Engine oil additives
Anyone with a good dose of common sense should take the time to read through this....that is, if you care about your car or truck, and don't want to be pissing money down the drain.....copied from another forum today while doing 'research'! LOL!
Actual link below, or you can just scroll down: http://www.rx7club.com/showthread.php?t=689158 I just read this report created by an Engineering group at the University of Waterloo. Snake Oil! Is That Additive Really A Negative? Information for this article was compiled from reports and studies by the University of Nevada Desert Research Center, DuPont Chemical Company, Avco Lycoming (aircraft engine manufacturers), North Dakota State University, Briggs and Stratton (engine manufacturers), the University of Utah Engineering Experiment Station, California State Polytechnic College and the National Aeronautics and Space Administration's Lewis Research Center. You Can't Tell The Players Without A Program On starting this project, we set out to find as many different oil additives as we could buy. That turned out to be a mistake. There were simply too many avail able! At the very first auto parts store we visited, there were over two dozen different brand names available. By the end of the day, we had identified over 40 different oil additives for sale and realized we needed to rethink our strategy. First of all, we found that if we checked the fine print on the packages, quite a number of the additives came from the same manufacturer. Also, we began to notice that the additives could be separated into basic "groups" that seemed to carry approximately the same ingredients and the same promises. In the end, we divided our additives into four basic groups and purchased at least three brands from three different manufacturers for each group. We defined our four groups this way: 1.) Products that seemed to be nothing more than regular 50-rated engine oil (including standard additives) with PTFE (Teflon TM) added. 2.) Products that seemed to be nothing more than regular 50-rated engine oil (including standard additives) with zinc dialkyldithiophosphate added. 3.) Products containing (as near as we could determine) much the same additives as are already found in most major brands of engine oil, though in different quantities and combinations. 4.) Products made up primarily of solvents and/or detergents. There may be some differences in chemical makeup within groups, but that is impossible to tell since the additive manufacturers refuse to list the specific ingredients of their products. We will discuss each group individually. The PTFE Mystery Currently, the most common and popular oil additives on the market are those that contain PTFE powders suspended in a regular, over-the-counter type, 50-rated petroleum or synthetic engine oil. PTFE is the common abbreviation used for Polytetrafloeraethylene, more commonly known by the tradename "Teflon," which is a registered trademark of the DuPont Chemical Corporation. Among those oil additives we have identified as containing PTFE are: Slick 50, Liquid Ring, Lubrilon, Microlon, Matrix, Petrolon (same company as Slick 50), QMl, and T-Plus (K-Mart). There are probably many more names in use on many more products using PTFE. We have found that oil additive makers like to market their products under a multitude of "private brand" names. While some of these products may contain other additives in addition to PTFE, all seem to rely on the PTFE as their primary active ingredient and all, without exception, do not list what other ingredients they may contain. Though they have gained rather wide acceptance among the motoring public, oil additives containing PTFE have also garnered their share of critics among experts in the field of lubrication. By far the most damning testimonial against these products originally came from the DuPont Chemical Corporation, inventor of PTFE and holder of the patents and trademarks for Teflon. In a statement issued about ten years ago, DuPont's Fluoropolymers Division Product Specialist, J.F. Imbalzano said, "Teflon is not useful as an ingredient in oil additives or oils used for internal combustion engines." At the time, DuPont threatened legal action against anyone who used the name "Teflon" on any oil product destined for use in an internal combustion engine, and refused to sell its PTFE powders to any one who intended to use them for such purposes. After a flurry of lawsuits from oil additive makers, claiming DuPont could not prove that PTFE was harmful to engines, DuPont was forced to once again begin selling their PTFE to the additive producers. The additive makers like to claim this is some kind of "proof' that their products work, when in fact it is nothing more than proof that the American legal ethic of "innocent until proven guilty" is still alive and well. The decision against Dupont involved what is called "restraint of trade." You can't refuse to sell a product to someone just because there is a possibility they might use it for a purpose other than what you intended it for. It should be noted that DuPont's official position on the use of PTFE in engine oils remains carefully aloof and non-commital, for obvious legal reasons. DuPont states that though they sell PTFE to oil additive producers, they have "no proof of the validity of the additive makers' claims." They further state that they have "no knowledge of any advantage gained through the use of PTFE in engine oil." Fear of potential lawsuits for possible misrepresentation of a product seem to run much higher among those with the most to lose. After DuPont's decision and attempt to halt the use of PTFE in engine oils, several of the oil additive companies simply went elsewhere for their PTFE powders, such as purchasing them in other countries. In some cases, they disguise or hype their PTFE as being something different or special by listing it under one of their own tradenames. That doesn't change the fact that it is still PTFE. In addition, there is some evidence that certain supplies of PTFE powders (from manufacturers other than DuPont) are of a cruder version than the original, made with larger sized flakes that are more likely to "settle out" in your oil or clog up your filters. One fairly good indication that a product contains this kind of PTFE is if the instructions for its use advise you to "shake well before using." It only stands to reason that if the manufacturer knows the solids in his product will settle to the bottom of a container while sitting on a shelf, the same thing is going to hap pen inside your engine when it is left idle for any period of time. The problem with putting PTFE in your oil, as explained to us by several industry experts, is that PTFE is a solid. The additive makers claim this solid "coats" the moving parts in an engine (though that is far from being scientifically proven). Slick 50 is currently both the most aggressive advertiser and the most popular seller, with claims of over 14 million treatments sold. However, such solids seem even more inclined to coat non-moving parts, like oil passages and filters. After all, if it can build up under the pressures and friction exerted on a cylinder wall, then it stands to reason it should build up even better in places with low pressures and virtually no friction. This conclusion seems to be borne out by tests on oil additives containing PTFE conducted by the NASA Lewis Research Center, which said in their report, "In the types of bearing surface contact we have looked at, we have seen no benefit. In some cases we have seen detrimental effect. The solids in the oil tend to accumulate at inlets and act as a dam, which simply blocks the oil from entering. Instead of helping, it is actually depriving parts of lubricant." Remember, PTFE in oil additives is a suspended solid. Now think about why you have an oil filter on your engine. To remove