97 jimmy composite headlight question
Old 11-04-2009, 12:28 AM   #1
You...Tonight
mostizzle's Avatar
ok guys i swear i searched and i turned up nuthin. anyways,i'm putting these headlights on my s10 this weekend and i wanna be sure about which is the high beam and which is the low beam. they're side by side so is the inside the low beam? and is the 9006 the low? thanks guys
Old 11-04-2009, 12:30 AM   #2
forum idiot
orangesonoma's Avatar
Re: 97 jimmy composite headlight question
gmc headlights from 94-97 are lows on the outside and highs in the middle..and yes 9006 are lows and 9005 are high
Old 11-04-2009, 12:38 AM   #3
You...Tonight
mostizzle's Avatar
thanks brian i appreciate it.
Old 11-04-2009, 12:40 AM   #4
You...Tonight
mostizzle's Avatar
would you also happen to know if when i splice into the stock harness if the hot wires are the same color or not?
Old 11-04-2009, 12:42 AM   #5
You...Tonight
mostizzle's Avatar
as in the hot wires for the highs and lows on the sealed beams in relation to the composites lol sorry man it's past my bed time lol
Old 11-04-2009, 12:44 AM   #6
forum idiot
i knew what you meant...not sure on colors matching... i know the driver side will have 6 wires and the passenger will have 3
they jump from the one plug to the other...black is ground...
but get a test light and test them...its simple...
Old 11-04-2009, 12:56 AM   #7
You...Tonight
mostizzle's Avatar
cool man thanks
Old 11-04-2009, 09:46 AM   #8
... i dont know?
old_skool_noma's Avatar
i concur, and those headlights are seckzie
ill check my wire colors in a little bit for high and low beam since i went from sealed beam to composite as well
Old 11-04-2009, 08:14 PM   #9
You...Tonight
mostizzle's Avatar
sweet man i'd appreciate it. i'm just tryin to weasle my way outta havin to bust out the voltmeter and all that cuz ima lazy douche
Old 11-05-2009, 12:47 AM   #10
... i dont know?
could just do it like me, wire it backwards about 2-3 times before you get it right
anyway, brown high, green low
Old 11-05-2009, 09:17 PM   #11
You...Tonight
mostizzle's Avatar
lmao thanks man ur the shit. i'll throw sum pics up when i'm done this weekend sumtime if all goes well
Old 11-05-2009, 09:18 PM   #12
throwin' codes
slick203's Avatar
http://www.s10forum.com/forum/f72/blazer-lights-361102/
Old 11-05-2009, 09:20 PM   #13
throwin' codes
slick203's Avatar
hope that helps... I'm getting ready to do a composite swap as well... post some pics when your done!
Old 11-05-2009, 10:37 PM   #14
... i dont know?
to be honest i just built a headlight wire upgrade + conversion harness for ssfan it should make the swap go pretty smooth, not to mention the added light output, im thinking about hooking it up in my truck tomorrow just to make sure everything works smoothly and ive got everything plugged into the right place, im worried about my diode being backwards and some of the headlight wires as well since i had the tech flex on them before i plugged them in and dumb ass me didnt mark wires.
Old 11-05-2009, 11:10 PM   #15
... i dont know?
speaking of the harness heres the pics of it
Old 11-06-2009, 12:02 AM   #16
You...Tonight
mostizzle's Avatar
i mite get around to makin a harness at sum point but i live in the city and theres street lights n junk up the ass so i don't need crazy bright headlights,maybe if i lived in the sticks or sumthin.to be honest i have real sensitive eyes and people with bright ass headlights drive me nuts lol
Old 11-06-2009, 12:05 AM   #17
... i dont know?
mine have been kind of sensative recently too, but my headlights are actually adjusted lower than they should be, so they are bright but they are not high enough not to blind people
Old 11-06-2009, 12:11 AM   #18
You...Tonight
mostizzle's Avatar
that makes sense. i recently lowered the back of my truck more but i never readjusted my headlights so they're shining the trees n shit lol i haven't bothered messin with em cuz i'm doin the swap anyways. i might just rock sum silver stars and be done with it
Old 11-06-2009, 12:16 AM   #19
... i dont know?
