1995 S/T Truck/blazer pinouts of connector blocks - S-10 Forum
post #1 of 17 Old 11-24-2009, 09:05 PM Thread Starter
SSRT-S10
my_nightmare's Avatar
Arrow 1995 S/T Truck/blazer pinouts of connector blocks
I will add these when I get them drawn. (I'm doing this to keep myself busy until I get a weekend to work on my truck. I have no "Life". LOL!)
Enjoy! Make this a sticky if you want to. I will do my best to get all I can draw from book on here a.s.a.p.
P.S. Most of the s-10 and blazer use the same color codes for same area of the harness. The 95 book I got list harness connectors for a 95 but also connectors I have found in 98 and higher trucks.
1) Ok here goes.... here is the headlight connector block located on the d/s fenderwell in a oval shaped connector.
I will add the door stuff next.
post #2 of 17 Old 11-24-2009, 10:20 PM Thread Starter
SSRT-S10
Re: 1995 S/T Truck/blazer pinouts of connector blocks
havn't got the doors done yet..., here is a pin-out of a 1999 heated/power mirror schematicI found this on another web site)
post #3 of 17 Old 11-24-2009, 10:22 PM Thread Starter
SSRT-S10
here is another I found on the web: 1997_mirror_schematic diagram
post #4 of 17 Old 11-24-2009, 10:24 PM Thread Starter
SSRT-S10
here is another on the web: 2000 mirror schematic
post #5 of 17 Old 11-24-2009, 10:27 PM Thread Starter
SSRT-S10
here is another I found on the net: 1997 mirror switch
post #6 of 17 Old 11-27-2009, 12:38 PM Thread Starter
SSRT-S10
1995-98 S-10 / Blazer Door Accessory 23-way (C220) Connector Block
post #7 of 17 Old 11-28-2009, 08:06 PM Thread Starter
SSRT-S10
1995-00 Power Door lock- mirror Feed - Connector Block (C-212)
post #8 of 17 Old 11-28-2009, 08:20 PM Thread Starter
SSRT-S10
1995-97 S-10 MAIN DASH HARNESS CONNECTOR BLOCK - BLOCK (C-200) - PART 1
post #9 of 17 Old 11-28-2009, 08:22 PM Thread Starter
SSRT-S10
1995-97 S-10 MAIN DASH HARNESS CONNECTOR BLOCK - BLOCK (C-200) - PART 2
post #10 of 17 Old 11-28-2009, 11:51 PM Thread Starter
SSRT-S10
1995-97 S-10 MAIN ENGINE HARNESS CONNECTOR BLOCK - BLOCK (C-100 AND C-104)
post #11 of 17 Old 11-29-2009, 12:24 AM Thread Starter
SSRT-S10
1995-00 Front RH Power Window Switch Connector Block
post #12 of 17 Old 11-29-2009, 03:23 PM Thread Starter
SSRT-S10
1995-99 Power Door Lock Connector Block (Driver Side 4-Door)
(More window connectors..hehehe )
post #13 of 17 Old 11-29-2009, 03:27 PM Thread Starter
SSRT-S10
1995-04 ODB II Serial Data Link Connector Block
post #14 of 17 Old 11-29-2009, 03:35 PM Thread Starter
SSRT-S10
Connector Block C-217
Location: Unknown as of yet. ( I Ain't found it in manual yet as for its' location.) I Think it somewhere on Blazers and/or 4-wheel drive trucks)
post #15 of 17 Old 12-08-2009, 12:19 AM Thread Starter
SSRT-S10
1995-98 S-10 / Blazer / Bravada Door Accessory 23-way (C220) Connector Block
(UPDATED 12/07/09)
post #16 of 17 Old 01-06-2010, 10:26 PM
New to the S-Series Game
the_s15_virgin's Avatar
User is: the_s15_virgin is offline
hey can i splice this harness to an 86 bulkhead motor harness plug and get this motor to run? I have swapped a 2.8 for a 4.3 and have this very harness as the end to a smooth prodject. Will this work?
post #17 of 17 Old 01-06-2010, 11:04 PM
How bout a pinout of a 86 gmc s15 bulkhead firewall connector. Engine harness to firewall. I am splicing a 1995 harness to this harness. It would help a lot.
