#1201 |
UN-BANNED B!TCHES!!!!!
Re: My newly acquired truck! =]
#1202 |
Crazy for a square body
....ok?
#1203 |
Had to do my neighbors lawn (Gas money..yay) but i managed to work on it a little. I put another coat of bedliner on the driverside notch and a couple coats on the passenger side. Still need to get in the spots where i didn't get and i need to put another coat of primer on the underside of the frame and bedline there. I removed the second bed mount on the passenger side too. Just brushed on a coat of primer cause i won't be doing anything with it until a week or two nd i don't want it to rust. Anyway got to get back to work and make it to my girlfriend's son,Charles' t-ball game still so i'll get to the pics
![]() ![]() ![]() ![]() Sucks.... ![]() Just test fitting everything... ![]() All the white pushlocks are temporary. I hate them because they won't tighten up enough and still leak a tiny bit. I'm replacing them all with suicide doors fittings when i'm done. Probably after scrapin because i still have a ton to do before i make the show |
#1204 |
ados egnaro
Location: Floyds Knobs/Clarksville, IN User is: OffLine |
i have that happen everynow and then. my tires will do that after about 20k if i leave them on the front for that long. im lazy on rotating my tires.
#1205 |
Truck is at my friend's brother's house right now. It was way to late and i have to be up at 7:30am for work so we couldn't get the u-bolts back on in time so i had to call it a night. All of the welding it finished. I need to cleanit with the flap disk like before and prime/bedline it then bolt in the bags and install the remaining pieces of four link. These are the only pics i have right now.. truck pics will come tommorow.
#1206 |
wow i read this all today. All i can say is that you have been wrenching in this thing for a long time. looks good.
#1207 |
Thanks. Here's the pics of the welding and stuff
![]() ![]() ![]() ![]() ![]() ![]() Keep in mind it still needs to be hit with the flap disk and primed/bedlined. I'm going to bring the primer and angle grinder to work tommorow and do one coat in the parking lot on my lunch break and one more coat when i leave to go home. |
#1208 |
Timeline that my kickass girlfriend surprised me with earlier. It doesn't show the totaled part but it shows everything before and after.
#1209 |
the brown turd
thats badass man...sounds like u got a good girl, cant wait to see it layed all the way out
#1210 |
Thanks. And i do. She knows how much it means to me so she tolerates me working on it as long as i don't spend all my time with it. It'll hopefully havve the bags on saturday or sunday. I just had a guy walk into the shop and asked who owned the little s10 and could he take a look at it.
Made me feel pretty good ![]() |
#1211 |
V8 with bags
looks good but those upper bag brackets are going need either a gusset or another bridge bar up front
any eta on it being fully lay'd out |
#1212 |
New grill doesn't fit. I knew the headlights wouldn't line up with the pre '91 core support but i thought it would still bolt on....WRONG. I put on my 3 piece for now. I have to buy a 91+ core support from the junkyard soon as i can and swap it. My bumper and clear lenses are on though. My list of things i need to do for scrapin is growing.....
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And no,the bumper lights don't work. They never have. I have to fix the wiring harness. But they look good in the daytime ![]() |
#1213 |
Plan to have bags on by Sunday. And i wanted another bar but didn't have enough steel. I need to find time to get by the shop and buy another piece. I have scrap that i can use so i get the same kind..
#1214 |
All damn day but....it's done
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() My friend being retarded ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() In some of the pictures there weren't nuts or washers on bolts or they weren't tightened but keep in mine the pics were taken before,during,and after we were done. It's all bolted down and tight. My driveshaft rubs when i rid fully down in the back and lifted up front but that's cool. I can fix that in 2 minutes. Next we have to fix some air leaks and replace some fittings and i need to sand my cab and spray it flat black and swap doors. Bed will be on tommorow after i fix the leaks on the tank fittings. It's only 1 or 2 spots. The rest are on the bag fittings which can be fixed with the bed on. I'm so ****ing happy right now...like when i drove to the gas station for gas after finishing up i had the biggest smile ever . Feels great to finally have it all bagged and laying out (Except the tires hit up front but once again 2 minutes and i can fix that. In other words: Angle grinder) ![]() |
#1215 |
Also before anybody rips on me,i plan to lengthen my wires later and route them neatly and i plan to replace all my union/pushlock/whatever fittings with suicidedoors fittings. The cheap ones were only temporary. And they are approved to around 170psi and i only run 140psi in the tank so i'm not worried.
#1216 |
sweet shit
#1217 |
Come out and plaaaaaaay!
#1218 |
When i get paid i'm going to get another peice of steel. I have a small piece i can take to get the same stuff. In just have to do it when i'm off and they are open.
#1219 |
ados egnaro
i say you drag off that leaf spring hanger.
#1220 |
Already planned on it
![]() Once it's drug down i'll grind the rest off and bedline the frame where it was. |
#1221 |
ados egnaro
sweet.
#1222 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() More pics of the bed on tommorow... |
#1223 |
shit looks sweet...its come a long way.. love the bmx tiedown lol
#1224 |
is gettin there...
looks siiick great job man
#1225 |
Thanks. I have to clean up the bed cuts but i'm satisfied overall.
#1226 |
ados egnaro
at this point i would maybe mount the licence plate at the top of the tailgate. or ontop of the tailgate just so you dont get hassled for a hard to see plate.
#1227 |
Good idea but i'm not worried about it. I put it there knowing it would be low.
