My newly acquired truck! =]
Old 10-29-2008, 06:58 PM   #651
Crazy for a square body
Kiko's Avatar
Re: My newly acquired truck! =]
Thanks. It's pretty nice because whatever i need i can find it somewhere.
I hope to be dragging again real soon
Old 10-29-2008, 09:09 PM   #652
Kiko's Avatar
Got the rear brake line on. I need to tighten the connections but it's bolted down snug. I have the front ready except for removing the line from the calipers. I need vice grips for that because it's too tight and trying to strip out. I'll do that tommorow when i can borrow a set since i don't have mine.
After that's done the next order of business is to swap fuel lines to the frame. I've got the front tires off my truck and waiting to swap spindles when i get the motor mounts on my new frame. I think i'm just going to cut the old ones off the frame and buy a new set this payday. They're probably shot anyway and too they're so rusty they would most likely be near impossible to remove.
I only got 1 hour in before dark but that was one cold ****ing hour of work. It's freezing outside already
Gas tank seems level now too. I've got to finish up a little bedliner under the transmission crossmember and do some spots that were missed on the front still. Not much longer...
Old 10-29-2008, 10:37 PM   #653
V8 with bags
V8Blaze's Avatar
hell yea its gonna look awesome with the entire frame coated. Its good motivation to keep it clean lol
Old 10-29-2008, 10:58 PM   #654
Kiko's Avatar
Dude,I washed my primer like it was a million dollar paint job,lol
Old 10-30-2008, 12:59 AM   #655
orangesonoma supporter
JChapoton's Avatar
Location: Warren, MI -- Home of GM's Tech Center--soon to be the new GM Headquarters
might I suggest you paint the gas tank and drive shaft and axel tubes. I will only take a few and is easier to do with the body off.
Old 10-30-2008, 02:40 AM   #656
Kiko's Avatar
I'm not really concerned with the driveshaft. The gas tank will eventually be replaced with a brand new one so i'm not worries about it. The rear end could use cleaning but i'd prefer not to mess with it right now.
It would be a nice touch but i've been without my truck for 3-4 weeks now so i'd just like to get it put back together and drive it right now.
Old 10-31-2008, 01:24 AM   #657
Kiko's Avatar
Got the front brake lines on. The paint brush has some thinner on it still and it thinned the bedliner when my girlfriend was putting it on (While i was laying in the dirt with a wrench,undoing the brake lines..) so the parts she did won't stick i don't think. Some of it looks ok while small parts look milky so i may have to hose it off and re-do those parts. It's all good though. It was kinda my fault anyway because i should have dried the brush out better after cleaning it.
No pics since everybody knows what brake lines look like when installed. I plan to get the fuel lines removed tommorow after work and installed onto the new frame. Then Saturday i will probably label all of the wires under the hood that way when Sunday comes and i put the motor on the frame i won't have to figure out where all of those wires go.
Hope to have motor bolted on Sunday evening and have my fuel lines connected to it. Maybe Tuesday or probably th next Sunday i will transfer the cab and hook up the wires and bleed the brakes and clutch (Yay....not. Bleeding hydraulic lines suck)
Busy,busy
Old 10-31-2008, 01:42 AM   #658
Registered Boozer
coloRADo_S10's Avatar
awesome! keep it up!
Old 10-31-2008, 08:46 PM   #659
Kiko's Avatar
Disconnected the fuel lines but i need to pick up some 3/8" drive sockets. I have 13mm sockets but no ratchet to fit them
A couple more nuts and my fuel lines should come off the frame. I won't be working on it tonight probably but i'm going to try and get off work early tommorow if i'm lucky and my co-worker shows up.
Just waiting on my girlfriend to get off then we're on our way to the coast guard base for a private tour
Pays to have a friend/co-worker who's in the coast guard..
Old 10-31-2008, 08:52 PM   #660
Registered Boozer
Are you going for fun?
Or are you interested in the service?
Sounds like fun anyway!
Old 10-31-2008, 09:15 PM   #661
Kiko's Avatar
Just going for fun. He's going to show us around the base and stuff so i thought it would be cool to take him up on the offer.
Old 11-01-2008, 01:16 PM   #662
Kiko's Avatar
Picked up some sockets last night but didn't really do anything to it because it was too late. Definately will have the fuel lines off tonight. The engine transfer should go on as planned tommorow.
Old 11-01-2008, 07:56 PM   #663
Kiko's Avatar
Fuel lines are on. I don't have them snapped into the clip that holds them to the frame but i'll fix that tommorow. I'm tired and ready to relax form work. It's starting to look like a truck again
Pics tommorow when the real action takes place.
Old 11-02-2008, 05:48 PM   #664
Kiko's Avatar
Unbolted the engine and removed the spindles and bags. I also put my steering box onto the new frame. I couldn't get an engine lift but the mechanic i know down the road is letting me borrow one tuesday when i'm off work again so hopefully it will be on the new frame by the end of the day.