IMO the silver stars dont do much without the upgraded harness, ive had the silverstars for about 3-4 years and i just did the wire upgrade a couple months ago, it made a HUGE difference, beandips thread has pics of before and after with silverstars
Old 11-06-2009, 01:20 AM   #20
You...Tonight
mostizzle's Avatar
thanks for the info i guess i'll just buy a matching set of plain ass sylvanias to replace the mismatched shit thats in the headlights lol
Old 11-06-2009, 01:36 AM   #21
... i dont know?
personally, id look at the nokya bulbs, you can get them in standard and high wattage, you can usually pick them up for $15 shipped per pair on ebay, ive heard good things about them versus sylvania, im planning to get the high wattage sets for mine
Old 11-06-2009, 01:51 AM   #22
4x4 v6 blazer
neo71665's Avatar
I'm a fan of Piaa but I run H4s and have no clue if they make them for your 2nd gens. I'm sure they do tho.
Old 11-06-2009, 01:54 AM   #23
... i dont know?
yeah they make the h4 adapter housings for the sealed beams, but composites look
Old 11-06-2009, 07:33 PM   #24
You...Tonight
mostizzle's Avatar
well thanks for all the help fellers on with the pics
before
Old 11-06-2009, 07:37 PM   #25
You...Tonight
mostizzle's Avatar
well there it is,it was easy as pie. i'll have to check into them headlights u guys are talkin about. i really need/want the olds bumper to go with this grille so if anyone know where ones hiding for cheap lemme know,if not i'll hunt one down with my tax money. in the meantime that gap under the grille looks like butt lol any suggestions or ideas to remedy this for the time being?
Old 11-06-2009, 07:56 PM   #26
992drjimmy's Avatar
before
Now send me the grille you took out.
Old 11-06-2009, 08:09 PM   #27
You...Tonight
mostizzle's Avatar
dude honestly that grille is a aftermarket i'll fitting piece of poopy lol i was thinkin more along the lines of using it as wall art lol
Old 11-06-2009, 09:34 PM   #28
... i dont know?
you might actually need to adjust the angle of the headlights, and personally id go with a 98+ sonoma bumper and a 94-97 sonoma grill.... im not biased or anything...
Old 11-07-2009, 12:30 AM   #29
You...Tonight
mostizzle's Avatar
not really a fan of the gmc grille but u never know what mite happen lol so how do u aim these mofo's? the long hex headed adjusters are for up and down and the inverted torx are left and right?
Old 11-07-2009, 01:20 AM   #30
... i dont know?
ive never found a reason for the long ones except maybe angle the lights or to lock the inverted torx
the inside inverted torx is your horizontal and the outside is your up and down, you can use a regular 1/4 inch socket to adjust those
Old 11-07-2009, 01:27 AM   #31
You...Tonight
mostizzle's Avatar
you rock dude i'll aim em tomorrow,all the animals sleepin in the trees will thank me lol
Old 11-07-2009, 01:32 AM   #32
... i dont know?
it took me a while to get mine aimed where i want em, i never could find a dark enough level spot to aim them, so id drive with them and adjust them and repeat until i finally got them at least close
Old 11-07-2009, 01:37 AM   #33
You...Tonight
mostizzle's Avatar
yeah i think the long driveway and the big white garage door thats behind the truck in the pic should get the job done,thats how i did my old ones and they were money til i dropped the back more lol
Old 11-07-2009, 01:40 AM   #34
... i dont know?
sounds good, you should have 2 really strong focus points with these lenses so its not hard to get them close
Old 11-07-2009, 01:51 AM   #35
You...Tonight
mostizzle's Avatar
yeah i noticed when i was drivin earlier and i was gettin mean mugged cuz the strong focus points were all up in peoples eyeballs when i was behind em lol
Old 11-07-2009, 02:41 AM   #36
... i dont know?
yep, they do that, i have mine pointed down below where most normal headlights are aimed becasue of them being quite a bit brighter
Old 11-07-2009, 08:52 PM   #37
You...Tonight
mostizzle's Avatar
well the retarded ass adjusters are garbage on the passenger side. luckily i was just able to kinda tug on em at the adjusting point,and becuz they're just plastic where the adjusters thread thru they just moved along the threads. i was real careful not to jack em up in the process tho,turned out pretty good tho. i had my buddy park rite next to me side by side and he turned his lights on at the garage door then i turned mine on and just used his as a cheat sheet basicaly. oh and i believe ur rite about the hex headed shafts just bein locks
Old 11-08-2009, 04:12 AM   #38
... i dont know?
