MyTruckHasNoPantsOn! - Page 22 - S-10 Forum
Old 01-21-2015, 12:23 PM   #1051
LOOK AT MY NIPPLES!
IhaveNoPantsOn's Avatar
Re: MyTruckHasNoPantsOn!
So, I picked this up from a guy on Facebook a few weeks ago.
An actual 2.2 5-speed tach cluster. The v6 auto one in the truck now is working fine, but it'll be nice to have the correct one in there. I'm gonna clear the needles, swap to LEDs and obviously swap over or adjust the odometer.
Don't want to lose 90k miles...
Speaking of the needles; both my original cluster, and the current one, from a 96 Blazer have wide orange needles. This one, which is also a 97, has thinner red ones. I'm assuming he just swapped them? The speedo one was off when I took it out of the box. I like them better anyways. Should look good cleared. They'll match the red lighting on my CD player.
Old 01-21-2015, 12:44 PM   #1052
WTFWBJD
mostizzle's Avatar
I think there's a thread showing how to change the odometer. If not, deathphoenix can help you out with that. The needles look just like the ones he put in my cluster. I forget what they were out of. I want to say Camaro.
Old 01-21-2015, 02:19 PM   #1053
Forever breaking this S10
NextName's Avatar
Yep, those look just like Camaro needles.
If you're looking for just clear thin needles, I have a couple sets if you don't want to change those since a lot of people desire the Camaro needles. They're white needles from an Alero but show up any color your LEDs are.
Old 01-21-2015, 03:56 PM   #1054
Maybe later.
tytotheler92's Avatar
Keep the Camaro needles. I may be bias however. lol.
Old 01-21-2015, 04:15 PM   #1055
LOOK AT MY NIPPLES!
Jerry, I've got that thread bookmarked and will be referring to it quite a bit. I'm definitely liking these needles. Just want to strip the white paint off the back of them so they're transparent. I think I've read that nail polish remover works well. I'll have to do a little searching.
Old 01-22-2015, 12:42 AM   #1056
WTFWBJD
mostizzle's Avatar
I think I recall some guys saying that's what they used. Not like you can't go to the boneyard and buy a handful for next to nothing to experiment with.
Old 01-22-2015, 11:53 AM   #1057
LOOK AT MY NIPPLES!
Quite right. Maybe I'll pull the old cluster apart and test it on those needles.
Old 01-22-2015, 06:56 PM   #1058
WTFWBJD
mostizzle's Avatar
Have fun putting the speedo needle back on. Mine was almost 10mph off when I installed it. I had to install the cluster without the lense, barely push the needle on, and then go drive around using GPS and the trial and error method to get the needle in the right spot by taking it off an then putting it back on. Pain in the nuts.
Old 01-22-2015, 07:24 PM   #1059
Maybe later.
Huh. Do the 94s not park the needle at power up? On the 95+ atleast, when you turn to key to run, all the needles park in their default position. I just swap them then. Obviously this only applys to the speed, rpm, and oil pressure, since those all default to zero with key on engine off, but you'll also see your current volt, temp, and fuel levels using this method, making it really easy. The only problem I always have pushing them on to far and having them skip and catch.
Old 01-22-2015, 08:12 PM   #1060
WTFWBJD
mostizzle's Avatar
That didn't work for me. Mine was also torn all the way down and completely reassembled with different stepper motors too. Pretty sure the cluster in the thread that I mentioned is my cluster.
Old 03-07-2015, 05:10 PM   #1061
LOOK AT MY NIPPLES!
No updates. Just feel like bumping this thread. Been driving this beast a little more lately since the roads have cleared up and there's FINALLY no snow in the forecast. Got a bit of work planned for this spring/summer, including:
Swap gauge cluster to actual 4 cyl/5-speed with LEDs and cleared needles
ZQ8 steering box, front sway bar and Cherokee steering shaft. Should steer and handle like a fūcking gokart.
Redo e-fan setup. Probably replace radiator too.
Shift rear end, bed and bumper to the left about 1/2". Everything's still tweaked from when I wrecked it a couple years ago.
Patch frame. Left front cab mount is just about detached from the frame. No Bueno.
Since everyone likes pics
Old 03-08-2015, 11:40 AM   #1062
fackinsteve's Avatar
Just read through your thread man you truck has come a long way! What part of Mass are you from?
Old 03-08-2015, 12:10 PM   #1063
FNG
greasemunky's Avatar
Another poor, lazy budget minded greasemonkey bangin away on his own ride, using junkyard and ebay/craigslist parts... Atleast im not the only one lol. Diggin those meshies, man.
Old 03-08-2015, 12:14 PM   #1064
LOOK AT MY NIPPLES!
Steve, I'm in Wilbraham, just east of Springfield. Nice Blazer you got. Welcome to the forum.
Greasemunky, it's been a struggle at times to work on this thing, but everything is finally coming together. I really love these wheels too. Thanks!
Old 03-08-2015, 12:26 PM   #1065
Nice I'm about an hour away, I live in Westboro
P.S its not a Blazer
Old 03-08-2015, 02:21 PM   #1066
LOOK AT MY NIPPLES!
