Project 83
Old 08-01-2008, 11:07 AM   #151
Truck #121616
Golana's Avatar
Golana has a little shameless behaviour in the past
Re: Project 83
Quote: Originally Posted by Onimun
Hey fair enough. In most cases however V8's get better Millage then 4.3's. Something to think about.
my 4.3 gets better milage than most v8's :P
i average about 26mpg city/highway mixed. driving from bc to alberta with the wind on my back, i got 37.5mpg once. hahaa, ill probably never get driving conditions like that again though :P
Old 08-02-2008, 12:20 AM   #152
Truck #121616
Golana's Avatar
Re: Project 83
i bought some supplies today, and started messing around with making my own halos. i got one that's perfect, but i cant seem to get the light to go to the top... maybe a less wide angle LED would do the job?
pics:
Here is a close-up of my home-made halo! looks good, except i cant get the light to get to the top...
here is a further away view of it. these will look sweet on something... i wanna find a way to incorporate them into my 83 somehow... maybe on the driving lights or fog lights...
what do you guys think?
Old 08-02-2008, 01:00 AM   #153
Truck #121616
Golana's Avatar
Re: Project 83
i wrapped the back of the halo with my aluminum tape to try and reflect more light to the top. it definately cleaned up the base where the LED's are! and i think i even got some light to go to the tip
check it out! better lighting and a bit more light distribution, all from a bit of aluminum tape.
Old 08-02-2008, 01:36 AM   #154
Truck #121616
Golana's Avatar
Re: Project 83
how about some white? its not half as bright as the blue... still looks cool though
Old 08-02-2008, 02:48 PM   #155
Truck #121616
Golana's Avatar
Re: Project 83
i tried spreading out the notches in the tubing, and it didnt really help...
this is with the notches skipping every second cut. doesnt look even half as good... oh well. im still trying to get things perfect...
here's a close-up. the fewer notches dont help with the light dispersal... dont know if its the material im using now or what... oh well...
here's the twins. i made the second good one this morning. woke up at 8:00, and i couldnt do anything until 9:30 when everyone was awake hahaa! waiting for time to go by sucks!
these look alot better than the half-notched one. i still cant figure out how to get the light to the top... the aluminum tape helps alot though, but its still not bright enough... im contemplating making another one, cutting it in half, and putting 4 LED's into the ring... we'll see how that works out.
Old 08-02-2008, 05:14 PM   #156
Truck #121616
Golana's Avatar
Re: Project 83
cut the 2 good ones in half and stuck another 2 LED's in them. i noticed on the one, its not a perfect circle... damnit
mounted on one of the projectors from my headlight that broke
daylight shot. this is the weird shaped halo...
top halo is the perfect one. i gotta fix the bottom one, or make a new one or something...
i think they look good now
Old 08-03-2008, 10:05 PM   #157
Truck #121616
Golana's Avatar
Re: Project 83
i was going crazy just sitting inside the house doing little shit, so i decided to go out and 'exercise my back, and keep moving' by working on my truck.
i did a bunch of stuff to the back end of the truck, fighting cob webs and spiders every step of the way!
i dont know who thought it would be a good idea to weld the bottom bolt that holds the leaf springs together, but it pissed me off when i couldnt unbolt it.
count em... yea, thats right... 5 freaking loaf springs! plus this thing had coilovers! wtf man... must have rode super stiff in the back...
the rubber here is pretty cracked... good thing im not using the leafs for much longer...
this thing is filthy inside... needs a bath or something... might just salvage what i can and grab another rear end at pick n pull. i dont even know what gearing this thing has...
my angle grinder made short work of the welded on bolt.
only thing is i need to find another bolt to put in there so the block doesnt slide around...
got a bit carried away on the driver's side... its very light though... shouldnt hurt too much...
sweet! mono-leaf!
i couldnt get the u-bolts on the driver's side loose, so i cut them off. im using 1 u-bolt per side right now. its not like im putting any weight on it anyways (not putting the tires on and lowering until the bumpstops are chopped)
as she sits right now. i like how an in-progress truck looks
still gotta put on my roll-pan. i got some plans before i do that though...
plans for tomorrow:
cut off bumpstops
detach ebrake cables from the drums
maybe start to notch the firewall and fenders for the front tires...
Old 08-04-2008, 03:58 PM   #158
Truck #121616
Golana's Avatar
Re: Project 83
well, i was workin a bit this morning. i got the ebrake cables out, and started to work on cutting the bumpstops off, and my only cut-off disk grenaded. and today, being a holiday, i cant go out and get some more... damn...
this is as far as i got cutting the bumpstops off today.
KABOOM! the thing caught an edge where i was grinding, and blew up
Old 08-04-2008, 04:17 PM   #159
It's name is Hamster.
TheFue's Avatar
TheFue is on a distinguished road
Re: Project 83
That happened here at Wyotech, but the disc took out some kid's nads.
Sent him to the hospital and he lost that ball, watch yourself man...
Old 08-04-2008, 04:20 PM   #160
Truck #121616
Golana's Avatar
Re: Project 83
ill be sure to put on a cup next time... thats freaky man...
