#101 |
Girl with wrenches
Re: Picking up "Project LS10"
you better get a dyno hp rating or run it in the 1/4 mile! I wanna know how good it rips!
#102 |
**5.3 Lover**
Let me know how you like that aeromotive pump i don't really know how much life i have left on my walbro.
#103 |
LS10
#104 |
LS10
Summit sent me some of the stuff I ordered:
#105 |
Killing Time
What did you use to polish those headers????
#106 |
Need LSx swap.....
![]() Age: 34
is that a M90 maggie?
#107 |
LS10
#108 |
LS10
#109 |
How does that 99-02 F-Body 4L60e dipstick fit?
#110 |
Girl with wrenches
can't the stock s10 dipstick be used?
#111 |
Killing Time
I thought you might have tried the cerma-glow ceramic coating polish...I'm thinking baot grabbing some...
#112 |
LS10
#113 |
LS10
#114 |
LS10
OK, I am back an in full force. We will have our house (second house) sold this Friday. This means I can start spending some money and time on this POS. lol I decided to ditch the supercharger and go NA for now but turbo later. Here is a few pics of me test fitting stuff again. Really need a wiring harness to start putting stuff back together.
I finally have room to run the stock F-body trans dip stick/tube. I also got some other things painted. ![]() ![]() ![]() Test fitting ![]() ![]()
#115 |
dam.. looks sweet.. wish i was keeping my truck and able to stuff like this..
#116 |
LS10
Did a bunch to the S-10 the past week. I ordered a wiring harness from Current Performance on Friday, can't wait for it to come in. I got all of the motor sensors in the motor, the passenger side iner-fender back in the truck with the coolant reservoir and ECU, installed a catch can w/new hoses, pulled the 4 cylinder ps pulley off (so I can install the dorman), and some other random stuff. Here are some pics but I doubt you can tell much from them.
#117 |
Fcuk Bourbon St.!!!
Location: State Capitol Raceway, Louisiana User is: OffLine |
^^^ On that catch can, I see you have the short hose coming off the port on the valley cover. But, where's that long hose going? I thought you were supposed to simply run it to an intake vacuum source.
#118 |
LS10
I had to do it like a LS1. I will post a pic of how I had to do it because I don't have a LS6 valley cover.
#119 |
Fcuk Bourbon St.!!!
Oh. I thought that short hose was going to the valley breather. It's going to an intake vacuum source, which makes sense. So, is it just that back left side of the motor that exhales oil? It seems to me you would "Y" both valve cover ports together, then run it into the catch can.
I have an LQ9 with an LS6 valley cover and a catch can, so I'm interested to know the hows and whys of your setup. |
#120 |
LS10
I agree with you 100% but this set-up seems to be a proven on several F-bodys on ls1tech. I will give this a shot and see how it does. I can always change it if it has problems. |
#121 |
Ls1 Bagged
I have mine set up the same way and have bout 500 miles and so far so good, it's catching oil.
#122 |
LS10
Did some small stuff on the truck today. I took the grinder to the bottom of the intake to make it smooth. This will allow the crossover tubes to fit under the intake without problems. I also took a pic of the hose I am using for the lower hose and the part number.
#123 |
LS10
Today I almost finished up the fuel system. I already installed the Aeromotive 340 Stealth so now it was time for the Corvette fuel filter and all the fittings. Everything went smooth and the filter is in but I still have to cut the steel braided line that I have running to the fuel rail.
#124 |
Ridin' on Twankies
I'm sure it will be fine as is, but are there any fittings made to adapt the stock line to accept the corvette fuel filter? or is the only way to use a section of hose, and clamps?
#125 |
LS10
I could have spent money on them but what you see is the return line. It doesn't have much pressure so it should be fine. Plus other guys are getting away with the return like that so Ill give it a shot.
Update coming soon... |
#126 |
LS10
Found a Upper radiator hose!!!! I also did some other small stuff that you may or may not be able to tell in the pics like heater hoses. Enjoy
#127 |
LS10
Put the front on her today, she looks happy.
#128 |
LS10
Just a pic of the engine bay. It's not 100%, still waiting on the wiring harness, V6 Throttle cable, windshield washer tank, ect.
#129 |
LS10
Picked up some spark plugs for the S10 and new wires to put on the truck tonight. I also hooked up all the vacuum hoses and bolted the intake down while I was out there.
Can anyone guess why I went with this plug? ![]() ![]() ![]() ![]() Hope tomorrow night I have enough time to install my trans cooler ![]()
#130 |
rollin on grown men
sick
#131 |
LS10
Thanks man!! I installed the trans cooler and lines tonight. I think it turned out nice. Here are some pics for your enjoyment. ![]() ![]()
#132 |
LS10
F-body LSD installed. I need to clean it up a little more, put the cover on and fill it full of oil.
#133 |
Looking good ! subbed for updates
#134 |
rollin on grown men
baller
#135 |
LS10
Look at what showed up today
![]() And it is all labeled!!
#136 |
Nice!
What did you run for a water pump? LS1 F-body with 3/4" spacers? |
#137 |
LS10
Yep
#138 |
Ridin' on Twankies
if you don't mind me asking, what did that harness cost?
I assume its a direct plug and play for the factory main fusebox and truck wiring? |
#139 |
keep up the awesome work..loving how the truck is turning out
#140 |
LS10
$850. If you pay 100% upfront it's free shipping but if you do half now and half later you pay for shipping.
#141 |
LS10
OK, I went to swap the manual shifter shaft on the 4L60E because I had the short shaft (ha ha) not the long shaft needed for the PN safety switch. While I was in there I put a new filter on too. Anyway got that done and over with. It was a dirty job but Mike Row (sp) never showed up. I also decided to paint the pan since it was off and looked like poop. Now I am waiting for paint to dry so it looks like tomorrow I will be finishing the pan up, installing some wire for the trans temp. gauge and maybe putting in the harness. Shooting for a Friday or Saturday fire up...maybe, the goal I set was end of the year and then moved it to Christmas.
Pics: ![]() ![]()
#142 |
Nice work....
#143 |
LS10
NO PICS, but I did put the pan back on the trans, hook up the wire from the trans temp gauge, install the PN switch, and start on the harness. So far the harness looks good and is going in ok. I will say it is a pain in the ass getting the wires down to the trans. I did have to mod one part of the harness. Where the plug for the alt. comes out of the wire loom on the harness was a few inches off. No biggie, I just had to cut the tape and pull the wires out to where I need them.
Does anyone have the bracket that holds the gear selector cable in place? I NEED ONE!! |
#144 |
out draggin.. brb
such a clean LS swap man. looking forward to seeing more of your progress
#145 |
LS10
#146 |
Molon Labe
![]() Age: 23
I love watching this project come together, its a little slow but its good to know you're doing everything right.
#147 |
LS10
That means a lot. Thanks. I know its slow and I was starting to get excited (thats when I want to cut corners) so I took a little time to just set in the cab and think about how two years ago I bought her it's not going to kill me to wait a little longer to fire her up. |
#148 |
any more progress to the truck?
#149 |
LS10
I bought a FAST 92 for the truck even though I already have a LS6 but, bigger is better right? lol I am in the process of running down a TB for it and I'm trying to round up some other parts that is needed to finish her up. It's still too cold to work in the shop so no work has been done on it in quite some time.
Pic of the intake...
#150 |
LS10
Made an order for the S10 and the boost pressure gauge is for the DirtyMax
![]() I also did some cleaning on the FAST intake
| Sponsored Links | |
Advertisement | |
