I'M STILL LIFTING!!!! Anyone else? (Pics Included)
Old 06-27-2007, 03:47 PM   #1
ASASN8
bladehines's Avatar
Post I'M STILL LIFTING!!!! Anyone else? (Pics Included)
Well i just started back 3 weeks ago. We will see if my surgery and higher testosterone levels help out. So far it seems like it has.
I will post before and after pics at the 3 month mark.
So far here is my diet:
Breakfast: Good high fiber cereal
Snack: small protein bar
Lunch: 1 cup ( already cooked white Rice)
4-8oz of lean meat depending on what meet ( this week of the 25th of june) i am eating steak roughly 7oz a day
1 cup steamed brocolli
Animal Pak
Snack: 2 cups of fresh fruit
Pre workout: Protein bar
Simple sugars/carbs
Animal Stack2
Dinner within 2 hours of working out
Protein, and lots of carbs.
I have gone from 135 to 142 pounds in 2 1/2 weeks. I am gaining muscle mass and strength almost 3 times faster then this time last year.
Old 06-27-2007, 04:05 PM   #2
ironpimp's Avatar
Re: I'M STILL LIFTING!!!! Anyone else?
How tall are you? thats good progress
Old 06-27-2007, 04:07 PM   #3
ASASN8
bladehines's Avatar
i am 5'8" or so
Old 06-27-2007, 04:14 PM   #4
ASASN8
bladehines's Avatar
Here is pics of me last year. before and after 3 months.
So far i am on my way to being bigger, and more cut!
(and yes i am in my underwear, and i didn't care what my hair looked like)
In these pics i was 135-140 before, and 148-150 after 3 months
EDIT:::::::::::::
make as much fun of me as you want!!!!! it's a good modivator
Old 06-27-2007, 04:18 PM   #5
.com
DigitalSoCal's Avatar
dude, a warning would've been swell
Old 06-27-2007, 04:19 PM   #6
ASASN8
bladehines's Avatar
i tried it won't let me change my first post! lol
Old 06-27-2007, 04:21 PM   #7
Captain Obvious
Imperial's Avatar
He mentioned he was posting before/after pics.
Nice work dude. I've just picked up working out again recently since it's warm enough to get in the pool. I'm working on my guido tan as well.
Dan (WhiteNoma) has been hitting the gym like a madman as well.
I really wish our weight loss club on here would've worked out.
Old 06-27-2007, 04:26 PM   #8
ASASN8
bladehines's Avatar
Re: I'M STILL LIFTING!!!! Anyone else? (Pics Included)
thanks for the change El capitain!
Old 06-27-2007, 04:32 PM   #9
Captain Obvious
Imperial's Avatar
np mang.
Old 06-27-2007, 04:39 PM   #10
ironpimp's Avatar
thats good progress.
I just hope you didnt keep the same boxer for 3 months lol
Old 06-27-2007, 04:42 PM   #11
ASASN8
bladehines's Avatar
nope i change weekly....lol
and remember for that period of time i was working out i had a lower then avg. testosterone level. but now that i had my surgery it's going up month to month. the 10th of july will be 3 months which i should start to see a difference in test lvls.
i do need to go to the tanning bed if i start to take my 3 month pics. i am white as a sheet right now.
But another cool thing. i haven't lifted for a year almost and i am already close to my strength in lifting! so i can't wait to see what 3 months does to me!
Old 06-27-2007, 04:51 PM   #12
Stock tires with 5.7
TuckaBlaze's Avatar
I need to loose my beer gut first...
Old 06-27-2007, 05:33 PM   #13
Dangerous
86MCSS's Avatar
good job so far. any supplements?
i still work out often. i need to take more pics of myself. i have leaned down 20 lbs but luckily i kept most my strength. i went from bench pressing 415lbs to 380lbs. i cant seem to keep my weight lifting up when i drop weight
Old 06-27-2007, 05:36 PM   #14
I RIDE LO
Kovz's Avatar
what kinda surgery did you have?
keep up the high goals. you are making good progress. nice diet plan too
i gained about 10 lbs. in 6 months. i have some pics, but i dont wanna jack your thread, so ill let you make that call.
anyways, good job brotha
Old 06-27-2007, 05:37 PM   #15
This is the end.
