My newly acquired truck! =]
Old 06-24-2009, 02:43 PM   #1401
kookennay's Avatar
Re: My newly acquired truck! =]
yeah check your leader hose for sure. mine was doing the same thing over night it was the check valves in them sticking open and leaking back thru the comps. i had to pull the filters of and put my finger over the intake hole to figure out thats were i twas coming from. i even bought new hoses and one did the same thing and it was brand new.
Old 06-24-2009, 02:44 PM   #1402
Crazy for a square body
Kiko's Avatar
I thought the check valve would fix that? I have a rigged up line for my 380 (3/8 Airline) and it blew off the barb fitting because i didn't have hose clamps on it yet and the check valve it had on the tank kept my tank from going down. I figured the check valve on the leader hose for the 400 would do the same incase the hose messed up.
Old 06-24-2009, 02:45 PM   #1403
Kiko's Avatar
I'll try to get a picture of my setup when i get home. I'll check the hoses too.
Old 06-24-2009, 07:06 PM   #1404
V8 with bags
V8Blaze's Avatar
those check valves are doo doo. My 450 lives inside my blazer and im on my second hose. My tank kept leaking and i couldnt find out where, finally replaced the leader hose and it works fine
If you already have a known good check valve put it b/t the viar hose/check valve and the tank, and see if the leak goes away.
Old 06-24-2009, 08:43 PM   #1405
Kiko's Avatar
Put my finger over the hole and when i let off you could hear air so i plugged it and pulled the fuse so the comp won't come on for now.
Still leaks a little but not as bad. Gotta check a few mor ethings later.
Old 06-25-2009, 10:54 AM   #1406
Kiko's Avatar
Swapped the check valve off my 380 so i'm back to just my 400 and fixed a leak on the gauge line. Last night i only like about 5psi so that's acceptable. Now i just need another leader hose for the 380.
Old 06-25-2009, 12:16 PM   #1407
V8 with bags
V8Blaze's Avatar
cool cool, and with different temp changes you loose a few psi. When i ordered mine suicidedoors had them cheapest but were out of stock, but this was last summer
Old 06-25-2009, 01:08 PM   #1408
Kiko's Avatar
They are $12.99 plus shipping on suicide doors. I may be able to order one this week. Just depends. I put off a lot of my bills the week of scrapin so i'm having to pay them this week instead. I'd like to order some bag plates to finish my tilt bed finally. It's been forever since i first did it.
Old 06-25-2009, 01:57 PM   #1409
V8 with bags
V8Blaze's Avatar
oh i know all about starting a project and then shit coming up and it beign half finished
Old 06-25-2009, 05:00 PM   #1410
the brown turd
s10v8drew's Avatar
haha yea, that shit does suck...i need a bag full of money left on my front porch...but trucks coming along nicely, u didnt happen to stop by the waylayed booth did ya?
Old 06-25-2009, 06:47 PM   #1411
Kiko's Avatar
I passed by it a few times.
Old 06-25-2009, 07:51 PM   #1412
the brown turd
s10v8drew's Avatar
hah o ok...thats where i was at, some guy stopped by and got a small chuck of ti, and i thought it might have been you, but wasnt sure
Old 06-26-2009, 01:32 PM   #1413
Kiko's Avatar
Nah wasn't me. I left my titanium at home. I didn't drag any on the way there or home. I wanted to but couldn't figure a way to mount the titanium and i didn't feel like staying until dark anyway.
Old 06-27-2009, 11:10 PM   #1414
Kiko's Avatar
Bored and waiting on my girlfriend so me and my friend cruised..
Old 06-28-2009, 01:11 AM   #1415
is gettin there...
Driveway Kustoms's Avatar
truck looks awsome man, its something to really be proud of
Old 06-28-2009, 02:19 AM   #1416
kookennay's Avatar
yeah the brand new leader hoses i had wit brandnew check valves stuck on my 450s i had to get out and tap one wit a hammer so it would unstick ever time i parked somewhere i would get some good check valves for sure
Old 06-29-2009, 02:53 AM   #1417
Kiko's Avatar
Got rid of the blower box since i don't have a/c
That's about all i did. I was bored and didn't have any parts so i just remved stuff i didn't need. I went out dragging earlier and the drag material flew off and hit the bottom of the transmission where the drain plug is and busted it so it ran out. I towed it home and i've got to fix that tommorow after work....yay
Old 06-30-2009, 08:02 PM   #1418
Kiko's Avatar
Can't fix the transmission......so lucky me i get to jack the truck up and pull the transmission and put another one in. Won't be done by the weekend probably but i can at least trailer it to the local show here for fourth of july.
Old 07-02-2009, 12:35 PM   #1419
Come out and plaaaaaaay!
Svtzx555's Avatar
One more reason to have whatever you're dragging in the rear and not the front.
