My newly acquired truck! =]
Old 10-07-2008, 06:29 PM   #551
Crazy for a square body
Kiko's Avatar
Re: My newly acquired truck! =]
Quote: Originally Posted by GreaseMonkey74
Cool, that's right down the road from where I work. Next time I drive my 91 s10 I'll swing by. Not to rob your thread but here is a pic of it:
Nice. I never seen it before. And yeah stop by one day. I work everyday except sunday and tuesday unless something happens like the wreck and i'm off for that.
We normally leave around 5 every day even though it says 5:30 btw
Old 10-07-2008, 06:31 PM   #552
Kiko's Avatar
Quote: Originally Posted by Svtzx555
Hey, if you can't get your g/fs dads truck, I got my s10 running halfway decent and I'll go up to the junkyard with you.
Sounds good. I would have to get a ride out there anyways. If we go in her dads truck you can ride with us if you want. It's got the half doors or w/e you want to call them. I'm going there soon as i get $100-$200 and buying a shitload of stuff to get it driveable.
Old 10-07-2008, 06:32 PM   #553
Kiko's Avatar
Quote: Originally Posted by lohenslohe
poor poor POOR chrome.
Yeah,it's a bitch. I pretty much had my front end done too. I will be buying the same bumper and the same grill though along with another set of those corner and bumper lights so no biggie
Old 10-07-2008, 06:35 PM   #554
Kiko's Avatar
Update:
Core support is off and both fenders are off. The motor mounts look like they moved a little so if i can lift the engine up some and loosen the mounts and move them back to the passenger side some it should center the motor and get it back where it was.
I need to get a floorjakc under the truck to lift it so i can remove my right,front wheel and get the tire fixed or replaced then put it back on. That will get it almost normal again. I then need to cut the frame and have those pieces welded back on. After that is on and the 2x2" crossmember between the frame for support i will almost be ready to bolt on fenders and everything then pherhaps test drive it (SLOWLY!) around the neighborhood. =)
Old 10-07-2008, 11:03 PM   #555
Day Dreamin
lohenslohe's Avatar
oh well then why am I all pissy about it. lol. trooper man, after ish happens you still staying strong on the build.
Old 10-08-2008, 01:23 AM   #556
Kiko's Avatar
Of course
Bag setup still works
The frame only appears bent in FRONT of the control arms so i just need to unbolt anything bolted to that section and measure then cut it off and measure 2 new pieces and weld them to replace the old pieces.
Engine sits crooked but i checked and it appears to be the motor mounts. From what i can tell something shifted involving them so i should be able to loosen them,lift then engine up a little,move it back centered,then tighten the mounts back down. I just need to get my hands on an engine lift.
Flat tire but it could have just gotten pushed off the rim and let the air out. I can't tell for sure yet but i plan to try airing it up first before taking it off.
Stripped and waiting for me to fix the frame and align the engine. Once those two things are done the major parts will be out of the way. Then it's on to installing the radiator and putting on my core support,fenders,hood,and headlights. Also aligning the bed and bolting it back down (Always been a bitch)
Oh,and this is what's left of my grill and lights... ****in bitch
I'm making decent progress on it but i lack the funds this week to make a shopping spree at the junkyard. My goal is to atleast have it back driving down the road by my birthday in November. It'll be my birthday gift to myself
Old 10-08-2008, 01:31 AM   #557
V8 with bags
V8Blaze's Avatar
that frame rail looks twisted badly, and since you idler arm bolts to it, its going to severly scew with your driving ability of it. Id highly suggest putting that on a frame machine, and get it checked out. As bad as that front horn is i assure you the first 2 feet of that rail is out of whack
edit, both those rails look pretty pushed to the passenger side also. Really suck to see it happen when y ou were making good process. Id call around about getting it put on a machine to check it out and see what they can do
Old 10-08-2008, 01:35 AM   #558
Kiko's Avatar
Almost forgot,it's ****ed up but believe it or not my upper bag plates for my notch came in UPS this afternoon..... >_<
Old 10-08-2008, 01:40 AM   #559
Off Vanning. bbl
95xtreme's Avatar
it might be cheaper to get a new frame, I bet it is bent behind the spring pockets. That was a hell of a hit glad you guys are ok. good luck on the rebuild just remember to not rush it.
Old 10-08-2008, 01:40 AM   #560
Kiko's Avatar
I checked behind the control arms and it looks the same. I stood over the engine and looked down also and the tires look lined up and straight. The front section of the frame is ****ed after the control arms for sure. Once the frame is fixed i plan to have some crossmembers made to insure that frame stays solid.
Old 10-08-2008, 09:52 AM   #561
GreaseMonkey74's Avatar
Okay I might be driving it this friday to get some new tires on it. I'll try to come by if I drive it.