Mulisha Troop's Avatar
Eat more whole foods.
Protein bars are eh.
I usually try to eat every couple of hours, with at least 500kcal, with varying protein amounts.
Food is where it's at.
Also, no need to work out for a full 2 hours.
If you want to gain weight, focus on compound exercises 3 times a week.
Less reps, more weight.
Old 06-27-2007, 06:00 PM   #16
ASASN8
bladehines's Avatar
yep my whole routine is all compound exercises. and my sacks are basically to keep me from eating more. i get roughly 3-4000 cals a day i don't need anymore. i am gaining better then i did before so i should be good on food untill i need to go up more after 3 months.
as far as surgery i had a vericoiel removal. basically a BIG varicose vein in my left sack on the veins to that nut. it let blood build up and raise the temp of my balls causing lower test levels, and pain! 70% of men have it but in varied degrees. The surgeon that did mine has been doing this for 20+ years and i had the biggest veins he had ever seen! some were up to 4mm wide!
but i am good now!
supplements just the animal pak and animal stack2. basically multi vitamins, and a small vasodialator with a test booster. So far it works good i take the pak at lunch, and the Stack 30min before working out with some carbs and protein.
Old 06-27-2007, 06:03 PM   #17
ASASN8
bladehines's Avatar
Here is my workout routine for the 3 months: the weight on the left is what i was doing, and the right is what i should be doing.
2. French Press: Place your hands on a barbell, about two hand-widths apart. Raise the bar above your head, then lower it behind your neck. Be sure to keep your upper arms close to the sides of your head. Only your elbows bent. From the lowered position, press the weight overhead by moving your forearms until your elbows are locked.
3. Incline Curl: With a dumbbell in each hand lean back on an incline bench. Let the weights extend the arms to a natural hanging position. From there, curl the weight to your shoulders. Return to the original position and repeat.
8. Dumbbell Circle: The barbells are simultaneously rotated in vertical circles in front of the body, with the wrists turned up at the bottom of the outward arc and turned down on the inner arc.
9. Reverse Curl: Take a shoulder-width grip on a barbell. Stand erect, with your arms hanging down at your sides and the barbell resting across your upper thighs. Press the forearms in against the sides of your rib cage. Without allowing your torso to move forward or backward, slowly curl the barbell upward in a semicircular arc, from your upper thighs to a point directly under your chin. Squeeze your forearms and upper-arm muscles as tightly as possible for a moment, and then slowly lower the weight back along the same arc to the starting point.
10. Wrist Curl 1: Forearms on thighs, palms up.
11. Wrist Curl 2: Forearms on thighs, palms down.
plus runnning for 30min and doing high steps.
also i do this at home:
DAILY TRAINING AT HOME
6:00AM
Sit ups = 4 sets of 20
Leg Raises = 4 sets of 20
Side Bends = 4 sets of 15-20
Abs: After work Tuesday, Thursday.
Waist Twists 4 of 70 with barbell
Sit-up Twists 4 of 20
Leg Raises 4 of 20
Leaning Twist 4 of 50 with barbell
Frog kick 4 sets Inf.
Roman Chair 2 sets Inf.
Leg Raises 2 sets Inf.
Side Bends 2-4 sets 15-20 with dumbbell
Shadow Boxing:
1 lb 100 punches
2 lb 100 punches
3 lb 100 punches
5 lb 100 punches
8 lb 100 punches
10 lb 100 punches
THEN BACK DOWN
Old 06-27-2007, 06:09 PM   #18
Headturners
2002ZQ8's Avatar
keep up the work bro
ive been in the gym for 4 months solid...and have had a trainer for 5 weeks 3 times a week recently
Old 06-27-2007, 06:23 PM   #19
ASASN8
bladehines's Avatar
here is where i am at now on the chart:
Old 06-27-2007, 06:54 PM   #20
RITALIN, IT LOVES ME!