Went to the beach with my friends today and got some good pics. A little difficult fitting two people in the bed and our stuff with the floor cut. On the plus side i had at least 3 times where people were like "I like your truck" or "Do that again".. Pretty cool ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() oil was low so i put in my bottle of stop leak stuff and i can't tell a difference yet. I assume it takes a while to take effect. My seals or something is leaking from age ![]() |
#1228 |
ados egnaro
that stop leak stuff as far as i have ever seen doesnt work very well if at all.
truck looks good. Last edited by NevurMind85 : 04-14-2009 at 09:05 PM. |
#1229 |
I don't know. I never heard about it. But it was $3 so i figured it would be harmless to try for now.
#1230 |
ados egnaro
yea shouldnt hurt anything.
#1231 |
first car and proud
badass. dang this makes me want the know-how to bag a truck. oh well...maybe someday.
#1232 |
Keep us up to date on that FBI 4 link cuz i dont think there is too many threads on it!!! Looks sweet man keep it up
#1233 |
no updates
#1234 |
You boys like MEXICO??
that sticker should say: "i can't lay vinyl to save my life"
just kidding, hahaha. but in all seriousness, ballin truck, dude. |
#1235 |
Off Vanning. bbl
So you are only bracing the entire rear load capacity of the truck off a couple plates so-so welded to the notch and one piece of tubing between the notches?
I can not believe you would allow your friend to sit back there aswell. Your stress points are not equally braced which can allow that plate to flex and bend. Please just get another piece welded in, personally I would never let something like that leave the shop let alone driving with weight on it. Sorry if it seems harsh but safety is not something to screw around with. |
#1236 |
ados egnaro
wow he said he is going to when he can afford it.
#1237 |
Off Vanning. bbl
It would be one thing if he still had his bed off, and no weight. But with the weight of the bed plus people and such its just not safe. Do it once do it right don't skimp out on suspension. |
#1238 |
First of all my welding is good. The upper plates are welded on the top AND bottom aswell as welded to that bar. I only had enough steel to make one piece. I WANTED two but that wasn't possible. I plan to take my spare piece to a steel supply place not too far and get another piece like it and weld another bar in front. Don't start bashing me for shit that i already know. I don't mind constructive criticsm but being an asshole is completely different.
And yeah,i've never put on vinyl stickers before. I had to look up the how-to on the website to see how they went on. Serious. Even my girlfriend ripped on me for it not being staight but it's good enough for me. My 4 link is doing fine for those who wanted to know. I did however bust a break line. It had a pinhole and when i hit the brake my fluid just sprayed out. It was on the right rear so i just called my girlfriend and my friend got me a brake line and when i got off work she drove me home to pick up my tools and me and my friend bled the brakes in my jobs parking lot after work once i got the cable on. But anyway.... me and my friend worked on it all day today and here's pics and updates ![]() ![]() Full rear lift ![]() Lifted fully ![]() Taking off the bumper ![]() Bye bye '89 core support ![]() New water pump just incase the old pos one went out during scrapin the coast ![]() New core support thanks to a '93 blazer ![]() Fastening... ![]() ![]() Bling,bling... ![]() I ripped the damn water pump gaskets trying to get it on and it leaks so i have to wait unil i get off work tommorow when the auto parts store is open to buy new gaskets and try again. I'm ****in tired...... ![]() Last edited by Kiko : 04-20-2009 at 12:38 AM. |
#1239 |
ados egnaro
that sucks man. oh well. bed looks like its not lining up right with the cab.
#1240 |
Off Vanning. bbl
As for your welding I am sure it will suffice but not but a couple weeks ago did you write about not welding much or before in general( i don;t recall off hand). But your welds do not have much for penetration into the notch or your one bridge bar. I just said the welds were so-so not perfect as no one's are. All I was doing was giving a little constructive criticism and am called an asshole. Otherwise the 93 grill looks good, good luck on making the the show. |
#1241 |
#1242 |
I still have a list of things but it's getting smaller. Chances are i will make the show. |
#1243 |
Registered Boozer
Oh man! i can't believe how crooked your sticker is. You sorry sonofa b
hahahahha j/m man. Shit looks tits. Can't wait to see it painted. Keep up the good work! You have gotten alot done since i have checked out your thread. |
#1244 |
no more S10
Just went through this whole thread. Shit man, that thing was haggard when you first got it, I mean damn! And when I got to the part where you were in that wreck. haha Thread reads like a bad story. Glad you finally got it fully laid out. Aint that the best feeling when it's late at night and you're sweaty and shit's a mess but you're done and it's laying on the ground. I remember finishing my 89 at like 3 or 4 in the morning and I was so worn out, I'm sure my friend was too, but it was just so freakin sweet to finally be done! And then you hit those switches for the first time... badass!
#1245 |
David
Trucks looking great man! Whens it going to be all the same color? Redoing it in primer would look great.
#1246 |
#1247 |
You really need to get another brace in there asap though. I was really surprised to see people riding around back there with only the one brace. I thought you were just pushing luck with just you in the truck, but I really can't believe your friends rode back there. I know you want to drive around as much as possible now that you're bagged, but just wait until you have another brace. I thought I remember you saying you got that steel for pretty cheap? Other than that, the truck looks good. The new bumper and grill look awesome. |
#1248 |
#1249 |
#1250 |
Bar won't work in front. My upper link bars and differential bracket hit. I'm going to do some gussets on the front. The steel i got it 1/4" thick and heavy as hell. Cost $30 for a square flat piece of it too. I'm going to measure and mark it then cut off two gussets from it and weld them on the front of the brackets. That should do the trick..
