IRS Dually - discuss - S-10 Forum
post #1 of 25 Old 12-01-2011, 09:51 PM Thread Starter
CNC Plasma Cutting
GoingCustom's Avatar
User is: GoingCustom is offline
Josh over at Killin' It Kustoms is building this IRS dually. He'll be out at Turkey Drag if any of you are going. Definitely going to turn some heads! I'm sure Josh will chime in and give some more details, but here are the basics: rear setup consists of a built ford 8.8 cobra rear end, custom halfshafts, 04 front wheel 2500hd hubs, .75" plasma cam cut spindles(goingcustom), all brake setup from 04, all 1.5x.250 dom for control arms, heims up top for adjustability, pollys everywhere else, custom sway bar and fox 2.0 resi shocks. Front and rear camber is the same.
Shock mounts are trimmed down in the next pic
Originally Posted by wildman ss View Post
GoingCustom has the nicest rides on this site
Originally Posted by Tex Star View Post
You're a true craftsman......
www.goingcustom.com (badass gates, art, corporate/holiday gifts)
1967 Mercedes Benz 230s - minor restoration - bagged (Accuair can suck a dick) - Project thread: http://www.s10forum.com/forum/f30/pr...rtimer-395664/
post #2 of 25 Old 12-01-2011, 09:55 PM
No longer a pizza tech.
90blueS10's Avatar
User is: 90blueS10 is offline
Re: IRS Dually - discuss
Will be sweet, but look weird laid out if it has any rear neg camber. Not sure how it would pull either. but its diffenitely outside of the box.
Ryan
90 2.5 5 speed, bag project
01 Jimmy 2dr 2wd daily driver
post #3 of 25 Old 12-01-2011, 10:00 PM
rc guy
User is: mlemorie is offline
Send a message via AIM to mlemorie
Neat idea, but I think there is going to be a lot of stress on that rear setup any time that there would be any sort of dynamic camber change such as chassis roll going around a corner. The wider profile of the dual setup will have a lot of leverage on that suspension, and it will not want to roll like a single wheel will. Either way though it looks good and he is definately using the right stuff to hold up to it, just have to see how it all works out. If he isnt out autocrossing the thing he should probably be fine lol. Props for doing something different though!
mlemorie is offline
post #4 of 25 Old 12-01-2011, 10:00 PM Thread Starter
CNC Plasma Cutting
It has negative camber in the rear, can see it in the 3rd pic; same camber as the front wheels. Outside rear wheel comes off the ground when laid out. Pretty sure I remember him saying the guy wasn't planing on towing with it, just building something different.
post #5 of 25 Old 12-01-2011, 10:02 PM
90blueS10's Avatar
Gay, no laid out towing no care.
And the 2nd and 3rd pictures didnt work when i first posted. but i see the camber now.
Ryan
post #6 of 25 Old 12-01-2011, 10:06 PM
It puts the lotion on
deeznutz's Avatar
User is: deeznutz is offline
Damn that truck is gonna be badass
03 Crew Cab
deeznutz is offline
post #7 of 25 Old 12-01-2011, 10:34 PM
BRB Facetat
jawa6306's Avatar
User is: jawa6306 is offline
Looks like the outside tires are either off the ground or close. I'm sorry but it's sort of meh with that camber.
jawa6306 is offline
post #8 of 25 Old 12-01-2011, 11:00 PM
Need to DO WORK son
Innis's Avatar
User is: Innis is offline
its a cool idea and obv hella good fab work but for some reason it just dosnt look right i dont know why, the shot of the full frame from the back just looks wierd
2001 S10 Bagged - Just need to DO WORK!
Innis is offline
post #9 of 25 Old 12-01-2011, 11:03 PM
resident crybaby
mesterz2889's Avatar
User is: mesterz2889 is offline
i thought this wouldve been awesome when i read the title but for some odd reason its not doin it for me. i love duallys and IRS set up but as stated before "meh" would like to see it when its done tho. hopefully change my mind
98 sonoma sd 3 link_show ---> soon to be 5.3/c4 irs...
89 iroc-z 350/t56_go ---> soon to be S/C 383/t56...
91 300zx_daily 400+hp twin turbo goodness
...by soon i mean not soon
post #10 of 25 Old 12-01-2011, 11:06 PM
DELIBERATE DESIGNS
GET_LOW's Avatar
User is: GET_LOW is offline
Cool idea for sure. Work looks good. Didn't he have a extra wide bed made for this truck too so he could run true duals?
Not sure on the drivability of it though since the geometry looks somewhat off IIRC from what it should be in a IRS. Been a long time since ive looked into the specifics on it. Instance center of the arms looks to be on the outer side of the vehicle.
Jordan (JJ, Gordo)
facebook.com/DeliberateDesignsLLC
~PROJECT THREAD~
GET_LOW is offline
post #11 of 25 Old 12-01-2011, 11:19 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
That is different for sure
-Jonathan
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #12 of 25 Old 12-02-2011, 01:17 AM
Killin' it Kustoms
tuckin20's's Avatar
User is: tuckin20's is offline
This is josh from killin it, to address some questions and comments.
