[Project] Clean Start - Page 6 - S-10 Forum
Old 07-14-2012, 08:04 PM   #251
Girl with wrenches
roademon's Avatar
Re: [Project] Clean Start
I miss my Z
Old 07-14-2012, 09:07 PM   #252
Lifted Moderator
Sonomanclature's Avatar
Yes, Yes you do.
Old 07-14-2012, 10:03 PM   #253
Girl with wrenches
roademon's Avatar
I can beat on the dodge like I did the Z. It's still too shiney and pretty.
Old 07-17-2012, 01:44 AM   #254
Lifted Moderator
Once upon a time ago I said " I hate toppers, and will never have another one".........
Then Craigslist happened
Old 07-17-2012, 10:39 AM   #255
Electrical Mod
deathphoenix99's Avatar
It's okay. At least that one doesn't look too bad. I hate toppers but I had to have one in college since I have a lot of crap.
Old 07-17-2012, 12:46 PM   #256
y'all suck dicks
badmofo529's Avatar
it would look better if it was the kind without the bump. it looks pretty good on there though
Old 07-17-2012, 02:22 PM   #257
Lifted Moderator
some day light pics, leveled out the ass end.
these wholes are on both sides, from Antenna mounts for a CB:
an then the 7 holes on the leading edge of the roof.
There are some other chips and what not in it, but over all its still in good condition. Unsure about keeping the rack and lights though, I like them but they are so obtrusive. If i could find a way to replace them with slim LED's to light a campsite or what not that would be nice.
Old 07-17-2012, 02:33 PM   #258
95s10rmtrooper's Avatar
Looks damn good
Old 07-17-2012, 03:18 PM   #259
Electrical Mod
I like the lights on there and the cage. Not the prettiest stuff out there, but should be good in function. As long as you don't park in a garage or low clearance areas, it shouldn't be an issue.
Old 07-17-2012, 03:55 PM   #260
Slowly but eventually
98lowerednewproje's Avatar
We don't have to worry about him ripping the garage door off or ripping the roof rack off. They cant park in the garage cause its full of stuff, lol.
Old 07-17-2012, 04:37 PM   #261
y'all suck dicks
badmofo529's Avatar
i like the rack and the lights
Old 07-17-2012, 07:57 PM   #262
Girl with wrenches
roademon's Avatar
I think it's time to design a rear bumper to match the front.
Old 07-17-2012, 10:27 PM   #263
Lifted Moderator
funny almost clipped the Mailbox house today, but i glanced in my mirror at just the right moment. . who puts a 24" overhang on a building that is 3 ft wide?
Old 07-17-2012, 10:28 PM   #264
Lifted Moderator
soonish
Old 07-17-2012, 10:28 PM   #265
Lifted Moderator
also siliconed all the holes up, so wait to test how water tight it is.
Old 07-17-2012, 11:00 PM   #266
Lifted Moderator
tight fit
Old 07-18-2012, 10:01 PM   #267
Molon Labe
Stewzer55's Avatar
Nice score!
Old 07-18-2012, 11:21 PM   #268
Lifted Moderator
Magnet tested the front diff, Thinking it was Iron because it has all the right stuff ( 5speed 4.3l) Turns out it isn't. Now I feel less unsure about swapping in a 3.73 diff. hopefully i can find one that isn't beat to shit, then a matching rear. found a guy locally that is SAS his blazer and selling the front and rear diffs( 98 blazer) I may get a hold of him and see if he would toss in the spindles and brakes. The rear is disc so would be nice to have DP calipers up front too. 150 each for those, might be able to swing it this coming paycheck.
Haven't decided if I'm going to keep the lights on the topper either, but i did hook the side ones up for shits and giggles ( also have an H§ LED bulb coming to try out).
Doesn't really light up a large area, if i do keep them im going to swap them ou tfor some wide angle work lights.
Old 07-21-2012, 10:38 PM   #269
Lifted Moderator
Reworked the wiring in the bed today, and flushed my coolant as well as lowered the Spar back down.
Pic from the rear, it's not the prettiest wireing but for the space it will do. The black box, now houses the Relays as well as acting as a power distro center.
Pin switch for the Interior light when i get one to put in .
Clap on
Clap off
Old 07-21-2012, 11:26 PM   #270
I take it I had a good idea then......cause you stole mine. That even looks like the same size black box that I bought.
Wiring looks as good as just about anything the toppers manufacturer would have done if they had wired it.
Old 07-21-2012, 11:44 PM   #271
Lifted Moderator
Your's is alot fancier than mine, I don't have a board with everything layed out neatly, couldn't do it because my relays are too tall. so its just a place to hold everything to make it look neater. this way there are 2 wires comming into the topper, a Main power and a 3-16 coated wire for the switch power. everything else is in the box.
edit this box is 8x4x3 or something like that
Old 07-22-2012, 12:25 AM   #272
Lol, yeah, its the same size box, a 8X5X3. I agree, makes things alot easier and neater.
