[ProjecT] LoW RangE
Old 06-28-2008, 09:51 PM   #151
That lil ole Ranger
83LOWrange's Avatar
83LOWrange is on a distinguished road
Re: [ProjecT] LoW RangE
and a sweet pic of the ACTION! lol
Old 06-29-2008, 01:54 AM   #152
Undesired Vacation
dawgnutz's Avatar
dawgnutz is on a distinguished road
Those welds are lookin better every pass! The 187 is a 220v welder?
Old 06-29-2008, 02:06 AM   #153
Human Element
TuckaBlaze's Avatar
TuckaBlaze is an unknown quantity at this point
does those upper bars have enuff angle to keep the rear end center?
thats about the most i can get out of mine, and i didnt know if it was enuff. i wanted it wide at the axle, and depending of if that is good enuff, i can do it the way i wanted it in the fist place...
Old 06-29-2008, 02:22 AM   #154
That lil ole Ranger
83LOWrange's Avatar
the PERSAY "perfect angle" is 40 degrees.. but with a rangers frame so damn narrow thats impossible...
i am redoing mine, i will be raising the bed floor so that i wont have to cut it at all. But what im still going to do, this will work for you also, take the crossmember and move it further towards the cab, and then weld your tabs facing the axle, so weld them to where they are pointing out and not up, but also weld them on the highest point on that crossmember, on the drive shaft hoop basically, have the two inner link tabs about 1/2" apart, and that will give you a decent amount of triangulation...
i hope that dont sound confusing
now on my lower bars, the way that i have my lower mounts welded, do you think that the 2x2 will twist? i have the plate so thats it half and half, and braced it up a good bit... so all the pressure isnt off the ber
Old 06-29-2008, 04:09 AM   #155
S10wannabee's Avatar
S10wannabee is on a distinguished road
looks good, but i would box the frame were the upper bag bracket is placed now, are is it already??,
welds look good!
Old 06-29-2008, 01:10 PM   #156
That lil ole Ranger
83LOWrange's Avatar
welds look good!
yea im going to, im welding a 6" piece of 2x2x1/4" angle vertically inside the frame first, and them i have some 1/4" plate that will go over it
Old 06-29-2008, 01:55 PM   #157
Burnt Blazer
black_ice_02's Avatar
black_ice_02 is on a distinguished road
hell yeah man just found this thread and read it all. Good work likin the build, I too have been on rps but like it more here. The only thing i can see to watch out for with offsettin the bags is wearin the bushings. It shouldn't be a big problem since your not offset that much. Love old square rangers and a hella buy. Good luck
Old 06-29-2008, 02:04 PM   #158
Plastic Welder
phillip7's Avatar
phillip7 is on a distinguished road
looking good!
Old 06-29-2008, 05:24 PM   #159
That lil ole Ranger
83LOWrange's Avatar
thanks guys, yea im going to just go ahead and cut it off and center it on the bar, but doing this it means that i have to cut of the leaf perch and build a mount to have it further out off the frame and i also have to move the tabs on the axle now
Old 06-29-2008, 05:29 PM   #160
That lil ole Ranger
83LOWrange's Avatar
ok well i welded the bridge bar back in again, finished the upper mounts, and primed everything... but i found some other stuff (DAMMIT!)
ok i noticed this, it just started because i deffinatly would have noticed this puddle...
so what could it be...? i look up and check this out, WTF!?!
PLEASE tell me this isnt horrible news.. thats the last thing i need to hear
Old 06-29-2008, 05:35 PM   #161
Trailors Are For Boats!
PunkDime99's Avatar
PunkDime99 has a little shameless behaviour in the past
uhmm....... thats not too goood my man... is it that far out like.. at all angles of motion? if so.. gees thats not to good brotha..
Old 06-29-2008, 05:38 PM   #162
That lil ole Ranger
83LOWrange's Avatar
mo it couldnt have been like that through this whole baggin process... because i would have noticed... maybe because i took my lowers off it pulled it out some? IDK
Old 06-29-2008, 05:40 PM   #163
PunkDime99's Avatar
i bet thats what it is.. BUT! id put on your lowers and peek your head down there.. you really want the minimal amount of that shaft sticking out.. looks like its about to fall out.. it will move in and out throughout the arc motion, but.. def try to keep it as close as possible without it being smashed into the tranny (just as bad)
Old 06-29-2008, 05:46 PM   #164
That lil ole Ranger
83LOWrange's Avatar
ok well ill go and put the lowers back on... but i have to rework the lower tabs on the axle and the frame... so if i hurry up and do that i can put them back on and leave them... but thatd be later tonight. so could i just refil the fluid after that?