It will not tow anything. Brett the owner just wants a crazy head turner. Everything is super built thow.
On the instant center. Its close the the hub of the opposite wheel. Only reason was distance, and the travel and the camver angles i wanted to acheive. Yes its not 100% accurate. I still lack building tierods and i may move the upper mount still. Just depends. Plus the geometry is exactly the same as the front.
Im glad to see positive feedback. I didn mean any of that to come off blunt or rude. I just figured id chime in.
The wide bed was for my 07 and its to run 24's with a stock width frame.
Josh
<st> severed ties new mexico's chapter. <st>
2007 classic d-max dually crew cab, bagged!!!
1993 mazda b2200 layin on 24's' with 255/30/24's
post #13 of 25 Old 12-02-2011, 02:27 AM
littledevil4802's Avatar
User is: littledevil4802 is offline
Send a message via AIM to littledevil4802
I'd rock the **** out of it either way.
92 reg. cab-lowered 5/4-sold
95 std cab- bagged about to be bodied
www.airedup.com
post #14 of 25 Old 12-02-2011, 03:19 AM
It's a trap!
scuffy's Avatar
User is: scuffy is offline
Needs supersingles
Originally Posted by TN-Noma View Post
leave him alone, hes a pilled up cripple, he doesnt know any better lol.
Gmthq>s10f
scuffy is offline
post #15 of 25 Old 12-02-2011, 04:21 AM
Killin' it Kustoms
tuckin20's's Avatar
I anyone wants to follow any of my builds you can add me on fb. Im trying to stay low key cause this isjust my hobbie/2nd job. My name is severed josh
Josh
post #16 of 25 Old 12-02-2011, 04:45 AM
This is doo doo baby!
wildman ss's Avatar
I like the work, i'm just not a big negative camber fan
Classy Chassy
wildman ss is offline
post #17 of 25 Old 12-02-2011, 01:02 PM
Killin' it Kustoms
tuckin20's's Avatar
Only reason we put camner in is because its pretty sick to have the outside wheel lift when laid...
Josh
post #18 of 25 Old 12-02-2011, 01:26 PM
Hot Rod Enthusiast
s10kid17's Avatar
User is: s10kid17 is offline
Looking good man, I really like the idea. Negative camber on a dually is awesome..
Mike.
s10kid17 is offline
post #19 of 25 Old 12-02-2011, 01:35 PM
MajesticLT03's Avatar
User is: MajesticLT03 is offline
Send a message via AIM to MajesticLT03
will that 8.8 handle a big dually?? regardless if its built or not.. or is that the biggest IRS axle housing there is?
'99 Silverado RCSB Stepside bagged on Fours
post #20 of 25 Old 12-02-2011, 01:46 PM
Inferno Fab
flnole78's Avatar
User is: flnole78 is offline
Send a message via AIM to flnole78 Send a message via MSN to flnole78 Send a message via Yahoo to flnole78
I like it and I have big respect for anyone that can and does build a custom IRS in any truck much less a dually that has custom built flat plate hubs. This thing is sick. Amazing work!
Do you have any pics of the hubs by theirselves? I'd like to see them.
flnole78 is offline
post #21 of 25 Old 12-02-2011, 05:52 PM
Extended cab or no cab.
cpolaris502's Avatar
User is: cpolaris502 is offline
I think it's pretty sweet. The picture from the rear reminds me of a scissor lift.
Cory - TWISTED KONCEPTS
1999 2dr Blazer-Bagged and V8'd {Build Thread}
2005 Silverado 2wd 4/6'd. 402ci LSx/4L80e/turbo 780whp/680tq, 17psi boost---- Build Thread
1982 2wd Chevy C30 Crewcab Dually, 454/Manual
2002 Audi A4 1.8T Quattro.
post #22 of 25 Old 12-02-2011, 09:18 PM Thread Starter
CNC Plasma Cutting
These are from the day I cut em out, I don't have any pics of them with everything welded/bolted to them. Think Josh might or I'll snag some from his FB and post em on here.
0 bevel through 3/4"
doesn't actually sit all the way down like this, but tolerances were right on.
and just because it's a badass pic!
post #23 of 25 Old 12-02-2011, 09:44 PM
Thas ****ing sick
www.airedup.com
post #24 of 25 Old 12-02-2011, 09:45 PM
Ehhh!
towb3's Avatar
User is: towb3 is offline
The pig pulling in the last picture almost looked like one that was owned by Kyle Bertsche from Severed. But on second thought i think his was a chevy.
The dually the thread is about will be sick.
Tory
Project thread for my '38 chevy. Slow updates.
http://www.s10forum.com/forum/f30/gi...-a-rat-424638/
towb3 is offline
post #25 of 25 Old 12-04-2011, 03:02 AM
needs a cheeseburger
tohoopty's Avatar
User is: tohoopty is offline
friend sent me this today from turkey drag
tohoopty is offline
