[Project] I'm bored why not!
Old 08-22-2008, 12:47 PM   #201
5-Speed Blazin
2k2indigoxtreme's Avatar
2k2indigoxtreme is on a distinguished road
Re: [Project] I'm bored why not!
Lol dont bolt it man, u gotta drill all them holes though frame steel... its not worth it. I had my notch for a year before I put it in ahhaha. But yeah, swapping the calipers is super easy, only thing I did was get stainless braided line from www.inlinetube.com
Old 08-22-2008, 12:49 PM   #202
-119 point(s) total
sonomanator's Avatar
sonomanator is infamous around these partssonomanator is infamous around these parts
sorry i didnt mean smooth i meant what products did you use to shave the 4x4 delete panel and all that junk.
Old 08-22-2008, 01:28 PM   #203
this website is lame!
bmxbang's Avatar
bmxbang is an unknown quantity at this point
ahh it was a two part plastic epoxy i picked it up at advanced auto.
its like 5 bucks but well worth it i probably used about 4 bottles of the stuff. i did the whole fiberglass route the first time and it was a mess. this stuff is super strong though and i havent had a problem with it yet!
Old 08-22-2008, 04:38 PM   #204
-119 point(s) total
how do you go about applying it over the hole?
Old 08-22-2008, 05:03 PM   #205
damned 4banger
Noremac's Avatar
Noremac is an unknown quantity at this point
that crap is awesome lol... i did this with 2 part epoxy from walmart.. it was like 4 bucks a tube.....
works great i am gonna do my dash like yours sooner or later..
Old 08-23-2008, 01:40 AM   #206
bmxbang's Avatar
basicly over the airbag delete spot i cut out some scrap plastic piece and set it in hole then just filled the rest of the hole up with it, let it dry then ruffed it up and filled it in some more.
then over the 4x4 delete i just left the plastic piece in and filled in all around it with the 2part stuff to make sure it was in there nice, snug and flush.
after the plastic was pretty flush with all the other stuff i just put some poly filler over the top of it to make a nice and smooth finish.
Old 08-24-2008, 08:23 PM   #207
bmxbang's Avatar
MY BLAZER RIDES LIKE A CADILLAC NOW!!!
i love my bolt in notch! pics soon.
Old 08-24-2008, 08:44 PM   #208
i wouldnt undertsand
Wicked Mayhem's Avatar
Wicked Mayhem will become famous soon enough
haha.. notch ftw! i still bottom out in my notch.. i should have mounted it a little higher.
Old 08-24-2008, 08:48 PM   #209
bmxbang's Avatar
taken with a camera phone
SAWEETAH!
Old 08-24-2008, 08:50 PM   #210
bmxbang's Avatar
yeah i have yet to run a full tank of gas and throw my spare tire back in so hopefully it will still not bottom out. we couldnt go much higher because of the body mounts in the rear . although i did get on it once and my driveshaft rubbed lol.
Old 08-24-2008, 08:53 PM   #211
yeah i was a dumbass when i did mine and wanted the top of the notch flush so i could weld there.. damn me lol... its fine though with air shocks and i drive slowwwwwwwwwww.
Old 08-24-2008, 11:53 PM   #212
Molon Labe
BudRacing's Avatar
BudRacing is on a distinguished road
What is caliper clearance like with the notch?
Old 08-25-2008, 12:18 AM   #213
bmxbang's Avatar
well i haven't drove it much maybe like 30 miles but what we ended up doing was grinding down part of the notch a little bit that we thought might hit the caliper but its super close but it hasn't rubbed yet to my knowledge im going to pull the rim off and check it in a few days to see if it has though.
Old 08-25-2008, 12:25 AM   #214
if your calipers hit, your brakes should kinda go out and you have to pump the pedal.. thats how mine was.
Old 08-25-2008, 12:27 AM   #215
Azzurri is on a distinguished road
That's what I was thinking about doing with my notch as well. Either that or just cutting the part out completely that might rub. Keep us posted.
Old 08-25-2008, 12:44 AM   #216
bmxbang's Avatar
well thats good that has yet to happen hopefully ill be good to go
Old 08-25-2008, 12:57 AM   #217
yeah as long as i didnt go up a big incline at an angle im good to go. i learned to go out wide and go straight up the incline hah.
Old 08-25-2008, 01:49 AM   #218
Molon Labe
BudRacing's Avatar
I flipped the brake lines so I don't have that problem any more.
Haha, I've learned that trick too. I thought it was from my front brake lines being stretched though.
I just need to notch for my calipers damnit. I'm only at a 3.375" drop in the back.
Old 08-25-2008, 02:09 AM   #219
i had that problem with my flipped brake lines. then i got my braided lines and the banjo fitting is round so it clears where the factory block fitting hit.. plus ive been alot more careful.
that reminds me i still need my braided lines for my front brakes lol...
Old 08-25-2008, 03:18 AM   #220
bmxbang's Avatar
so chris is your notch not as far up as mine is? i thought it was alittle weird how the notch didnt really line up with the top or bottom of the frame and it had a little overhang. also how hard is it to notch for the driveshaft? is it just a mater of cutting away some stuff.
Old 08-25-2008, 03:29 AM   #221
yeah, the top of my notch is level with the top of the factory frame rails. i wanted more area to weld on so thats why.. but i should of pushed it up as high as i could. and notching for drive shaft.. i had to notch up under the truck. like center console area. at first with just 3" drop leafs and 3" normal blocks it hit my rear crossmember alot.. but then i put in shims like i needed and no more hitting. just up under the truck. but about 5 minutes with a plasma took care of that.
you can see here where i notched
and the amount of room inside my notch with no air in shocks
and yay for not being able to sleep...
Old 11-19-2008, 05:46 PM   #222
bmxbang's Avatar
yah for sweet wheels!
soon to be lifted!
Old 11-19-2008, 06:13 PM   #223
I wonder how it tastes?
cpolaris502's Avatar
cpolaris502 is just really nicecpolaris502 is just really nicecpolaris502 is just really nicecpolaris502 is just really nice
You can get around just fine at that height. What is the need for the lifting? Jut go burn up those tires then buy smaller ones.
Old 11-23-2008, 07:40 PM   #224
bmxbang's Avatar
it rubs like a mofo over every bump and i like having suspension travel lol. i like winters and not caring wether i hit a hole or bump in the road... it might stay at this height we will see.
Old 11-23-2008, 07:52 PM   #225
pansy
Old 11-23-2008, 08:10 PM   #226
i guess we know who the true minitruckers are in here lol.
Old 11-23-2008, 08:22 PM   #227
AKA DavidAndSomeNumbers
David12460's Avatar
David12460 is on a distinguished road
Screw it. All I did was snow tires and put my ZQ8s back on... Bring on the snow!
Old 11-24-2008, 04:13 PM   #228
bmxbang's Avatar
to tell you the truth... im getting tired of it
Page generated in 0.20193 seconds with 12 queries