BUCKET's Avatar
yep, lifting here too. no pics as of present. I am bad about that.
5days a week in gthe gym for an hour. different group each day.
Old 06-27-2007, 07:59 PM   #21
Stealth Sierra
WhiteNoma's Avatar
been busting my ass as well... i have salad 2 meals a day... and a balanced meal for dinner.
i hit the gym up everyday for atleast 2 hours usually around 3. Overcoming a hemmeraged groin muscle and trying to stay under the radar of my previously torn rotator cuft.
Old 06-27-2007, 08:14 PM   #22
limeade
01black4.3's Avatar
I'm still going at it (I did skip about 2 weeks...) anyways, I went from 170lbs to 176lbs in 2 weeks.
Old 06-27-2007, 08:19 PM   #23
This is the end.
You're doing too much imo, but if it's working for you, then it's working.
Old 06-27-2007, 08:22 PM   #24
S-Clusive's Jester
TruStinger's Avatar
just so you know, going more than an hour is really a waste. your glycogen(or something) levels drop unless you are genetically gifted. since you're going everyday you are probly overtraining your muscles like crazy and arent gonna get anywhere fast. you should go 3-4 times a week, try alternating lower body and upper body. its VERY easy to overtrain your triceps especially.
they do have exercises specifically for rotator cuffs also.
Old 06-27-2007, 08:24 PM   #25
S-Clusive's Jester
TruStinger's Avatar
bladehines, the next 3 months are going to suck because you arent going to get anywhere near the same improvement as the first 3. its pretty demoralizing but keep on it.
Old 06-27-2007, 08:25 PM   #26
S-Clusive's Jester
TruStinger's Avatar
i started working out like 7 months ago as more of a weight loss deal. i started at 220, now im sitting at 193. also it seems no matter what i do or eat i maintain my weight. i havent really gotten much stronger because i cant do much high weight by myself. the summer is here so i do alot of sports and stuff so working out has taken a back seat.
Old 06-27-2007, 08:29 PM   #27
Moderator
What?'s Avatar
not bad
my meals are simple
morning, any delicious 1 bowl of cereal i want
lunch i have 3 canned fish and draining out all the oil and just having over 40% of protein per canned fish
mid afternoon, couple hrs b4 workout, i have couple bagels
dinner, nothing really, probably slice of pizza or 2 or whatever fruits in fridge
rest of day i drank ALOT of water, probably average over gal of water every 3 hr and almost gal of water at gym per hour and during the day whenever if i feel need to eat, i drink my mixed fruit drink which contains(peach, pear, pineapple, orange, apple, banana, honey, strawberry) but i mixed them seperately in normal size powerade and have probably 3 per day of that
im currently at 6'2 and 193lb, my goal is to lose my beer belly and some muscle and cut back drinking
fruits are like natural energy man, waaaaaaay much better than energy drink with too much caffinee and perfect 6-8hr sleep and no nap, then when my work gets slow, i get up on jump rope, do laps around the shop with 5lb-10lb dumbbells "as hitting the punching bag: while running, and hitting the ground for pushup back and forth
easy sleep and passout everytime and results are coming up good
Old 06-27-2007, 08:35 PM   #28
Stealth Sierra
WhiteNoma's Avatar
ive been to physical therapy... i stretch and work it out every day... I disagree on the hour comment... i do a very thorough work out working different muscles different ways. i ofcourse alternate muscle groups.. and make time for significant cardio. 6 days a week. Im not exactly a beginner at this regiment.
Old 06-27-2007, 08:41 PM   #29
This is the end.
Re: My Routine...
Here's my basic routine, and daily diet.
I'm basically bulking (since forever) and gaining as much LBM as possible.
This has really worked for me, and a few people who compete help me set it up.
I always start off my pre-workout supplements. Then I begin stretching, just some dynamic stretches to get the blood flowing, and to loosen up a little. Usually under 10 exercises, depends on how I feel. If I'm lazy I do more to get my heart rate up, and get the blood flowing. Then I do some warm up sets, one or two with maybe 50% weight, at the most. Then depending on the day, I move on to my actual lifting routine.
