Propane powered forklift - S-10 Forum
post #1 of 12 Old 05-11-2006, 05:56 PM Thread Starter
CRMW70's Avatar
User is: CRMW70 is offline
Send a message via AIM to CRMW70
So at work we have this propane powered forklift. It is a Yale, with a 4cyl engine. We had the tank refilled and now it is running like shit. Is there such a thing as stale propane? It takes a little longer to start and won't hold an idle. Idles real rough and can smell unburnt propane out of the exhaust.
Anyone know what's up?
1994 (1st gen) Chevrolet Blazer Tahoe LT 2WD 4DR 4.3L "W"
Mostly stock, , K & N drop in w/ hack job, Autometer gauge pod Trans temp / Fuel pressure, Dynomax Cat back, and a Flux capacitor.
CRMW70 is offline
post #2 of 12 Old 05-11-2006, 06:36 PM
Dangerous
86MCSS's Avatar
User is: 86MCSS is offline
Re: Propane powered forklift
Vacuum leak on the engine? It could be many things. Propane , heck any forklifts are usually not well taken care of and serviced as often as they should be.
86MCSS is offline
post #3 of 12 Old 05-11-2006, 06:48 PM
lilredxtreme's Avatar
User is: lilredxtreme is offline
Send a message via AIM to lilredxtreme
sounds like its leaking and not getting as much to the motor as it should......
post #4 of 12 Old 05-11-2006, 06:50 PM Thread Starter
CRMW70's Avatar
Yeah I know. It has 13,000 hours on it and who knows what kind of service it gets. Tipping the scales at 7400lbs doesn't make it easy to move around.
I am thinking of a basic tune up, plugs wires, cap, rotor.... But where do you get that stuff?
CRMW70 is offline
post #5 of 12 Old 05-11-2006, 06:52 PM
Mmmm Tire smoke.
indigo s10's Avatar
User is: indigo s10 is offline
Moisture build up. When I was in high school, I worked at a grocery store that had a propane floor buffer I ran on Saturday night. When I put a new tank on, the carb would freeze up. The compressed LP is so cold it would freeze the H2O vapor in the air and the buffer would die. Try letting a little of the pressure off the tank and see if that helps.
03 ZQ8 W/ 4.3
post #6 of 12 Old 05-11-2006, 07:08 PM
Yes, those are my feet
Web-Foot Freak's Avatar
User is: Web-Foot Freak is offline
bad idea, as soon as you let a little LP out, the remaining liquid in the tank will vaporize keeping it at the same pressure. oh, and LP fumes attract bugs
2 questions: 1) did the running rough problem happen as soon as you put the refilled tank on there, or did it happen a day or two later? 2) was it running just fine before you put the new tank on?
I probably should have asked that in reverse order, oh well...
To answer your question, there's really not stale LP gas, but there are different grades. Yales come off the same production lines the Hysters I work on do. And the Hysters are supposed to use HD-5 grade fuel. Now with 13K hrs on the dial, I'm sure a tune-up wouldn't hurt. If you can get me a serial number, and a model number I can get you the part #'s you need
Rick
14 Town & Country
10 Town & Country
95 s10 (needs motor)
13 Felt Z100 (w/aerobars)
post #7 of 12 Old 05-11-2006, 07:14 PM
Rick
sorry to whore but DAMN!!! WTF happened to your feet?
post #8 of 12 Old 05-11-2006, 07:17 PM
birth
14 Town & Country
10 Town & Country
post #9 of 12 Old 05-11-2006, 07:30 PM
VVVthat thing is deadVVV
NeverEnough188's Avatar
User is: NeverEnough188 is offline
birth is a bitch aint it? gettin the um,bilical cord wrapped around your neck aint cool either. Zamboni's run on propane too. they are a blast to drive!
-Travis-
03 zq8 xcab 5/5 drop and some other goodies
post #10 of 12 Old 05-11-2006, 07:40 PM
User is: poconojoe is offline
Try another tank of propane, I've seen them get air in it and it make the fork lift run crappy.
If your tank has a top you can convert to fit your grill, try using it on your grill. If the grill doesn't stay lite, the propane is bad.
post #11 of 12 Old 05-11-2006, 08:43 PM
I still watch cartoons!
zoideraserb's Avatar
User is: zoideraserb is offline
Send a message via AIM to zoideraserb Send a message via MSN to zoideraserb Send a message via Yahoo to zoideraserb
yea, we had hyster 30s at my old work... i guess they were in need of a tune up because they would die unless you revved them till they warmed up when you started them lol.. so sad that my brother was the head of maintenace huh?
-Gear
A recent study shows that 92% of all teenagers converted to emo/punk etc. Put this in your sig if you're one of the 8% who stayed gangsta as shit.
Don't be a pussy, use her parent's bed...... If the mom walks in, just say "Hi, you're next!"
post #12 of 12 Old 05-11-2006, 09:06 PM
Vandelay Industries
cruisinlows10's Avatar
User is: cruisinlows10 is offline
I operate forklifts alot at my job. The #1 thing that comes to my mind in your case is moisture buildup. Does it take forever to start and then when it does you have to hold the gas pedal down to keep it running good? And you asked where you get parts. All of our yale lifts have madza 2.2's in them. Even our old yales had mazda motors. Not sure i the old ones are 2.2's or a different engine but i know its a mazda motor. We just got 4 brand new lifts at work and they are NICE. We still have a couple old yales too. Anyhoo, Our forklifts are serviced by a yale authorized rep. Dougherty Truck Equipment Service or something close to that and there is a lift that needs some adjusting and the rep should be there tomorrow if he is i will ask where they get their parts.
