MyTruckHasNoPantsOn! - Page 20 - S-10 Forum
Old 05-08-2014, 08:52 PM   #951
LOOK AT MY NIPPLES!
IhaveNoPantsOn's Avatar
Re: MyTruckHasNoPantsOn!
Crossmember showed up today!
Came with a couple other brackets that I'm guessing are for relocating the straps? Not sure, it didn't come with any instructions. And some stickers, which are good for at least 1/2" more drop, each.
Old 05-09-2014, 08:08 AM   #952
get over it....
Bad-S10's Avatar
lol... gonna stack the stickers between the blocks and leafs...
Old 05-09-2014, 11:04 AM   #953
LOOK AT MY NIPPLES!
Gonna fold em in half first. Get twice as much low.
Old 05-09-2014, 11:43 AM   #954
get over it....
Bad-S10's Avatar
instead of 1/16 will drop 1/8th .... does it make any faster?
what is that crossmember for anyways? gas tank?
Old 05-09-2014, 12:06 PM   #955
LOOK AT MY NIPPLES!
Yeah, raised gas tank crossmember. Mine is just about rotted through where the strap bolts to it. I'm planning on bagging it this coming winter, so I'm gonna need it anyways. Figure it would make the most sense to buy it now and swap it when I replace the bed.
Old 05-12-2014, 09:34 PM   #956
LOOK AT MY NIPPLES!
Got some paint on the crossmember.
Also just about finished up with bodywork on the bed. Still have a little rust to combat and some old filler to remove and redo, but everything should be done and painted by the end of the month.
Old 06-08-2014, 09:41 PM   #957
LOOK AT MY NIPPLES!
Well, I've got a fair amount done in the past month or so.
A few weeks ago I got a few things painted.
Did the upper part of the door panels satin black, and the handle trim silver. Also wrapped the door handles in some black vinyl. So, the interior is pretty much how I want it. I painted the side mirrors, since the right one was pretty crappy looking and scuffed up, and the left one was never painted.
Also removed the cap, pulled off the rack, and sanded and prepped it.
Last Monday I picked up a drivers door from the junkyard. Absolutely no rust, and the hinge pin holes are perfect.
Had a bit of a dent, but I took care of that.
Got the rest of the chips and dents worked out, too.
Today, I pulled the headliner,
in order to remove the third brake light assembly, and shave it.
I used panel-bond again, like on the tailgate filler.
A little filler, and it's pretty much done.
Still needs a little finishing, but it's getting there!
Gonna call and get some prices on paint tomorrow, and probably drop off the bed, cap and door Tuesday, since I have it off. This week, I'm planning on pulling the bed off, replacing the cab corners, and installing the raised tank crossmember.
Old 06-08-2014, 09:57 PM   #958
Iron LS2 coming tomorrow.
s10xtremist's Avatar
Awesome progress!
Old 06-08-2014, 10:06 PM   #959
LOOK AT MY NIPPLES!
Thanks! It feels good to finally be getting somewhere with it.
Old 06-08-2014, 10:34 PM   #960
I only experience that feeling for a few minutes every couple of weeks. Then, I find some BS that fcuks up my roll and the project stalls again.
Old 06-09-2014, 04:56 AM   #961
Maybe later.
tytotheler92's Avatar
This is exciting.
Old 06-09-2014, 09:52 AM   #962
LOOK AT MY NIPPLES!
It sure is! It's nice to not look at it and shake my head in disgust.
Old 06-09-2014, 11:23 AM   #963
get over it....
Bad-S10's Avatar
thats nice thou, we finally getting some good weather... good to see that u didnt give up on it...
Old 06-09-2014, 12:56 PM   #964
LOOK AT MY NIPPLES!
I'm never gonna give up on this thing. If I had a garage to work in, it would've been done by now.
Old 06-09-2014, 04:28 PM   #965
keepin it freshhh
Slowlowandbangin's Avatar
If you have any questions with the tank crossmember install, I took some pics in my thread and you have my number just let me know.
Old 06-09-2014, 05:22 PM   #966
get over it....
Bad-S10's Avatar
nice good to know... hope to see it soon...