suspended solids, right? Right. Therefore it would seem to follow that if your oil filter is doing its job, it will collect as much of the PTFE as possible, as quickly as possible. This can result in a clogged oil filter and decreased oil pres sure throughout your engine. In response to our inquiries about this sort of problem, several of the PTFE pushers responded that their particulates were of a sub-micron size, capable of passing through an ordinary oil filter unrestricted. This certainly sounds good, and may in some cases actually be true, but it makes little difference when you know the rest of the story. You see, PTFE has other qualities besides being a friction reducer: It expands radically when exposed to heat. So even if those particles are small enough to pass through your filter when you purchase them, they very well may not be when your engine reaches normal operating temperature. Here again, the' scientific evidence seems to support this, as in tests conducted by researchers at the University of Utah Engineering Experiment Station involving Petrolon additive with PTFE. The Petrolon test report states, "There was a pressure drop across the oil filter resulting from possible clogging of small passageways." In addition, oil analysis showed that iron contamination doubled after using the treatment, indicating that engine wear didn't go down - it appeared to shoot up. This particular report was paid for by Petrolon (marketers of Slick 50), and was not all bad news for their products. The tests, conducted on a Chevrolet six-cylinder automobile engine, showed that after treatment with the PTFE additive the test engine's friction was reduced by 13.1 per- cent. Also, output horsepower increased from 5.3 percent to 8.1 percent, and fuel economy improved from 11.8 percent under light load to 3.8 percent under heavy load. These are the kind of results an aggressive marketing company like Petrolon can really sink their teeth into. If we only reported the results in the last paragraph to you, you'd be inclined to think Slick 50 was indeed a magic engine elixir. What you have to keep in mind is that often times the benefits (like increased horse power and fuel economy) may be out weighed by some serious drawbacks (like the indications of reduced oil pressure and increased wear rate). The Plot Thickens Just as we were about to go to press with this article, we were contacted by the public relations firm of Trent and Company, an outfit with a prestigious address in the Empire State Building, New York. They advised us they were working for a company called QMI out of Lakeland, Florida, that was marketing a "technological breakthrough" product in oil additives. Naturally, we asked them to send us all pertinent information, including any testing and research data. What we got was pretty much what we expected. QMI's oil additive, according to their press release, uses "ten times more PTFE resins than its closest competitor." Using the "unique SX-6000 formula," they say they are the only company to use "aqueous dispersion resin which means the microns (particle sizes) are extensively smaller and can penetrate tight areas." This, they claim, "completely eliminates the problem of clogged filters and oil passages." Intrigued by their press release, we set up a telephone interview with their Vice- President of Technical Services, Mr. Owen Heatwole. Mr. Heatwole's name was immediately recognized by us as one that had popped in earlier research of this subject as a former employee of Petrolon, a company whose name seems inextricably linked in some fashion or another with virtually every PTFE-related additive maker in the country. Mr. Heatwole was a charming and persuasive talker with a knack for avoiding direct answers as good as any seasoned politician. His glib pitch for his product was the best we've ever heard, but when dissected and pared down to the verifiable facts, it actually said very little. When we asked about the ingredients in QMI's treatments, we got almost exactly the response we expected. Mr. Heatwole said he would "have to avoid discussing specifics about the formula, for proprietary reasons." After telling us that QMI was being used by "a major oil company," a "nuclear plant owned by a major corporation" and a "major engine manufacturer," Mr. Heatwole followed up with, "Naturally, I can't reveal their names- for proprietary reasons." He further claimed to have extensive testing and research data available from a "major laboratory," proving conclusively how effective QMI was. When we asked for the name of the lab, can you guess? Yup, "We can't give out that information, for proprietary reasons." What QMI did give us was the typical "testimonials," though we must admit theirs came from more recognizable sources than usual. They seem to have won over the likes of both Team Kawasaki and Bobby Unser, who evidently endorse and use QMI in their racing engines. Mr. Heatwole was very proud of the fact that their product was being used in engines that he himself admitted are "torn down and completely inspected on a weekly basis." Of course, what he left out is that those same engines are almost totally rebuilt every time they're torn down. So what does that prove in terms of his product reducing wear and promoting engine longevity? Virtually nothing. Mr. Heatwole declined to name the source of QMI's PTFE supply "for proprietary reasons." He bragged that their product is sold under many different private labels, but refused to identify those labels "for proprietary reasons." When asked about the actual size of the PTFE particles used in QMI, he claimed they were measured as "sub-micron in size" by a "major motor laboratory" which he couldn't identify - you guessed it - for "proprietary reasons." After about an hour of listening to "don't quote me on this," "I'll have to deny that if you print it," and "I can't reveal that," we asked Mr. Heatwole if there was something we could print. "Certainly," he said, "Here's a good quote for you: 'The radical growth in technology has overcome the problem areas associated with PTFE in the I980s'" "Not bad," we said. Then we asked to whom we might attribute this gem of wisdom. DuPont Chemical, perhaps? "Me," said Mr. Heatwole. "I said that." QMI's press releases like to quote the Guinness Book Of Records in saying that PTFE is "The slickest substance known to man." Far be it from us to take exception to the Guinness Book, but we doubt that PTFE is much slicker than some of the people marketing it. The Zinc Question The latest "miracle ingredient" in oil additives, attempting to usurp PTFE's cure-all throne, is zinc dialkyldithiophosphate, which we will refer to here after as simply "zinc." Purveyors of the new zinc-related products claim they can prove absolute superiority over the PTFE-related products. Naturally, the PTFE crowd claim exactly the same, in reverse. Zinc is contained as part of the standard additive package in virtually every major brand of engine oil sold today, varying from a low volume of 0.10 per cent in brands such as Valvoline All Climate and Chevron l5W-50, to a high volume of 0.20 percent in brands such as Valvoline Race and Pennzoil GT Performance. Organic zinc compounds are used as extreme pressure, anti-wear additives, and are therefore found in larger amounts in oils specifically blended for high-revving, turbocharged or racing applications. The zinc in your oil comes into play only when there is actual metal-to-metal con tact within your engine, which should never occur under normal operating conditions. However, if you race your bike, or occasionally play tag with the redline on the tach, the zinc is your last line of defense. Under extreme conditions, the zinc compounds react with the metal to prevent scuffing, particularly between cylinder bores and piston rings. However - and this is the important part to remember - available research shows that