#201 |
out draggin.. brb
re: Project: Please MTV... Gimp My Ride!
thanks guys.
#202 |
It puts the lotion on
Sexay!
#203 |
out draggin.. brb
Woke up this mornin and took a look outside. Rainin but with this in my driveway again all i see is sunshine.
And a pic of what My pressed and swiveled hydraulic fittings look like for ya guys ![]() ![]()
#204 |
Yep only way to run air line.I'm runnin 3/4" I.D. gates.It's O.D. is just about a 1".Pain in the ass.
Only thing i would suggest is running rubber grommets where it goes into the bed from tank.I bought a couple that were just a little bit bigger than my line.Cut it in 1/2 an worked it around the line.An trim off what ever excess you have left.I used a 90 degree pick an a small flat head screwdriver.It takes a bit,but its a piece of mind |
#205 |
are the lights oxidized or are they letting moisture in? They look a little cloudy in this pic.
#206 |
out draggin.. brb
And as far as the headlights go. Seems i got a little leak over the past yr of sitting. Theyre not oxidized. Raining today in CT and its the first day its been outside so just one thing Ill have to button up. No biggie its not going to be a rainy day driver but i will fix the issue |
#207 |
What did you use to make your rear plate mounted like that? |
#208 |
I know I said it before but I love this truck! Keep up the good work gimp!
#209 |
Sorry mang,them old days of installin car audio running power cables thru metal fire walls etc.I see it allot an one of my little ocd things lol
#210 |
out draggin.. brb
#211 |
out draggin.. brb
![]() i have 5/16" hollow spacers I just picked up this morning for Ace Hardware tho. Gonna slide two more screws right threw them to keep the plate angle the same and attach the damn plate light u see hangin in the pic ![]() |
#212 |
Location: In A Little Town Called "Rome" User is: OffLine |
#213 |
out draggin.. brb
12gal
#214 |
Ridin' on Twankies
Those hoses look good! and i know they are nearly bulletproof. We have a machine here at work to make those lines. Expensive but worth it.
Ever thought about putting some snap in bushings in the bed floor though? I know it would take a LOT of rubbing to make a hole in those hoses, but would overall look a little cleaner with them, and wouldn't cost but maybe 5 bucks. Not exactlly sure what size hole you got there, but this site sells them cheap. http://order.waytekwire.com/productd...20DIA%201-3/8/ Also, a lot of stereo shops have these on hand too. |
#215 |
out draggin.. brb
^^ ive got rubber gromets all ready for the 4 holes in the bed but ill tell you its a fight getting them over the pressed on fittings attached to the lines and keeping them straight. You may be on to something thanks for that!
#216 |
Ridin' on Twankies
I hate rubber grommets, but they do serve a purpose in some spots.
But the best bet for you would be those snap in gromets. I run them in the floor of my truck for the airlines, and 1/0 stereo wires. Work perfect, my local stereo shop just usually gives them to me, as they cost like 2 pennies each lol. |
#217 |
gettin layed
#218 |
thx bro. whats good with you and your truck?
I am good. I have the truck taken apart some what to clean and paint the frame and trying to figure out if I want to keep it static or bag it but gota get body work done two so idk lol! |
#219 |
Is it just me or is your bed sagging?
#220 |
I was wondering whats up with that too... Seems to happen quite a bit on bagged trucks
#221 |
out draggin.. brb
If thats what you're talkin bout Edit. I also only have 4 corner bed mounts so its a tad flimsy
#222 |
yeah thats what I was looking it..
My bed only has 4 mounts for it also .. but it also has the wheel well braces extended and welded to the frame may just be the angle of the picture |
#223 |
out draggin.. brb
Nah its not the angle bro it really is off like that when im parked right there in my driveway pisses me off. As soon as i air it up or if i back it in the bodyline between the cab and bed is absolutely fine
#224 |
Registered Asshole
mine does the same thing, but i think if my driveshaft pushing against my cab
#225 |
out draggin.. brb
#226 |
gettin layed
notching the cab is cake... the hardest part is pulling the interior....
#227 |
out draggin.. brb
#228 |
gettin layed
i feel ya man that's the life of a mini trucker... you ever feel like you start one project and when you get in the middle of it you have like 5 more projects start up... for me every time it never fails...
#229 |
out draggin.. brb
^^^ story of my life
#230 |
truck looks really good.
#231 |
#232 |
Registered Asshole
yeah i am eventually. my truck lays perfectly where i'd like it with the cab how it is now, but just the fact of it pushing against the driveshaft i don't like. |
#233 |
#234 |
out draggin.. brb
#235 |
out draggin.. brb
#236 |
out draggin.. brb
Damn i need to get to it and tub the front.. Now
#237 |
nah just get the bumper painted, then tub it lol
#238 |
out draggin.. brb
lol jk brah
#239 |
out draggin.. brb
#240 |
Lololololol I did, I did.
#241 |
i f'n love those wheels!!!
#242 |
Ridin' on Twankies
On that site, that was just a random site I found on those snap in grommets.
You can get them elsewhere, I'd try googling snap in grommet, or snap in bushings as some places call them. Maybe eBay, or partsexpress.com, or another audio related website. Lemme know if you have troubles ordering I can order them using my works tax id number |
#243 |
gettin layed
Gimp any parts store should have them maybe even a stereo shop for running large wire... I think I have seen them at lowes also... Good luck man truck looks sick... Also love the wheels...
#244 |
out draggin.. brb
Ya i checked with Waytek this morning and they are a wholesaler only so no go there. Ill find them no doubt. Looked on Egay and found perfect size but the seller had a lot sale of #100 or maybe ot was #300 going for $33 bucks. Dont really need that many but i guess i could always gauge my ears again and hold down a couple people people and do theirs too right
#245 |
Ridin' on Twankies
^^ this. lol
What size are you needing? This might sound stupid, but you can go to lowes, on the "hardware" isle, and they have those blue slide out drawers. They sell snap in desk grommets, which are pretty much the same, they just have a top part you can remove or install to hide/organize wires etc. You can just take the top part off, and use just the snap in part. And they are cheap, and sold individually. Id check that out if you have a Lowes store near you. |
#246 |
355 member
yeah those wheels are dope
#247 |
out draggin.. brb
#248 |
love me some uni-bits!!!!!
#249 |
out draggin.. brb
This is what happens when you go to a Memorial Day get together and a chic needs to move your truck so she can leave. Told her Id move it but "nah nah its ok just hang out and relax ill do it for it and bring your keys right back" atleast its just my beater
Id never let anyone touch the bagged truck ![]()
#250 |
y'all suck dicks
ghey
| Sponsored Links | |
Advertisement | |