Workout A = Push:
-Squats
-Lunges
-Bench Press
-Military Press
-Close Grip Bench/Parallel Dip Bars
-Tricep Extension
Workout B = Pull:
-Deadlifts
-Leg Curls
-Bent Over Barbell Rows
-Pullups/Lat Pulldowns
-Dumbbell Curls
Splits/Reps/Sets:
Mon: Workout A - 2 Sets of 8-12 Reps
Wed: Workout B - 2 Sets of 8-12 Reps
Fri: Workout A - 4 Sets of 4-6 Reps
Mon: Workout B - 4 Sets of 4-6 Reps
I started off with a weight I could do the minimum routine with, rep and set wise. Each block rotation, I would increase it by a rep. I could feel the difference, but then my muscle endurance was building. So when I hit the rep limit, and could move the weight easily, I would add like 2 1/2 to 5 lbs and start all over. Great routine.
Immediately after I workout, I stretch more. This time static stretching, and I make sure every area and part of my body gets attention. This is the stretching you do and hold in place for said amount of time. I usually have about 12 to 15 stretches I do. Works wonders.
Old 06-27-2007, 08:47 PM   #30
This is the end.
Re: My Diet...
Wake up about 6:30a.m.
Meal #1 – Oatmeal, couple pieces of small fruits. On the weekend eggs, whole grain toast, or protein pancakes, and fruit. More protein!
Get to school around 7
:45a.m.
At school, 9:45a.m.
Meal #2 - Oatmeal, couple pieces of small fruits. On the weekend eggs, whole grain toast, or protein pancakes, and fruit, or Chicken breast(s), salad, veggies, brown rice.
While at school,
11:30a.m.
Meal #3 – Half of a homemade protein bar.
Get home from school,
1:30p.m.
Meal #4 – Chicken breast(s), salad, veggies, brown rice.
Home,
3:45p.m.
Meal #4 – Pre-Workout Shake. Creatine (maintain with bulk CEE on off days, green bulge on lifting days) Taken regardless of lifting/off days.
Home, 4:15 or 4:30p.m.
Workout.
Home,
5:00p.m. or 5:15p.m.
Meal #5 – Post-Workout shake.
Home, 6:30p.m. or 6:45p.m.
Meal #6 – Some sort of beef, brown rice, salad, veggies, small amount of fruit.
Home,
9:15p.m.
Meal #6 Night-time shake, half a homemade protein bar
Sleep,
9:30p.m. or 10p.m.
Shakes & contents…
Normal Shake:
2 cups milk
1 scoop ON whey protein (or should I use 2?)
1 cup crushed rolled oats
2 tablespoons natural peanut butter.
Flaxseed oil (only add during the afternoon)
Pre workout shake:
2 cups milk
2 cups rolled oats
Post workout shake:
2 cups milk
1 scoop ON whey Protein
1 cup rolled oats
Night time shake:
3 cups milk
1 scoop ON casien protein
Supplements used…
Optimum Nutrition, 100% Whey Protein (chocolate)
Optimum Nutrition, Casein Protein (chocolate)
Now Adam, Multi-Vitamin
Flaxseed Oil (unknown brand)
Green Bulge CEE Creatine.
Higher Power BB.com Bulk CEE.
Old 06-27-2007, 08:54 PM   #31
This is the end.
It took a little while to get use to, but if you're seriously about anything, you'll make yourself do it. My gym is in my house, so it's somewhat easier in that aspect. I don't have to deal with making a special trip out just to go to the gym.
My diet isn't set in stone, so it's structured so it can vary time wise if I can't get to a meal right away, but I very, very rarely miss one. With the help of my fiance, I make all of my meals before hand, and load up a big ass ice chest and take it to school with me. When at work (I work as an EMT, gone a day or two at a time), I do the same thing.
I also do a lot of other little things like weighted calf raises, some forearm exercises, and stuff like that. So that's just a general workout routine. I add little things here and there, but I don't do much cardio, and I sleep as much as I can.
