Project: Cab Over
Old 09-06-2009, 12:10 AM   #301
Draggin Moderator
98layinframe's Avatar
Re: Project: Cab Over
undercoating on the inside of a switch box!?! why not just tape the connections or use shielded connectors on the switches? seems alot less messy and simple.
Old 09-06-2009, 12:49 AM   #302
Startin' From Scratch
PowerDown's Avatar
or they do have "spray on electrical tape" less thick than undercoating.
Old 09-06-2009, 01:14 AM   #303
Hoods are overrated
sadexcuse4s10's Avatar
most of the time you have to use ring terminals on your wires with little screws in the middle to snug them to the switch.
kind of hard to shield a ring terminal with a screw in the middle when the screw head has live power also.
I think when i hit the switches hard a few times i loosened the little nuts that held the switches in their holes i drilled then it was spark time inside the box. i just sprayed the inside of my can switchbox with undercoating then put all the shit back in after it shorted out one time. it's not like undercoating is super thick.
Old 09-06-2009, 11:50 AM   #304
Draggin Moderator
heat shrink tubing.
Old 09-06-2009, 04:40 PM   #305
Hoods are overrated
heat shrink tubing is for soldered connections.
how are you gonna heat shrink a ring terminal after you screw it to the back of the switch. the ring terminal is a crimp connector anyways
Old 09-08-2009, 09:33 AM   #306
Easy, you shrink tube it up as far as possible on the wire, then shring tube over the entire back of the toggle.
Old 09-08-2009, 10:47 AM   #307
PowerDown's Avatar
thats true and the best way, but if he just wants to coat the inside of the can so if the connectors get loose they wont short then heat shrink wont work.
Old 10-03-2009, 10:06 PM   #308
square bodies ftw
cruisinlows10's Avatar
Got the firewall skin done.
Old 10-03-2009, 10:06 PM   #309
square bodies ftw
along with the passenger side vent (minus a little spot putty)
Old 10-03-2009, 10:08 PM   #310
square bodies ftw
Paint stripped most of the hood
just a shot looking in from the center back glass
Old 10-03-2009, 10:27 PM   #311
Drag-N-Fly Customs
sonomaguy's Avatar
Wow, she's looking really good with all the repairs.
Old 10-04-2009, 12:03 AM   #312
eats "rice"
94sdime350's Avatar
Wow man. The whole reason I bought my s10 was because I have a 1949 chevy 1ton panel. "AD" truck. My plan is to stretch my regular cab dime chassis and swap it for the old panel stuff. While Im doing the body on the panel , I am having some fun w my V8 dime. PM me if you wanna swap any info. I got tons of information and sources on a build like this.
Old 10-04-2009, 11:35 AM   #313
Drag-N-Fly Customs
sonomaguy's Avatar
I saw on the net the other day someone who made kits to put the older chevy trucks onto s-10 frames. Thought the link was on here but don't remember now.
Old 10-04-2009, 09:54 PM   #314
square bodies ftw
Yeah there are a couple companies out there that make kits to put the regular trucks on to s10 frames. However my truck is a whole other animal. It shares none of the regular truck mounts.
Old 10-10-2009, 01:34 AM   #315
Registered Pimp
x98zq8x's Avatar
This is such a cool thread you have good taste in badass trucks!
Old 10-11-2009, 08:39 PM   #316
square bodies ftw
Thanks. Its about to get more badass. Lookie what the UPS man left on my porch while i was out of town. I just got home tonight and found it.
Old 10-11-2009, 08:40 PM   #317
square bodies ftw
Old 10-11-2009, 08:48 PM   #318
Innis's Avatar
damn if woulda known that was on your porch i woulda tried to find your house haha
Old 10-11-2009, 08:58 PM   #319
Registered Pimp
x98zq8x's Avatar
Nice shopping cart!
Old 10-11-2009, 09:15 PM   #320
Knowledge is power.
s10pimpin209's Avatar
that cart is slammed . nice
Old 10-11-2009, 09:31 PM   #321
Registered Pimp
x98zq8x's Avatar
I didnt notice haha even better
Old 10-11-2009, 10:27 PM   #322
square bodies ftw
ahh the shopping cart. its primary use is as a mobile parts bin around the shop.
Old 10-24-2009, 10:12 PM   #323
square bodies ftw
here goes possibly my favorite update so far
We temporarily re-assembled the fenders, steps, inner fenders, and all the supporting bracketry. We did this to figure out how we are going to fit a radiator and to test how the supporting bracketry worked with the s-10 frame.
Old 10-24-2009, 10:13 PM   #324
square bodies ftw
Old 10-26-2009, 09:38 PM   #325
square bodies ftw
no pictures of it, however, the suicidedoors gas tank cross member is now permanently in place of the stock one
Old 10-26-2009, 09:51 PM   #326
sosolos10's Avatar
what size WV motor is that
Old 10-26-2009, 11:04 PM   #327
square bodies ftw
Pretty sure its a stock vw motor. Id have to ask my dad.
