#501 |
Re: [Project] GreyScale - Shaved, Bagged, and V8'd 4-door 1st Gen
just read all 10 pages... truck is sick man. ain't really into lowered blazers or 4 drs but you made er look good. good work
#502 |
It's all rattle canned
this thing is sick!
#503 |
Oaktown Trucks
As usual, things aren't going as fast as I'd like on the truck. I'm liking the way it's turning out though. I was working on it till about 11 tonight and got sick of sweating my ass off and being mosquito bate. Here's a few pics of what I'm doing though.
Here's what the setup looked like when I started And here's some of the work I've been doing to get the compressors and tank mounted between the framerails above the rear axle. This is the tank bracket I made that spans across the stock shock towers Here's the tank bracket installed You can see how it mounts to the shock tower here Here's the new slim 5 all plumbed and ready to go. |
#504 |
bellcranks no more
cool! and bench vice on the ground lol
#505 |
Oaktown Trucks
Ya, I got that for Christmas but haven't had the time to install it on the bench the way I should so for now it remains portable.
#506 |
Its that dam ADD!
Re: 4-Door Love project pics
#507 |
4DoorLove
sweet i finally found the thread lol i didnt relize you had it in you sig lol lots of good info thatll help me out when building mine soo how many bagged 4door first gens are in michigan lol and i was thinking about keeping my cpi v6 because everyones switching to v8s but reading this im gunna have to be on the lookout for a 350
#508 |
Oaktown Trucks
Cool man. Glad you found it. Hope some of the info helps out. It's been a big learning experience. I'm going to Havoc this weekend and I'll have some new pics of the rear air setup after I get back. The V8 is great but gas mileage sucks. I guess it just depends on how much you plan on driving it. I'll be puting over 1000 miles on it this weekend.
#509 |
4DoorLove
well geuss what i got me a 350!!!its in a s10 now hes running manafolds off some thing witch my dad was mad he just built a set of headers for his 89 blazer chassi and well i was wondering were you got your headers i cant seem to find them anywhere
also do you have any finished interior pics?? Last edited by dropped4doorblaze : 08-02-2008 at 01:24 AM. |
#510 |
Oaktown Trucks
The interior is far from finished. I'll be taking some pics next weekend probably. I still have a lot of little things to take care of on the air managment. Then some small things to look at on the engine, then I'm relocating the batteries to the back of the truck. THEN I'll be able to start on the interior.
#511 |
Oaktown Trucks
Seems things can never be easy. I got the ignition fixed with no problem. I threw the steering column back together though and it has a ton of slop. I can pull the wheel out about a 1/4" and the shaft drops right out of the bearings. No clue what's causing it. The hub is mounted all the way down on the steering shaft and the "c-clip" is reinstalled in the notch like it should be.
I spent some time fixing leaks on the tank. Still haven't had a chance to run the air line to the bags. I've sprayed the tank down with soapy water about a dozen times. I don't hear any leaks now or see any bubbles. Did a leak test last night with it up on jack stands. Pressure at 10pm Tank: 160 psi Bags: 100 psi Pressure at 6am the next morning: Tank: 100 psi Front Left: 60 psi Front Right: 40 psi Rear Left: 90 psi Rear Right: 70 psi Still a lot of room for improvment. The bag pressure was about what I expected since I haven't changed out the hose or checked the fittings at the bags. Before I reworked everything the front left bag would be completly aired out in the morning. I thought the tank pressure would be better after all the work I've done. No idea where I'm losing it from. |
#512 |
bellcranks no more
mmm leaks are annoying. sounds like you have them everywhere, with varying amounts lol
#513 |
Oaktown Trucks
Yup. All I can do is keep plugging away at them as I find them.
