96 Tail light wiring schematic/color code?? - S-10 Forum
post #1 of 10 Old 09-27-2005, 08:04 PM Thread Starter
s10blazed's Avatar
User is: s10blazed is offline
Send a message via AIM to s10blazed Send a message via Yahoo to s10blazed
Does anyone have these handy or know where I can get it? I need to know the color code for the wiring going to the rear harness for the tail lights/license plate lights. Most importantly:
R turn signal
L turn signal
running lights
brake lights
reverse lights
plate lights
and any corresponding grounds
post #2 of 10 Old 09-28-2005, 11:28 AM
Canyon Carver
User is: s10cyncrvr is offline
Re: 96 Tail light wiring schematic/color code??
2002 S-10(pick-up)
Park Turn Signal Lamp - LR
YEL - Turn Signal Supply Voltage
BRN - Park Lamps Supply Voltage
BLK - Ground
Park Turn Signal Lamp - RR
DK GRN - Turn Signal Supply Voltage
BRN/WHT - Park Lamps Supply Voltage
BLK - Ground
Marker Lamp - LR
BLK - Ground
Marker Lamp - RR
BLK - Ground
License Lamp - LR
BLK - Ground
License Lamp - RR
BLK - Ground
Backip Lamp - LR
LT GRN - Backup Lamp Supply Voltage
BLK - Ground
Backup Lamp - RR
BLK - Ground
post #3 of 10 Old 09-28-2005, 11:53 AM Thread Starter
s10blazed's Avatar
Originally Posted by s10cyncrvr
2002 S-10(pick-up)
BLK - Ground
BLK - Ground
Marker Lamp - LR
BLK - Ground
Marker Lamp - RR
BLK - Ground
License Lamp - LR
BLK - Ground
License Lamp - RR
BLK - Ground
Backip Lamp - LR
BLK - Ground
Backup Lamp - RR
BLK - Ground
Thanks! YOu're the man!
post #4 of 10 Old 09-28-2005, 12:30 PM
forum idiot
orangesonoma's Avatar
you copy and pasted for a 02 s10..he has 96...in 96 the brown and white wire does not exist...i may be wrong but im sure it is 98 and up that has the brown and white wire...
but the turn signal and reverse sound correct
Brian
orangesonoma is offline
post #5 of 10 Old 09-28-2005, 12:52 PM
Canyon Carver
I just have the shop manuals for the 2002. I figured that would put him in the right direction, if they are different he can ask again. That's why I put the 2002(pickup) at the top.
post #6 of 10 Old 09-28-2005, 12:55 PM
Some Day
96dragginSdime's Avatar
User is: 96dragginSdime is offline
Send a message via AIM to 96dragginSdime
we have brown, black, dark green, light green, yellow wires back there
Trucks for sale!!!!!!!!
post #7 of 10 Old 09-28-2005, 12:59 PM
Some Day
ehh I will look in alittle bit
post #8 of 10 Old 09-28-2005, 01:47 PM
forum idiot
brown is parking lights
black is ground
dk green is right turn/brake
yellow is left turn/brake
and lt green is reverse
Brian
post #9 of 10 Old 11-06-2005, 10:10 AM
austinS10's Avatar
User is: austinS10 is offline
Send a message via MSN to austinS10
I'd really like to know the same for a 2000 S10 pickup 5-speed. Mostly I would like to tap into the reverse wire and mount a small light on my bumper that comes on only when I put the truck in Reverse. Is that possible?
post #10 of 10 Old 11-06-2005, 10:47 AM
ZR2 member
Scott01's Avatar
User is: Scott01 is offline
black is ground
Right there in front of you.Most trailer wiring is universal across all makes.
Scott01 is offline
