Project SINOMA - Page 12 - S-10 Forum
Project SINOMA
Old 02-19-2012, 07:45 PM   #551
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
Quote: Originally Posted by StirFrey
first one, will i need different metal rods for my power lock modules?
third, i read somewhere in one of phil's posts that i could wire one of these modules after the pass window switch so that both the driver and passenger switches make the passenger window go automatically right?
im still wondering about these two things, and thanks for the links phil, and yes about the speaker, im so relieved lol
Old 02-20-2012, 10:07 PM   #552
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
still hoping someone can help me with those ^ im gonna do all this, this weekend and kinda need to know before then so if anyone has any thing for me.
i was also wondering if i could use the heater controls from a 98+ instead of my original ones? i dont see why i couldnt unless the fan speed control was mechanical or electronic instead of vacuum controlled... the 98+ is all vacuum right?
Old 02-22-2012, 03:13 AM   #553
Lifted Moderator
Sonomanclature's Avatar
Re: Project SINOMA
Hey can you do me favor and measure from the ground to your wheel well front and rear.
Old 02-22-2012, 02:18 PM   #554
Electrical Mod
deathphoenix99's Avatar
Re: Project SINOMA
The lock rods are the same, so no need to change them out. And yes, check the threads I linked, they answer how to wire up the modules.
Old 02-22-2012, 07:21 PM   #555
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
awesome thanks!!
Old 02-22-2012, 07:25 PM   #556
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
rf = 35"
lf = 34.5"
rr = 36.5
lr = 36.5
but i also have 4 70lb sand bags in the bed
Old 02-22-2012, 10:20 PM   #557
Lifted Moderator
Re: Project SINOMA
you were rite Jerry, but it is close
mine is in at
lf37.5
lr36.5
rr36.5
rf37
Old 02-22-2012, 10:50 PM   #558
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
i also have really small tires on the front for the winter
Old 02-22-2012, 10:59 PM   #559
Lifted Moderator
Re: Project SINOMA
yea I was thinking yours was higher though, but i have 31's all the way round.
Old 02-22-2012, 11:00 PM   #560
Brought to u by Carls Jr.
mostizzle's Avatar
Re: Project SINOMA
ItoleU
Old 02-22-2012, 11:08 PM   #561
Electrical Mod
Re: Project SINOMA
My s10 sat at 35" up front I believe and about 36" in the rear. But I was on 29" tires basically.
Old 02-25-2012, 02:46 PM   #562
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
working on the power windows and locks, as well as the new dash today, im still not 100% on these EZ up things... it looks like wire A is just for power, b goes to up or down (which ever i want to do automaticly), C is for up or down (the other one, obviously) and D goes to the motor, and the motor goes back to the swith for whatever C is connected to? this is what i am going with unless i hear from someone that this is a bad idea.
i also had a question about powering everything, the harness can just be pluged in like i was originaly hoping. i should just be able to run a power wire to the windows and power to the locks and then grounds... right?
Old 02-25-2012, 03:07 PM   #563
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
here is what im going with
Old 02-25-2012, 10:26 PM   #564
Electrical Mod
Re: Project SINOMA
No man, you only wire one wire up to the switch. So cut the line going to up or down and splice the now "two" wires to the module and then the module needs a ground a power wire. I forget off hand which wire goes where. Did you read the thread about it?
Look at this stock diagram of the module, and read my post below it.
http://www.s10forum.com/forum/f62/in...2/#post6587454
Apparently one of the links I gave you was bad....but I forget where I was trying to link. It's probably something out of the electrical sticky.
Old 02-26-2012, 10:35 AM   #565
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
im lost dood, from the link you gave me compared to my ez up drawing, i see nothing wrong?
Old 02-26-2012, 11:11 AM   #566
Electrical Mod
Re: Project SINOMA
You have B and C going to the switch, only one wire from the switch goes to the module. The other wire goes to the motor as normal withough changing anything. The switches are setup to be a ground always when the switch isn't pressed. I'll see what I can do later, I'm still not awake right now.
