#1701 |
BOUGHT NOT BUILT
Location: Mt. Washington, KY User is: OffLine ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Re: [Project] UP? or downż
what ever happened to putting a roof rack back on it?
#1702 |
i wouldnt undertsand
and as for the temp, I'm happy with where its at. i did a search and mine is where most peoples is, along with my dad saying the temp is fine, and with what Cory has said. and you all have some weird ass theory's on the damn speeding bird! |
#1703 |
The Werk Truck
Location: Huntington Beach, Ca. User is: OffLine ![]() ![]() |
How difficult was it to get the old mechanical fan off? What'd You use?
#1704 |
weeeeeee(let it pass by once then it will play normal speed) ![]() |
#1705 |
Wanna see some magic?
My dad has a kick ass wrench to take off the pulley fans, if I knew what it was called I'd tell you. I'll look at it tomorrow. How hard was it to install the new fan?
#1706 |
and the fan was easy as hell to install. got my main power from the b+ wire off the fuse box to relay(fused), switched 12v source, ground(relay and fan) then wire from fan to relay. and ta da. factory shroud works and everything. |
#1707 |
Awesome. I have to replace my heater core and intake gaskets, so might as well try an e-fan out and see how it is.
I'm getting one of those mirrors w/ auto dim, compass and temp readings from me to me for my 18th birthday ![]() |
#1708 |
Molon Labe
Do you have a thermostatic controller? I think I read you got one but it might have just said relay.
#1709 |
no, just a relay. ive tried the controllers on my old luv truck, and the 2 i tried sucked. i dont drive the truck a ton so i dont care about running all the time.
and i got some goodies in today! my braided lines for the front brakes finally! ![]() and my delphi pump! ![]() |
#1710 |
Molon Labe
Original equipment fuel pump, ftw. I've heard too many cases of cheap pumps lasting a month or less. Yours wasn't the first.
How much did those SS lines run you? |
#1711 |
#1712 |
cleaned up the wiring for my efan...
heres how i did it.. tied in with the oxygen sensor. ![]() cut the box some to let the wire go in without being pinched ![]() all covered up ![]() relay mounted ![]() overviews, looks clean for me! ![]() and you can see the fuse for the power wire in this pic right when it comes out the the fuse box. hard to see, but its there. ![]() ![]() ![]() ![]() |
#1713 |
I.G.'s FTW!
How much power gain did you notice? So the fans are on all the time when it's running? What's the temp it's usually at going down the road? What about sitting still idling for a while in hot weather?
#1714 |
yesterday it only got up to 90 degrees.. today was a little cooler. idling it sits infront of 210. you can see the whole white line for 210 and a little black infront of that.
i do stop n go traffic. i drive about a block or so and im stopped again so it always stays there. |
#1715 |
bellcranks no more
no shroud? it wouldhelp a lot i think...
#1716 |
I.G.'s FTW!
#1717 |
Have a nice day!
that's exactly how I wired mine
#1718 |
ados egnaro
Location: Floyds Knobs/Clarksville, IN User is: OffLine ![]() |
you dont need a shroud, the one that came on the fan is just fine as long as it sits flush with the radiator.
#1719 |
and it got above 210.. while driving, wtf? i was sitting in burger king parking lot and the temp got up to 210, then i drove off, it dropped back down to where it normally is, then jumped up past 210 and sat there for about a minute then went to 210. and my voltage with the efan and headlights SUCKS. it drops down 2 notches below 14 when completely stopped at a light. then as soon as i get off the brake and it starts rolling it goes right back up to 14.. is that bad? i might do some searching around n see what the best factory fan is to run.. i know its been posted here many times, im just gonna do some research. the thing that makes me kinda nervous is that its been fairly cool here this past week, so when it get hot as hell again im sure the temp will get up there. |
#1720 |
Molon Labe
Yeah, that's what I was tryin to tell you about. And since I know you're in Texas, you're in the same heat boat that I'm in.
If you get a thermostatic controller it'll help out your voltage problems because the fan won't always need to be on, especially at night. Secondly, a shroud (as Ryo suggested) would also be a good idea. Some sheet aluminum, a bender, and some self tapping screws should do the trick. |
#1721 |
I wonder how it tastes?
Location: Rogers, MN User is: OffLine ![]() ![]() ![]() ![]() |
I just went through your brake install and it sounds like you had to do the exact same things that i did. Grinding on the spindles and shimming the abutment brackets.
and whats the status on the cowl? |
#1722 |
and the cowl is sitting in the garage on my dads anglia. i was going to try n drop it off the day i got it from ya and i called my buddy about doing so, and he said he would give me a call. he never called. he said its gonna kinda be hard gettin it in cause its kind of big. i will try calling next week, depending on what ike does here.. but i got my wipers painted, and went ahead and put then back on yesterday. |
#1723 |
Trucks lookin amazing man, hope the hurricane didnt sweep you or the blazer way
#1724 |
and i finally am getting around to making my hole in my floor less ghetto. at first i just cut out 3 sides and bent it back cause i was in a hurry. now im making it look better... the temp seal up job... ![]() opened.. yes i know the hole is way bigger than it needed to be but i didnt have much of an idea where the hole was.. but this way its super easy to work on lol. ![]() new one taped off ![]() cut ![]() where im at now.. closed ![]() opened ![]() i need to go buy some kinda of weather stripping for it now.. and it wouldn't hurt to weld in a little brace or something along the back side of the cut out(side with dzus fasteners.) its a little flimsy |
#1725 |
This is doo doo baby!
Location: Marrietta/Lawrenceville, GA User is: OffLine ![]() |
I need to cut a hole in my floor except for the pumpkin not the gas tank
#1726 |
Molon Labe
That's a pretty good idea if you expect to be needing to access the fuel pump more than once. I'll have to keep that in mind when mine finally goes. I'm at 150k and I don't think it's ever been replaced.
#1727 |
The Werk Truck
HEY YOU"RE ALIVE!
Glad to hear that You made it through okay. On a completly unrelated note, I have the same phone. So far, so good. Doesn't sound near as good as my pebble did, but it's alot heavier duty and stands up to the shit I put it through. |
#1728 |
the only reason i decided to cut a hole was i dropped the tank the 1st time to put in a cheapo one, and it was a pita. so i decided to cut a hole to put the delphi in it. plus with my luck with fuel pumps, i think the hole is good. plus with the hole there, i can change the fuel pump start to finish in about 15 minutes. just pull my spare tire out, unclip the rear part of the side panels, remove top and bottom plastics, pull carpet back, undo dzus fasteners, change pump, and reassemble. |
#1729 |
and yeah the phone is ok. i took the *shock and water resistant* a little to far i think. i always talked on it in water, would drop it in my drinks to mess with people, throw it wayyy in the air and not catch it.. after about 6 months of that it would start shutting it self off if i closed it. |
#1730 |