Old 11-04-2008, 04:13 AM   #665
Kiko's Avatar
I'm ****ing tired....
I hope to get it bolted on the new frame tommorow. I need to pick up a new positive battery wire and some misc parts like a 90 degree end for one of my vacuum lines because it broke. Also need some gaskets and gear oil. I'll post tommorow evening when i'm done with everything.
Old 11-04-2008, 04:55 AM   #666
Registered Boozer
Awesome.
I hope by the time i get back from Cabo to grab up a newer 2.8L to put in my 4wd. Need it for all the snow we've gotten out here. lol!!!
Keep it up! I seem to like that phrase! But it fits. I can't wait to see what you do next. When your done are you going to sell all the parts from your parts truck to recoop some money or just keep them as lawn decorations?
Old 11-04-2008, 12:27 PM   #667
Kiko's Avatar
Lol,i am going to sell some parts but i may paint a few and make some lawn ornaments.I'm using the control arms off my old frame for my blazer aswell as some others parts. The cab off the donor truck is for sale is anybody needs it. $75 and i have the title to it.
Old 11-04-2008, 01:25 PM   #668
Registered Boozer
lawn ornaments FTMFW
Old 11-04-2008, 07:02 PM   #669
Kiko's Avatar
Engine is on the new frame. I need to find the bolts to hold the engine mount to the frame mount though. I have some in to hold it but i can't find the right ones. I'll find them and put them in asap. I need a transmission mount thursday when i get paid too. They only run $7.99 plus tax and take like 5 minutes. The engine fell today though and i need a harmonic balancer and one other pulley on the front. ****ing sucks but oh well.
I've got pics but i'll upload them after i return the engine hoist to the mechanic's shop that let me borrow it.
Old 11-04-2008, 07:17 PM   #670
Off Vanning. bbl
95xtreme's Avatar
How bad was the damage to the harmonic balancer? If it took a hard enough hit to destroy it you may have damage to the crank as well.
Old 11-04-2008, 07:55 PM   #671
Kiko's Avatar
Not that bad. It bent the edge of it but it wasn't catastrophic. It's bent just enough to piss me off. I'm going to price them new when i get home tonight.
Old 11-04-2008, 08:26 PM   #672
Off Vanning. bbl
95xtreme's Avatar
why not snag them off your blazer motor for now?
Old 11-04-2008, 10:35 PM   #673
Kiko's Avatar
Those are bent too...
I need more parts anyway. I can't hook stuff up and drive it until i get those parts and i won't be able to get them until 2 days form now so it wouldn't help much. I don't think i will be making m deadline of my birthday though
It's this sunday and unless i work on it form 6pm until 1am every afternoon i won't make it...
Old 11-05-2008, 02:48 AM   #674
Kiko's Avatar
Old 11-06-2008, 10:34 PM   #675
Kiko's Avatar
Picked up some parts today. They didn't have the pulley for the harmonic balancer though. I did however get the power steering pump pulley but i am waiting until Sunday to rent the puller/installer to put it on.
I bought this setup so i can install my bags and lines then use a portable air tank with 120psi to raise the front up so i can move it out from the carport to install the cab (No room under there)
I need to look for the pulley on the harmonic balancer but nobody local has it except for junkyards probably. I may try and pull one local at the u-pull it and just spraypaint it and make it look new or order one off summit or something...
Didn't have time to get the front put together but i plan to have the lower control arms back on,spring pocket cut,and bags installed tommorow evening after work. Pics tommorow..
Old 11-06-2008, 10:37 PM   #676
lowconstruction's Avatar
dude i bet your neighbors really hate you.
Old 11-06-2008, 11:00 PM   #677
Kiko's Avatar
Nah they don't really care. The older lady who lives next door (You can see her hous ein some of the pics of the frame under the carport) actually encourages me on my truck. Also most of the remaining neighbors love my truck and were sad it got wrecked. While i don't like them all the time i must admit they can be pretty cool people.
Update: I called summit and the guy found me a chrome pulley for the harmonic balancer that is a stock replacement. What's awesome about it,the chrome version is actually cheaper than the black one
It should be here around tuesday considering i'm ordering it online now.
Btw lowconstruction,i have a '86 blazer frame,some parts,and another 4.3 engine on the other side of my house aswell
Old 11-06-2008, 11:14 PM   #678
94 S10 355 Tremec
94 SS S10 4.3's Avatar
Damn that is alot of progress..
