6. wire cutters/strippers
7. 7 mm (9/32) socket and ratchet or nut driver
8. spade connector
9. soldering iron and solder
10. Shrinkwrap or electrical tape
11. beer (optional)
Here is a pic of the power lock module for reference, I got mine out of a 1993 Jimmy thanks to the 4WDFactory. (Thanks 4wdjoey!)
First thing to do figure out where to mount the module. I put mine under the passenger seat. Just a couple of small screws to keep it bolted to the floor. I removed the center consoles to run the wiring as well.
Then unbolt the covers underneath the driver's side of the dash.
Locate the power lock relay, it is just above the accelerator pedal.
You will need to remove the driver's door panel and driver's kick panel as well.
Here's the wiring for the RKE module:
Pin A: Orange/Black wire - Hot at all times. I went to the left side of the fuse box with this.
Pin B: Tan wire - Driver's power lock solenoid. I went along the door wiring to the solenoid and tied it to the tan wire.
Pin C: Purple wire - pin 4 of the ALDL connector.
Pin D: Orange/Black wire - Hot at all times. I tied this in with the other O/B wire at pin A.
Pin E: Black wire - ground. I ran this to an existing ground on the steering column, I also ran another wire from this to pin 8 of the ALDL connector.
Pin F: Lt. blue wire - lock switch. I ran this to the lt. blue wire on the power lock relay.
Pin G: black wire - unlock switch. I ran this to the black wire on the power lock relay.
Programming your RKE remotes:
Find the data line connector.
It is located under dashboard on driver's side of vehicle.
The top row of pins reads left to right and are numbered 1 through 8.
Locate pins 4 and 8.
If you have metal contacts in pins 4 and 8 then you have keyless entry.
Connect pin 4 to pin 8 with a jumper wire.
The door locks should lock and unlock to signify entering of programming mode.
Now press and hold both the LOCK and UNLOCK buttons on your remote until the door locks lock and unlock.
Repeat for each transmitter to be programmed.
When finished remove the jumper wire from the data line connector.
Tie the wires up out of the way and replace all panels. And you're done!
I will add to this later when I install the factory alarm system.
My S-Series has W body parts. Meaning it's a bigger piece of sh*t than all of yours combined.
My build.
post #2 of 3 Old 07-26-2009, 02:50 AM Thread Starter
Re: Adding factory keyless entry to your 1st gen S-Series
For ****'s sake...I just learned this won't work on most 2 doors...
My build.
post #3 of 3 Old 08-21-2011, 10:56 AM
24digger's Avatar
User is: 24digger is offline
I know this is old, but trying to get this to work.
Has anyone been successful?
I have picked up a blazer relay, still no luck in getting it to work. I also read that it may be required to change the lock switch. Hoping this is not the case.
24digger is offline