Old 08-04-2008, 04:28 PM   #161
The Werk Truck
dawgnutz's Avatar
dawgnutz has a spectacular aura aboutdawgnutz has a spectacular aura about
Re: Project 83
I got 9 stitches. 3 undr the skin, and 6 on the top of my right knee a few years ago when I was grinding the welds on my notch. I was using a 7in fiber disc with a 4in backing plate (D'oh!). Nice little scar. Be careful bro!
Old 08-04-2008, 04:47 PM   #162
Truck #121616
Golana's Avatar
Re: Project 83
wow, thats scary... this is the first time ive ever had a disc blow up. the pieces just hit the top of the inner fender and bounced around. i had to move me leg out of the way because the sparks were hitting my leg and burning though my pants hahaa
Old 08-04-2008, 11:41 PM   #163
Ex-Import Lover
Nate_C is on a distinguished road
Re: Project 83
i cant look at your truck
because it gets me sexually excited.
Old 08-05-2008, 05:28 PM   #164
Truck #121616
Golana's Avatar
Re: Project 83
went out and got some more cut-off discs, and went at it again.
cut the pass side bump stop off! came off easy as pie. i had to cut it a different way then what the tutorial i looked at showed *shakes fist*
what i did was cut just before the welds on the bumpstop, then pried it off, then ground the welds off, then grinded it down smooth.
dirty and just starting to rust underneath. glad i did this.
nice and smooooooooth... well, not as smooth as it could have been, but the thing was loud, and i didnt want to bug the neighbors as much as i had already...
undershot of the smoothness
painted up so it doesnt rust.
backed up view. i like how the frame contours without the stupid bumpstops
driver's side before
see the white line on the finger? the disc caught an edge and jerked the grinder out of my hands, and the disc ran up my finger. if i wasnt wearing my welding gloves, i would have probably lost a finger! these things are hella scary!
this is as far as i got before that disc caught and ran up my glove.
it only blew a little chunk out, so it wasnt too bad. i just grind on some fresh metal lightly till the wear is all even again.
i dont want to have to do this for a long long time... or maybe next time, ill get a torch or something... cut-off discs scare me!
noticed this after i put my gloves back on... the thing bit BOTH my fingers!
another one bites the dust hahaa!
here's part of the disc. when i was grinding, it caught and EXPLODED! very violently! i pried at that piece, and found that inside hahaa!
here is the frame all smoothed up. this side was a pain in the ass! it killed 2 discs and i had to run to the store to buy another to finish it up.
underside view of the smoothed frame. i was kinda worried about the sparks shooting at the gas tank... i guess there's no leaks hahaa
didnt notice this till i got inside. the disc cut through the glove and into my finger. what kinda grosses me out is the cut is the same width as the disc... i could take the disc and it would fit inside the cut hahaa
thats all for now folks! i need some u-bolts so i can set the bitch back on the ground before we go on vacation!
Old 08-05-2008, 06:06 PM   #165
V8 with bags
V8Blaze's Avatar
V8Blaze is on a distinguished road
Re: Project 83
you need to buy different disks. I cut off both bumpstops with the same disk on my blazer, then cut both notches with teh same disk too. either they are cheap or your putting waaaaaayy to much rpessure on them or something. but progress is progress man, keep it up
Old 08-05-2008, 06:12 PM   #166
Truck #121616
Golana's Avatar
Re: Project 83
im letting the disk do all the work... i make light passes with it until the metal is cut through hahaa
and they are dewalt discs.... dont know if i got a few defective ones or what...
how did you cut both bumpstops AND both notches with the same disc?!
i used 1 disc for both my LCA's though... might be just too many weird andles on the bumpstops for me...
Old 08-06-2008, 05:36 AM   #167
The Werk Truck
dawgnutz's Avatar
Re: Project 83
progress is cool! exploding discs, Eh..............Not so much! LOL!
Old 08-12-2008, 12:39 AM   #168
Truck #121616
Golana's Avatar
Re: Project 83
well, im back from my trip had alot of fun! hahaa
i took 322 pictures of everything there! went up to PEI and ate a pacific 1lb lobster! 1st lobster i ever ate. the lobster, plus an all you can eat buffet was 34 bucks!
anyways, got home today, and before we left calgary, i went to UPS and grabbed my bags! so stoked! these things are HUGE! i honestly didnt expect any of this stuff to be this big...
i might post some pictures from my trip, but they are all big, and i have to resize them, and there are LOTS! so i might just post a couple hahaa
im wicked tired right now, so im probably gunna go to sleep, and hit 'er hard tomorrow! get some hardware and get the spring pockets cut out for the bags.
do balljoint castle nuts come with new balljoints? or can i buy them separately? when i got my truck, it only had the castle nuts on the passenger side... driver's side was just snugged down pretty good...
Old 08-12-2008, 01:28 AM   #169
kaczarollision's Avatar
kaczarollision can only hope to improve
Re: Project 83
looks good. new ball joints should come with castle nuts.
