#201 |
ClubECM.com
Re: My 'day off' daily driven project.
#202 |
I piss excellence
#203 |
![]() i dont know about that swap... the first thing i thought of when i saw that pic, was the old Chrysler/ Dodge mini caravans from the 80's! ![]() Last edited by 98layinframe : 06-20-2008 at 08:09 PM. |
#204 |
dropt
haha. i think that's the guy from street source that i linked to. i think it looked better on that blazer from SEMA.
#205 |
ClubECM.com
That truck is awesome. I can only hope my comes out that clean looking. I've considered sectioning my front bumper like I did the rear but not intergrating it to the body. Like that crackhead Paris Hilton would ay, "Thats Hot".
#206 |
i wouldnt undertsand
#207 |
dropt
#208 |
my dad can beat up ur mom
#209 |
ClubECM.com
Ok wel I should havehad Sunday and today off but I didn't. Had to cover a shift on Sunday at work when one of my employees had to go to the hospital, and today I had some errands to run so I didnt get much done... Plan on two days worth of work and end up only getting in a few hours. Typical of my luck.
So I started cutting the ends off the bumper to section it so I can make the angle the same as the lights. I also plan on pulling it in closer to the body by about 1.5"s. This also mean the air damn will have to be shortened down the road too. Its not much but I know you guys love photos so here are a few more. ![]() ![]() |
#210 |
#211 |
dropt
yeah i'm just wondering how the headlights do look. i'm not worried about his grill, cause the one he used doesn't look right.
#212 |
broke ass MOFO
John, your kickin ass. i miss my dime(s). damn now i need to go get one haha
#213 |
ClubECM.com
Mike whatever happen to that C10 you were going to get for dirt cheap?
#214 |
umm yea
Location: newly relocated 2 Glen Burnie MD User is: OffLine ![]() |
i dont think the grill eon that one looks too bad....
what grille is goin to be used on this one though? |
#215 |
ClubECM.com
#216 |
ClubECM.com
Well went shopping this morning, thentook the bike to get it's inspection and came home to work on the truck for a little bit. Here is what got done.
I made pie cuts to remove some material so I could bend the bumper back to flow better with the headlight. Once I'm finished welding the lower seams I will bolt it up, bolt up the ends, and then trim the center peice I removed and weld I back into place. Cuts. ![]() Clamped. ![]() Almost finished welded. Still have a few spots to touch up after grinding. ![]() Now here is how it looks after... ![]() Here how it looked before. Any better? lol ![]() |
#217 |
Hardcore 1st Gen'r
awesome
makes it look more finished. |
#218 |
I want sonoma grill!
very nice!
#219 |
its just greg
X2, not a fan of the billet grill on the other guys truck. |
#220 |
umm yea
i forgot you had said what grille already. whoops.
the bumper looks good so far. |
#221 |
ClubECM.com
Got one side pretty much tacked into place. I have to notch the back side for clearence, then I'll bolt up the bottom and finish welding it.
And no the headlight isn't sagging, that is my templet that I used to protect the headlight while I was tacking the bumper together. ![]() |
#222 |
Mcfly Minis inc
Nicw fab work, I love the front end.
#223 |
ClubECM.com
Eh, I wish, but thanks. lol
As yu can see in that corner of the bumper I made the pie cut alot larger than it should have been. Now I need to cut a peice to fill it tomorrow. ![]() |
#224 |
ClubECM.com
Had a 7 hour meeting for work today but once I got home there was a little more progress was made.
I welded up the bottom side of the sectioned areas, now all I need to do is grind the welds smooth. Then I will bolt it back onto the truck and work on mounting the grill. I'm hoping not too difficult. It will need some fiberglass work fr the finished product, but right now I want it roughed in so I can finish the bumper and start the hood and fenders. |
#225 |
Plastic Welder
So where are the updates at?
#226 |
ClubECM.com
Ok well I had to take a step backwards before I moved forward.
I trimmed the grill down so it would fit but once it was in place I realized that my messurements where off by almost 3.4". Between the slight curbe at the bottom of the grill shell, and the higher lip at the back of the bumper I decided to just f**k it and go back and cut it off again. Removed the bumper and cut more from the frame horns and then sectioned more out of the bumper. The grill is cut but still needs to have brackets made to hold it into place. I clamped it back together, added some tack welds and test fitted it. Even threw the airdamn under it for the full effect. ![]() The airdam isn't bolted on but if you look at the corners you can see how much different the angle is, and over all on the sides it's about a 1" shorter. My friend was up this weekend working on a fiberglass trunk for his car and talked me into making a fiberglass nose for the truck. Basically we'll make a blank Of the original airdam and modify it where needed. Still debating adding a opening in the front or not. |
#227 |
dropt
nice progress. looks like it's really coming together. i got one of my sierra headlights off eBay the other day for $60 shipped. can't wait for it to get here so i can size it up. keep up the good work man.
#228 |
ClubECM.com
Here is a photoshop someone from another forum did in MS Paint.
As I stated, I thinK I want a opening on the lower section, but I'm kind of digging the body lines he put in it too. ![]() |
#229 |
blacker then black X
im not into that ^
i think if you mold the xtreme airdamn around everything it will look real good. IMO |
#230 |
Tater Kustomz
wow...this build is awesome...lol...it looks good...and props for the rear bumper...thats DEFINITELY something u dont see every day...very cool!
#231 |
Daily Driver
#232 |
I love it
