LinkBack (1) | Thread Tools |
#301 |
I want sonoma grill!
Re: [Project] Living up to my username
The guy who is doing my welding for me is not fabricator by any means, im going to try and make do with the setup as planned(including the front link bar mounts), and try to use my idea because I feel it will work. And yes, I realize with my notch moved back 1" im going to need to put the shock bar all the way in the one corner of the notch. Thanks for noting that, but im one step ahead of ya Call me stubborn if ya want, but im going to try it my way first, then I will see how things go. But I know other setups have incredibly different bar lengths, like the ART airbar, that thing uses the stock leaf perches(in the stock location) for the new front link bar mounts. So the front link bar mounts on that are like twice the length of the wishbone links. And those setups are decent and work for people, Now my link bars are going to be 9" short even if I get my new 2.5" longer ones made, so Im still MUCH better off then the ART airbar people. We will have to see what happens tomorrow I guess when i do a little trial and error. Last edited by xtucking22s : 06-24-2007 at 01:37 AM. |
#302 |
sorry to find out you having all these problems dude...keep your head up.
#303 |
UNDER CONSTRUCTION
one other problem you may run in to moving the perch forward, is the reason that they get moved back in the first place. it may lay out on them before the frame hits.
lengthening the lower bars is going to make for some serious pinion angle change. what is the backspacing on your wheels? i don't have 22's but i do have 285's in the back and it doesn't hit anywhere. |
#304 |
bank owned
*subscribes*
Just found this project thread. Looking good so far! Good luck with figuring out your front lower link situation. |
#305 |
those 'weights' on the axle arnt weights, and they dont position the sway bar because theyre on just about every rearend out there. theyre guides for the axle on the assembly line, part of a jig fixture..
#306 |
I allready checked and if i move the mounts forward 2.5" the perches still are no where near close to laying on the ground before the frame, they are still plenty off the ground. My wheels have a +18mm offset I believe. i got an angle finder(after going to sears, salvo, home depot, pep boys, then harbor frieght where they finally had one). Im going to go play with stuff outside today and measure some angles. I pmed Dave(Avtekk) and he seems to agree that my idea seems the best solution for now, but I might have to correct things by also buying axle tabs with longer tabs on it to get everything back to correct angles(which i even mentioned myself back in the original post i made about this problem). I realize I gotta spend more money, but I feel this is fixing things the right way, and if its a matter of getting it done the right way then im willing to pay for it. |
#307 |
baggin
Location: Frostburg, Western Maryland User is: OffLine ![]() |
damn, in less than 1 month u have over 300 posts here.... awesome!
i didnt read the whole thread yet, but im gonna follow it pretty close. one question, if you dont mind me asking... i have seen threads about your truck in the past with your lambo doors and such.... including what you have so far in bags, how much money do you have in the truck? i dont mean to be a dick, its just that i want to do a lot of the same things you have done but being 20 and a shitty job kinda sucks... lol nice truck tho man, i'll be watching! |
#308 |
David
truck is looking good. love the blue powdercoating
#309 |
I AM A GENIUS!
Ok, so I have to say it......I WAS RIGHT! And I have actually improved upon SD's design i feel. anyways, Im going to go threw everything in an excel file because I think it is the most clear, before you read that know this. i tested everything at 2 different "ride heights", 1" and 3.5" between axle and frame, i think ill preolly end up riding around more around the 3.5" range or else im gonna be riding cali style all the time cuz i cant ride with the front very low lol. The measurements in the first blue part of the table are merely distance related to how high I put the truck up on the 4 jackstands when I balanced the truck on 4 jackstands the other day. SO the truck is perfectly level, and these measurements were taken for "relative" measurements to see how much things moved. There are 2 "case studies", one doing things Suicidedoors way, and one doing it my way. My way consisted off flipping the bolt on axle tabs around 180 degrees, and also moving the frame mounts towards the cab 2.5". This has causes my front link bars to now be .5" longer then the SD way ![]() look at all that nice comfortable clearance i have now( i only have 1 bolt holding the frame mount on because i was just testing this out before i drilled 6 more holes in the frame): ![]() see what i mean? i flipped the axle tab arounds. Doing it this way means I didnt even have to notch the axle pad at all, but its too late for that lol ![]() ![]() When I began my testing this morning and started moving things around I was extremely suprised to see that even suicidedoors parts cant be perfect.....one of the lower bars had the end piece just fall off. it looks like it was barely ever welded on? wtf? I know SD gaurantees/warranties their metal work and welding, so im hoping they will make and send me a new link bar. I couldnt believe it when the damn piece just fell off! Dave? help? its fine for now and all, but I want a new one before I go out driving on on all this ![]() ![]() In conclusion, the problem is solved, and I dont have to buy longer link bars, or new axle tabs. All the original parts work! (with the exception that the link bar end broke off and I want a new one of those) Last edited by xtucking22s : 06-24-2007 at 05:42 PM. |
#310 |
#311 |
Short Bus Anonymous
Looks good! And I dont think that nut gets welded on or else you couldnt turn it to tighten it down...