Sucks it busted the trans case. What time does the show start at MGM friday?
Old 07-02-2009, 01:22 PM   #1420
Kiko's Avatar
5pm. I don't think i'm going... Naomi broke up with me. I'm probably going home and going to bed. I don't even feel like working on my truck right now. It's just sitting there.
Old 07-03-2009, 05:17 PM   #1421
Kiko's Avatar
I may be going. She is at least talking to me some so i'm in a way better mood. If i go my truck will be trailered to the show. I'm gonig to finish trimming my neighbors yard and try to get a transmission from the junkyard so i can be ready to start putting it in this weekend. If i can get my hands on some smaller diameter tubing i will cut off my upper bag mounts and raise them so the rear will lay out. If i do that then sometime later this week i will pull out the bench seat and pull the carpet back so i can cut my floor and weld in the driveshaft tunnel i have sitting in my room so i can lay it out without the driveshaft rubbing. After that it's off to drag the leaf spring hangers
Old 07-06-2009, 01:47 PM   #1422
Kiko's Avatar
$500 for a transmission. If it was automatic i would be in luck but thanks to it being 5 speed i can't find one so i will be looking at a high price. I almost have mine off just can't get to some bolts. This is stating to piss me off. I've been to two junkyard in 100 degree weather trying to find one with no luck. I found a guy who has three but he's the one wanting $500 plus my busted one. Sucks but looks like that's what i will have to do.
Old 07-06-2009, 05:22 PM   #1423
blown up .....again
Shaggem's Avatar
try ebay? I would sell you my spare casing but I'm going to use it to build one. try craigslist as well.
Old 07-06-2009, 06:24 PM   #1424
V8 with bags
V8Blaze's Avatar
500 dollars for a used trans is the most rediculous thing ive ever heard. My brand new th350 was only 600. Swap to an auto if you can find one cheaper b/c that much for a manual gear box is unbelievable
Old 07-06-2009, 06:37 PM   #1425
s10blaazzaa's Avatar
i hate yer red bowtie. you didnt get the one out at barrys?
Old 07-06-2009, 07:01 PM   #1426
Kiko's Avatar
Couldn't find manual 4.3 transmissions. Only auto. I bought my truck partially because of the manual transmission so i don't want to swap to auto. I'm going to try picking up a shopper and see if they have any for sale. I'm getting pissed not having a way to go places when i feel like it. What's wrong with my red bowtie?
Old 07-07-2009, 09:55 AM   #1427
Svtzx555's Avatar
Do you still have your old auto trans for the blazer? I'm thinking of swapping out my th350 for a 700r4. Its probably been sitting in the rain though?
Old 07-07-2009, 11:30 AM   #1428
Kiko's Avatar
I got rid of it a while back.
Old 07-07-2009, 06:43 PM   #1429
Kiko's Avatar
I just can't catch a break...
Did this on purpose. Didn't hurt anything but it helped my get a little lower... :P
What i did do that hurt...
How my poor truck sits.... I wanna drive it so bad :'(
I might take my $500 i would spend on the transmission and buy a gmc jimmy that runs. Then i can save up for the transmission while driving the jimmy. Plus i really want a suv to drive..
Old 07-10-2009, 01:52 PM   #1430
Kiko's Avatar
Found a transmission for $300. It's getting pulled by someone else and i just have to pick it up and put it in. Hope to have it back on the road no later than monday morning. After that i'm re-doing my upper bag mounts and bridge bar/s to make the back lay out (Upper mounts too low) and if i can,order the bag plate for my tilt bed.
I've been looking at weld-on hood cowls/scoops because they're a lot cheaper than buying a new hood. I can't decide which i like better though. opinions?
http://www.techhoods.com/Fiberglass_...s/Scoop-01.htm
http://www.techhoods.com/Fiberglass_...s/Scoop-02.htm
Old 07-10-2009, 03:14 PM   #1431
s10dollar's Avatar
do the first one looks better
Old 07-10-2009, 08:34 PM   #1432
V8 with bags
V8Blaze's Avatar
do you guys get a pop up that say that is the old page and price and availability might be different? b/c on their other site they dont offer those scoops anymore that i can find its got a redirect to www.carhoods.com
Old 07-10-2009, 09:10 PM   #1433
Kiko's Avatar
I get that but i didn't the first time. If i have to i'll look for one on e-bay. I was mainly getting an idea on price and what was available. I'm trying to make my stock hood look like a stock cowl hood but without forking over $400+ Not sure how well it will work but it's worth a shot.
Old 07-12-2009, 11:56 AM   #1434
Kiko's Avatar
I got bored and had a old tire to practice on....
When i get the money to have my tires flipped around i might sand down the side and enlarge the white walls until i can get my 18's.