*Subscribing
Old 11-06-2008, 11:33 PM   #679
Kiko's Avatar
Was told the worng part on summit. The only pulley they have is an underdrive pulley so i'll be getting a few more horsepower and i am getting a new serpentine belt too since the pulley is a little smaller.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ASP%2D541000&N=70 0+0&autoview=sku
http://store.summitracing.com/partde...5&autoview=sku
Old 11-08-2008, 02:36 AM   #680
Kiko's Avatar
Bags rub so i need to cut the spring pockets some more but i didn't bolt everything down yet anyway so it won't be a hassle to remove. I've got to take the bags out tommorow or Sunday and cut the spring pocket then the front should be done. I have it setup so i can fill my portable 7 gallon tank to 100psi and air up the truck level using it.
Pics but i don't have time to resize and upload tonight. I'll post them on my lunch break tommorow at work.
Old 11-08-2008, 01:32 PM   #681
Kiko's Avatar
If my transmission was raised a little this is how it would actually lay..
My temp setup for working on it..
Down..
Up...
Whole thing...
I've got to take my bags back out and cut the spring pockets more but other than that it's good to go. I need to tighten down my castle nuts and lower control arms but everything is just on temporarily right now. Next step after getting all of that finished is tightening my brake lines and fuel lines then put the cab onto the frame and start plugging wires and stuff back up. I need to charge my battery too i bet.
Old 11-10-2008, 02:41 AM   #682
Kiko's Avatar
Old versus new
Damage to the old power steering pulley
Installed
Driveshaft connected
Everything is how it used to be....but shouldn't this be in further? It will come out more when i slide the transmission forward so it goes into the crossmember hole.
Damage to the hamonic balancer pulley (Crankshaft pulley or w/e else you want to call it)
I tightened my brake lines earlier and checked my driveside bag. It still leaks for some reason but **** it. I'm going to see if i can get my friend Nick over to look at it since he has more experience and maybe he can figure it out. I may have to buy another bag because i can't find a leak on the fitting or anything. I'm fixing to look on summit for a fan/water pump pulley because my dad pointed out mine is ****ed up. The shaft on the pump looks good but the pulley looks bent. I'm considering using the electric fan off our old '91 cavalier and removing my engine driven fan. I'm not for sure on it yet though. Anywya that's my current progress. i need to finish tightening stuff and making sure everything is lined up right then i will be ready to lift the cab onto the frame,bolt it down,and start hooking up the ratnest of wires. Progress when i get everything tight and figure out how to get the cab up and onto the frame.
Old 11-10-2008, 12:11 PM   #683
Registered Boozer
OK, im back! It just keeps lookin batter. Did you try takin the bag off and filling it with air, put it in a bucket of water and see if bubbles appear??? That way you can figure out if its the bag thats leaking or not.
Old 11-10-2008, 01:28 PM   #684
Kiko's Avatar
I thought about that but no,i didn't. I might do it this evening when i get home but i hate taking the cotter pins out and removing everything then putting it back. It's a pain. I'll do it though and if it's the bag i guess i'll order another dominator 2500. I'm trying to find a water pump pulley right now. Summit has one from march pulleys that is $61.88 and should work nicely with my underdrive pulley. I'm ordering it or a stock one form lmc. Probably just order the one form summit this thursday when i get paid again.
Old 11-10-2008, 01:40 PM   #685
Come out and plaaaaaaay!
Svtzx555's Avatar
Thats some mad progress. Keep it up.
Old 11-10-2008, 08:46 PM   #686
Mr. Sparkle
Onimun's Avatar
Looking good Kiko!
Ever think about cleaning the watery rust off the engine while the engine was out? May look 100X's better once you get the truck back together.
Old 11-10-2008, 09:37 PM   #687
Kiko's Avatar
I found the leak on the driverside. It's coming from the bag fitting. I just ordered a new one from suicidedoors and it should be here by the end of the week i hope. My underdrive pulley is being delivered tommorow sometime. I just need to figure out how to keep my crankshaft form turning when i try to break those bolts loose.
I have thought about cleaning the engine but i'm not sure what to use to get it clean..? I'm ordering my water pump pulley this Thursday. I found one on summit that will work with my underdrive pulley setup.
I've decided that i'm running a chrome 3 piece grill since i only have core supports for the older grills. I'm sticking with the bumper like i had and the clear bumper and corner lights though.
I've got to get my fitting replaced then i can air it up and roll it out next to my old frame and lift the cab onto the new frame.
Old 11-11-2008, 01:27 AM   #688
Kiko's Avatar
Got my pulley off the harmonic balancer (Learned a trick from a car forum actually) and took a look at the water pump. I know there's a round piece with studs that goes onto the shaft then the pulley slides on and finally the fan slides on and bolts it all together. I can't figure out how the round piece is held onto the shaft though. It looks like it has a groove for some kind of retaining clip but i looked at the one off my blazer and i can't see one. I'm thinking about just swapping the water pump off the blazer but i need gaskets and silicone first.