Old 02-26-2012, 12:37 PM   #567
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
Old 02-26-2012, 02:08 PM   #568
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
this is mackey, he is old, we have had him for a LONG time... poor guy has this weird ear bacteria that makes him walk in circles sometimes and he always holds his head at an angle
this is my dads barn/shop
when you walk in
his table lift
other corner of the shop
his awesome dyna low rider... i want it, its a rare color, dragonfly green
and my dash out
Old 02-26-2012, 07:07 PM   #569
Independent
sonomaguy's Avatar
Re: Project SINOMA
Nice Gargoyle in the second pic. Actually, you have a few cool things there down on the farm. Get much snow there or is that about it?
Old 02-26-2012, 07:30 PM   #570
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
yeah, not much snow at all in wisconsin, been kind of a weird winter, there are a couple other gargoyles around the property too
Old 02-27-2012, 11:48 PM   #571
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
my phone mount
Old 02-27-2012, 11:57 PM   #572
Electrical Mod
Re: Project SINOMA
So how does it all work/?
Old 02-28-2012, 12:58 AM   #573
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
windows are great, havnt put the ez downs/ups in yet, also havnt done the locks... not sure where to get/send power for them... and i gotta get behind my dash again.. sounds like i shorted/pinched a speaker wire, also my dash speakers are backwards... so thats a thing... oh, and my phone mount i really like, but i have an issue with the aux out, it doesn't always work and when it does i cant use the 5.1 surround sound boost feature or whatever my phone has
edit: one other thing im kinda iffy on is the drivers door lock... it seems kinda sloppy, can i put my stock lock unit on the power module?
Old 02-28-2012, 08:18 AM   #574
Electrical Mod
Re: Project SINOMA
I don't believe you can. What do you mean sloppy? It's been awhile since I've used them, but they used to work fine when I pulled them. For power for the locks, use the fuse block stock position.
Old 02-28-2012, 08:34 PM   #575
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
idk, seems like it doesnt latch as securely as my old ones, i might just be crazy though... the lock is harder to move though, that is kinda annoying.
i do know where to get power from, i just need to figure out where to send the power... like which wire on the blazer door harness to connect power to, and which is ground
Old 03-28-2012, 11:31 PM   #576
Diesel Tech
richarddhoward's Avatar
Re: Project SINOMA
love the truck bro, I didn't read all of it, what spindles did you get? And why did you have to lengthen the driveshaft? because of the spring over?
Old 03-29-2012, 01:49 AM   #577
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
thanks man!
i went with aim spindles, they were more my budget, but i wish i had spent the money on fabtechs right away...
and yeah the drive shaft needed to be longer because of the soa, if i had moved the axle forward a bit, and then shimmed it so the pinion was up more and the trans was pointing down more in back i could have used the stock one... but i didnt
Old 03-29-2012, 01:54 AM   #578
Diesel Tech
Re: Project SINOMA
thanks man!
And what size tire are you running? I like the height you are sitting at. I want to run 31's but I was just going to go with shackles and AAL, mostly because I do haul everyday in my truck.
What makes you want the fabtechs over the AIMs? I've been trying to decide on it, and right now I have no budget, so i can wait for awhile lol
Old 03-30-2012, 01:02 AM   #579
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
i have 31x10.50x15 in back and 265/75/15 in front, they come out to be the same size tho, i wish i had the fabtecs because it would probably fix the tire rub i have... so im gonna have to trim the bottoms of the fenders back and hammer out the inner fender some to fix the rubbing...
Old 03-30-2012, 10:27 AM   #580
Diesel Tech
Re: Project SINOMA
From what I am hearing, everyone experiences that, no matter the spindle.
Old 03-30-2012, 01:44 PM   #581
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
the fender but not the inner well and the upper control arm
Old 04-06-2012, 10:54 AM   #582
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
I'm back in the states, and on my way back to wisconsin tonight, in case anyone was worried
Old 04-20-2012, 02:10 PM   #583
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
Old 04-20-2012, 02:32 PM   #584
Diesel Tech
Re: Project SINOMA
How much did those run you? And after you install them, let me know how you like them, I was looking at those! Or these:
http://www.autozone.com/autozone/par...357426_0_7413_
Old 04-20-2012, 03:15 PM   #585
We Bend Stainless
JDrummond Service Inc.'s Avatar
Re: Project SINOMA
I ran those air shocks on my s10 and loved them!
