97 Blazer rear wiper clicking and not really working rear sprayer problems too - S-10 Forum
post #1 of 7 Old 06-14-2010, 02:47 PM Thread Starter
Working on aircraft
ablues10's Avatar
User is: ablues10 is offline
When I turn it on it clicks and bounces around a bit. Sometimes I can play with the switch and it will pop back up and work once or twice. I have not looked at it yet but before I do, does it sound like I will need a new motor or is it something else? Also the rear squirter doesnt spray. The pump works cause its brand new. Any little tricks there?
pics more pics ^ project pics
ablues10 is offline
post #2 of 7 Old 06-15-2010, 02:59 AM Thread Starter
Working on aircraft
ablues10's Avatar
Re: 97 Blazer rear wiper clicking and not really working rear sprayer problems too
Took it apart tonight. There is a big plastic wheel gear in the motor and the teeth were stripped a little bit. I filed the edges down and now it seems fine. Still cant figure out the squirter. It seems like its blocked.
ablues10 is offline
post #3 of 7 Old 06-15-2010, 05:18 PM
1996 4.3 5 speed xtra cab
tommyboys10's Avatar
User is: tommyboys10 is offline
You might have a coincidental combo of two things. Look at the multi function turn signal switch too for your sprayers.. Im having the same problem.
post #4 of 7 Old 06-15-2010, 09:41 PM Thread Starter
Working on aircraft
ablues10's Avatar
I was thinkin the line could be pinched somewhere but I dont know where to look without ripping out the whole carpet
ablues10 is offline
post #5 of 7 Old 11-10-2014, 01:46 AM
User is: 04colyZQ8 is offline
mine clicks two, only works if I help it! how does the gate come apart? any how two? mines a 95.
Were is the switch for the rear sprayer?
post #6 of 7 Old 11-12-2014, 01:35 AM
User is: thetank225 is offline
Question Re: 97 Blazer rear wiper clicking and not really working rear sprayer problems too
I have a 98 s10 blazer and my rear switch is on the dash. I am having issues with mine as well too. When I fill the reservoir up with washer fluid and hit the rear sprayer, nothing comes out on the back glass, but I did notice that there were some drops coming from underneath on the back left side and I pulled this plug out and all that washer fluid that I just pumped in there came gushing out. I have yet to find out why it will drain there instead of going to my back glass though.
post #7 of 7 Old 11-13-2014, 09:40 PM
denis's Avatar
User is: denis is offline
If you go to the dealer, you can get a printed picture/ diagram of the entire routing of the rear washer line, from the front pump, to the rear wiper blade. There is more than one picture involved. Basically, the washer line runs
pump > under firewall > inside truck along floor on driver side > driver side area by tail-light > up inside body pillar to top of roof > across body roof just inside where hatch opening is located > inside body roof opening on passenger side by hatch hinge > through wiring cable run into top of hatch > down passenger side inside of hatch to bottom of window glass > across under glass to the center of the inside of hatch > rear wiper motor area > out of rear of hatch to wiper blade
every place that I have used a ">" there is a connector, between two lines. Any of those connectors can leak. You can replace most of the connectors with a short length of rubber vacuum line, I use 5/64 inch I think.
The washer lines themselves are hard line plastic, and can wear through from rubbing against the metal body work.
Pull the interior panels, starting at the rear inside, body roof, inside hatch opening, and look for leaks. Mine was leaking just where the line enters the hatch at the roof area on the passenger side.
1998 LT Blazer 4x4, 120K miles. REPLACED PARTS: intake manifold gasket, radiator, engine heater (heated freeze plug), alternator, A/C compressor, distributor, spark plugs and OEM wires, transmission shift solenoid, rear pinion seal, remote oil lines (both sets), water pump (twice), fuel pump and sender, FPR (fuel pressure regulator), 3 input/ output drive-shaft seals in Transfer case
denis is offline