well, i got my old headlights out to steal one of the headlight plug pins and i looked at the adjustment system, the torex uses a nut on a gear to move the lens angle left right up and down, the nut can get stripped out and thats how you can move them by hand (my old lights)
the hex head adjusters can tilt the headlights so if your lights are winking at you like the 98+ has a problem with you can change the angle, and from what i could tell, you could even center them vertically with the grille if you have a fitment issue with the same hex head adjustments
Old 11-08-2009, 04:16 AM   #39
94SDimeDriver's Avatar
I was about to suggest the gmc front fascia but it seems by oldschools pic you would have a gap in the middle. Just find you a junker bravada, shouldn't be too hard. I put a Bravada front end on my truck but I opted for the 98-02 instead of the 95-97, I just like the never ones better.
Old 11-08-2009, 04:19 AM   #40
you know what, i think I am wrong but if you measure your current grille as compared to the 98-02's you could use that front fascia instead since it looks better. It will look just like the one in my avatar. I haven't got the foglamp kit yet but I am, also haven't put my grille in yet because I need to file out some of the retaining points.
Old 11-08-2009, 06:02 PM   #41
You...Tonight
mostizzle's Avatar
i think the big headlights and the newer bravada grill looks like ass lol, i'm either get the 96-97 bumper or i'm gonna run a 98 and up dime bumper and i'll make a fiberglass filler or maybe even steel for the gap. the lights are aimed pretty good and i'll be on the look out for a set in better shape but for now all my lights work and it's all together so ima rock it the way it is for a few weeks then i'm takin it off the road for the winter cuz theres more important things to be done. during that time i'll be searchin for the olds bumper which i do have a line on a couple but they're out in the boons so we'll see what happens. either way i'm fairly confident i'll have it lookin right again this spring
Old 11-08-2009, 06:08 PM   #42
You...Tonight
mostizzle's Avatar
important things such as...cab corner,cutting the front coils to cure the lean and get it down further,rear swaybar,c-notch,clean and paint the frame,gettin sum spacers for my bed to replace the lost ones so my cab and bed will be flush again and welding up a small crack in my floor board.. man thats a laundry list lol and who know i mite not get any of it done lol jk
Old 11-08-2009, 09:06 PM   #43
I wouldn't suggest cutting your springs for a variety of reasons starting with safety but it's your truck.
Old 11-09-2009, 09:35 PM   #44
You...Tonight
mostizzle's Avatar
yeah i know how the majority feels about cuttin em but i'm only doin a half coil or so. even if i buy new springs ima end up choppin sum off one side the cure the stupid chevy lean anyways cuz i don't want to jam a spacer in there and end up gettin 2 inches of drop instead of the 3 on one side. long story short the front needs to come down to level out with the rear,i'm tired of lookin at a leanin ass truck regardless if i'm the only one that can tell it's leanin and i have no money so yeah
Old 11-09-2009, 09:38 PM   #45
... i dont know?
cutting isnt a problem, just go slow and keep the heat down, you will need to take out about half a coil, its how track cars suspensions are tuned
Old 11-10-2009, 07:29 PM   #46
You...Tonight
mostizzle's Avatar
i know that, i just didn't wanna start a debate with the guy lol, people have been cuttin coils since theres been coils. i ain't skurd of bumpy roads and stiff suspension lol
Old 11-10-2009, 08:05 PM   #47
You skurd of the springs popping out of the cups? Just asking.
Old 11-10-2009, 09:47 PM   #48
... i dont know?
half a coil will not cause them to pop out, and that would only happen if the front wheel came clear off the ground and you didnt have shocks
Old 11-10-2009, 09:51 PM   #49
992drjimmy's Avatar
You made a good point. So the guys who say spacers are unsafe cause they can pop out. That could not happen unless it took the shock clean out with it also.
Old 11-10-2009, 09:56 PM   #50
... i dont know?
pretty much, unless they dont wrap around the spring and just raise the spring and bushing up, you will have less of a pocket for the spring to sit in
Page generated in 0.64890 seconds with 33 queries
[Output: 212.18 Kb. compressed to 193.33 Kb. by saving 18.85 Kb. (8.89%)]