more zinc does not give you more protection, it merely prolongs the protection if the rate of metal-to-metal contact is abnormally high or extended. So unless you plan on spending a couple of hours dragging your knee at Laguna Seca, adding extra zinc compounds to your oil is usually a waste. Also, keep in mind that high zinc content can lead to deposit formation on your valves, and spark plug fouling. Among the products we found containing zinc dialkyldithiophosphate were Mechanics Brand Engine Tune Up, K Mart Super Oil Treatment, and STP Engine Treatment With XEP2. The only reason we can easily identify the additives with the new zinc compounds is that they are required to carry a Federally mandated warning label indicating they contain a hazardous substance. The zinc phosphate they contain is a known eye irritant, capable of inflicting severe harm if it comes in contact with your eyes. If you insist on using one of these products, please wear protective goggles and exercise extreme caution. As we mentioned, organic zinc compounds are already found in virtually every major brand of oil, both automotive and motorcycle. However, in recent years the oil companies voluntarily reduced the amount of zinc content in most of their products after research indicated the zinc was responsible for premature deterioration and damage to catalytic converters. Obviously this situation would not affect 99 percent of all the motorcycles on the road - however, it could have been a factor with the newer BMW converter - equipped bikes. Since the reduction in zinc content was implemented solely for the protection of catalytic converters, it is possible that some motorcycles might benefit from a slight increase in zinc content in their oils. This has been taken into account by at least one oil company, Spectro, which offers 0.02 to 0.03 percent more zinc compounds in its motorcycle oils than in its automotive oils. Since Spectro (Golden 4 brand, in this case) is a synthetic blend lubricant designed for extended drain intervals, this increase seems to be wholly justified. Also, available research indicates that Spectro has, in this case, achieved a sensible balance for extended application without increasing the zinc content to the point that it is likely to cause spark plug fouling or present a threat to converter- equipped BMW models. It would appear that someone at Spectro did their homework. Increased Standard Additives (More Is Not Necessarily Better) Though some additives may not contain anything harmful to your engine, and even some things that could be beneficial, most experts still recommend that you avoid their use. The reason for this is that your oil, as purchased from one of the major oil companies, already contains a very extensive additive package. This package is made up of numerous, specific additive components, blended to achieve a specific formula that will meet the requirements of your engine. Usually, at least several of these additives will be synergistic. That is, they react mutually, in groups of two or more, to create an effect that none of them could attain individually. Changing or adding to this formula can upset the balance and negate the protective effect the formula was meant to achieve, even if you are only adding more of something that was already included in the initial package. If it helps, try to think of your oil like a cake recipe. Just because the original recipe calls for two eggs (which makes for a very moist and tasty cake), do you think adding four more eggs is going to make the cake better? Of course not. You're going to upset the carefully calculated balance of ingredients and magnify the effect the eggs have on the recipe to the point that it ruins the entire cake. Adding more of a specific additive already contained in your oil is likely to produce similar results. This information should also be taken into account when adding to the oil already in your bike or when mixing oils for any reason, such as synthetic with petroleum. In these cases, always make sure the oils you are putting together have the same rating (SA, SE, SC, etc.). This tells you their additive packages are basically the same, or at least compatible, and are less likely to upset the balance or counteract each other. Detergents And Solvents Many of the older, better-known oil treatments on the market do not make claims nearly so lavish as the new upstarts. Old standbys like Bardahl, Rislone and Marvel Mystery Oil, instead offer things like "quieter lifters," "reduced oil burning" and a "cleaner engine." Most of these products are made up of solvents and detergents designed to dissolve sludge and carbon deposits inside your engine so they can be flushed or burned out. Wynn's Friction Proofing Oil, for example, is 83 percent kerosene. Other brands use naphthalene, xylene, acetone and isopropanol. Usually, these ingredients will be found in a base of standard mineral oil. In general, these products are designed to do just the opposite of what the PTFE and zinc phosphate additives claim to do. Instead of leaving behind a "coating" or a "plating" on your engine surfaces, they are designed to strip away such things. All of these products will strip sludge and deposits out and clean up your engine, particularly if it is an older, abused one. The problem is, unless you have some way of determining just how much is needed to remove your deposits without going any further, such solvents also can strip away the boundary lubrication layer provided by your oil. Overuse of solvents is an easy trap to fall into, and one which can promote harmful metal-to-metal contact within your engine. As a general rule of thumb these products had their place and were at least moderately useful on older automobile and motorcycle engines of the Fifties and Sixties, but are basically unneeded on the more efficient engine designs of the past two decades. The Infamous "No Oil" Demo At at least three major motorcycle rallies this past year, we have witnessed live demonstrations put on to demonstrate the effectiveness of certain oil additives. The demonstrators would have a bench- mounted engine which they would fill with oil and a prescribed dose of their "miracle additive." After running the engine for a while they would stop it, drain out the oil and start it up again. Instant magic! The engine would run perfectly well for hours on end, seemingly proving the effectiveness of the additive which had supposedly "coated" the inside of the engine so well it didn't even need the oil to run. In one case, we saw this done with an actual motorcycle, which would be rid den around the parking lot after having its oil drained. A pretty convincing demonstration - until you know the facts. Since some of these demonstrations were conducted using Briggs and Stratton engines, the Briggs and Stratton Company itself decided to run a similar, but somewhat more scientific, experiment. Taking two brand-new, identical engines straight off their assembly line, they set them up for bench-testing. The only difference was that one had the special additive included with its oil and the other did not. Both were operated for 20 hours before being shut down and having the oil drained from them. Then both were started up again and allowed to run for another 20 straight hours. Neither engine seemed to have any problem performing this "minor miracle." After the second 20-hour run, both engines were completely torn down and inspected by the company's engineers. What they found was that both engines suffered from scored crankpin bearings, but the engine treated with the additive also suffered from heavy cylinder bore damage that was not evident on the untreated engine. This points out once again the inherent problem with particulate oil additives: They can cause oil starvation. This is particularly true in the area of piston rings, where there is a critical need for adequate oil