Old 10-08-2008, 01:10 PM   #562
Off Vanning. bbl
95xtreme's Avatar
Just was thinking about your truck, the frame took a good hit and sectioning that part of the frame into your current frame is risky since that patch will have to hold up to the same impact or worst in case of another accident.
I had less of a hit taking out of a frame of mine to the tune of 700 dollars on a frame rack. And since it is a regular cab s10, might be simpler and cheaper to buy a new frame and transfer your bed, cab motor and tranny over too.
Also you would be able to clean everything thing up real nice on the transfer over too. Trust me I know what it is like to want to keep the same truck after putting alot of work into it. Just want to make sure it gets put together right.
Old 10-08-2008, 01:14 PM   #563
Come out and plaaaaaaay!
Svtzx555's Avatar
Yeah, my vote is for getting another s10 frame and just transferring parts.
Old 10-08-2008, 01:26 PM   #564
Kiko's Avatar
I don't really plan to drive it daily when it's repaired. I will only drive it for a short while until i can buy another cheap truck for a daily. My only worry ab out the front section being replaced is making sure the welds are good enough to hold the frame together once the weight of the core support,radiator,grill,and bumper arer on it.
I will start fixing more soon. I need to get some tools that i need first.
Old 10-08-2008, 06:10 PM   #565
AE86 SR5's Avatar
I would get another frame for that truck, it would be probably be cheaper and you could clean it up nice.
Old 10-08-2008, 11:53 PM   #566
Mud Master
Dork's Avatar
Please buy another frame and transfer your parts over.. As much as you want to save this one, its just not smart. If you do fix this frame, at least have it welded up by a professional.
Old 10-09-2008, 12:22 AM   #567
umm yea
JoPre's Avatar
ya man hate to say it but im thinking another frame may be in order here.
Old 10-09-2008, 02:50 AM   #568
Kiko's Avatar
I'll definately be having someone who knows what they are doing weld it. I don't intend to weld it myself.
Old 10-09-2008, 08:54 PM   #569
umm yea
JoPre's Avatar
well after you get that done you are goin to get it on a rack just to make sure everything is inline right?
Old 10-10-2008, 01:31 AM   #570
Kiko's Avatar
If i straighten it i will. I took off the bed and the rear goes to the left some. I might just say **** it and buy this $500 rolling chassis '82 from the classifieds i just picked up.
I'm working on possibly a $300 regular cab square body. The body i was told is in good shape and it's not for sure if it runs so that is a deciding factor on if i buy it. I have to talk to the neighbor who offered to sell it and go take a look asap.
IF the truck he's wanting to sell me runs and drives i'm planning to buy it so i can have a vehicle to drive again and buy a parts truck to strip and use the frame off the parts truck to put the parts off this truck onto.
If i get another regular cab square body i definately want to make it a drag truck once i get a new frame for this one. Just check back because right now i'm not sure but if it runs i definately want this other truck for $300.
That would make my count....3 square body s10's
Old 10-12-2008, 09:05 PM   #571
Kiko's Avatar
Ok,truck is pre '91 so i need a core support BUT everything lines up. Nothing is damaged and the bed is good. Cab is good and the front windshield is good. I'm paying $250 and i'm supposed to get it tommorow. The front tires are flat so we couldn't tow it but i'm bringing my rear wheels and putting them on the front of that truck so the guy can tow it to my house.
Once it's here i'll start stripping the parts. I forget but it's either a 2.5 or 2.8 and manual transmission. If anybody is interested in the engine and transmission they will be for sale. I'll also be parting out any of the other body parts that i don't need as i will be swapping all of my parts over to this trucks frame.
I'll post pics when i get it. In 2 weeks i should have it all swapped over with the help of my friends after work.
Old 10-12-2008, 09:29 PM   #572
umm yea
JoPre's Avatar
sweet. good deal man.
Old 10-12-2008, 09:44 PM   #573
Moderator
Wicked Mayhem's Avatar
sweet, i def. wouldnt try fixing that frame, you really dont have alot done to it to where you cant be back at the same point again since you have the bag parts.
Old 10-13-2008, 03:29 AM   #574
Kiko's Avatar
True. i will be using my cab and everything though. I only want the frame from the other truck. I will use the control arms on it though since i don't want to swap them. I will be using my drop spindles on the new frame and then installing my bag setup on it and i will be using my rear axle and leaf springs. The cab,bed,engine,transmission,and everything else off my truck will be put on the new frame AFTER i sand it and coat it with undercoating to clean it up.
