[Project] Living up to my username
LinkBack (1) Thread Tools
Old 09-26-2008, 07:42 AM   #4901
mister880's Avatar
mister880 is on a distinguished road
Re: [Project] Living up to my username
RPI is in NY...
Old 09-26-2008, 09:34 AM   #4902
I want sonoma grill!
xtucking22s's Avatar
xtucking22s is on a distinguished road
oh ok then...
Quote: Originally Posted by Driveway Kustomz
dood is that rpi?
Quote: Originally Posted by xtucking22s
since the thread got bumped anyways, here are some cool pics i got (i didnt take them myself though, a friend took em) with some friends in downtown baltimore last week
Old 10-04-2008, 11:27 AM   #4903
I was going to wait till it got painted to show pics, but i decided im putting of painting it until i get all my fiberglass projects done and do it all at the same time. So here is the center console I built throughtout the first half of September:
Began with tapping up the floor:
Then a second layer:
Then came fiberglass matte, 3-4 layers depending upon the area
hardened and removed from the truck:
Tripped to desired foot print:
Then to start mounting stuff off of I wanted a material I was more comfortable working with, so I cut a piece of 1/2" MDF and made it go the length of the console. I just screwed this in into the fiberglass piece
Then using more 1/2"MDF, some 2" PVC pipe, and a universal underdash mount headunit kit I got my general shape
Here you can really see how the fiberglass mold of the floor will truely fit like a glove versus if I had just used a flat piece of wood for the base of the console:
Then I used speaker grill cloth to wrap the console, then resin that up. (not pic)
Old 10-04-2008, 11:28 AM   #4904
Then I began the actual fiberglassing. I used fiberglass cloth for this that I cut into multiple sized strips
flipped over
then ill skip over the multiple layers that followed since it all looks the same lol
Then I used marglass to begin smoothing things out, cut out the holes for the gauges, and for the top part where a fuse box will then go into. The wooden piece will be treated with some foam padding then be wrapped in leather of vinyl of some sort:
with switches put in now (7 holes but only physically had 4 in for this picture)
Old 10-04-2008, 11:30 AM   #4905
Then i decided to do a test fit, and I am really really happy with the way it fits and flows with everything.
Then i decided, i really like it so much that im going to put the gauges in it, and roll around with it until I get it painted. which will be sometime this winter
I allready talked with John at Getbored for some tips/pointers/suggestions for what I can do to improve upon my work to make it as good as can be as well as prepped best to give it to him in a form for him to take over and finish the smoothing/sanding/bondo before he paints it. SO PLEASE FOR THE LOVE OF GOD, LETS NOT TURN THIS INTO A FIBERGLASSING TECHNIQUE DISCUSSION THREAD. This is the way i did it, it turned out just fine. This is not meant to be a teching aid for anyone, so dont hold me responsible for you trying to do something and saying I tought you wrong. If you wanna learn how to do fiberglass then read NickZagaitas (sp?) how to thread.
Old 10-04-2008, 11:34 AM   #4906
x-blazin
blazerxtreme18's Avatar
blazerxtreme18 is on a distinguished road
looks good man...looks better than the old one did i think...cant wait to see it painted
Old 10-04-2008, 11:35 AM   #4907
Now I have also been working on an overhead console. Driving around in my sierra one day I thought to myself it would be cool looking to put this overhead console into the s-10 and throw 2 of my gauges in there. (my old center console had 6 gauges, so i needed to find a home for all of them. except im not putting my ammeter back in currently, or if i do it will be next to the battery rack whenever i get to doing that). Anyways, i knew that for the diesel guys they make a gauge mount for this overhead console. so ya...things worked out well. now pics on that:
this is my sierra's in the sierra:
then I very roughly test fitted it in the s-10. It looks right at home! well with a little help it will
Now unfortunatly the factory map lights wont work because it is very bulky on the backside of the overhead console, it isnt flush with the mounted surface. See the tabs on the overhead console that make it fit into the sierra? ya i needed to cut those off to put this thing in the s10 so that it sits flush on the headliner. The headliner of my sierra is like cutout underneath the overhead console so it uses those tabs. anyways, ya, so the stock lights wouldnt work, so I needed to find somethign different. So I found these cool high output 1Watt LED flood lights from oznium. decided i would make them work. these things are bright! And yes...they are blue....yes im bringing back a little bit of blue-ness lighting love to the truck, but leaving it plain and simple.
gauge mount I bought from So Cal Diesel and my 2 voltmeters (one for starter battery, one for main batteries)
Oh, and I bought another overhead console off ebay for $20. so i didnt actually hack up my sierra's lol, I put my sierra's overheadconsole back in after the initial test fit the first night.
Now after removing the factory map lights, i was left with a ~2" hole, well the LED lights are only like 1-1/8", so I cut a piece of plastic with the correct 1-1/8" hole and like a 2-1/2" outerdiameter and plastic welded it to the overhead console
Then molded that new piece of plastic in and smoothed it out to make it all blend in and look "right"
This still needs some work as well, but thats where it stands now. I have sanded this thing a lot to remove all the factory texture.
Old 10-04-2008, 11:39 AM   #4908
That's right take it
eriley's Avatar
eriley is on a distinguished road
That looks awesome! I hate the console I built for my truck this summer I like this method a lot better.
Old 10-04-2008, 11:40 AM   #4909
bank owned
kevdog's Avatar
kevdog is on a distinguished road
Awesome work man! I wish that I had the time, patience, and experience to build custom one-off fiberglass pieces. I tried my hand at it once and ended up very, very disappointed in myself. I'll try it again someday... maybe when I get a set of bucket seats for my ride.