#312 |
#313 |
Short Bus Anonymous
I believe it does or at least on my KP6link it does, you can turn the end in the bar and turn the nut to the bar to tighten it...
#314 |
Center your wheels!
ummmm dude...
thats a jam nut to tighten down against the link bar so that after you adjust the length of your bar the bushing won't twist on you. Its supposed to be like that... |
#315 |
#316 |
Short Bus Anonymous
Well the only way it could have fell off is if you unscrewed the end out of the bar. And the other one might just be tight but it will move...
#317 |
ok so what do i do with it? just put it back on the link bar and screw it tight up to the end of the link bar? I dont really understand how that does much of anything, but if thats what your supposed to do then ok cool lol
#318 |
Short Bus Anonymous
Yes sir, adjust the bar to length you want and tighten it up.
#319 |
Center your wheels!
its attatched because it was powdercoated as one whole unit and the powdercoating is holding it together. Trust me it will come off relatively easily.
And just FYI...moving the lower perches down lower on the frame will change the angles between the wishbone and lower bars which can potentially cause you to have axle roll/pinion angle change (which SD worked hard to eliminate with the kit) |
#320 |
#321 |
Center your wheels!
yeah that was too confusing from at first glance so I just kinda skipped over it haha. Honestly if I had the kind of time I used to have at school to just sit on the forum all day long every day I would have already read every word of every post in your thread, but I'm so damn busy now a days that I can really just kinda browse over stuff anymore and look at the pictures haha. So sorry if I'm not catching a lot of the important details its because i'm just looking at the pics lol
#322 |
haha, its allright, i understand. i also dont read every word of every post anymore since ive graduated and ive been so busy, but an excel sheet is kinda like a picture lol. its a graphical representation...which is kinda like a picture lol. But ya see what i mean? everything is going to be honkey dory with pionion angle and angles of the lower link bars in relation to the wishbone. Ive found a geniune perfect solution to the problem at hand, like the true engineer i am
#323 |
Center your wheels!
after looking at your spreadsheet, it seems that while you did improve on the angles at a 1" ride height, your new angles are worse than SDs angles at a 3.5" ride height. What kinda angles are you looking at when its fully lifted?
#324 |
At the 3.5" ride height the numbers only got slightly worse, but we are talking like a 1 degree of difference here. I will probably cruise at somewhere between 2-3" between axle and frame i imagine. And that would be for "daily driving" which com to think of it is pretty non existent. So any driving would be driving around at a show, or so a show or at the grounds of a show or something where i would wanna drive low anyways, so i think im golden.
#325 |
Center your wheels!
ok as long as you got it all figured out i'm gonna trust ya
#326 |
Yup, i think im good to go now! time to continue on with the project, unless someone sees a fatal error in my solution, anything other then someone flipping out about 1 degree of pinion angle difference or something at one specific ride height lol.
#327 |
Center your wheels!
oh haha. you're sooooooooooooo funny.
lol j/k man ![]() |
#328 |
#329 |
Canyon Carver
1. You'll still have to check the pinion angle after the notches are put it and with the rear end at layed out height. It should be close to that 4 degrees.
2. You were not right, lol. Last night you were wanting to use an 18" lower bar. Now your using a 16" lower bar, 1/5 the increase that you were proposing earlier. Totally different plan. |
