I know its not a s10 but need help
Hey guys, I had no idea where to post this, and its not in a mitsubitchy forum cause im too damn lazy to create an account but ... i got a 2000 montero sport 3.0 ... family car ... for some reason the motor compartment gets hot as F*** like i cant touch to hood prop ... or even pop the hood without burning the hell outta my hand ... now the motor isnt overheating or runnin hot its runnin normal ... im lost and confused on this one ... any ideas?
Hardcore Chevy Metalhead
Location: Wyoming (better known as hell!) User is: OffLine |
Re: I know its not a s10 but need help
This is the only thing I can think of
got fire insurance? if so let her go!
She Does?!?!?!
I would say that the engine heat isnt escaping the engine bay.....which the heat would cause alts to go out. Just cut a hole in the hood to let the heat escape...or just let it burn
I need to man let me tell ya ... I bought it from my cousin because at the time I was driving my dads caddy ... I miss that thing ... but it had no heat and no AC and I got a 2 year old and a 1 year old ... and when it was cold we put the kids me and my wife in her 2000 mustang ... so he told us for the truck 1500 ... paid cash ... but I gotta have a daily when my truck gets here so I dont have to rush to finish the dime!
She Does?!?!?!
Some cars and trucks have a way for heat to escape through the cowl. Not to be a smart ass, but heat rises.
makes sense ... no i know your not bein a smart ass dude i will check that when my 1 year old goes down for her nap my sons on the couch lol ... asleep
k just went outside to see about the cowl thing ... the only hole in the cowl are the few holes for the plastic rivets and screws ... and the wiper arms and stuff ... no hole through that for heat ... it seems like heat is going up and cant get out ...
She Does?!?!?!
well, is this like a good car or a beater? if you dont care if it doesnt look perfect i would loosen up the hood at the hinges and throw some washers in there so the back of the hood is tilted up and let the heat escape that way
well I am kinda thinkin of taken the inner fenders out LOL ... yeah its just the family car ... dont care what it looks like ... if the alt would stop goin out so quick and the timing do right it would be a good truck ... but damn i hate when i go to pop the hood and cant for 10 - 20 minutes depending on how long i drove it ... before i can lift the hood
She Does?!?!?!
I dont know if id take the inner fenders out just yet. There is something wrong under there and since its not running hot id check the exhaust manifolds. There might be a heat shield or something missing or may vave a clogged cat or something. And thats whats making the under hood temps crazy
the radiator fan? would that have anything to do with it? itll run for a second after the trucks starts and then cut off i dont know if itll run again or not?
She Does?!?!?!
That might have alot to do with it. Id check to see if it turns on or not. That could be what forces the air down to escape
well it turns on for a couple seconds when i start it up but if it cuts back on i dont know i let it run for a couple minutes with the hood shut and nothing ... its a fan thats behind the radiator where you can see it through the grill
Life Begins @ Zero PSI
Sounds like you have an electric radiator fan. If you follow the wires you will notice a thermostat sensor that turns the fan/s on/off. Make sure they going on/off when the engine is up to temp.
Another thing is if your hood is bare metal on the inside the heat will naturally radiate through. If it's insulated it will not radiate through as much. I'd say you should get an accurate reading of your engines coolant temp and make sure it's not running too hot. There are tools that can do this and I've also seen radiator caps with temp readings on them. If you're talking about a ton of heat and your OEM temp gauge is reading normal I would still think something is not right. |