Old 10-04-2008, 01:02 PM   #4910
Wanna see some magic?
01cherryreds10's Avatar
01cherryreds10 is on a distinguished road
So the map lights on the overhead console from a Sierra won't work?
Old 10-04-2008, 01:57 PM   #4911
finally bagged!!
pewter_dime_99's Avatar
pewter_dime_99 is on a distinguished road
i love the new consoles man! the upper console is tits!
where did you get the universal underdash headunit kit? i really wish i would have had something like that when i did my console.
Old 10-04-2008, 02:35 PM   #4912
Trailors Are For Boats!
PunkDime99's Avatar
PunkDime99 has a little shameless behaviour in the past
hey man you can get those anywhere.. Circuit City, Best Buy, tweeter..
they use em alot in old cars with the AM knob radios so that you can put an aftermarket in the car without hackin up the sweet dashboards..
Old 10-04-2008, 05:59 PM   #4913
AKA DavidAndSomeNumbers
David12460's Avatar
David12460 is on a distinguished road
Looks great Adam. I like the overhead console. I want to do something simular in the future.
Old 10-04-2008, 06:57 PM   #4914
I needs paint!
kovz34's Avatar
kovz34 will become famous soon enough
Console looks great adam. If I had to do things over, I would probably want something similar for mine. Good job!
Old 10-04-2008, 08:06 PM   #4915
"SHOW TIME PRIME"
mccord's Avatar
mccord is on a distinguished road
adam center consol looks great. i deff like this one better than the old one. cant wait to c it painted!!
Old 10-04-2008, 10:59 PM   #4916
fresha' than a mafucka'
fluX's Avatar
fluX will become famous soon enough
I like the old one better .... but still looks cool.
Old 10-05-2008, 12:05 PM   #4917
I AM THE PENGUIN OF DEATH
Joker Relentless's Avatar
Joker Relentless is on a distinguished road
Looking great Adam
Old 10-05-2008, 10:40 PM   #4918
I wonder how it tastes?
cpolaris502's Avatar
cpolaris502 is just really nicecpolaris502 is just really nicecpolaris502 is just really nicecpolaris502 is just really nice
wow, very awesome work.
Old 10-05-2008, 11:48 PM   #4919
Thanks a lot guys, I appreciate the compliments as always. Ill be getting started on my next thing very soon. which is a 10.4" touchscreen fiberglassed into the main dash bezel like orangesonoma and purplepassion have done. Ill get on that starting next week I imagine and Ill do the same thing I did here, post pics once I get it to the point that I give up and wait it out till i get Getbored to finish of the smoothing of it and paint it.
Old 10-05-2008, 11:49 PM   #4920
eriley's Avatar
make sure you take lots of pictures so if I decide to do that in the future I can come here and see how
Old 10-06-2008, 09:46 AM   #4921
xtremefour
xtremefour's Avatar
xtremefour
I really like the consoles especially the top one. I had the same idea a couple of years ago. I used to have a tripple gauge pod and cut all of them off. I used a piece of 1/4" plexiglass and molded the gauge pods to that. It was not thick enough to cover up the back side so I used aother 1/4" piece and mounted it above my rear view mirror. I will have to get pics but it came out well. Your truck will look real nice at night with all the gauges lit up.
Matt
Old 10-06-2008, 10:40 AM   #4922
Junk's Avatar
Junk is on a distinguished road
I really like that console, awesome work!
Old 10-06-2008, 02:04 PM   #4923
I Like Fire....HaHaHa
NickZigaitis's Avatar
NickZigaitis is on a distinguished road
LOL!! Cried laughing
Old 10-06-2008, 02:37 PM   #4924
snausages
2001xBlazer's Avatar
2001xBlazer is on a distinguished road
lets make this a thread on how much the verizon ENVY sucks!!!!!!!lol
looking good man
Old 10-06-2008, 03:12 PM   #4925
S10wannabee's Avatar
S10wannabee is on a distinguished road
that console looks very good man.. great idea on the overhead console also!!
Old 10-06-2008, 05:30 PM   #4926
Chevy Ridin HIGH
SlamBlackSdime's Avatar
SlamBlackSdime is on a distinguished road
Center console looks good, two quick questions- is this your first fiberglass job? and does the new console get mounted to the floor like the stock one, or does it just rest there? thanks and keep up the great work
Old 10-06-2008, 08:31 PM   #4927
lol I thought you would get a kick out of that.
This is my seconf fiberglass job I have done, the only other one being my first center console that I made a little less then 2 years ago. And this console will just rest on the floor. It hugs the floor like a glove and I feel no need to bolt it down. My previous custom console just chilled there and that worked fine. Only time it would move would be if I got in a car accident in which case ya I know the console will fly up and decapitate me, so there now no one can bring that arguement up cuz im flat out saying it myself.
Old 10-07-2008, 01:44 AM   #4928
cokehead
Dr. Pepper's Avatar
Dr. Pepper is on a distinguished road
id suggest fusor for doing the bezel. stuff is awesome man. but if fiberglass is your thing. . .
but seriously fusor is awesome.
Old 10-07-2008, 12:42 PM   #4929
deuce deuce!
Kunde's Avatar
Kunde is on a distinguished road
lets get to page 100 ! the console is lookin good bro. IMO the overhead is a little much but still looks good.
Old 10-07-2008, 12:57 PM   #4930
