My newly acquired truck! =]
Old 12-28-2008, 04:01 PM   #851
Crazy for a square body
Kiko's Avatar
Re: My newly acquired truck! =]
Replaced the power steering line,and replaced the plugs and wires. It stutters a little bit still but not as bad. Mostly at low rpm but when driving it'll stop stuttering when i get up in speed but high rpm it wants to stutter just a little until i shift.
I drove it up the road to captain d's and the gas station though so that's a major improvement =)
Old 12-28-2008, 08:10 PM   #852
Registered Boozer
coloRADo_S10's Avatar
is your idle high enough?
Old 12-28-2008, 09:16 PM   #853
Kiko's Avatar
I'm not sure. It stopped stuttering now though. Hitting 70mph and flooring ti tends to help that
I guess it was just from sitting for so long and me driving like a lunatic today got everything cleaned out. It drives pretty nice but the steering has slack and it pulls to the left and it's hard to keep it straight and not go into someones lane. I did get to drag it tonight and today. I even drug down my road with my neighbors watching. They didn't know what the hell was going on
Old 12-29-2008, 02:37 AM   #854
Kiko's Avatar
****ing fan clutch flew off the shaft it goes on and went straight into my new (Almost $200) radiator and put a tiny hole in it. I had to limp home with no fan and a leaking radiator and stop every so often to let it cool down and put more water in once it started climbing.
Basically i need to buy a new fan clutch,and blade. I would have used the blade but we couldn't find it in the road. It had $14 worth of bolts on it that i would have liked to returned and gotten the money to put towards parts too.
Except for that one thing it drove decent today.
Pics when i get my camera (Tommorow) out of my mom's car. While i'm waiting on the money for parts i think i'm going to go ahead and pull that leaf.
Old 12-29-2008, 02:44 AM   #855
Registered Boozer
Im thinking you might have had some carbon in it to make it stutter. You might have just burnt it out. So thats good but i say don't waste anymore money on a new fan put the electric one in. You haven't been driving this long whats a little bit longer.
Old 12-29-2008, 05:01 AM   #856
Mr. Sparkle
Onimun's Avatar
Sorry to hear about that Kiko. Should have sued Locktight.
Old 12-29-2008, 01:17 PM   #857
Kiko's Avatar
Nah the bolts were good. The fan clutch actually came off the shaft that bolts it to the water pump pulley. The shaft is still bolted to the pulley but the clutch and the fan blade (Still bolted to the clutch) shot off and flew into the radiator then shot out from under my truck after putting a pinhole in my radiator.
Carbon might be the problem. My plugs when i changed them were kinda black so i'm assuming it's carbon. I've never let it sit this long so i'm not sure what it could be. I'm just going to run it and see if it starts to clear up. It seems like it's getting a little better already.
Quick question though,the hole in the radiator is really tiny. It's a pinhole really. Is there anyway to patch a hole that small or am i going to be forced to buy a whole new radiator?
Old 12-29-2008, 05:20 PM   #858
the brown turd
s10v8drew's Avatar
i've used quicksteel several times to patch things..i punched a hole in my oil pan once and cleaned it up real good and put that shit on it and it worked fine, its like a putty that hardens..it wouldn't hurt to try that first since its only about 5 bucks...
Old 12-30-2008, 01:23 PM   #859
Kiko's Avatar
That quick steel seams to be doing the job. I need to wire the + power wire from the fan to an ignition source then i'll be good. It's only temp though then ii'm just going back to a regular fan. I'm not too into the e-fan now that i've messed around with it. Way too much trouble..
Old 12-30-2008, 11:56 PM   #860
ados egnaro
NevurMind85's Avatar
eh it only seems like trouble im glad i finaly did the efan. i dont know why i waited so long.
Old 12-31-2008, 12:07 AM   #861
Kiko's Avatar
I wired it all ghetto for now. I just ran the wire between the fender and cab then inside the cab by the door hinges and since i dont' have a/c i stuck the wire in with the fuse for the a/c. I think my transmission is leaking where the shifter goes on. The gasket it had when i took it off wasn't re-usable and they don't sell one at the parts stores so i didn't put one on. I'm planning to check it once it cools and see i it's lost fluid and put silicon on and put the shifter on.