flow. In practically all of the reports and studies on oil additives, and particularly those involving suspended solids like PTFE, this has been reported as a major area of engine damage. The Best of The Worst Not all engine oil additives are as potentially harmful as some of those we have described here. However, the best that can be said of those that have not proved to be harmful is that they haven't been proved to offer any real benefits, either. In some cases, introducing an additive with a compatible package of components to your oil in the right proportion and at the right time can conceivably extend the life of your oil. However, in every case we have studied it proves out that it would actually have been cheaper to simply change the engine oil instead. In addition, recent new evidence has come to light that makes using almost any additive a game of Russian Roulette. Since the additive distributors do not list the ingredients contained within their products, you never know for sure just what you are putting in your engine. Recent tests have shown that even some of the most inoffensive additives contain products which, though harmless in their initial state, convert to hydrofluoric acid when exposed to the temperatures inside a firing cylinder. This acid is formed as part of the exhaust gases, and though it is instantly expelled from your engine and seems to do it no harm, the gases collect inside your exhaust system and eat away at your mufflers from the inside out. Whatever The Market Will Bear The pricing of oil additives seems to follow no particular pattern whatsoever. Even among those products that seem to be almost identical, chemically, retail prices covered an extremely wide range. For example: One 32-ounce bottle of Slick 50 (with PTFE) cost us $29.95 at a discount house that listed the retail price as $59.95, while a 32-ounce bottle of T-Plus (which claims to carry twice as much PTFE as the Slick 50) cost us only $15.88. A 32-ounce bottle of STP Engine Treatment (containing what they call XEP2), which they claim they can prove "outperforms leading PTFE engine treatments," cost us $17.97. Yet a can of K Mart Super Oil Treatment, which listed the same zinc-derivative ingredient as that listed for the XEP2, cost us a paltry $2.67. Industry experts estimate that the actual cost of producing most oil additives is from one-tenth to one-twentieth of the asking retail price. Certainly no additive manufacturer has come forward with any exotic, high-cost ingredient or list of ingredients to dispute this claim. As an interesting note along with this, back before there was so much competition in the field to drive prices down, Petrolon (Slick 50) was selling their PTFE products for as much as $400 per treatment! The words "buyer beware" seem to take on very real significance when talking about oil additives. The Psychological Placebo You have to wonder, with the volume of evidence accumulating against oil additives, why so many of us still buy them. That's the million-dollar question, and it's just as difficult to answer as why so many of us smoke cigarettes, drink hard liquor or engage in any other number of questionable activities. We know they aren't good for us - but we go ahead and do them anyway. Part of the answer may lie in what some psychiatrists call the "psychological placebo effect." Simply put, that means that many of us hunger for that peace of mind that comes with believing we have purchased the absolute best or most protection we can possibly get. Even better, there's that wonderfully smug feeling that comes with thinking we might be a step ahead of the pack, possessing knowledge of something just a bit better than everyone else. Then again, perhaps it comes from an ancient, deep-seated need we all seem to have to believe in magic. There has never been any shortage of unscrupulous types ready to cash in on our willingness to believe that there's some magical mystery potion we can buy to help us lose weight, grow hair, attract the opposite sex or make our engines run longer and better. I doubt that there's a one of us who hasn't fallen for one of these at least once in our lifetimes. We just want it to be true so bad that we can't help ourselves. Testimonial Hype vs. Scientific Analysis In general, most producers of oil additives rely on personal "testimonials" to advertise and promote their products. A typical print advertisement will be one or more letters from a satisfied customer stating something like, "1 have used Brand X in my engine for 2 years and 50,000 miles and it runs smoother and gets better gas mileage than ever before. I love this product and would recommend it to anyone." Such evidence is referred to as "anecdotal" and is most commonly used to pro mote such things as miracle weight loss diets and astrology. Whenever I see one of these ads I am reminded of a stunt played out several years ago by Allen Funt of "Candid Camera" that clearly demonstrated the side of human nature that makes such advertising possible. With cameras in full view, fake "product demonstrators" would offer people passing through a grocery store the opportunity to taste-test a "new soft drink." What the victims didn't know was that they were being given a horrendous concoction of castor oil, garlic juice, tabasco sauce and several other foul-tasting ingredients. After taking a nice, big swallow, as instructed by the demonstrators, the unwitting victims provided huge laughs for the audience by desperately trying to conceal their anguish and disgust. Some literally turned away from the cameras and spit the offending potion on the floor. |
Re: Engine oil additives
The fascinating part came when about one out of four of the
victims would actu ally turn back to the cameras and proclaim the new drink was "Great" or "Unique" or, in several cases, "One of the best things I've ever tasted!" Go figure. The point is, compiling "personal testimonials" for a product is one of the easiest things an advertising company can do - and one of the safest, too. You see, as long as they are only expressing some one else's personal opinion, they don't have to prove a thing! It's just an opinion, and needs no basis in fact whatsoever. On the other hand, there has been documented, careful scientific analysis done on numerous oil additives by accredited institutions and researchers. For example: Avco Lycoming, a major manufacturer of aircraft engines, states, "We have tried every additive we could find on the market, and they are all worthless." Briggs and Stratton, renowned builders of some of the most durable engines in the world, says in their report on engine oil additives, "They do not appear to offer any benefits." North Dakota State University conducted tests on oil additives and said in their report, "The theory sounds good- the only problem is that the products simply don't work." And finally, Ed Hackett, chemist at the University of Nevada Desert Research Center, says, "Oil additives should not be used. The oil companies have gone to great lengths to develop an additive pack age that meets the vehicle's requirements. If you add anything to this oil you may upset the balance and prevent the oil from performing to specification." Petrolon, Inc., of Houston, Texas, makers of Petrolon and producers of at least a dozen other lubrication products containing PTFE, including Slick 50 and Slick 30 Motorcycle Formula, claim that, "Multiple tests by independent laboratories have shown that when properly applied to an automotive engine, Slick 50 Engine Formula reduces wear on engine parts. Test results have shown that Slick 50 treated engines sustained 50 percent less wear than test engines run with premium motor oil alone." Sounds pretty convincing, doesn't it? The problem is, Petrolon and the other oil additive companies that claim "scientific evidence" from "independent laboratories," all refuse to identify the laboratories