#2251 |
Brought to u by Carls Jr.
Re: Mostizzles dime
#2252 |
Re: Mostizzles dime
i just may do it again
#2253 |
Re: Mostizzles dime
#2254 |
The WaterBoy
Re: Mostizzles dime
#2255 |
Lifted Moderator
![]() Age: 25
Re: Mostizzles dime
#2256 |
Re: Mostizzles dime
You can fit your hand behind the light from the top? I'll have to look again. I'm pretty sure I have to pull my bumper to change turn signal bulbs too. IIRC I tried it once before and there was no room because the Bravada bumper doesn't stick out as much.
#2257 |
Lifted Moderator
![]() Age: 25
Re: Mostizzles dime
wait? bumper ligths or the little ones in the headlights? im talking about the ones in the head lights. the others i had no issue with but thats a nother matter.
#2258 |
Re: Mostizzles dime
I'm talking both actually but my first post was about the little side markers.
#2259 |
Lifted Moderator
![]() Age: 25
Re: Mostizzles dime
oh, those ones i just pull my screws for the headlights then pop the light out the front.
#2260 |
The WaterBoy
Re: Mostizzles dime
^^^x2
#2261 |
Wondersmith
Re: Mostizzles dime
i thought you could reach the bumper lights from underneath? i know i could on my noma before the front end swap
#2262 |
Re: Mostizzles dime
I don't think there's enough room. I guess I could get off my ass and look.......nah, I'll wait until the bulbs show up. lol
Well I got those LED panels today only to find out that my measurements were an inch off. lol Now I'm either going to just use 1 or try to figure out a way to cut one down. Here's what the circuit board looks like, and the lights. Tips and thoughts on cutting one of these down? ![]() ![]() ![]() ![]()
#2263 |
NoLifeDesigns.com
![]() Age: 21
Re: Mostizzles dime
No clue, but you'll love even one of them. I have one in my hardbody and it lights up pretty good.
#2264 |
**** Yeah.
Re: Mostizzles dime
Looks like the board is set up as a bus system with each row of 3 LEDs having its own resistor, so you should be able to trim the board down with a Dremel and jumper the two busses together to replace the trace you cut off on one side and have it work just fine.
#2265 |
Re: Mostizzles dime
Word, that's what I was thinking. Like this correct?
#2266 |
**** Yeah.
Re: Mostizzles dime
You got it
#2267 |
Re: Mostizzles dime
Well that didn't work. lol
#2268 |
**** Yeah.
Re: Mostizzles dime
Shit that's not good...what's the other side of the board look like? May need another jumper to replace a cut trace on that side...
#2269 |
Re: Mostizzles dime
Yeah, there's a bus on the other side that has to be jumped. I can't solder to save my life so I've decided to say fcuk it and just use the one for now.
I did put the LEDs in my front markers today... ![]() ![]() Also broke the clip tabs off my grille(knew it), was reminded of how much I need new headlight assemblies, and noticed a stone chip in my grille. Whatever though, at least now I won't have to worry about breaking my grille while removing it anymore. I could two part epoxy the shit back together but I replaced the inserts that the 4 upper grille bolts thread into and they do a fine job of holding the grille on tight by themselves. |
#2270 |
Lifted Moderator
![]() Age: 25
Re: Mostizzles dime
Really 1 should be plenty bright.
#2271 |
Re: Mostizzles dime
But I'm anal and I wanted the panel to take up the whole lens. lol
#2272 |
Girl with wrenches
Re: Mostizzles dime
Hey Mo snap a pic when it's dark out. I am curious as to how well they light up.
I have 2 led panels for my dome light and I've stuck with one for now. I find it to be enough personally. |
#2273 |
Re: Mostizzles dime
Just took these...
![]() ![]() Pics really don't show how they look in person. They're a lot brighter and more yellow. There were amber 194s in there before so they looked orangy. |
#2274 |
![]() Age: 30
Re: Mostizzles dime
Yeah one is PLENTY. The 2dr's have nearly no light at night, but with one of those I can see errrrrrtang.
#2275 |
Re: Mostizzles dime
Well I messed with the dome light today. I found that the closer the panel is to the lens the crappier it looks so I decided to hardwire it and eliminate the stock bulb fixture so the panel lays flat in the bezel.