Besides the fluid dripping on the y-pipe and smoking it drives good except for something in the alignment or something beinf out of wack. It stays straight though but you have to really pay attention and try.
Old 12-31-2008, 12:34 AM   #862
the brown turd
s10v8drew's Avatar
quicksteel works again i love that shit
Old 12-31-2008, 01:20 AM   #863
Registered Boozer
awesome! sucks that it happened but its probably for the better
Old 12-31-2008, 02:32 AM   #864
Kiko's Avatar
Looks like i might be driving to work in the morning. I'll post some pics tommorow when i get off and have a chance to take some.
Old 12-31-2008, 02:14 PM   #865
Come out and plaaaaaaay!
Svtzx555's Avatar
You have to use silicone when you put the shifter in the transmission.
The truck probably just needs to be aligned...I would check out the front end first though to see how wore out the tie rod ends, center link, and idler arm are before getting it aligned.
Old 12-31-2008, 09:15 PM   #866
s10blaazzaa's Avatar
this is what happens when i tell you to do something and you dont do it. the fan and clutch were both bent and messed up in the first place. next time you should listen to me buddy. you cannot use raggedy shituff.
Old 01-01-2009, 04:26 AM   #867
Kiko's Avatar
Yeah,yeah. I know. I just never listen. You should know that by now. It's all fixed. The only problem i'm having now is similar to your fuel pump problem. Randomly it will start and immediately stumble and die. It will try it when sitting idling sometimes and other times while driving down the road.
It just started doing it today.
Old 01-01-2009, 04:31 AM   #868
Registered Boozer
What? No Pix!
Old 01-01-2009, 08:56 PM   #869
Kiko's Avatar
No pics. I forgot to get some at the gas station when i stopped for gas. I did get some kickass videos though,courtesy of my kickass girlfriend
I'll try to get pics tommorow. I just keep forgetting or i don't feel like opening my gate and driving somewhere just to get photos. I'm taking a weeks vacation hopefully Monday and i hope to be able to pull the leaf from both sides and remove the bump stop brackets and put my bed back on. While i'm at it i'm going to clean up the inside and start swapping my doors and bench seat. Hopefully clean up under the hood and get rid of all the hacked stuff i did under there so i coudl drive it and do it proper. I'm also going to start making a list of parts to get my front end back like it was (Minus a 1 piece grill)
Old 01-01-2009, 09:03 PM   #870
Registered Boozer
awesome!
Old 01-02-2009, 12:50 AM   #871
Kiko's Avatar
I popped my hood to fix my passenger headlight and get it hooked up only to find rusty water on my air cleaner,alternator,and hoses under the hood. I got to inspecting stuff and my upper radiator hose touched the alternator fan tonight and it got a hole in the side and sprayed water everywhere. I fixed the headlight so they both work now (although the passenger light is shitty and is temporary until i can afford a new set)
I've got to buy another hose and figure out a way to keep that from happening again. I want to just buy another truck to drive though. I found a GMC S15 that's really clean but they want $1500 for it. I won't go over $700-$1000 though because that price is way too high. It's a 2.5 4 cylinder with a 5 speed. It's also just like my truck. I'd love it for a daily since it's a 4 cylinder and i could easily slam it the first day i bought it and drive it.
I need to figure out what's wrong with my truck though that's causing it to try and die randomly. If i could fix that then it would be fine.
Old 01-02-2009, 10:19 AM   #872
Svtzx555's Avatar
If you've got rusty water in the cooling system, you need to flush that stuff out.
And just look at the GMC and offer them less.
Old 01-02-2009, 12:06 PM   #873
Registered Boozer
good advice. ^this guys on top of things
Old 01-02-2009, 12:33 PM   #874
Svtzx555's Avatar
^^^I know this guy...he gets on top of certain things when he feels like it. Lol. But yeah, he needs to get on flushing that shit out and not using bend parts like the fan and clutch that he knew were bent. Oh well. You like and learn.
Kiko, what happened to that upper radiator hose I gave you? Did you give it back or do you still have it? I think I remember you saying that it was too short or something? Measure what you have and I'll see if I have one sitting in my garage.