Old 08-12-2008, 01:37 AM   #170
Truck #121616
Golana's Avatar
Re: Project 83
good, cause i cooked the balljoints in the arms when i welded the plates on them hahaa! (they were smoking, not sure if they are good or not anymore) ill probably get a couple castle nuts for now, and see if i can get away with the balljoints in the arms...
Old 08-13-2008, 12:21 AM   #171
Truck #121616
Golana's Avatar
Re: Project 83
45 bucks later, i have my bag mounting hardware, and 4 u-bolts.
now i can get the truck's ass back on the ground, and tear the front apart to fit the bags.
Old 08-13-2008, 07:47 AM   #172
Drifting Nomad
Outlawz24's Avatar
Outlawz24 is on a distinguished road
Re: Project 83
At least the one upside with this truck is since it isnt in a rush to be completed you can take your time and maybe have it bagged all the way around by the time you get an engine in it.
Old 08-14-2008, 01:03 AM   #173
Truck #121616
Golana's Avatar
Re: Project 83
today, i got a whole bunch o shit done!
i swapped wheels between Blue Bitch and 83 (so B.B. has the z28 rims)
i insured Blue Bitch!
i ran all the crap and garbage from 83 (and random house stuff too) to the dump! 9/25 worth of scrap hahaa! there was so much shit in the back of B.B. that she was tucking tire haha!
then i went to the car wash and washed her! she was pretty filthy...
hmmm... well, i guess thats all i did today hahaa! but it took me all day to do...
remember this picture?
i fitted the bag cup, and it would not lay flat with it like that. i used my torch and a couple pry-bars, a hammer, and my vice grips to get that damn tab straight again. i might have to chop that tab off when i get the airlines ran cause i think its right in the way of the bag cup hole...
on a shitty side-note, my tv is starting to die, so im gunna have to save up for a new one. prolly gunna go 37 or 42" plasma or LCD, so my truck progress is going to be slowed.
i need to order the air tank and a couple compressors so i can start to play around with the bags i think im gunna have to trim my cups down so i can lay as much as i want to... cause i squished the bag as much as i could, and it was about 3" tall... im not gunna touch anything until i get the drop spindles and the bags working, that way i can see if i actually need to modify stuff...
no pictures of anything done today, i killed my batteries on the vacation, and havent purchased new ones yet hahaa! i might see if i can get some life out of them tomorrow and take a few pictures of the stuff set up.
Old 08-14-2008, 01:56 AM   #174
Truck #121616
Golana's Avatar
Re: Project 83
hmmm... i guess i did take pictures... i forgot hahaa!
ass end back on the ground. swapped wheels with blue bitch cause i like the stock look on a bagged truck.
you can see my custom made u-bolts installed. rides a little low hahaa! ive got some stuff in the box and no shocks, so right now its resting the u-bolts on the frame.
i like the looks of this. all really low to the ground. she's gunna get just a little bit lower than she is now!
now i really, REALLY like the looks of this! in progress baby!
about 2" all around from layin frame!
Old 08-15-2008, 01:23 AM   #175
Truck #121616
Golana's Avatar
Re: Project 83
was pricing out fittings today... holy shit they are expensive!
i talked to my uncle, and he and my bro can hook me up with all the fittings and valves i need. they work at a mech shop where they use air fittings for semi's and hydro/vacs and stuff like that. so their stuff is quality!
hopefully gunna have that stuff pretty soon. im sure they can even hook me up with an air tank! if not, ive got mine picked out at SD.
im not sure weather i should build my notch with rectangle tubing and fishplate the corners, or get the 8 piece notch...
Old 08-15-2008, 02:22 PM   #176
The Werk Truck
dawgnutz's Avatar
Thumbs up Re: Project 83
That's cool man! It always helps to have someone in key places! As far as the notch, I used a kit from Altered Image (way bak in the day) before they turned into CanDo Specialties. It came out great. What You really have to think about is, How much will they make youbuy, and how much the stick goes for.....? And after all the work does it make more sense to buy a kit with all the work already done......?
Old 08-15-2008, 02:32 PM   #177
Truck #121616
Golana's Avatar
Re: Project 83
i could probably buy enough that i need, or i could even get that through my uncle as well hahaa!
i can guarantee that i can build them cheaper than 100 bucks. the only thing is, it would be easier to install the 8 piece vs the rect. tubing... way easier, and i dont want to screw anything up...
Old 08-15-2008, 02:44 PM   #178
The Werk Truck
dawgnutz's Avatar
Re: Project 83
werd........sounds like you got the hookup for sure! LOL!
Old 08-17-2008, 04:59 AM   #179
Hardcore 1st Gen'r
jman's Avatar
jman
Re: Project 83
[quote=Golana;5497168]was pricing out fittings today... holy shit they are expensive!
[quote]
you sound like me not so long ago. i have about $370 in fittings. about $4K in my suspension setup so far and i still have to buy the 4-link quality parts add up quick. builds coming along nicely.
Old 08-30-2008, 05:41 AM   #180
