[Project] GreyScale - Shaved, Bagged, and V8'd 4-door 1st Gen
Old 01-09-2008, 11:55 PM   #401
SFBD 4 door
TrYiN2LaYaDiMe's Avatar
TrYiN2LaYaDiMe is on a distinguished road
Re: 4-Door Love project pics
where is that mdf tied into??? for the back support that is?
Old 01-10-2008, 03:17 AM   #402
Oaktown Trucks
Mystic_Knight's Avatar
Mystic_Knight is on a distinguished road
If you look closely at the pics you can see 4 bolts through the front of the notch. It doesn't seem like much but it's actually pretty strong. There's actually another piece of 3/4" MDF between the back of the seat and the front of the notch cover. That makes it about an inch and a half thick. The back of the seat is almost vertical so there won't be a ton of weight pressing against the back of the seat even if someone's sitting in it. Eventually there will be more once I start building the structure for the amps and sub.
Old 01-16-2008, 11:17 PM   #403
dailydragger7's Avatar
dailydragger7 is on a distinguished road
hey man do you by chance know if those rear crossmembers are the same distance from the axle in a 2 door 1st gen blazer. cuz i am wanting to do the same setup as you did and i am wanting to know if your measurements would be the same on a 2 door as well. thanks man
Old 01-16-2008, 11:41 PM   #404
Oaktown Trucks
I'm pretty sure a 2dr is slightly different. Not sure by how much off the top of my head. We put the custom crossmember close to where the stock one was. The new one just has a better surface to mount tabs to and the driveshaft tunnel is a lot taller.
Old 01-17-2008, 12:03 AM   #405
oh yeah they are different dramatically.lol. i just went outside in the snow and looked and measured and the crossmember(factory one) is like 10-15 inches from the axle and it half way up the slant part that heads up to the notch. i think i am going to order the same lengths as you and then just put the xmember where need be....hell minitrucking means custom not stock.lol. i dont know what i will actually do yet. i am trying to see if they will send it to me as an universal kit instead of a fixed kit
Old 01-17-2008, 12:13 AM   #406
Oaktown Trucks
I'd build the crossmember then take measurments. I'd hate to see you order the links then find out something could have been better. My 4-link takes up quite a bit of room but I have an extra 6" or so of truck to bury it under. I can name about a half dozen small things I wish we did a little different. Take your time figuring out your setup on your Blazer and you'll appreciate it later.
Old 01-17-2008, 12:14 AM   #407
SFBD 4 door
kyle leave doug alone damn it he needs to finish his interior!!!!! and needs to lay the paint down so it will actually be a grey scale.
hurry up dougie
Old 01-17-2008, 12:19 AM   #408
Oaktown Trucks
Haha. Paint probably won't happen till summer. As far as the interior goes, I'm making real good progress on the rear bench. Just have some small trim pieces to make. Unfortunatly I blew my intake manifold gasket on my 2nd gen today so that kind of side tracked the 1st gen work.
Old 01-17-2008, 12:22 AM   #409
SFBD 4 door
good luck with that i know it is gonna be a bitch. and u keep this slow as progress up and im gonna have to unsubscibe to this thread. lol ok i wont but it sounded good.
Old 01-17-2008, 12:40 AM   #410
Oaktown Trucks
I should have pics of the finished rear seat up this weekend. Maybe even tomorrow. Just want to finish the trim work so it doesn't look half assed.
Old 01-17-2008, 01:35 AM   #411
oh i am going to put the xmember in first its just i am looking at the options. i am asking sd right now if i can order that kit as an universal deal so i can build it to the measurements that i need when i get in there.
it is bagged right now but i want to redo it and do bags on bars cuz now it looks like someone just hacked it up and just threw it in there. ask steve he seen it......
Old 01-17-2008, 01:37 AM   #412
i also dont have to worry about the back seat cuz i aint keeping it... i am building a raised back floor in it with sheet metal when i get it all done so i have plenty of room to mess with
did you have to move some fuel lines out of the way when you put that new crossmember in cuz i saw that there is some there and i was wandering what you did with them.
Old 01-17-2008, 11:08 AM   #413
Oaktown Trucks
I just custom bent all new brake lines because the other ones were falling apart. Then the fuel line runs inside the framerail till it hits the custom crossmember. After that it goes over top the crossmember and runs along the side of the framerail on the inside.