Old 01-02-2009, 01:53 PM   #875
Kiko's Avatar
It's not too bad but is does have some rusty color to it. I'm buying a new hose when i get off work because i don't know where that hose is if i even have it still. I need to fix my engine problem too. I asked and i also read up on it and it seems like maybe a small intake leak. If so i'm just going to drive it close by my house and be carefull with it until i can save the $261 for an edelbrock intake that i really want. Once i get it i'll put new gaskets on and replace the manifold and call it a day.
Before i go and do all of that though i'm going to check and make sure it's leaking. I just need some carb cleaner to spray around the edges to check for leaks. I'm taking a weeks paid vacation Monday so i'll have pretty much all week to work on it and pull those leafs.
I should be driving it again tommorow.
What are you doing this weekend?
Old 01-02-2009, 02:58 PM   #876
Registered Boozer
I know you weren't asking me but im partying. lol its my ****in bday!
*********thread jack******lol
Old 01-02-2009, 07:09 PM   #877
Kiko's Avatar
Happy birthday.
Once i get the engine problem fixed i'm looking to buy
*Chrome front bumper without trim holes
*Billet 3 piece grill
*Clear corners and bumper lights
I hope to get another passenger fender too 'cause the one i have is mangled and doesn't line up with the body because of it. I'm fixing to leave work and hopefully make quick work of that radiator hose.
Old 01-02-2009, 10:36 PM   #878
V8 with bags
V8Blaze's Avatar
im really glad to see this thing back on the road, your luck seems about like mine, ive had everything break atleast twice on my truck while building it. Glad to see im not the only one fighting a dime. Looking forward to some pics with the bed on
Old 01-03-2009, 12:41 AM   #879
Kiko's Avatar
Well,it tried dieing on me 2-3 times before i pulled out of my parking spot at captain d's tonight. It also stumbled when i was pulling out of the auto parts store into the turning lane. I tried carb cleaner and i can't tell if it's leaking on the intake. I sprayed around the edges where i could get and didn't notice a change in idle. Could it be timing again? I forgot to hook up a plug to the side of the block when we were setting the time but i hooked it up afterwords. It's on the passenger side in the middle near the header. It looks like an 02 sensor or something. It used to drive fine. Any ideas? It tries to die when idling sometime and sometime when driving. Giving it gas stops it though.
I'll put the bed on after i pull a leaf spring this week and cut the bump stop brackets off.
Old 01-03-2009, 02:14 PM   #880
Kiko's Avatar
I brought my camera to work and i have pics for those of you who were wanting them. I'll post them when i get home because i didn't bring my camera cable to work with me.
Old 01-03-2009, 07:36 PM   #881
Kiko's Avatar
I'm going to pull the leaf springs tommorow or Monday. I haven't decided yet but it'll be done this week and the bed will be back on. I'm going to try and get to the junkyard this week and rummage around for some parts if i have the money.
EDIT: Before anyone rips on me for my driverside headlight,i didn't have any screws to hold it in and i had to go somewhere so i just electrical taped it so it would stay up and no wobble when i drove. I think i have some screws somewhere but if not i'll buy some this week and that's one of the things i was going to tidy up
Old 01-03-2009, 08:07 PM   #882
Registered Boozer
Truck looks good. Diggin' the racing stripes on your headlight.lol
had to give you shit. You had it comin. lol Really looks good tho.
Old 01-03-2009, 08:47 PM   #883
Kiko's Avatar
Ha. I should have known you'd mess with me about it :P
I'm pulling the leaf springs right now. Just stopped long enough to double check the how-to since this is my first time messing with leaf springs.
Thanks s10-forum
Old 01-03-2009, 08:52 PM   #884
is gettin there...
Driveway Kustoms's Avatar
i think i remember telling you to cut those stops when you had the frame apart..... lol had to bust your balls too
Old 01-03-2009, 10:34 PM   #885
Kiko's Avatar
I'm removing the bump stop brackets tommorow when it's daylight. I have the driveside dropped. I'm fixing to measure the difference between the driverside and passenger side real quick. I'm going to trim the bumpstops for now.
Old 01-03-2009, 11:21 PM   #886
Kiko's Avatar
It dropped about 1 1/4" without the bed on. My passenger u-bolts are ****ed. Something bent the hell out of them and one is going to have to be cut off. I can't get them until tommorow morning when the parts store opens either. So no seeing my girlfriend tonight and no driving my truck
Pics in a bit..