#514 |
Oaktown Trucks
Looks like the truck's going on hold for a couple months. Just got word they're shipping me to Karlsruhe, Germany for two months to work. I'm hitting a local cruise this weekend and MAYBE Dropt N Destroyed on one of my trips home. We'll see how I feel when I get back. Sucks that I have to miss 2 months of good truck working weather but I can't pass up this chance to hit Germany, get some OT pay, drink beer on the job, and drive on the Autobahn.
#515 |
bellcranks no more
hey shit yea germany would be awesome!
#516 |
SFBD 4 door
Location: Columbia, Tenakey Location: Tupelo, Ms User is: OffLine ![]() |
good luck bro and return home safe alot of shit is happening over sea's u never know whats gonna happen.
#517 |
Oaktown Trucks
Thanks though. |
#518 |
SFBD 4 door
there is alway wars in them countries over there that msnbc and cnn dont report on lol. |
#519 |
The Werk Truck
Location: Huntington Beach, Ca. User is: OffLine ![]() ![]() |
LOL! Right on man! Go Do tha Damn Thang!! The Blaze'll be here when you get back!
#520 |
Oaktown Trucks
Someone asked me about how difficult it was to do my LEDs so I figured I'd post my answer here in case anyone else was interested.
Tail light fillers take a lot of time to put in on their own. If you want them to look right you can't just weld them in and slap some body filler on them. You can see in the pic below how the top of the filler had to be cut in small sections so I could be bent to match the body line. Then all those slots have to be welded shut and the welds have to be ground down. Once they're installed the slots have to be carefully cut into the fillers and studs need to be welded to the inside of the fillers for the led buckets to mount to. After that's done the lenses have to be epoxyed in place then sanded down to the same level as the body. After that you have to do all the body work that's normally associated with shaving anything. Thanks to Pooch and everyone else that helped make these look right. I think it's the last set of tail light fillers he'll ever do. The tail light fillers and leds are Custom Classic items purchased from Street Issue Customs. Thanks again to Doug at SIC for the great customer service and Mike at Custom Classic for building the custom buckets.![]() ![]() ![]() ![]() ![]() ![]() Last edited by Mystic_Knight : 09-05-2008 at 07:12 PM. |
#521 |
Oaktown Trucks
So, I was just told the trip to Germany for work was canceled. They may be sending me to Austria for 2 months the first week of October though. Should find out next week. Before I go, I'm taking the truck to a show up near Flint this weekend and then to the Dropt Out show on the 27th and 28th. Then it'll probably be put away for the winter since I probably won't be back till Thanksgiving.
As far as the truck goes, The air setup is complete now. All under the truck, all run with Parker push-lok fittings and grey hose (had to match the trucks theme ). I love that stuff. Super flexible and it seals great. I aired it up to 120 psi and checked it the following night and the gauge hadn't moved. ![]() I'll try to get some pics up before this weekend. http://www.airridefittings.com/store...x&cPath=71_130 http://www.airridefittings.com/store...ndex&cPath=129 Last edited by Mystic_Knight : 09-10-2008 at 01:00 PM. |
#522 |
The Werk Truck
That stuf sounds pretty cool! You have any pictures of the fittings and all the stuff under the truck? Does it look like shop Air hose? What is the price? Per Foot or for so many feet?
#523 |
Finally Bagged
Nice Doug! Glad to see this thing getting closer to completion. I need to catch up with all you oaktown guys sometime soon. I've been so buys I haven't even been on the forum hardly at all.
#524 |
Oaktown Trucks
Ya man. Some of us are heading up to a show in Owosso this Sunday if you're interested. The details are on our forum.
#525 |
Finally Bagged
#526 |
Life Begins @ Zero PSI
Sweet rims, are they Boyd's like mine?
#527 |
<3's EDM
![]() god how i miss that garage. |
#528 |
Oaktown Trucks
Ok, maybe not. ![]() |
#529 |
fresha' than a mafucka'
all the trucks in oaktown are sick. i wish i wish in oaktown! haha
#530 |
Oaktown Trucks
Haha. Thanks man. It's all a scam. We're just good at taking pics and photoshopping.