Old 06-29-2008, 06:01 PM   #165
That lil ole Ranger
83LOWrange's Avatar
ok well i can get it... i looked up what my wheel base is stock... and there is about 3" of the shaft that is out, so thats why my wheelbase is 3" longer than stock right now...
but im going the get it back stock, tack the axle to the notch and redo my bars.. hopefully this will fix it right
Old 06-29-2008, 09:17 PM   #166
V8 with bags
V8Blaze's Avatar
V8Blaze
everything looks good man, sucks about the wheelbase though
where in la are you
Old 06-30-2008, 12:27 AM   #167
That lil ole Ranger
83LOWrange's Avatar
where in la are you
well i got the wheelbase now... i just took off my lowers and when i layed it out it would pull out, and out more and eventuall enough to start to leak... but its an easy fix! but i have it all squared and all i just have to weld the axle to the notch...
but man i aint but like maybe 3 hours from ya... im 40 minutes north of alexandria! but im hoping this weekend ill have it done, if you want you could come and help! HEHE i got a pool and extra beds bro!
Old 06-30-2008, 01:54 AM   #168
Human Element
TuckaBlaze's Avatar
you know im at ft polk LA right?
Old 06-30-2008, 02:44 AM   #169
Undesired Vacation
dawgnutz's Avatar
Louisiana Build party! You guys can go from house to house helping each other build Your shit! LOL! Start at one and just knock'em down! LOL!
Old 06-30-2008, 03:07 AM   #170
That lil ole Ranger
83LOWrange's Avatar
no, no i didnt... but i have a friend in pitkin
i plan on working friday, saturday, and sunday basically all day and night long this comin weekend
Old 06-30-2008, 03:07 AM   #171
That lil ole Ranger
83LOWrange's Avatar
Question Re: [ProjecT] LoW RangE
HAHHA i wished! dude you live in CALI! talk about build party
Old 06-30-2008, 12:06 PM   #172
Human Element
TuckaBlaze's Avatar
I Would come over and help in a heart beat if you really needed the help... Gas hurts for me to come help and not really do anything cept drink beer lol...
Old 06-30-2008, 03:36 PM   #173
V8 with bags
V8Blaze's Avatar
V8Blaze
yea 18 mpg in the blaze is decent b ut a 3 hour ride would blow. and th e old lady doesnt have a car still thanks to that delivery truck. So i play taxi on my days off too. Wish yo were closer, id be down for helping
Old 06-30-2008, 04:21 PM   #174
beaniebmx's Avatar
beaniebmx is an unknown quantity at this point
problems that i see with it,
#1 the right link bar on the axle has no bushings, meaning the axle couldve rotated in the link bar enough to pull the driveshaft out 1/2 inch or more.
#2 the driveshaft/linkbar crossmember doesnt even appear to be welded to the frame, it looks like the whole weld broke off on both sides. picture below it even shows driver side is the same way.
maybe those welds broke off allowing the axle to rotate enough to pull it out that far
all you need to do is push the driveshaft back into place, fill it back up with fluid and keep working.
mine got shoved into the tranny, previous owner did a 4/4 drop with no set back plates, drips tranny fluid daily, but i sold the truck and gave the new owner the plates and seal
Old 07-01-2008, 04:53 AM   #175
That lil ole Ranger
83LOWrange's Avatar
yes, good eyes... i began to cut out that crossmember and then i noticed this mysterious puddle! LMAO
also on the bushings, neither of the uppers had bushings at the time... i JUST NOW pressed in my superpivots... but i need the correct length then, but now that im raising the bedfloor and redoing that crossmember its no biggie..
i did get the shaft back in, and then i think i have my wheelbase set right and everything is lined up now, all i have to do is tack the axle to the notch for ride height and set my pinion angle, then weld my new crossmember and my new tabs on the axle...! alot of work that if i knew what i was doing then, would have been avoided!
but anyway one question on my wheels! what do you all think? POLISHED or CHROME? chrome is $100 bucks more...
Old 07-01-2008, 04:55 AM   #176
That lil ole Ranger
83LOWrange's Avatar
i definatly know how you feel bro! well if you want this friday - sun. its balls to the wall on her to get her done! NOW I KNOW ITS THE 4th!!! but i imagine that we will grill a shit load and i have a pool and places to sleep... so if you want to come for a day or all 3... its cool wit me! no matter what
trust me, theres plenty to do! i know how it feels to drive and "help" and you end up jus lookin or BS'ing.... well this truck HAS TO MAKE pineville dammit!
raised bedfloor and all! hell i prolly wont sleep those nights...
Old 07-01-2008, 10:46 AM   #177
Human Element
TuckaBlaze's Avatar
i could not make it this weekend, but i could make it next weekend. My family and everyone is geting together for the 4th on thursday... Its also a celebration for my pop for finishing kemo.
Old 07-01-2008, 12:37 PM   #178
That lil ole Ranger
83LOWrange's Avatar
ahhh ok ok...
well the next weekend is the show, so thats why i have to have it finished by sunday, and then ill have like 5 days to raise the bed floor
Old 07-01-2008, 12:58 PM   #179
Plastic Welder
phillip7's Avatar
Well good luck, hopefully you can get it done!
Old 07-01-2008, 02:27 PM   #180
That lil ole Ranger
83LOWrange's Avatar
i know man... im taping off the lines to cut my bed floor and raise it starting tonight. by sunday the bag work should be done
Old 07-01-2008, 10:25 PM   #181
V8 with bags
V8Blaze's Avatar
V8Blaze
sounds fun, good luck with getting it done
Old 07-02-2008, 12:09 PM   #182
That lil ole Ranger
83LOWrange's Avatar