Old 06-09-2014, 05:44 PM   #967
keepin it freshhh
I'm probably going to bass pro this week
Old 06-09-2014, 06:50 PM   #968
LOOK AT MY NIPPLES!
Thanks Tommy. Maybe I'll make my way out that way Thursday.
Old 06-09-2014, 08:19 PM   #969
mostizzle's Avatar
Looks good man. Nice job.
Old 06-09-2014, 08:53 PM   #970
LOOK AT MY NIPPLES!
Thanks Jerry! Glad to see your thread being updated, too.
Old 06-09-2014, 10:51 PM   #971
mostizzle's Avatar
Not like there's anything significant going down but thank you. lol
Old 07-04-2014, 09:05 PM   #972
LOOK AT MY NIPPLES!
This happened a week ago
Still have a bit of wet-sanding to do to get it nice and smooth, but for my first time ever painting anything with a gun, I don't think it came out too bad. Planning on getting these sanded and buffed out, and the door and tailgate painted tomorrow and Sunday.
Old 07-04-2014, 11:31 PM   #973
mostizzle's Avatar
Is that just base coat or did you clear it already too?
Old 07-05-2014, 08:16 AM   #974
LOOK AT MY NIPPLES!
I ended up just going with single-stage.
Old 07-05-2014, 08:22 AM   #975
100000 Internet points!
koeberle04's Avatar
Looks good. Likin the progress
Old 07-05-2014, 08:36 AM   #976
Daily Dragger
Jott_06's Avatar
Metallic single stage + wetsanding and buffing is not good. If your not carefull you can make a real mess. Back when i was first learning to paint i sprayed a door metallic blue and when i buffed it i ended up with "rings" everywhere that i went through the last coat of paint. The color will still be there but you disturb the metallic. now i only use single stage on solid colors.
Old 07-05-2014, 09:34 AM   #977
LOOK AT MY NIPPLES!
Thanks for the advice, Jott. I'll test it out on an inconspicuous area first, just to see how it turns out. The bed doesn't really need much, but the cap is very textured. I mean, it doesn't look bad; almost intentional. But, I'd like it to be smooth.
Old 07-05-2014, 04:20 PM   #978
LOOK AT MY NIPPLES!
Before
After
Half way through the first side. You can see how rough it still is on the right.
Still a little hazy. All I've done so far is sand with 1500 grit, then go over it with rubbing compound. Still needs a final buff.
Got a couple 'fossils' that wouldn't sand out, but most of the runs I had are gone.
Tomorrow I do the cap, which is gonna need a lot more work.
Old 07-05-2014, 09:04 PM   #979
ItAintNatural
aaronweisler's Avatar
How did you like spraying out of a gun?
Old 07-06-2014, 11:08 AM   #980
LOOK AT MY NIPPLES!
Not bad. Not much to it. Just gotta keep steady speed and distance. Same as spray cans. I know I need to make some adjustments to get it to lay smoother.
Old 07-06-2014, 10:55 PM   #981
ItAintNatural
Way better the spray cans imo, consistency and control are mountains to molehills
Old 07-08-2014, 09:06 AM   #982
keepin it freshhh
to reduce that texture you wanna make sure you keep a consistent distance and speed with the gun like you said. Keept the tip about 6"-8" from the panel and watch the paint lay out of the gun. If you have the correct distance but are still getting crazy texture, you need to slow down and let it flow out more onto the panel.
what you have there is a good example of a dry texture, next time you need to follow these steps to apply a medium-wet coat/ texture and it'll be much more betterer!
Old 07-08-2014, 11:53 AM   #983
LOOK AT MY NIPPLES!
Thanks Tommy! I should be doing the tailgate and door this weekend, so we'll see how it turns out. Another question, though. When shooting the primer, I had to crank the pressure up to around 20 psi, just to get it to spray decent, without globbing up. I reduced it correctly, but it just wouldn't spray right. I ended up leaving the pressure there when I did color, which likely contributed to the dry spray. Any idea why I would've had such an issue?
Old 07-08-2014, 06:18 PM   #984
keepin it freshhh
What primer, sealer, high build, wash/etch?
Old 07-08-2014, 06:19 PM   #985
keepin it freshhh
What's the formula or ratio for the primer that globbed?
If you do not want to register, fill this field only and the name will be used as user name for your post.
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