that conducted the tests or the criteria under which the tests were conducted. They claim they are "contractually bound" by the laboratories to not reveal their identities. In addition, the claim of "50 percent less wear" has never been proven on anything approaching a long-term basis. Typical examples used to support the additive makers' claims involve engines run from 100 to 200 hours after treatment, during which time the amount of wear particles in the oil decreased. While this has proven to be true in some cases, it has also been proven that after 400 to 500 hours of running the test engines invariably reverted to producing just as many wear particles as before treatment, and in some cases, even more. No matter what the additive makers would like you to believe, nothing has been proven to stop normal engine wear. You will note that all of the research facilities quoted in this article are clearly identified. They have no problem with making their findings public. You will also note that virtually all of their findings about oil additives are negative. That's not because we wanted to give a biased report against oil additives - it's because we couldn't find a single laboratory, engine manufacturer or independent research facility who would make a public claim, with their name attached to it, that any of the additives were actually beneficial to an engine. The conclusion seems inescapable. As a final note on advertising hype versus the real world, we saw a television ad the other night for Slick 50 oil additive. The ad encouraged people to buy their product on the basis of the fact that, "Over 14 million Americans have tried Slick 50!" Great. We're sure you could just as easily say, "Over 14 million Americans have smoked cigarettes!"-but is that really any reason for you to try it? Of course not, because you've seen the scientific evidence of the harm it can do. The exact same principle applies here. In Conclusion The major oil companies are some of the richest, most powerful and aggressive corporations in world. They own multi- million dollar research facilities manned by some of the best chemical engineers money can hire. It is probably safe to say that any one of them has the capabilities and resources at hand in marketing, distribution, advertising, research and product development equal to 20 times that of any of the independent additive companies. It therefore stands to reason that if any of these additive products were actu ally capable of improving the capabilities of engine lubricants, the major oil companies would have been able to determine that and to find some way to cash in on it. Yet of all the oil additives we found, none carried the name or endorsement of any of the major oil producers. In addition, all of the major vehicle and engine manufacturers spend millions of dollars each year trying to increase the longevity of their products, and millions more paying off warranty claims when their products fail. Again, it only stands to reason that if they thought any of these additives would increase the life or improve the performance of their engines, they would be actively using and selling them - or at least endorsing their use. Instead, many of them advise against the use of these additives and, in some cases, threaten to void their warranty coverage if such things are found to be used in their products. In any story of this nature, absolute "facts" are virtually impossible to come by. Opinions abound. Evidence that points one direction or the other is avail able, but has to be carefully ferreted out, and is not always totally reliable or completely verifiable. In this environment, conclusions reached by known, knowledgeable experts in the field must be given a certain amount of weight. Conclusions reached by unknown, unidentifiable sources must be discounted almost totally. That which is left must be weighed, one side against the other, in an attempt to reach a "reasonable" conclusion. In the case of oil additives, there is a considerable volume of evidence against their effectiveness. This evidence comes from well-known and identifiable expert sources, including independent research laboratories, state universities, major engine manufacturers, and even NASA. Against this rather formidable barrage of scientific research, additive makers offer not much more than their own claims of effectiveness, plus questionable and totally unscientific personal testimonials. Though the purveyors of these products state they have studies from other independent laboratories supporting their claims, they refuse to identify the labs or provide copies of the research. The only test results they will share are those from their own testing departments, which must, by their very nature, be taken with a rather large grain of salt. [End of original article] ************************************************** ********** As if we needed any more evidence about the bogus claims of the "Snake Oil" merchants, there's an interesting article in the October 1998 issue of Consumer Report magazine about an oil additive called "Prolong". Their nationwide television ads claim that this oil treatment bonds a 1-molecule-thick low-friction coating to metal surfaces in the engine resulting in longer life, better mileage, more savings. It supposedly protects the engine even when the oil is drained. The ads show Al Unser driving a Dodge Viper on a racetrack in the Mojave Desert without oil or drain plug, and a testimonial from a woman who supposedly drove from Santa Barbara to L.A., almost 5 hours, with no engine oil. Consumer Report took two factory rebuilt GM 4.3 litre V6 motors, had them installed into Chevy Caprices, broke them in with regular oil, changed the oil and filter, added Prolong to one engine, drove another hundred miles or so to let the stuff take effect, then drained the oil out. Both engines failed simultaneously after 5 miles and about 13 minutes. The Federal Trade Commission has been notified. ************************************************** ********** And in the January 1999 issue of Cycle Canada magazine, we read "The manufacturers of Slick 50 oil additive and Splitfire spark plugs have been forced to deal with class-action lawsuits launched in the US regarding false television and print advertising claims. Settlements are likely to take the form of discounts and rebates to consumers who purchased the products." Now that additives have been explained lets go back to discussing oil filters, LOL. Just trying to help educate the masses. Eric |
I own <several ties>
I haven't read a single word in that essay you just copied / pasted above me but i'm guessing it's about zinc in oil? lol
Try reading........you might like it! LOL! It touches on zinc; but I can assure you.......it's NOT what you probably think it's about. If you don't want to be scammed and dumbed down the rest of your life (at least concerning oil additives) I'd suggest you take the time and read it.......same line of thinking should be applied to many other areas of our lives.
More power to you! At least you'll get the info. absorbed somehow.
goin broke but n style
i didn't read it either, but i think all those additives inlcuding fuel additives are a joke.
I do use BG products at work, but i use them cause i get paid too. IMO your eng is gonna produce carbon, and it will eventuatly fail. some oil/treatment in a can wil not stop this from happening. |
y'all suck dicks
cliffs?
READ!!!!! Are you guys only on here to look at pretty pictures?! LOL! Like I mentioned earlier......this shit applies to many other things we are duped into buying.....but of course you need to make those connections yourself. The article itself pertains to oil additives.
y'all suck dicks
Thought so! LOL!
Still gonna run my Lucas synthetic oil stabilizer every oil change...
Jus cause..... |
Professional Insultant
OK I read every word of it- we can make some conversation.