I have my driveshaft tunnel and bridge plates in for the rear. I need to buy more once i get everything swapped over to this new frame then i can resume my work on buying parts and bagging the back. I'm thinking about buying a cheap welder (Good one though) and learning to weld so i can just weld my own shit when i get ready to bag the rear. It beats stripping it and driving 20 miles like that to have it welded then 20 back and having to put everything back.
I dunno but i would definately love to have my own welding stuff. I'll post some pics when i get it home tommorow.
Old 10-13-2008, 10:12 PM   #575
Kiko's Avatar
Got my parts truck for $250. I got kinda scared when i got home that i ****ed up and bought a longbed but i measured and the beds are the same. They just look different for some reason.
I'm using the frame form the parts truck and the front windshield. I will also be using the upper and lower control arms. The rest will come from my truck (Even leaf springs) I have to buy a radiator though and core support for a '91
The truck i bought doesn't run obviously and it's a 2.5 manual. It's got some nice goodies on it that i cna use on stuff or strip and sell. If anybody wants something pm me and i will let you know if i'm getting rid of it and a price.
I will be sanding the frame and coating it black before my parts are put on it. I think that's about it. I will be moving my airtank to the rear of the frame and making a mount but besides that nothing else will really change right now.
I'll start stripping it tommorow and when i can get my friends over we will get the big stuff off.
Old 10-13-2008, 10:54 PM   #576
umm yea
JoPre's Avatar
moving on with it quickly... nice
Old 10-13-2008, 11:51 PM   #577
Kiko's Avatar
Yup =)
I need it stripped then i'm buying 2 gallons of black bed liner and brushing it onto the frame once i sand it down. When that is dry i'll start putting some of my parts onto the frame. I need to get an engine lift form my friend Eric before i can transfer the engine and transmission
Old 10-14-2008, 01:15 AM   #578
V8 with bags
V8Blaze's Avatar
glad to see this moving in the right direction. Good luck on the rebuild man
Old 10-14-2008, 01:07 PM   #579
Kiko's Avatar
Thanks. I'm ready to have it done because i miss driving it really bad
Just for fun i thought i'd get a pic of my front yard right now while this is going on. It normally doesn't have parts in it but with the parts truck and my old scrap parts there it looks like my own mini junkyard
Old 10-14-2008, 02:32 PM   #580
Kiko's Avatar
Got the bed off finally. Damn bolts are a bitch to break loose the first time (I remembered that from when i changed my bed so i was prepared with a bitch stick.... aka pipe )
Next i will remove the hood,and fenders. Once those are off i'll take out the core support and then next will be pulling the cab. Once everything else is off i will pull the gas tank and then engine/transmission. Once all of that is gone i will be able to get my friend Russel over with his angle grinder and we'll each sand the frame at the same time and get it cleaned up in a matter of 1-2 hours. Once that's finished i'm buying 2 gallons of black bed liner and rolling it onto the frame before setting MY engine/transmission onto it.
Old 10-14-2008, 02:36 PM   #581
Kiko's Avatar
Oh,and while i'm putting everything on i'm considering running mono leaf with blocks until i get the remaming bag parts. I know it's not exactly the best but i know plenty of people locally who ride mono with no problem. If i do i'll also put my gas tank in the bed to avoid hitting it on driveways.
Once the trucks on the road again i'm going to get the rest of my bag parts. I have some but i was in the middle of ordering the rest when this happened.
Old 10-14-2008, 02:54 PM   #582
Svtzx555's Avatar
Keep up the good work.
Old 10-14-2008, 03:36 PM   #583
Keep it up, glad to see you moving along.
Old 10-14-2008, 07:36 PM   #584
umm yea
JoPre's Avatar
keeping busyy... youll be there befor you know it at this rate
Old 10-14-2008, 09:14 PM   #585
Kiko's Avatar
True. My friend Nick is on his way with his '91 extended cab. We're stripping the front end and i might put in his ignition module too
Old 10-15-2008, 12:27 AM   #586
Kiko's Avatar
Got the left fender off and the hood. There were spider nests,ants,and roaches EVERYWHERE on the truck. Seriously,we were under the truck loosening some bolts and a cockroach was just sitting inside the frame staring at us...UGH >_<
I can get the right fender off by myself tommorow after work and possibly the core support and the radiator. I'm not sure if i will get a billet 3 piece grill or go back to the grill i had. I'm getting the same bumper though. Also got some ideas for frame coating and prices earlier.
I'll post some pics of the truck and some photos where me and Nick wre just messing around with our trucks and the camera.
Old 10-15-2008, 02:04 AM   #587
Kiko's Avatar
It's really my tag
Plan to get the other fender off tommorow at least. If possible i want the core support and radiator out too. It will be at least Sunday before i have enough people over to lift the cab off the frame.