Old 10-31-2009, 05:15 AM   #328
no hackjobs here
sadistic2.2's Avatar
looking good charlie keep it up bro that thing better be ready when i get back i want to take a ride in it
Old 11-11-2009, 12:12 AM   #329
square bodies ftw
Thanks Brian. I hope you are doing well. We miss you.
Old 11-29-2009, 04:53 PM   #330
square bodies ftw
Grille shell mounted up front (the chrome bars are detached so they dont get dinged up) Regular truck front bumper in process of being mounted. We had to heat and bend the bumper brackets as well as notch the bolt holes but it is ready to go on. It only needs 4 bolt holes drilled in the truck frame.
Old 11-29-2009, 04:54 PM   #331
square bodies ftw
suicidedoors cross member installed
Old 11-29-2009, 04:56 PM   #332
square bodies ftw
The bed is semi mounted. The rear mount has been made. We are in the process of making front mounts for it. The fender on it is junk and is just there for mock up. It also will be mounted lower on the bedside.
Old 11-29-2009, 04:59 PM   #333
square bodies ftw
Progress made on dads '52. Passenger door back on and the hood back on. It needs a wiring harness, gauges mounted,seats mounted, door weather stripping and it will be ready to go down the road.
Old 11-29-2009, 05:01 PM   #334
square bodies ftw
a couple of bugs in the driveway too.
Dads baja bug with my daily in the background
Old 11-29-2009, 05:03 PM   #335
square bodies ftw
Erins bug (one of my car club members)
Old 11-29-2009, 05:04 PM   #336
square bodies ftw
Old 11-30-2009, 04:29 AM   #337
Get some
Dvst8r's Avatar
Thata nice canti setup you got there. We just put the bolt on version on my buddies truck this past weekend.
http://www.s10forum.com/forum/f125/p...65/index2.html
Old 11-30-2009, 11:30 PM   #338
square bodies ftw
Looks good on that truck After I get this bed mounted I can start getting mine welded in.
Old 12-25-2009, 09:56 PM   #339
square bodies ftw
Drivers door sand blasted. It needs a little repair but its in really good shape compared to what the passenger door started as.
Old 12-25-2009, 09:58 PM   #340
square bodies ftw
Center strip removed from the hood. It's actually made up of two parts. The outside part was shot. I am modifying a strip from a stock truck hood to work. We removed the inner section of the one for my hood and saved it, and took the outer section from a stock truck hood to be modified.
Old 12-25-2009, 10:00 PM   #341
square bodies ftw
New front panel in the bed.
Forward bed mounts are modified 78 corvette front bumper brackets
Old 12-25-2009, 10:03 PM   #342
square bodies ftw
Using one of the stock s10 mounts for a mid-mount for the bed. Both the front and mid mount use a stock cross sill.
We made a new frame for the floor out of angle steel
Old 12-25-2009, 10:05 PM   #343
square bodies ftw
The rusty piece here is the stock radiator housing. The front sheet metal all bolts to it. It has been modified to work. The radiator will have to go more forward.
Old 12-25-2009, 10:06 PM   #344
square bodies ftw
Got the forward cab mounts bolted down permanently.
Old 12-25-2009, 11:18 PM   #345
Drag-N-Fly Customs
sonomaguy's Avatar
Looks like lots of fab work but coming along nicely.
Old 12-26-2009, 10:52 AM   #346
I Like Fire....HaHaHa
JACKEL's Avatar
And crimp connections are the worst.
Here is a tip. Pull the plastic piece off the ring terminal. Melt some flux in its basin and dip the wire connection hole into the flux. Unsheath the wire insulation. Slip in heatshrink onto the wire. Slip the wire into the hole on the ring terminal. Heat the terminal with the solder iron and feed in solder (as if you were tig welding with solder). Let it cool, then snug the heat shrink over the solder connection and but the shrink up to the ring terminal then shrink it. The result is a soldered insulated connection with ONLY the ring terminal exposed. Extremely professional looking when complete and 100 million times more reliable than a crimp.
Old 01-02-2010, 05:11 PM   #347
sosolos10's Avatar
Hey man What part of Va are you located
Old 01-03-2010, 10:17 PM   #348
square bodies ftw
Im about an hour south of Roanoke, why?
Ive been busy, will have new pictures tomorrow.
Old 01-03-2010, 10:25 PM   #349
sosolos10's Avatar
I live in Romney WV Its east of Winchester VA i think ive seen that two tone VW at a car show up this way
Old 01-05-2010, 01:10 AM   #350
square bodies ftw
Doubtful, she just got it from tennesse a month or two ago.
I am smack in the middle of converting the rear to disc brakes.