I should post another article I found, it was testing oil from the 1940-1970 vs oil made today with virtually no change in the ingredients. (some of the old oil just had some weird things added, such as high amounts of Graphite, which they advertised working like PTFE) I want to know more about Stop-leak additive, I wonder if it's the same formula as PTFE lubricant additive, except instead of claiming the particles stick to the moving parts- those particles settle all over the place and hopefully block up a leaky seal. Like this article mentioned, a lot of company names are under one big company and they sell the same formula under different names and prices- they just do it to net all kinds of buyers. Some people buy the cheapest, they make a few bucks off them, some want that 'peace of mind' and buy the more expensive one and they make a few more bucks off the same product. |
Federated Auto Parts Parts Plus Auto Parts Value Tech Xcel Wolf's Head Rallye Gulf Mann Filter STP Prestone Amalie Greased Lightning STP We were producing 1/3 of the oils and ATF's for Advance Auto Parts until we were underbid by a competing oil company late last year and lost the contract packaging agreement with them. For special stuff like ATF+4, which requires Chryslers approval before we can market an ATF as such, we will normally piggy back a major blenders approval. In the case of the ATF+4 (for instance) we would buy that product already blended in bulk from Ashland (Valvoline) and have it shipped via rail to our plant in Tampa. We would then package it accordingly to whichever brand we are running that day. O'reilly Auto Parts executives took a plant tour of our facility early last month and we are supposed to be doing a test run of product for them as soon as the boxes and labels arrive at our plant. |
^ that's cool! Thanks for the information
so it really isn't about what brand you buy, or where it came from, but what certifications or specifications it meets it's always hard to determine which oils are actually 'high quality,' or maybe there really isn't any?? Is it really just checking to see if the oil meets the OEM engine specifications and viscosity and no oil has anything added to improve beyond that? I guess there is a few different 'kinds' such as some being marked as "Energy Conserving" which is not recommended for motorcycles because most use a wet clutch. I think it's a thinner film strength and is less restrictive on the moving parts in the engine, but gives less protection. In auto-tech my professor always swore to using motor oil intended for diesel engines because of the higher film strength they require to meet spec. |
Z-MAX ring a bell. how in the hell does 1 chemical work in every fluid in the car?
Z-Max is owned by Bruton Smith, also owns Sonic automotive group and about 5 nascar tracs throught out the USA. When my BMW dealer got sold out by a local owner to sonic automotive, they wanted us to use this product. they sold it for like 30.00 a bottle. every bottle that was given to me was either poured in the oil drain bucket or was run in a techs old military blazer that would run on anything that would burn. I now work for MB and we have customers all the time bring in their own perferred oil and oil additives as well as fuel additives. I am like what the hell are they wasting all their money for. If they want to give it away, they could donate it to me. lol. another thing is whether you run oil from 1950 or 2012 the car now a days burn so much cleaner. I would doubt that running 62 yr old oil in a new car would have any ill effect on how the eng wears. I hate when i see all the adds for 3k miles or 3mth oil changes. It just makes me think how gullible people in the US are. most can go 5k b4 needing serviced. |
resident crybaby
^Well, I guess you can continue on in willful ignorance then! LOL!
I break stuff.
Interesting to see that the Restore stuff (that comes in a silver can, 4-6-8cyl 'formulas') isn't on that list. That's all I've ever used... Most recent oil change I put it in my '02 and picked up 2mpg on an oil change rather than my usual 2mpg down on the first tank after a change. No other changes either.
Not claiming it to be a snake oil, I just use it every few oil changes on both of my trucks because it's cheap and *seems* to do at least some good. Also doesn't include any chemicals in any of the reviews I've seen, although they won't say what their "CSL" is. Would love to see some concrete tests though or hear if anyone else has had luck with this one. http://www.restoreusa.com/Engine_FAQs.html |
^My guess is that it's similar to Marvel Mystery Oil in that it has strong detergents in it that clean/lubricate the upper cylinders. That being said, it also more then likely thins the oil down.......both of these factors alone would constitute a slight increase in your mpg's. But, like the 'article' above shows, the modern conventional motor oils of today already have a high percentage of additives and detergents in them to keep the engine clean all the while not thinning down the oil itself. This is why the voice in the back of my head always kept me from pouring that Sea Foam into the crank case! LOL! I've only bought it twice and put it in the gas tank both times.
Btw, my mpg always seems to drop off a hair towards the time the oil needs to be changed.......around 3,500 miles.....when it's no longer looking clean. As soon as I change the oil the engine idles smoother and my mpg goes back up a hair. I only run 2 quarts of 20/50 Valvoline Racing oil along with 1 1/2 quarts of conventional 10/30 Valvoline.........2.5 takes 3 1/2 quarts of oil. The conventional 10/30 has the detergents in it.....don't recall of the VR1 Racing oil does or not; but it looks like a much better quality oil; and clings to the internals much better then any other oil I've seen.
VR1 does have detergents in it, Ashland makes another "not street legal" oil that has less detergents though. But, why run the VR1 in the first place? I could see doing so if you needed the ZDDP, and it's a 20W50 VI oil, of course it's gonna film internals better than the 10W30.
#24 |
Smellfungus T. Woodcock
Zddp
#25 |
I went with the Valvoline Racing oil based on a recommendation by a friend that builds 8 second blown Chryler Hemi engines. I think he was under the impression that my Duke had a flat tappet setup in it instead of rollers. At the time I wasn't sure; but I did find that the VR1 Racing oil was still clung to parts he pulled out of an engine and had set in a bag (actually, it was a crank); that had been sitting for quite some time. The conventional 10/30 won't do that.......and almost all of it runs off of the internals when the engine sits for a while.
#26 |
It's a trap!
The domestic house cat is a small carnivorous mammal. Its most immediate ancestor is believed to be the African wild cat. The cat has been living in close association with humans for somewhere between 3,500 and 8,000 years.
#27 |
^So in otherwords, your post count means more to you then actually contributing to the forum and/or this topic........gotcha!
#28 |
I did some research on stop-leak additive. Looks like it's just the opposite of Energy Conserving oil, it thickens the oil, it's not PTFE. A lot of them try to swell the seals with ester.
