#101 |
Re: Project: Metal Head
very nice work man
#102 |
subscribed, i cannot wait to see this all done!
#103 |
Interpretive Rides
Hey,
So ive been designing a cantilever rear clip on my computer over the last couple days to get an idea of what im doing and how (saves the trial and error i would have to go through). So this is what im thinking. I know that it will work on the computer, but what are the advantages...disadvantages etc.....??? I basicly designed it hoping it would be a nice ride. Oh and the wheels are 22's with 30 wall tires...What do u think....................... thanks ![]() ![]() ![]() ![]() And the suspension lifted ![]() ![]() Last edited by curt_minke : 12-03-2008 at 01:14 PM. |
#104 |
"Da Dog"
Wouldn't you need some kind of Panhard bar to keep the rearend from moving side to side? I would try to incorporate that in you computer rendering also to see how it would work with it.
#105 |
Interpretive Rides
ya there is a panhard bar going in. just don't have it drawn yet. |
#106 |
Vroom 2.2 Vroom
looks badass!
#107 |
keepin it freshhh
that frame is coming out nicely, sweet welds.
did you have the frame measured before you started? |
#108 |
Vroom 2.2 Vroom
can someone explain to me what a panhard does?
#109 |
Interpretive Rides
pan hard bar connects the links together from side to side so that the rear end can;t sway or slid from side to side. Its hard to explain without a drawing
#110 |
You should do a watts linkage instead of a panhard bar... just my opinion, i love watts linkages, im definitley doing that on my next project... which will start whenever i get off my lazy ass and finish the one at hand...lol
#111 |
Street Spec Kustoms
project looks awesome man. its always easier to just cut out all the bad shit and start over again. thats becoming my theory lol
#112 |
looks good man
#113 |
ya also might want the frame boxed in instead of just plates...lol
#114 |
Hoods are overrated
defenitely watts link
and i'd change the mounting point where the lift lever meetsl the upper link bar. 2 tabs on top of each link bar and a link end on the lever bar would be easier and cleaner looking. |
#115 |
is gettin there...
idk id run a watts link on that, just for coolness factor, and matching the canti
#116 |
Interpretive Rides
Question. Where can i find a good example of a watts link.... |
#117 |
Interpretive Rides
#118 |
B JELUS
What program were you using to draw the setup? Looks nice, i am familiar with Autocad and invetor and am just starting to learn ProE this year! Can you tell your pinion change through the motion? Cause i am drawing mine up in Inventor and i was wondering if i could cycle the suspension though its motion and figure out my pinion change. |
#119 |
Awesome work man!!! I came in this thread just in time, I got to see a lot of progress and now it gets really good
#120 |
Interpretive Rides
Ya im using Solidworks 3d. Its very similar to intentor. I have used inventor as well. What i found for the pinion angle is i set my axel in the program parallel to the transmission (or related angle) and then delete the mate. This now allows me to build my links to the axel and not have a mate holding it in place. Then it has a free motion that you can move with the mouse. This also now makes it able to be measured for pinion angle when the axel is up, down, or half way. This might be kinda confusing but im trying. Let me know if this helps. Other than that i have now drawn in a mock up of what im going to use. THanks to all the comments i am now going to use a custom made watts link instead of a panhard bar. Also changed the cantilever arms. Let me know if anything seems out of wack. Thanks ![]() ![]() ![]() ![]() |
#121 |
I don't know much about this but it looks like the cantilevers may make contact with the bags during motion.
#122 |
Vroom 2.2 Vroom
Thats badass. I really like the watts do that not panhard bar.
#123 |
gnarly
#124 |
Life Begins @ Zero PSI
Sweet work on your computer. I'd love to see it done.
#125 |
Vroom 2.2 Vroom
they shouldnt rub because when the bag is completley deflated it has its largest diameter. so there for it should clear. |
#126 |
Interpretive Rides
#127 |
looks great man keep up the good work and keep on the updates
#128 |
///RELAXED
Looks damn near identical with the setup we did a while back...I like it lol. If you do decide to run your bags like that there are a couple things you should keep in consideration!!
#129 |
wow, looks good
#130 |
damn lookin good man keep it up...
#131 |
Its Mr. Kandel to you!
that frame was at indy 07
The four-link bars were sick! |
#132 |
lookin good man, hey i seen in another thread that you race motocross...where are you located at? you still race?
#133 |
Interpretive Rides
[quote]lookin good man, hey i seen in another thread that you race motocross...where are you located at? you still race?[/QUOTE
Thanks. Ya Im done with full time racing now but I have my own track so I def didn;t stop riding ha. Its a full size track designed with supercross style sections from the ama circut. Its an awesome track. But ya im up here in Ontario, Canada. |
#134 |
making some magic happen
werk is completely night and day from beforte til now. definately a killer new design but how tall will your center notch be for your driveshaft be? it looks like almost 8" from where the floor is gonna be....... man i hope my frame comes out that clean
#135 |
Interpretive Rides
#136 |
is gettin there...
nice job choosing the watts link, but my only concern with that wicked frame is the back end where those plates hang way down to come in contact with the ground.
1. are those goin to stick below the bed? and 2. when you go on an incline without being fully aired are those going to rub the ground? |
#137 |
Interpretive Rides
#138 |
[quote=curt_minke;5837280]
We should get together and ill bring the super kicker! |
#139 |
double post
#140 |
Interpretive Rides
def man. The guy who built freekstyle mx freestyle jumps used too live right beside the track so we did have a compound at one point lol. Totally have to come up in the spring when the snow F***s off lol..
#141 |
B JELUS
![]() Im gona put mine behing the axle so you can layout flat and then you can drop the ass end and ride cali and get the drag blocks instead of the frame. |
#142 |
hows this going so far?
#143 |
Interpretive Rides
#144 |
very interested. How far are you from the falls? im sure i could get some people to come up with me the Session up there. Hitting all the same tracks around ohio is getting old.
#145 |
Scoop
Sweet ride, great work.
*Subscribes* |
#146 |
Interpretive Rides
#147 |
you can't jsut design your cantilevers strong enough to resist to the
axial force??? or can you put the cantilever with some angle to resist to the axial force ??? |
#148 |
damn yo ive been wanting to come up there for awhile...i really wanna ride at Gopher Dunes. Some of my friends have rode in a couple nationals up there and they said that track gets gnarly ruff
#149 |
wow ok ?'s and comments
loving the work,excellent welds,great ideas one ? Do you plan on fish plating any of your seams? ****subscribed**** |
#150 |
Interpretive Rides
So here is the latest update.
Got a new shop so ive been busy moving everything. As of right now no actual progress except for these cad drawings. ![]() ![]() ![]() ![]() |