Old 04-20-2012, 03:24 PM   #586
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
i was thinking coil overs, but i dont want a rough ride when im not hauling stuff, so i went with air, this is what i have
http://www.autozone.com/autozone/par...0_116379_6636_
and its about what i paid,
i didnt get them from auto zone tho lol
oh and mine are for c1500 cuz im soa
Old 04-20-2012, 03:31 PM   #587
Diesel Tech
Re: Project SINOMA
That's sweet, what'd you run for pressure empty and loaded?
Old 04-20-2012, 07:09 PM   #588
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
i know the lowest pressure you are supposed to run is 20psi
Old 04-22-2012, 11:06 AM   #589
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
i was wrong, lowest pressure is 25psi
they ride a little rough, but i knew that was going to happen, i guess im a little surprised how much of a difference it made, im thinking it will get better after i break them in.. at least i hope haha.
i have been meaning to make shock mounts that come off the axle tube for a while now, i had been using the stock mounting location after flipping the mounts over when i did the soa, so basically the shocks weren't doing anything
my dad has access to a machine shop at work, so we went there to make a set
and here they are cut out
and all done, i can get more pics if anyone wants, i sprayed some rubberized undercoat on them to hopefully prevent rust
Old 04-22-2012, 11:08 AM   #590
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
going to be working on my other green machine today probably
my dad's collection right now, im jelly
\/ of this one especially
oh and i went to visit my mom last night, she bought me an 8 pack of beer... i laughed when she sent me the pic but apparently these are real lol
Old 04-24-2012, 09:08 PM   #591
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
i hate them.
Old 04-24-2012, 10:48 PM   #592
mostizzle's Avatar
Re: Project SINOMA
Ryan, are you still having the problem with the trans falling out of 5th? Mine did it from time to time too but when I took the super boot off it stopped doing it. I just switched to a soft boot and so far so good. I think maybe because of the way the super boot had to be situated to cover the hole in the floor the resistance pulled the trans out of gear sometimes.
Old 04-25-2012, 04:55 PM   #593
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
hasnt happend since it started getting warmer out, it would always do it in the morning when the boot was very stiff and cold so its probable that that is my issue, i want to get a boot like yours, would be cool if i could find one thats green tho
Old 04-25-2012, 05:52 PM   #594
mostizzle's Avatar
Re: Project SINOMA
You know anyone that's handy with a sewing machine?
Old 04-25-2012, 06:07 PM   #595
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
mmm... yes
Old 04-25-2012, 06:16 PM   #596
mostizzle's Avatar
Re: Project SINOMA
Buy a bullshit cheapo soft boot, mock it up and make sure it works the way you want it to, remove all the stitches from the boot so whomever is wielding the sewing machine has a pattern, buy some fabric that you find to be of the groovy variety, make das boot, profit.
Old 04-25-2012, 06:52 PM   #597
Diesel Tech
Re: Project SINOMA
x2. I am handy with a sewing machine, but I don't own one. (thanks to a mother that was a home economics teacher) They aren't to bad to make though. Hell you could probably hand stich it, or take it to a local upholstery shop to have it done with the same idea.
Old 04-25-2012, 08:20 PM   #598
mostizzle's Avatar
Re: Project SINOMA
I'm just the opposite. I can hand sew shit but I have no idea how a sewing machine works. lol But yeah, technically all the stitching could be down on the inside so you could do a pretty janky ass job sewing it and still have it come out decent looking.
Old 04-25-2012, 09:16 PM   #599
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
haha true, but im decent with the stitchery and sewery, i would still rather have this person i know sew it up lol
Old 04-26-2012, 06:51 PM   #600
Wondersmith
StirFrey's Avatar
Re: Project SINOMA
le bike...