There was a debate whether it was better to use a heavy weight oil only, because the stop-leak additive with ester will weaken the seals by swelling them. On this forum members say stop-leak 'clogs' the engine, but from what I read there is nothing in stop-leak that would block up oil passages. It thickens the oil, and some have ester to cause seal swelling (it's a chemical reaction with the seal, it doesn't clot up the oil itself), Also on bobistheoilguy.com someone made the point that seals will shrink and harden with age, so the ester more 'restores' the seals and doesn't make them swell beyond factory specs. the thicker oil might have a harder time reaching the smaller places that need oil, but nothing about it should cause any kind of blockage. Of course oil-starvation is oil-starvation no matter if it's blockage or 'slow-oil.' My ZR2 has a minor main seal leak. (I loose about half a quart in a years time, never seen it drip, but I get a light oil coating down there) I think I'll try conventional 5w-40 and make sure it is NOT an EC type. ------------------------------------------------------------- I use 1 can of seafoam a year for fuel stabiliser (when I store my motorcycle over winter) and I pour the rest of that into my truck's fuel tank. I've used it on a buick that was diesieling through the brake booster line and it cleared up the problems, but I've seen zero benefits from adding seafoam to oil. |
#29 |
Thanks for contributing something of value! I thought about using the seafoam through the vacuum line to the intake before; but haven't done anything but run it through a tank of gas so far. I can't help but wonder if you pour it into the intake (through the brake booster vac line) and let it sit for a while like everyone does; if some of it will get past the rings when you run the engine and thin the oil down.
#30 |
If you are worried about it seeping past the rings, you can just do right before you change the oil. When you pour it through the crankcase it tells you to change the oil within 300 miles. (but then it tell you to add 2oz of seafoam to the new oil- I never did that)
If your truck runs great now, you wont see any benefit from seafoam, if your truck has some gunk build up issues/bad MPG, this MIGHT fix it if you cross your fingers, but it does keep fuel 'fresh' my bike runs much better when I pull it out after 4 months of sitting when it had seafoam in the fuel. The 73 buick 350 was a lucky case, it had enough carbon build up in the cylinders it'd run for almost a full minute after you shut it off. Most would have suggested an actuall tear-down and cleaning/rebuild, we were cheap highschool kids. It said 8oz, we sucked 8oz through the brake booster then poured the other 8oz straight down the carb and let it sit for a day. The next day the car wouldn't start. We tried everyday for a week before it finally fired up- what a smoke show it made! and it ran good after that- it's still running strong today. -- I wouldn't be surprised if me using the seafoam in the crankcase of my ZR2 and switching to synthetic oil is what caused the main seal to start leaking in the first place. Gunk was probably keeping it snugged up down there. |
#31 |
Yeah, the truck runs pretty good right now; so it probably would not benefit it to put the Seafoam in the crank case or vac lines. It smells exactly like rubbing alcohol to me though. I've used Stabil to keep gas that was stored from going south. I had it in a generator that sat for just over a year.........needed gas for my truck one day and siphoned (spelling?) it out. The truck ran just fine. And, my riding mower would start right up after it sits all winter if I have Stabil in the gas as well. It's marketed for marine use; but really helps with moisture issue from this damn ethanol they're cutting the gas with.
#32 |
#33 |
During the height of the $4+ fuel prices I found a quarter of a can of acetone, didn't see any MPG gain, but I was more surprised I didn't see any ill effects, it was with my old 2.2L reg cab.
I was using it to clean my paint gun and it made my rubber gloves fall apart- then burned my skin! I hope my fuel lines weren't disentgrating from the inside. lol I've used stabil too- works just as good for cheaper. I just pick seafoam because the carburator jets clogging up is really common on these bikes. I went down to pick up oil for my truck- I was going to go with Rotella, but I plan to run it year round and the Rotella was 15w-40. So instead I got some 10w-40 Valvoline maxlife highmileage. It didn't list ingredients but it says it 'treats seals' so I'm guessing it has ester in it. I still always use the 15w-40 rotella T for the bike |
#34 |
I think this article might explain why you did not notice any effects using the acetone...or at least, any mpg gains.....but you need to read all the way through. Some sites I had been to prior to this one made claims of improvement in mpg/performance (mostly across the board) when 1-2 oz. were added per 10 gallons of gas. In light of this article these claims now leave me uncertain.
http://peswiki.com/index.php/Article...ne_and_Ethanol |
#35 |
I'd have to see it...
There was a guy in my auto-tech class that did a lot of work to his 68 mustang. the engine was swapped to probably the same as the 85 t-bird in that article. He added a 2 gallon tank to the trunk, that had lines running to the battery and to the air intake. He filled it with water and said the battery separated hydrogen and it was sucked into the intake and improved his MPG. He said it worked, and I watched the car run and the water level in the tank drop. The scariest part was he was suppose to be a genius, I highly doubt he did anything more than added a water-injection system. |
#36 |
^I think you are correct sir! LOL! Non the less, this is all very entertaining at the very least! LOL!
#37 |
The only way I would ever believe tests that disprove Prolong were if they were performed in my presecence, on an automobile motor, not a small engine designed for abuse. After all, you cant run most car engines on air cooling alone, and the fuel the small engines burn contain oil, (2 cycle!) which lubricates the upper engine during operation. You cant really compare something like a lawnmower engine to an automobile engine and come out with accurate results - which is why I laughed when I saw that thread. Its a completely different design and operation. Prolong was investiaged by the FTC for supposedly making claims it couldnt back up - but was cleared of any wrongdoing, and their products were proven to do what they claimed in advertising and on the bottle. Here is an excerpt: Did Prolong get sued or fined by the FTC?No, the facts are that the FTC thoroughly investigated all of the tests and evidence that supported Prolong’s product claims in much the same manner as going through a very detailed IRS audit.