Old 01-04-2009, 12:10 AM   #887
Kiko's Avatar
My u-bolts. I might can save them but i dont know. It'll be a pain in the ass to do that's for sure. I'm thinking i can cut below the nut where it's bent and since i'm pulling a leaf i'lll have plenty of u-bolt sticking out because the leaf pack won't be so thick. The other u-bolt i may can bent out some with a couple big ass wrenches. IF i have to that is. I'd much rather buy two brand new u-bolts. All that's left is to get the other u-bolt off and pull the leaf then bolt the leafs back and bolt the u-bolts back.
No bed + a muddy front yard = ****ing sucks
And finally i get to use it
Old 01-04-2009, 01:41 AM   #888
Kiko's Avatar
Fixed on u-bolt. The other i had to cut so much off that it isn't long enough to go through that bottom plate and tighten up. I went ahead and got the nuts threaded on the one u-bolt and i lowered it back down so both wheels are on the ground. I'll get another u-bolt tommorow. I'm going to go ahead and remove the bumpstop brackets and install my bed too. The bed won't go on until i can get enough help though. I can't lift it alone and i have to get 2-3 people to lift it without messing something up.
Old 01-04-2009, 04:28 AM   #889
Registered Boozer
awesome! Just curious but is it going to be a crappy ride now?? will it bottom out??
Old 01-04-2009, 02:12 PM   #890
Kiko's Avatar
It will with the bumpstops and brackets. I'm not sure once i remove them because i never rode with monoleaf + the overload. I'm hoping my shocks are stiff enough to help prevent bottoming out. I already bottom out withe the 3" blocks but that's with bumpstops. I won't really know for sure until i drive it.
It's only temp though because i have some of the parts already to bag the back. I'm waiting on income tax to buy my 4 link. For now i'm just buying small parts and the parts to fix my front end. It will be fully bagged soon so the monoleaf will be gone.
Old 01-04-2009, 03:26 PM   #891
Registered Boozer
and then when you bag it you are going to send me those blocks. lol
i was curious about the ride. i dont know any of that stuff. i just add leafs.lol
Old 01-04-2009, 03:43 PM   #892
Kiko's Avatar
I've never added or removed leafs so i have no idea. I have seen trucks riding bumpstops with monoleaf and i have seen trucks (Like mine for instance) that aren't even touching the bumpstops. I have the passenger bracket off btu i'm not doing the driverside yet. I'll do it tommorow. ****ing GM welds are a pain to grind off..
If you want the 3" blocks later i'll ship them to you cheap. I was contemplating keeping them and if i ever get a v8 first gen project i could use them on it.
Old 01-04-2009, 03:48 PM   #893
Registered Boozer
Hell ya i will. But i wont if you are going to use them again. Maybe ill still make them if i can get one of the teachers to stop bitching about the DONATED materials they get and let me use the damn aluminum. lol
But if not GIMME!!!!!!!
Old 01-04-2009, 03:51 PM   #894
Kiko's Avatar
I forgot you were making some. You should stick with that. It would be a lot nicer in the end because you made them yourself.
****ing mud....
Old 01-04-2009, 03:55 PM   #895
Registered Boozer
Ya i would like to. We/ll see when you start baggin the rear of your truck we'll talk about it again?? Whether i want to wait to make them or not.
Old 01-04-2009, 03:56 PM   #896
Registered Boozer
License plate=awesome
Old 01-04-2009, 04:01 PM   #897
Kiko's Avatar
Thanks
I wanted FKNL0W but the woman at the dmv seen through that so i had to make it less "Vulgar". I got the actual tag in the mail about 4 days after it got totaled which just so happened to be the same day i got it hauled home...
Old 01-04-2009, 04:06 PM   #898
Registered Boozer
Thats awesome!
Old 01-04-2009, 04:14 PM   #899
Kiko's Avatar
Bed is almost done. I'm touching up a couple spots that i'm not happy with but it's pretty much finished.
God i'm bored.........
Old 01-04-2009, 06:18 PM   #900
ados egnaro
lmfao at the mud hahahahahaha.
Page generated in 0.67207 seconds with 32 queries
[Output: 220.59 Kb. compressed to 201.66 Kb. by saving 18.93 Kb. (8.58%)]