Not sure why I said Blazer. Nice truck either way.
Must've been looking at Greasemunky's avatar. You're both new members. I got confused.
Old 03-08-2015, 04:27 PM   #1067
Haha it's all good dude. You plan on going to any shows this year?
Old 03-08-2015, 10:03 PM   #1068
LOOK AT MY NIPPLES!
As many as I can! First big one is at Umass, April 18th
https://www.facebook.com/events/1374961862821636/
Old 03-08-2015, 11:03 PM   #1069
Yeah I'll be there! I'll probably show up with a crew of people so I won't be hard to miss
Old 03-09-2015, 06:35 AM   #1070
LOOK AT MY NIPPLES!
Good to hear. See you there man.
Old 03-09-2015, 08:53 AM   #1071
Boozebag
Mad Max's Avatar
Heh heh...
Wilbraham = home of Freindly's Ice Cream...
Man, you guys got doooooooshed with snow this year.
I used to live in Marblehead, I remember a few heavy duty snow storms.
F that.
Old 03-09-2015, 11:10 AM   #1072
LOOK AT MY NIPPLES!
Hell yeah. I live less than a minute from the Friendly's factory. We did get a shitload of snow. Still not as much as they did farther east though. Hopefully no more coming.
Old 03-16-2015, 11:58 AM   #1073
LOOK AT MY NIPPLES!
Got the courtesy lights swapped out for LEDs. And installed a clear dome light lens.
Pics obviously don't do much justice. Very cool, bright white in person. Weather permitting, I'll be pulling the cluster, swapping odometers, and installing the new one. Should look tits.
Old 03-16-2015, 01:32 PM   #1074
Connor94's Avatar
How did you get into those map lights to change the bulbs?
Old 03-16-2015, 03:08 PM   #1075
LOOK AT MY NIPPLES!
Very carefully pried the lenses off. I actually used the tip of an electrical test light, since it was sitting there. A very small flat blade screwdriver would be best. It's also a bitch to get the lights out of the socket/holder.
Old 03-16-2015, 03:50 PM   #1076
Connor94's Avatar
I tried prying on em but i didnt want to break them, ill have to give it another go. Thanks!
Old 03-16-2015, 05:27 PM   #1077
WTFWBJD
mostizzle's Avatar
Looks good. I love my clear dome light lens. I don't know wtf they were thinking with the dumb ass milky dome light lenses.
I used a small screwdriver to get into the map lights.
Old 03-16-2015, 06:05 PM   #1078
Wow that looks waaay better
Old 03-16-2015, 06:39 PM   #1079
LOOK AT MY NIPPLES!
Thanks Steve! Can't wait to get the rest of the lights swapped out and the new cluster installed.
Old 03-16-2015, 08:49 PM   #1080
I'm going to have to copy and paste this mod into mine sorry (not sorry)
Old 03-17-2015, 01:51 AM   #1081
Professional Insultant
TokoDragon's Avatar
LED lights look sweet!
Old 03-22-2015, 04:20 PM   #1082
LOOK AT MY NIPPLES!
Thanks! Gave the truck a good cleaning today. Took it through the car wash, then shined the tires, did a quick wipe and vacuum on the interior, and did my biannual Sharpie touch up of all the chipped and faded black trim.
So fücking shiny!
Old 03-22-2015, 04:41 PM   #1083
So hawt
Old 03-22-2015, 06:16 PM   #1084
WTFWBJD
mostizzle's Avatar
Your truck cleans up so nice.
Old 03-22-2015, 08:09 PM   #1085
Maybe later.
Looks awesome!
Old 03-22-2015, 09:55 PM   #1086
poop
JCmopar's Avatar
I quite enjoy this truck.
Old 03-23-2015, 07:39 AM   #1087
LOOK AT MY NIPPLES!
Thanks guys. I appreciate the love. No homo.
Old 03-25-2015, 02:51 PM   #1088
Flame It ALL
Stewzer55's Avatar
At this point, I think the truck is wearing pants.
Old 03-25-2015, 03:16 PM   #1089
LOOK AT MY NIPPLES!
You'd think so, wouldn't you?
Old 03-25-2015, 07:05 PM   #1090
Pants are overrated imo
Old 03-26-2015, 07:57 PM   #1091
S-10 and a Cummins
Turbotyler's Avatar
I am getting aroused
Old 03-26-2015, 08:17 PM   #1092
LOOK AT MY NIPPLES!
If all this homoeroticism keeps up, Neil is bound to show up...
Old 03-26-2015, 09:42 PM   #1093
Flame It ALL
Stewzer55's Avatar
No, but Matt will, or maybe Ken.
Old 03-27-2015, 07:42 PM   #1094
F1NG3R5UMG1RL5!
Dirt Nasty's Avatar
ive never seen anyone keep change in the console change holder.
mine always ended up in the cup holders haha
You may post new threads
You may post replies
Powered by vBulletinĀ® Copyright Ā©2000 - 2011, Jelsoft Enterprises Ltd. SEO by vBSEO 3.2.0
vBulletin Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