Old 01-17-2008, 01:49 PM   #414
oh ok. i was just wandering. i was thinking that i was going to be doing the same thing
Old 01-17-2008, 06:57 PM   #415
SFBD 4 door
copy cat
Old 01-17-2008, 07:45 PM   #416
oh there is no copy catting on the way you have to run those line steve. you have to run the over the x member. dumbass
Old 01-17-2008, 07:49 PM   #417
SFBD 4 door
im talking about it all yo yo
Old 01-17-2008, 07:55 PM   #418
hey i aint coping it all i am doing some stuff that like came up with. lol
Old 01-17-2008, 10:00 PM   #419
Oaktown Trucks
Quote: Originally Posted by TrYiN2LaYaDiMe
where did you get this from im interested in doing this to my blazer but i wanna do a 98 center console and what not. just let me know what vechile year and make u got it from please
and ill be driving mine this weekend hopefully!!!
Old 01-18-2008, 12:37 AM   #420
Oaktown Trucks
Give me a half hour or so and I'll have pics of the new rear seat. Trust me, it's worth the wait...
Old 01-18-2008, 01:06 AM   #421
Oaktown Trucks
I've been working on this for a couple weeks now in my spare time. I was looking online and found a local auto parts place selling a set of seats from a Cadillac CTS-V. The back seat was about 3" too wide so I had to cut the foam down to make it fit. The frame that held everything together wouldn't work at all with the wheel tubs getting in the way. It took a TON of cutting and modifying to get it to fit right. I think they turned out good though. Super comfortable too. They sit a little high but there's not much I can do about that with the 4-link. I'll take it all apart this weekend and restretch the leather to get it to fit a little better. Then I'll get it all screwed into place.
The front seats are going to be a whole other challenge. Wish me luck...
Old 01-18-2008, 01:41 AM   #422
<3's EDM
jcrazyjj's Avatar
jcrazyjj is on a distinguished road
you should put tv screens in your headlights. lol.
but seriously that looks really nice doug. after you re-stretch out the leather, itll look top notch, nice work.
Old 01-18-2008, 01:54 AM   #423
Oaktown Trucks
Thanks man. No screen in the headlights... there's already one in the center console.
Old 01-18-2008, 02:20 AM   #424
this website is lame!
bmxbang's Avatar
bmxbang is an unknown quantity at this point
wow man that rear seat looks sick! im guessing you have the matching front ones also or no?
Old 01-18-2008, 10:01 AM   #425
Oaktown Trucks
Ya, I have the fronts too. They're going to be a lot of work to get them to fit right though. Don't expect anything real soon. I might just put them in there with the center console I have to take a pic and mock things up again.
Old 01-18-2008, 05:49 PM   #426
SFBD 4 door
looks good dougie! and ya they do sit high huh.. but hey at least ull have them in there
Old 01-19-2008, 01:18 AM   #427
Oaktown Trucks
Ya, I can probably take another inch out of the height if I want. I would just take a little more work. Right now you can sit on the center of the seat over the 4-link and it's actually kinda comfortable. If I took another inch off the padding it might be a little hard. Maybe I'll just roll with it this way for the summer and if people complain I'll work on it later.
Old 01-19-2008, 02:55 AM   #428
The Werk Truck
dawgnutz's Avatar
dawgnutz has a spectacular aura aboutdawgnutz has a spectacular aura about
That's sic man! I cant' wait to see the fronts!
Old 01-21-2008, 11:57 PM   #429
Oaktown Trucks
I tossed 1 of the fronts in to see how they fit. I also put the SRX center console I got in there. Keep in mind this is just thrown in. The stock seatbelts haven't even been removed. It gives you a good idea of what it'll look like though. 200% better and much more comfortable. SEXY
Old 01-22-2008, 12:15 AM   #430
bellcranks no more
greencactus3's Avatar
wow that looks tits
Old 01-22-2008, 12:21 AM   #431
SFBD 4 door
nice i like ur dual belt buckles lol. are you gonna make them function????? and they look huge in there.
Old 01-22-2008, 12:31 AM   #432
Oaktown Trucks
Factory buckles will be gone. B-pillar will be glassed to fill the belt notch. The seat will be bolted to the floor with grade-8 bolts and fender washers so the CTS-V belts are functional and safe. How much of the seat will function will depend on how I e