Old 07-23-2012, 12:52 AM   #273
Girl with wrenches
roademon's Avatar
Needs moar lights
Old 07-23-2012, 03:36 PM   #274
idk if i like the topper or not its proabbly one of those things that will grow on ya
Old 07-29-2012, 02:47 AM   #275
Lifted Moderator
Did this last weekend, but forgot to share.
Moved my 110V outlets from here
To here
Also removed one for space sake.
Old 07-29-2012, 03:17 AM   #276
Nice. And now I don't feel so bad, your carpet is as dirty or dirtier than mine.
Old 07-29-2012, 10:36 PM   #277
Lifted Moderator
for the time being, i havent vacuumed the truck out on almost 3 weeks.
Old 07-30-2012, 08:46 PM   #278
Molon Labe
Stewzer55's Avatar
Sean, have you considered going to a PVC or rubber floor?
Old 07-31-2012, 02:25 AM   #279
Lifted Moderator
Negative , I like the look and feel of the carpet more. vynal and or rubber jsut ahs a cheap look an feeling to it.
Old 08-06-2012, 10:30 PM   #280
Lifted Moderator
AD244, verry tight fit on TBI with stock air cleaner housing
Old 08-08-2012, 04:06 AM   #281
whitelowereddime's Avatar
same belt?
Old 08-08-2012, 04:19 AM   #282
Lifted Moderator
yea i am useing my stock belt, but its stretched a bit. I'm going to replace it next month .
Old 08-08-2012, 04:23 AM   #283
can i get the exact part number you used for the ad244? no one at the parts store knows what a ad244 is here
Old 08-08-2012, 02:23 PM   #284
Lifted Moderator
8237 is the number on mine, just checked with autozones website and it came up with a few.
Old 08-08-2012, 02:36 PM   #285
Lifted Moderator
just got these from the brown truck, Thanks to Jaewolf
Old 08-08-2012, 09:48 PM   #286
Lifted Moderator
after some work
Old 08-09-2012, 03:07 AM   #287
racetruck?
Old 08-09-2012, 03:14 AM   #288
thanks
Old 08-10-2012, 12:05 AM   #289
Lifted Moderator
got my new steering box in today, as well as the control arms. going to rough align it tomorrow, to hold over until I can hit up a good alignment shop.
no pic of the steering gear, but you all should know what one looks like.
Old 08-10-2012, 09:04 PM   #290
Lifted Moderator
I need to find some Z bars, my drivers is pretty well toast. Thes are with the driver side maxed. the BJ angles are pretty good. I have about 3-4 turns left on the passanger side.
balljoint angle.
Old 08-19-2012, 06:28 PM   #291
Lifted Moderator
The girl and I just got back from our weekend camping trip. had a few nice little drives while we were out. Stayed in Leadville Friday and Saturday nights, spent the day saturday driving over Hagerman Pass. not a challenging drive, but fun.
Eisenhower tunnel, took us 2 hrs to get to this point from Denver, someone put their Rig in the ditch on the other side.
View from atop the stone near our site.
Tent is in the middle of the pic.
A few from the drive up the Pass.
At the Continental Divide atop the pass.
And down the other side.
Then we drove to Basalt, and through to Aspen, then Over Independence pass( fun corners on that one).
Part of Independence Pass
Got back to our site around 8pm, got a fire going and ate dinner.
packed all our things today, then headed home. Stopped at Lookout Mountain along the way.
Random Hitchhiker we picked up
Over all we covered 477 miles, used 26 Gallons of Fuel, covered altitudes ranging from 6k -11,925 ft. Averaging 18.9MPG.
and Not one mechanical issue the whole time.
Old 08-19-2012, 07:08 PM   #292
mattmac2007's Avatar
looks like a lot of fun
Old 08-19-2012, 07:09 PM   #293
Lifted Moderator
It was enjoyable.
Old 08-19-2012, 07:37 PM   #294
Girl with wrenches
roademon's Avatar
Sweet dog!
Old 08-19-2012, 11:08 PM   #295
Lifted Moderator
Sweet dog!
yea, want to come bathe him now?
one thing I did notice, is I need a Solid drivers motor mount. the one I installed in march is already toast.
Old 08-20-2012, 12:04 AM   #296
Girl with wrenches
roademon's Avatar
Haha no I'll let you bathe him
Just weld that motor mount up and it will never be an issue again
Old 08-21-2012, 08:39 PM   #297
1low4x4's Avatar
So how do u like your zq8 box in comparison with your old 4x4 one?
Can u link me to where u got yours?
I guess I was wrong about buying them locally. I went to go get one, even though all the parts stores claim to have them, they dont. At least not in Utah...
Old 08-22-2012, 03:28 AM   #298
Lifted Moderator
the one i bought was a Delco unit, got it from RA, but they dont have it listed at the moment , it was for an 86 Mionte with RPO F41.
Old 08-22-2012, 03:37 AM   #299
Lifted Moderator
part number 360516561
Old 08-22-2012, 04:13 AM   #300
1low4x4's Avatar
Oh yes you allready told me once it's not A zq8 durrr.
Cool thanks for the part #
