Project: Metal Head
Old 01-30-2009, 03:10 PM   #201
Vroom 2.2 Vroom
Oldskool94's Avatar
Re: Project: Metal Head
i really like the new wheels.looking good btw.
Old 01-31-2009, 01:33 AM   #202
Innis's Avatar
hey man, good thing to see some progress on this thing, cant wait to see it rollin soon, we will def have to cruise the beach when im home in the summer!!
Old 02-03-2009, 12:11 AM   #203
Interpretive Rides
curt_minke's Avatar
more progress.
cleaned the shop, and finished welding the one rear frame rail..
[/IMG]
My aRM muscle locked and looked f''ed up so i snapped a pic...
looks broken
Old 02-03-2009, 12:27 AM   #204
~Sunkin Sins~
Wybrow's Avatar
Damn man! Thats an ass load of welding...looks like your clearances are pretty well perfect though....job well done.
Old 02-03-2009, 12:50 AM   #205
Scoop
sonomaguy's Avatar
Some very nice welding there, now get a new clear shield for the front of the welding helmet so you can see better.
Old 02-03-2009, 12:53 AM   #206
Scoop
sonomaguy's Avatar
Quote: Originally Posted by curt_minke
more progress.
LOL, the fender looks kind of funny sitting out there with the wheel under it and no truck around.
Old 02-03-2009, 09:58 AM   #207
Interpretive Rides
curt_minke's Avatar
lol yeah, i thought it was staring at me while i was welding so i snapped a pic of it too haha
Yeah it took me about 2.5hrs to weld and grind that one frame rail. and i still have to finish the drag arms.
Old 02-03-2009, 05:06 PM   #208
firefighter260
rebels10's Avatar
i love the new wheels. and the work looks amazing.
Old 02-03-2009, 05:17 PM   #209
reaper13's Avatar
looks real good man, real good
Old 02-04-2009, 09:19 AM   #210
Interpretive Rides
curt_minke's Avatar
more progress.
I finished grinding the first frame rail and tacked the other one together.
And a couple drawings when i got bored.
Old 02-05-2009, 11:55 AM   #211
Vroom 2.2 Vroom
Oldskool94's Avatar
i really like your truck it reminds me alot of mine. and sweet drawing i wish i could draw that good.
Old 02-05-2009, 08:50 PM   #212
lame-o
dragginbalz's Avatar
I hope you don't take this the wrong way and I know it is a little late now, but next time you do these, you should fit the top and bottom caps so that they sit right inside the two side plates like this
(full or half open corner)
It will be a ton less grinding than welding it the way you did.
You can get a nice bead in the corner then just round over or square up the edge. Very little grinding, less weld removed. (I usually prefer the slightly rounded over edges as opposed to the perfectly square)
The rails and whole project look awesome! Keep up the good work!
t
Old 02-06-2009, 12:51 AM   #213
2legit2quit
iLLblazer's Avatar
t
I looked at the pics and that was my first thoughts. You ground away the majority of your weld the way you did it, and made alot more work for yourself grinding.
Old 02-06-2009, 07:53 AM   #214
lame-o
Thanks for posting an actual pic Joel. That is much better example than the drawing I found!!!
But that is exactly how I would do it. You just kiss the edge with a grinder and you are done.
t
Old 02-06-2009, 10:38 AM   #215
Interpretive Rides
curt_minke's Avatar
ok guys,
First of all thanks for the tips... I take everything to heart from all you guys (and gals). But let me explain myself so you understand why i did it this way.
First of all, the reason i didn't go full or half open corner is becasue of the way i had to bend the material around the plates. It would be very difficult (especially cause i work by myself) to keep a constant half open corner to weld to and remember I only had 3/16 wall thickness to weld to. This could cause serious warping with the thickness of the material being quite thin, and not building a jig to weld it (because its obviously one off). Furthermore, when i tack the pieces together i now have a straight square edge. Now you may ask, how you can you get full penitration? Well see once its all tacked together, straight, and they way i want it i now take my grinder with a coarse stone disc and grind out a 37 degree angle on both pices till the material is about 1/16 (.0625) away from right through. Now i have my welder set to burn a full penetration weld in the "V" style groove i made. Then what is left for me as a "weld cap" above the surface which is what i grind off. Now the cap still may take extensive grinding, BUT the weld is fully penitrated and allows me to have a square edge.....
So now i have a fully welded frame rail with perfectly straight, square edges. This makes it 100 times easier to create my own fillet around the rail and not have to depend on the radius the weld made doing the half or full open corner weld. I have done many half open or full open corner welds were i have ground it smooth to a nice radius on the "dependant weld" but found that i have had to go back and add "weld material" to the radius were the weld would be less than the radius i was going for.
So in my prospective, with the goal i am trying to achieve, my way may take a little bit longer but in the end it makes it a hell of alot easier for my to grind my own radius and keep it square and uniform without having to touch up spots.
Wow that was long. ha hopfully you guys understand what im saying. Haha if not i made a drawing for you guys to understand better how i weld it.
Again thanks for your comments and concerns!!!!
Old 02-11-2009, 11:41 PM   #216
Interpretive Rides
curt_minke's Avatar
rear rail welded
Old 02-12-2009, 12:06 AM   #217
BodyDropped Member
Kenny_Cox's Avatar
that looks great.
Old 02-12-2009, 01:24 PM   #218
theres a truck comin through the wall! wait, no thats just a grille. nice lookin rails.