If anyone needs any help with anything, let me know, I would be glad to help whomever achieve their goals. I know when I started out it would of been amazing to have someone who knew what was going on to help me out. Took me a lot of time to do the research, but I eventually made some friends with really helpful people.
Old 06-27-2007, 09:00 PM   #32
BUCKET's Avatar
her we go,
7:30 alarm goes off 8:00 am at gym and starting
moday, chest
bench
incline dumbell press
cable x overs
flys dumbell/machine (depending on what is going on)
pushups
and then one tri work out (usually dips)
tues, biceps
seated preacher curl
hammer curl
cable machin curl
drop set curl (machine)
abs
wed. legs
squats
sled press
extensions
curl
then walking lunges from back of the gym to the front door (then I leave) barely
turs. tri
dips
skull crushers
pull downs
behind head extension
and one chest exercise (bench)
abs
fri back/sholders
dead lifts
military press
machine rows
side and front sholder extensions
dumbell rows
shrugs
cardio; slowly adding more and more.
food
no food first thing.
after gym 9:30am
1 cup oat meal
scoop of whey
glutamine
flax seeds in the shake
milk
pills,
bcaa's
animal pak
and my daily dont kill people pill, prozak
i then every day make 2 cups of brown rice with 3 big cans of chicken(each can rinced 3 time) boiled together
1:00 pm
premade bowl of brown rice and chicken
4:00
7:00
10:30
glass of milk with a scoop of whey and glutamine
bout to add a early morning milk and protein before work out.
did not add weights and sets , kinda of irrelevant
stats;
5'7"
200lb
bench 225
squat 315
dead 315
I am not cut, still hold a little weight around the middle.lol
Old 06-27-2007, 09:02 PM   #33
BUCKET's Avatar
bout to get some sperilina to supplement my lack of veggie intake. I need it
Old 06-27-2007, 09:06 PM   #34
This is the end.
Yeah man, your diet is really lacking.
Also, you really really really need some protein when you wake up and before your workout. You mentioned adding a shake, but you need more. Eat a good whole foods breakfast.
You'll notice a huge difference in strength, energy, etc.
Old 06-27-2007, 09:16 PM   #35
Red X = Pure Sex!
onelowX's Avatar
Congrats to all you that have such strict workout routines and diets. I wish I had the discipline to keep to that kind of lifestyle.
Old 06-27-2007, 09:20 PM   #36
limeade
01black4.3's Avatar
Woot! I just weighed myself (last time was last week) and I weigh 180 now!
Old 06-27-2007, 09:22 PM   #37
This is the end.
Anyone can do it. A little ambition and motivation and you're golden.
My routine and diet is pretty intense, but my diet isn't so bad because I have like 200+ pages of bodybuilding food recipes and all kinds of shit. So I try to change it up so it doesn't get stale. Caloric intent, and nutrients stay the same though.
Every couple months I throw it all out the window though, I don't lift, have a few cheat days in a row, and drink some beers. It's a great time, but I usually end up regreting it because it's even harder to fall back into routine.
Like I said, if you have a goal, and need help reaching it, I'm willing to offer any advice you need.
Old 06-27-2007, 09:24 PM   #38
Red X = Pure Sex!
onelowX's Avatar
Thanks man, I will keep that in mind. I need to get back into better shape, I am single now. Gotta get ready for the women again.
Old 06-27-2007, 09:41 PM   #39
well ive been hitting the gym for 6 months or so ive lost alittle went from 208 to 180 but im only 5"5 so im not where i want to be i think i hit a brick wall. Havent gained havent lossed. What would your diet and or routine consist of.
Old 06-27-2007, 10:10 PM   #40
at the end of january i decided to start working out and eating healthier.. i started at a weight of 325 and I am now 253.. i am 6 ft tall... i have lost my motivation lately but i hope to get down to 225 soon... at first i did mostly cardio but now im starting to really enjoy lifting wieghts and stuff.. it is fun
Old 06-27-2007, 10:12 PM   #41
blazinblack's Avatar
yeah ive been lifting for about 8 months,
ive got some pics... dont wanna whore,
but it like from 2 months of working out to about 7 months.