Underdrive pulley will be on tommorow. Pics then.
Old 11-11-2008, 01:49 AM   #689
white wall member
tolowinorlando's Avatar
good work mang
Old 11-11-2008, 02:19 AM   #690
Registered Boozer
So freakin glad you found the leak. It woulda been a bitch to take the bag off. I just suggested it cuz i wouldn't wanna buy another bag.$$$
Screw cleanin the engine get it running like you want worry about the engine later like you were saying before. BUT it would be a good i dea while its out cuz its convenient.
Old 11-11-2008, 07:51 PM   #691
Kiko's Avatar
Got my underdrive pulley earlier this afternoon..
Difference..
Installed..
I might go by real quick and pick up some water pump gaskets and swap my water pump from my blazer 4.3.. Pics if i do.
Old 11-11-2008, 10:03 PM   #692
Kiko's Avatar
Swapped water pumps with my blazer's 4.3 after getting gaskets and silicone. Pics later. I've still got to swap the radiator hose on it because mine has been replaced since i bought the truck and the other is old as crap. Getting a new fan blade from summit Thursday. I should have my new serpentine belt on tonight when i get back home. I'm eventually replacing all of the pulleys but for now i'm just replacing enough to get it running. I need to do a couple more things still then i think it will be ready for the cab.
That underdrive pulley has got me itching to do more stuff to my engine so once it's fully bagged i'd like to build up my 4.3 a little bit too.
Old 11-12-2008, 02:49 AM   #693
Kiko's Avatar
Old water pump
"New" water pump (Came off my blazer 4.3)
The leak....
I put everything together on the driveside but i didn't tighten the castle nuts on the balljoints yet. I just set everything in lace and hand tightened the nuts so i could take it off the jack and get it normal for now. The new fitting for the driverside bag is on it's way and once it get's here i'll just lift the truck,stick the jack under it,raise the jack,then let the air out of the bags and swap the fitting.
I need to find one piece for my valve cover. Anybody know what the peice is that comes out of the passenger side valve cover and the vacuum line connect it to the throttle body? The previous owner electrical taped it because it was broke and i can't figure out what they're called so i can replace it...
Old 11-12-2008, 01:48 PM   #694
Svtzx555's Avatar
A pic might help. Probably some sort of pcv valve. Hope you get it running soon. I just got my s10 back up and running. A new distributor and spark plugs work wonders.
Old 11-12-2008, 05:25 PM   #695
V8 with bags
V8Blaze's Avatar
its the pcv, if the metal part messed up or the rubber, if you need one ive got a whole 4.3 ill mail them to you if you need em man
Old 11-12-2008, 11:51 PM   #696
Kiko's Avatar
It will be soon. I need to figure out how i am getting my cab on without damaging stuff. I'd prefer to get a lot of people and lift but it's hard to get that many people at the same time. The engine pretty much needs a fan blade and it's good.
Old 11-12-2008, 11:53 PM   #697
Kiko's Avatar
Thanks but it's cool. I'll price them at advance and probably buy a new one and install it tommorow evening after getting home from work. I always wondered why it was taped but i never messed with it. Glad i didn't
Old 11-13-2008, 02:36 AM   #698
Kiko's Avatar
Here's an idea...couldn't cap off where the hose form the pcv valve goes into the throttle body then use one of those "Breathers" or whatever that some people have on their valve cover? Or would that hurt anything?
Old 11-13-2008, 05:20 PM   #699
V8 with bags
V8Blaze's Avatar
the pcv is setup like that so the vaccum in your intake sucks the pressure and what not out. id leave it setup how it is. ive never been able to find an exact description of the workings of that. But i know older cars *40s at the newest* had just hoses that run out and down the side of the engine and they would smoke out of the tube so alot of guys hook up new style pcv systems to do away with it.
Old 11-13-2008, 11:05 PM   #700
Kiko's Avatar
I just bought another pcv valve and popped it in. I was trying to take out my heater hose form the intake manifold but the ****er is corroded to hell and i was wiggling it and it just broke off in my hand. The threaded peice is still in the intake manifold (****!!!!!) but a little is sticking out so maybe,MAYBE i can put some plyers or vice grips on and work it loose with some penetrating spray and patience.
If not i'm going to try buying a big bolt extractor and if that doesn't work i'm contemplating just using a rubber mallet and screwdriver to break that part off and take a shop vac or something and get any pieces that fall into the hole on the manifold.
Shits pisses me off....
Also,i put in 4 quarts of gear oil in the transmission and it's not full. How many does it take? The auto takes like 5 but i don't think 1 more quart will do it on mine. I've been having an aggrivating day that has just dragged by..
Page generated in 0.68006 seconds with 32 queries
[Output: 226.64 Kb. compressed to 207.79 Kb. by saving 18.85 Kb. (8.32%)]