Old 02-12-2009, 01:37 PM   #219
Interpretive Rides
curt_minke's Avatar
lol haha thanks guys i should hopefully have that rail ground down tonight and should be able to cut the uglly ass back half off this weekend!
Old 02-12-2009, 02:18 PM   #220
Vroom 2.2 Vroom
Oldskool94's Avatar
sweet we need more progress pics.haha
Old 02-12-2009, 02:54 PM   #221
Forvm Lurker
anALLSHOx's Avatar
i know this might sound like a stupid question but is that a ball hitch receiver on the very front of the frame???
Old 02-12-2009, 03:01 PM   #222
Interpretive Rides
curt_minke's Avatar
ha i have to explain this everytime. It is a good idea but im goin to make it better. Its for if it ever gets stuck down you can put a reciver in and use that to jack it up to be able to get it off the ground. Where it sits the reciever will come out the front air dam so you don't have to remove the bumper. Ill just have to make a qucik disconnect grille for the air dam so you can get at it. When i redo it i will be making my own that isn't crappy or bought off a shelf and welded in.
Old 02-12-2009, 03:10 PM   #223
Vroom 2.2 Vroom
Oldskool94's Avatar
good idea thinking ahead.
Old 02-12-2009, 03:10 PM   #224
Forvm Lurker
anALLSHOx's Avatar
that's ingeniously smart, i always had to use a 4x4 piece of wood and 2 jacks..
Old 02-12-2009, 08:08 PM   #225
~Sunkin Sins~
Wybrow's Avatar
Woot, progress! Get this shit done. I know, Im one to talk.
Old 02-16-2009, 10:35 PM   #226
Innis's Avatar
shut up and go post in your own thread
man, progress is looking good, i was at home in kincardine all weekend i should have tried to get together with you for some drinks
ah well next time
Old 02-17-2009, 11:57 AM   #227
Vroom 2.2 Vroom
Oldskool94's Avatar
progress is looking good.
Old 03-02-2009, 12:22 AM   #228
Interpretive Rides
curt_minke's Avatar
PICTURE UPDATE! yEaH! rear rails are in!
Old 03-02-2009, 12:40 AM   #229
Close2theground's Avatar
Hell ya good work brotha ! nice and level
Old 03-02-2009, 01:45 PM   #230
resU deretsigeR
INTERNATROLET's Avatar
Man that's pretty...
Old 03-02-2009, 11:30 PM   #231
Its Mr. Kandel to you!
kandel123's Avatar
i like
Old 03-03-2009, 12:02 AM   #232
Turbocharged Pimp
jimhrabe's Avatar
looks good!
Old 03-03-2009, 07:25 PM   #233
kandel123's Avatar
why dont you try and make a level frame next time!
Old 03-03-2009, 08:42 PM   #234
B JELUS
GET_LOW's Avatar
If your referring to the angle, its impossible with a doored truck. Even stockfloored. its prob only like 2 inches max.
Old 03-04-2009, 01:14 AM   #235
Interpretive Rides
curt_minke's Avatar
Quote: Originally Posted by kandel123 why dont you try and make a level frame next time!
what are you guys talking about im confused>?
Old 03-04-2009, 01:23 AM   #236
BodyDropped Member
Kenny_Cox's Avatar
i think Kandel was only kidding, trying to point out the fact that in the pics there is a level, and it always reads perfect.
Old 03-04-2009, 08:29 AM   #237
kandel123's Avatar
yep. Not sure what drag racer is talking about
Old 03-05-2009, 05:14 AM   #238
Interpretive Rides
curt_minke's Avatar
lol oh ok well thanks haha
Old 03-05-2009, 02:50 PM   #239
Vroom 2.2 Vroom
Oldskool94's Avatar
so trucks looking really good.
Old 03-05-2009, 03:38 PM   #240
Droppedime08's Avatar
badass idea on the rear frame rails..i really like it
Old 03-06-2009, 12:57 AM   #241
Innis's Avatar
lookin real good man, lovin the frame rails!!
Old 03-11-2009, 12:37 AM   #242
Interpretive Rides
curt_minke's Avatar
more!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! pics.......
Old 03-11-2009, 12:51 AM   #243
resU deretsigeR
wowza!
Old 03-11-2009, 01:57 AM   #244
V8 with bags
V8Blaze's Avatar
WOW! this might be one of the nicest frames ive seen built on here. Keep the pics coming
Old 03-11-2009, 11:41 AM   #245
looks great man, can't wait to see more !
Old 03-11-2009, 11:53 AM   #246
Vroom 2.2 Vroom
Oldskool94's Avatar
thats a sweet ass update nice work.
Old 03-11-2009, 12:14 PM   #247
B JELUS
GET_LOW's Avatar
Yeah i don't know what that kid is talkin about either. He must be stupid or something.
(I thought i was in slappy's thread and about the angle part on his floor )
Old 03-11-2009, 12:46 PM   #248
Turbocharged Pimp
jimhrabe's Avatar
Looks great so far!
Old 03-13-2009, 05:10 PM   #249
~Sunkin Sins~
Wybrow's Avatar
Wow dude looks amazing!!!
Old 03-18-2009, 10:13 PM   #250
Innis's Avatar
wow curtis this is awesome, i think over Easter weekend i am gonn have to drive up there from my parents house on Saturday and come check it out in person
keep it up!
Page generated in 0.66821 seconds with 31 queries
[Output: 219.65 Kb. compressed to 200.81 Kb. by saving 18.83 Kb. (8.58%)]