Old 06-27-2007, 10:47 PM   #42
ASASN8
bladehines's Avatar
anyone feel free to post what ever pics! i will post more in about 2 months or so. i start all my routines on monday with the abs, and puches and everything. this week and the past 2 weeks i have stayed on the same diet not straying a bit and i have only done the Gym workouts. so tuesday i start the abs, punches etc.....
and once you hit the gym for a month and see good results, muscle tone, weight loss, that is enough to keep you motivated for the next time you go!!!
Old 06-27-2007, 10:51 PM   #43
ASASN8
bladehines's Avatar
at the end of my 3 months i should weigh 150+ and my strength should be above that of last time. again remember i am working with "probably" double the testosterone i was working with last time. which will help out a BUNCH!!!
Old 06-27-2007, 11:13 PM   #44
BUCKET's Avatar
no pics but yea, my diet could use more food, but I am also not bulking at all. In my routen I also work 8+ hours a day and still go to school. lugging compact, easy to manage 3/4 tupperwar bowls is easy. (not on the bike though) adding more stuff to carry (is do able ) but not with my schedule right now.
I havent taken pics in proll. 2 years. lol
I left to go to school at LA taech 2.5 years ago at 167lb 8%
could not afford gym and 60/70$ week in food, but was running constantly
8 months later I come home at 152
money again, back to eating like a monster for a year. no lifting though and it took its toll.
back at my old ways (aside from running) in the gym.
Old 06-28-2007, 12:21 AM   #45
left side i weighed 300 right side i weighed 264... i can tell the difference but i dunno if anyone else can
i am at 253 now so i look alittle smaller but i have been lifting alot too.. i love how the more work you do the more changes you see in your body..its awesome!!
Old 06-28-2007, 12:25 AM   #46
BuenosDingDongDiddlyDias
xJuice's Avatar
nice, i can tell. you almost have to go down a size in your jersey now haha
Old 06-28-2007, 12:26 AM   #47
haha yeah..and that jersey didnt even fit when i started..lol nice to beable to wear it again
Old 06-28-2007, 12:36 AM   #48
Low in Alaska
Alaska's Avatar
i'm still lifting... like kyle said, though... summer is here, and i do alot more outdoor activities...
i gave up tryin to bulk for now..that shit's too hard, especially when i climb a mountain every other week, and ride my bike 20-25 miles at a time..or run on the beach 3 or 4 miles... strenght is still staying, and muscles is still building and defining, though.. i dont have a strict routine. i go to the gym 4 times a week, usually, and cardio 3 or 4 times a week. i'm never in the gym for more than an hour, and usually right around 45 minutes..i eat pretty much whatever i want, but it's usually healthy...
remember: fishing is a workout (when you're catchin fish in the Kenai River or catchin Halibut out in the Cook Inlet it is)
Old 06-28-2007, 12:46 AM   #49
when i first started:
couple of months ago...
im only 16.
6'2 230lbs.
Old 06-28-2007, 01:35 AM   #50
My self esteem is lower
get layed's Avatar
damn man, you're pretty stout! I started working out about three months ago @ LA fitness. I can't say I see a definate gain yet, but im feeling it. I know it's working, so that's all that matters. I'm 5-9'' and wheigh about 140lbs. I didnt start when you guys did or anything, I just got tired of feeling and being a weakling. lol So maybe I should take some before and after (say 6 months later?) just so i can say hey, I got this far. I'm not on a real strengit diet of any sorts. I try to eat healthy as possible. However working construction and on the go, choices are sometimes limited. But before I work out i eat some protein bars and drink protein shakes. Take vitamins daily and so forth. I work out about two hours a day, 2 - 4 days a week always fallowed by a half hour or so of swimming. Trying to gain a six pack in the process. I never imagined how hard it is to get. Any pointers or advice im all ears. Lookin good guys, keep it up!
Page generated in 2.38130 seconds with 32 queries
[Output: 231.22 Kb. compressed to 212.26 Kb. by saving 18.96 Kb. (8.20%)]