Prolong Super Lubricants distinguished its conduct and had a much different experience than many of our competitors. The following products had claims that the FTC complained were false or unsubstantiated. The product owners were sued by the FTC and eventually entered into settlement agreements with the FTC and agreed to pay the following fines: 1978 STP Oil TreatmentSued by FTC, Settled, Fined $500,000 1995 STP Engine TreatmentSued by FTC, Settled, Fined $888,000 1997 Slick 50 Engine TreatmentSued by FTC, Settled, Fined $10,000,000 1999 Motor Up Engine TreatmentSued by FTC, Settled, Fined $100,000 2000 DuraLubeSued by FTC, Settled, Fined $2,000,000 2003 zMax Power SystemSued by FTC, Settled, Fined $1,000,000 Now, that excerpt was taken from prolong's own website. So if you dont believe that, here is a link to the FTC's own website and details the investigation and its results. http://www.ftc.gov/os/1999/11/prolong.do.htm Prolong was basically ordered to do what it was already doing. Thats because the FTC cannot simply walk away, even when they find no wrongdoing. And now another link, where Prolong held up their claims under extensive testing by the FTC itself. (18 months of testing in Prolong's case) http://www.carbibles.com/additives.html The problem here is that people take the word of another forum member (not just here, in most forums) without trying things for themselves, or doing follow up research. They see a big lengthy post full of information and think the author must be credible. When I myself want to make claims or debate anything, I provide links and information as well as testing done by a thrid party when possible. I could honestly care less if anyone else uses the stuff; not my engine to maintain. It may or may not even do anything for the engine when maintained properly - theres the 1,000,000 mile S10 2.5L and I dont think Willie used prolong in it at all. The real problem I have with this stuff is people telling me to stop doing something I am doing because its wrong/wasteful, when they themselves have not tried it or done any testing at all. No one that claims it is snake oil ever links to the FTC investigation or 3rd parties who tested it - we are just supposed to take them at their word for it. The only link they provide (when any is provided) is the Consumer Reports test that prompted the FTC Investigation - and was proven to be faulty by the FTC itself. Both of those, the quote and the reply, have already been discussed by Ed and I in the iron Duke forum. I just copy pasted my reply about the Prolong, including all of those links, for informative purposes. |
#38 |
That is an HHO Generator. It seperates the hydrogen molecules from the oxygen molecules in the water via electrolysis. The system requires distilled water and baking soda along with the battery charge to function. (there are also solid state HHO generators, but those are complicated and more expensive to make) Much debate still goes on about hydrogen enriching your engine, but in my experience, it works. Naysayers are usually people who have never tried it and purport to be chemical engineers by the seat of their pants. Mythbusters proved on video that a car can run 100% on Hydrogen. They usaed an older Cutlass and disconnected the fuel line, then injected Hydrogen straight from a tank into the carb - and the car ran on it. Besides, your car is already running on Hydrogen. Crude Oil is composed of a variety of compounds, mainly Carbon, Hydrogen, Oxygen and Sulphur. Hydrogen is where the combustion comes from. Its just dirty hydrogen that your vehicle is burning. If you dont believe it, look up the structure of gasoline. (also, oil is a hydrocarbon - hydrogen and carbon) A simple test can show any naysayer that it actually does work - just add a valve to the system to allow the hydrogen flow to enter the air intake, and close it off when you want. Start the vehicle with the valve shut, then open it - the engine will idle up until the PCM or ECM compensates for the added combustible. Just how effective this system is depends on what vehicle you have. Small carburated engine benefit the most, as they do not require much Hydrogen to work and the carburator can easily be adjusted to lean out the gasoline. Carbuerated V8s benefit the same, you just have to have a larger HHO generator. Computer controlled engines see less of a benefit than older engines. The PCM/ECM can only adjust so much, so it will only lean out the fuel supply to a certain point. However, the extra Hydrogen wont make it run rich because its a gas, not a vapor. I did see a computer controlled 3.3L Dodge Caravan see a 3-4mpg improvement with HHO on it. I drove the vehicle for a couple years until i discovered HHO, then installed a home made HHO generator. The MPG gain was immediate. I drove it for 7 months and then disconnected the device - and my MPG dropped back to 19-21mpg. It was getting 22-24 with the HHO. These are averages too, not just highway economy. It does work, though the internet is full of naysayers - but these guys never have video to back up their side, whereas many, many people have made these devices themselves and documented the results. (Youtube is a great place to see these vids) The Mythbusters video is there as well. |
#39 |
It's "Neanderthal"
Why would you disconnect this device if there was such a mileage improvement?
#40 |
Because he's an idiot.
#41 |
It's "Neanderthal"
Agreed.
#42 |
Justice Brothers has some good stuff... privately manufactured and scientifically proven to make your bearing so slick that your engine could run for for a while with no oil at all (like say a rock hit yo oil filter, you didn't know it, and all yer oil drained out... which they have documentation of a customer that this happened to)
#43 |
I love these snake oil threads.........
#44 |
I break stuff.
I work at Lowe's in Plumbing and I get guys coming in all the time to build the HHO generators, asking me how well they work. I'm an engineering student (Electrical) and just sort of laugh and ask them how much they expect it to put out with the way they're building them. Sure, one would work if built with catalysts, but separating the hydrogen from the oxygen takes a fair amount of energy...and where's it coming from? How much are you spending on filtration or distillation to get water free from impurities, and how much electrical power are you feeding it?
Just not worth it with current technologies that I've seen yet... I'd believe the oil thinning in my case, but if that were the whole cause, I'd be able to switch to a thinner grade of oil and get the same results. I don't
#45 |
agent00kevin, but did you try running an engine to 200k without the Prolong oil additive? What if you came up with the same results as buying all that additive?
-------------------------------------------------- So the new oil I bought worked better than expected. I was getting a good coat of oil across my oil pan where the engine/trans meet and 2 weeks ago I tried the high mileage oil. It's basically what you'd find in a bottle of "stop-leak" heavier weight oil with ester. After I changed the oil I sprayed the bottom side down. I crawled under there today and not a bit of oil is down there. I didn't actually use any oil additives. I think my problem was switching to synthetic. probably energy conserving oils when I bought the truck. It doesn't matter what brand I bought, it just needed a thicker oil. I guess I'll save my transmission jack for later, I was ready to drop the trans and change the main seal. |
#46 |
^Yup! I think I've come to the point where I'll just keep using good quality oil with out adding any additives (haven't done so with this truck since I've owned it in fact); and will just change it at 3,000 miles instead of the 3,500-3,800 that it's been getting. Seems that it doesn't start to get real dirty or darker colored until after the 3,000 mile mark.
| Sponsored Links | |
Advertisement | |