Old 10-15-2008, 07:16 PM   #588
Kiko's Avatar
Headed home from work now to remove the other fender and maybe a couple other parts. Deadline is roughly 3 weeks and 4 days (My birthday) so i'll be busting my ass to get it done by then. Pics later.
Old 10-15-2008, 09:26 PM   #589
Kiko's Avatar
Tommorow the inner fenders come off..
Sunday the engine/trans should be out and hopefully the cab will be off.
Old 10-15-2008, 09:30 PM   #590
is gettin there...
Driveway Kustoms's Avatar
thats an awsome find, i cant wait to see this thing back together...i loved this truck good luck man, keep her goin
Old 10-16-2008, 02:14 AM   #591
Kiko's Avatar
Thanks. Inner fenders are now off. The cab is unbolted and should be off this weekend. The engine and transmission will be out Sunday or maybe Saturday.
My deadline is now officially 3 weeks and 3 days
Edit: After work today i might go ahead anf jack up the rear and unchain the axle then slide it out from under the truck. While i'm at it i might go ahead and remove the gas tank too. That's going to be it for tommorow though. One day i need to get the door panels off so i can use them. I'm also saving some other small parts to use on mine but i'll get to that later.
Old 10-16-2008, 08:47 PM   #592
Kiko's Avatar
Rear end and driveshaft are out
The interior door panels i'm using on my truck. I'm going to spray them with black vinyl dye though because that red is hideous. I may use the vinyl bench seat too and spray it black and repair some knicks in the seat.
It took all my leftover energy after work to drag the rear end out so i'm drained. Tommorow i'll remove the gas tank and remove those old shock and other stuff. I might use some floor jacks and jack up the cab instead of lifting it manually. Then drag the frame out from under it. Whichever way is easiest and i can do first.
Old 10-16-2008, 10:41 PM   #593
umm yea
JoPre's Avatar
sweet, i love watching progress in this thread, theres always something to read.
Old 10-16-2008, 10:49 PM   #594
V8 with bags
V8Blaze's Avatar
hey if you arent using that parts truck tailgate, wanna cut out the chevy stamping and send it to me lol, seriously
but im very glad you are swapping the frames, and IMO being able to pull the body off and cleaning it and painting it will make it so much nice in the long run. Sucks you had to do it, but its a great excuse to have a nice and sexy frame
Old 10-17-2008, 12:02 AM   #595
umm yea
JoPre's Avatar
mannn ive been wanting to do what i think you want to do with that stamping. =/ youll probably do it befor me though. damn you.
Old 10-17-2008, 01:26 AM   #596
Kiko's Avatar
If you send a money order or something for shipping then sure. But i don't really know how much that would cost to ship. And yea i wanted to do that before with my rusty frame but didn't want to pull everything. I get to do it now but i wish it wasn't under these circumstances
I'm about to go outside and pull the gastank off and unplug some wires from the engine. Pics in a bit
Old 10-17-2008, 02:30 AM   #597
Kiko's Avatar
Gas tank is out. I got one strap off but couldn't get the other (Damn old ass bolts) so i had to cut the strap. I'm cutting off the bolt heads tommorow and removing the rest of it. I've got the back of the cab jacked up some now and a pipe laying across the frame to keep it up. I need to jack up the front and put a pipe under it then when we lift we have something to hold onto. If i have to i might can run a chain over the big oak tree limb and create my own cab hoist. That would be the shit if it worked.
It is now 3 weeks,2 days until the completion deadline for my truck...
Old 10-17-2008, 08:09 PM   #598
Kiko's Avatar
Remaining bit of the gas tank strap is now off. I've almost got the exhaust off where it was welded to the frame for support (Gay) but my cutting disk wore down and i don't feel lik putting another on right now. Tommorow hopefully the engine comes out and i can pull the cab and get to work cleaning the nasty frame and coating it.
Old 10-17-2008, 10:01 PM   #599
V8 with bags
V8Blaze's Avatar
progress is progress, and i i know how you feel about not wanting to **** with it for long after you get off work, im the same way
Old 10-18-2008, 01:17 AM   #600
Kiko's Avatar
It's not really that i don't want to but i don't have much time. It takes me a while to get all of the rusted bolts loose and by the time i have 1 or 2 things done it's time to stop and eat dinner and go see my girlfriend because i have to be up for work the next day at 7:30am so when i get home at 6:00pm there's not much time to work on it and have time to see my girlfriend and still get sleep.
Sunday i plan to work on it all day until 5 or 6pm though. I should have the engine and transmission out by the end of the day sunday. I hope to get the cab off too then i can pick up the frame coating at the store and start sanding.
Page generated in 0.69449 seconds with 32 queries
[Output: 226.67 Kb. compressed to 207.79 Kb. by saving 18.88 Kb. (8.33%)]