Pulled out the stock terminals and drilled a hole in the bezel that the panels wires can pass through... ![]() ![]() ![]() ![]() ![]() Should look really good when a Kansas member does me a solid and gets me a clear lens from LMC. lol I might just say fcuk it and order one sooner or later. |
#2276 |
![]() Age: 30
Re: Mostizzles dime
looks clean.
#2277 |
Re: Mostizzles dime
Thanks man. I'll have to go out there when it gets dark and see what's doin.
#2278 |
Re: Mostizzles dime
Things bright as shit! lol I'll try n get a pic tomorrow.
#2279 |
**** Yeah.
Re: Mostizzles dime
Now you've got me wanting an LED dome light...not sure if I wanna go with white, or red to match my LED footwell lighting. I'll be installing a Blazer overhead console so I can use the map lights if I actually need to see something, thought the all red lighting could look cool as hell...
#2280 |
Re: Mostizzles dime
#2281 |
**** Yeah.
Re: Mostizzles dime
I kinda had my eye on this one: http://www.ebay.com/itm/18-5050-SMD-...ht_2476wt_1274
I've got a couple 6x 5050 panels in the stock footwell lights that throw a ton of light...also it's from a US seller so it should take less than the month it takes from Hong Kong Fooey. |
#2282 |
Re: Mostizzles dime
Not bad. I'm a cheap ass though, and it only took like a week and a half to get them. lol That price isn't as bad as most of the other U.S. sellers on there is.
#2283 |
Lifted Moderator
![]() Age: 25
Re: Mostizzles dime
#2284 |
Girl with wrenches
Re: Mostizzles dime
Funny I find stuff from China actually ships way faster than within America for some reason. I've had stuff bounce all over the damn country for 3 weeks before getting to me where it seems from China it just comes direct.
#2285 |
Electrical Mod
![]() Age: 23
Re: Mostizzles dime
That's because you're in Canadia eh?
#2286 |
Lifted Moderator
![]() Age: 25
Re: Mostizzles dime
#2287 |
Re: Mostizzles dime
damn, your package was held for 3 months? Was there any chafing? Did you end up with prune dick? lol
Here's this weekends reason for not working on my truck... Vettebro had caliper fail which cause a brake fire. It pretty much destroyed all the brake components and the bearings in the trailing arm so we replaced everything... ![]() ![]() ![]() ![]() Coolest table/storage cabinet ever... ![]() Sweet Bentley... ![]() I posted all those in the cell phone thread too so don't get your shorts in a knot if you've seen them already. Here's a pic of my dome light at night. The pic really doesn't do it justice...
#2288 |
**** Yeah.
Re: Mostizzles dime
#2289 |
poop
Re: Mostizzles dime
I want that sweptline. And bright dome is bright.
#2290 |
The WaterBoy
Re: Mostizzles dime
#2291 |
Re: Mostizzles dime
Yeah I need to get that thing running. It needs body work and it just plain sucks to drive, needs updated brakes, steering and front suspension.
#2292 |
The WaterBoy
Re: Mostizzles dime
Is it yours.
#2293 |
Re: Mostizzles dime
Yep. I bought it a long time ago, swapped the tired 318 for a fresh one and never finished it. Needs everything under the hood wired and all new brakes to be drivable. I also have a 400 and big block 727 for it but I just don't have the time or money right now.
#2294 |
**** Yeah.
Re: Mostizzles dime
Quit dickin' around on the internet and go turn some wrenches
#2295 |
Re: Mostizzles dime
Either that or I'm gonna sell it, it's been sitting for years. At least it's in a garage now.
#2296 |
No longer a pizza tech.
Hey moseph. You still need that cover from el em cee?
#2297 |
Re: Mostizzles dime
I do. I PM'd J about it a little bit ago. The part# is 36-4207 and it's $7. No clue what shipping from your place will run.
#2298 |
**** Yeah.
Re: Mostizzles dime
If you're ordering one, get me one too
#2299 |
Re: Mostizzles dime
Shit it might be too late, Ryan was going there today I think.
#2300 |
**** Yeah.
Re: Mostizzles dime
Ah crap, maybe next time.
| Sponsored Links | |
Advertisement | |