Old 07-12-2009, 06:08 PM   #1435
Kiko's Avatar
Well.....paid for the transmission and i'm supposed to have it tommorow. I'll work on it a little after work this week until it's done. Not sure what else i'll do when i get paid. Might just do the rear setup and cab notch.
Old 07-15-2009, 12:27 PM   #1436
Monster1211's Avatar
Sat here and read this thread for an hour.....dont know you man but it's cool how much work you put into fixing your dime!
Old 07-15-2009, 01:27 PM   #1437
Kiko's Avatar
Thanks.
Old 07-15-2009, 06:38 PM   #1438
the brown turd
s10v8drew's Avatar
hah i've been following this thread for probibally 7 months, and i know i have seen at least a dozen times where someone said they just read your whole thread, thats got to make you feel good lol...o yea, sorry to hear bout your trans man.
Old 07-15-2009, 08:00 PM   #1439
Kiko's Avatar
Yeah it sucks. I'm fixing to go up to the shop and pick it up. I found one for $240 and i paid (Or owe) $60 for the guy pulling it out of the other truck. Once i get this done i have a ton of stuff planned to do. It's all built up because i haven't been able to do anything for trying to find a transmission. I'm going to try and start putting it in later tonight and work on it after work until it's done. Before the weekend i hope...
Old 07-15-2009, 09:41 PM   #1440
Hey dude. I need you to give me your number. I got robbed so I don't have anyones number. Text me. L and m shaves white walls. The safe way. Ride by there. Copy cat
Old 07-15-2009, 09:51 PM   #1441
Kiko's Avatar
I used a grinder for now. I've looked it up and a sander with 180 grit is the best way. Just didn't have a high rpm sander to use. But i know now it works. Just need to buy the tool. I wondered why you never replied to my text. My # is 214-2026
Old 07-17-2009, 03:35 AM   #1442
Heavy Metal Junkie
rusty10690's Avatar
yea i too spent an hour going thru this whole thread one day, all the way from when you got it, to when you put a new bed, to were it got hit, and then bagged till now, i check this daily its actualy in my favs so i can just click to it keep up the good work
Old 07-23-2009, 01:52 AM   #1443
Lilblue4x4's Avatar
Thumbs up Re: My newly acquired truck! =]
dam dude i just spent hours readin through this thread lol this is amazing mad props to you especially because youve done everything yourself. lovin the truck it looks good
Old 07-24-2009, 02:15 AM   #1444
LOW CADDY DIME's Avatar
same here man, ive been sitting here for about an hour checking your thread out. keep up the good work.
most people would have given up...props
Old 07-24-2009, 03:55 AM   #1445
you think of something
thatoneguy29's Avatar
you give me inspiration to continue working on my truck, what kind of paint did you spray on it i like the flat black
Old 07-24-2009, 01:57 PM   #1446
Kiko's Avatar
Rattle can flat black. It works for now just so i can drive around with a truck that's one color. It's going to be a bitch when it comes time to paint because i have to sand it all back off before i can paint it.
Old 08-08-2009, 11:29 PM   #1447
Krusher's Avatar
Seems like I wasn't the only one to sit and read through from the beginning! I started reading it and skipped to close to the end and was confused when a different truck was being talked about so I went back and read it ALL to find out about what happened. I've been watching it now since you first got the current truck going and was only front bagged. It has DEFINITELY came a long way and keeps looking better every time you do something to it. Can't wait to see it painted!
Old 08-10-2009, 01:30 AM   #1448
Heavy Metal Junkie
rusty10690's Avatar
i have a feeling he gave up, i check this daily and no updates sine july 24
Old 08-12-2009, 01:10 PM   #1449
Kiko's Avatar
I'm still working on it. I have been really busy. I'm going to get my $$ from the other guy and i'm going this week to pull a transmission somewhere else. I heard they have one in now at the u-pull it and i'm going to check. I'm tired of riding my road bike 4.5 miles to work every morning.
I miss driving my truck
One update i kinda fixed my leak on my guage line. It's still leaking some but i can fix that. I need to replace the line anyways. I also got metal to rebuild my upper moutn setup. I'm using the upper plates but making new bridge bars and raising the mounts since they were welded to low and it sits just a little off the ground. I also have my driveshaft tunnel already just waiting on putting it in. Only things on my mind are the air leak and the transmission. Once those are done i'm going to just drive it. I'm not taking it down for a while. I'll do little things that won't stop me from driving it since i have been without it for a while now.
Old 08-17-2009, 09:58 PM   #1450
thats a sick find...i might be the only person out there thinking this but i like the 1st gen. front ends better than the 2nd gen. they sit a little higher and I think they look more like a truck. only personal opinion though.
Page generated in 0.67351 seconds with 32 queries
[Output: 215.83 Kb. compressed to 197.02 Kb. by saving 18.81 Kb. (8.72%)]
