k^wood's daily driver build - S-10 Forum
Old 02-27-2012, 09:37 PM   #1
i have vehicular add
twist_of_fait's Avatar
the goal of this build is to have a very functional mini to dd, also must be able to pull my boat and haul a quad. truck is a 97 4.3 auto with 99k miles
here is the beast got it Thursday evening
started building a few things for it
finished lowers
lower link mount/shock mounts
welded and painted up
more to come tomorrow
Old 03-01-2012, 01:23 AM   #2
Re: k^wood's daily driver build
well got my blocks in the rear for now, installed my nitrogen tank,accuair and tank, also cut the spring pockets and got my 26oo's in the front here she is cashed out on 2057515,stock lca and sectioned cups, inners still intacked for now
Old 03-01-2012, 01:49 AM   #3
littledevil4802's Avatar
that should look real good laid out I really like that color
Old 03-03-2012, 04:51 PM   #4
here is shot of the trimmed pocket w/sectioned upper cup chassis tech denominators d2600's
well today i ordered spindles and shock relocators and air ride gauges. hope to build the rear diff bracket and wish bone buy next weekend maybe get my notch in we will see.
Old 03-13-2012, 10:51 PM   #5
well spindles came in yesterday from nate @ lrd ,along with some other goodies. also scored a set of centerline daggers there 18's with 235/40/18's, ditched the abs and added a proportioning valve, still need to make and ecu mount and get a different overflow bottle
abs gone, used a c10 prop valve cut a and reflared the lines
my new wheels on
Old 03-30-2012, 11:28 PM   #6
minor update got my spindles on and started notching the frame
bed pulled
one notch down one to go!
Old 03-30-2012, 11:34 PM   #7
oh i forgot also swooped up an 03 noma rear bumper
Old 03-30-2012, 11:47 PM   #8
It puts the lotion on
deeznutz's Avatar
Quote: Originally Posted by twist_of_fait
Looking good. Is there something mounted to the fender and bedside or am I seeing shit?
Old 03-30-2012, 11:58 PM   #9
no there is ****in tie down hooks on there the old man that owned it had a canoe that he hauled.... there gone now need to do some body work
Old 10-10-2012, 10:05 PM   #10
got my sanden 709 in today! supper stooked 2 min 0-200 psi on five gallons at an idle
Old 11-05-2012, 11:22 PM   #11
decided to crew my truck started build my own rear door couldn't find any in my price range....cheap! cheapest i found was 650 each
Old 11-05-2012, 11:58 PM   #12
jcp0420's Avatar
Thats badass!!
Old 11-10-2012, 01:34 AM   #13
started the crew swap
Old 11-10-2012, 02:51 AM   #14
this just got that much better.
Old 11-10-2012, 02:27 PM   #15
porn!
Old 11-10-2012, 03:07 PM   #16
Lifted Moderator
Sonomanclature's Avatar
So this is a Crew on an Excab frame? If so lots of pics on the body mountings would be awsome.
Old 11-10-2012, 04:36 PM   #17
you are correct crew on xcab frame we will see about pics of the cab mounts till maybe the end of the build got keep up the suspense lol!
Old 11-10-2012, 05:16 PM   #18
out draggin.. brb
Gimp's Avatar
i had no idea this thing was even getting bagged from your original first post. But now im on board and liking everything I see. lookingforward to seeing more profress man
Old 11-10-2012, 07:54 PM   #19
layed_sdime
95v8sdime's Avatar
Awesome build bro. Loving the crew cab idea. Keep it up man
Old 11-10-2012, 11:31 PM   #20
-Class Act-
Casper98's Avatar
Looks good Kevin, can't wait to see it next year.
Old 11-11-2012, 11:21 AM   #21
thanks billy
Old 11-11-2012, 11:54 AM   #22
relocated harness
mocked up hydo-boost
there is a ton of small differences in cabs from 97 vs 2001 sux its taking me longer than i thought.
Old 11-11-2012, 06:41 PM   #23
bam bitches
Old 11-11-2012, 07:03 PM   #24
that bed looks way better than the factory crew cabs...never liked the hombre style rear fender
Old 11-11-2012, 09:12 PM   #25
mhilt13's Avatar
that looks awsome makes me want a crew so bad!!
Old 11-11-2012, 09:15 PM   #26
SMURF
ridinlow's Avatar
my new wheels on
[/QUOTE]
I have the same wheels. 18x8 18x9.5. the centerlines are nice.
Old 11-11-2012, 09:35 PM   #27
why the hydroboost brakes?
Old 11-11-2012, 09:46 PM   #28
DWN2ERTH's Avatar
the crew looks badass
Old 11-12-2012, 12:20 PM   #29
out draggin.. brb
Gimp's Avatar
relocated harness
i need to do this really bad. How was it and what is the process of doing it? I take it this can be done without pulling the dash right? appreciate any info you could give me before i tear mine up too much more layin on it
Old 11-12-2012, 11:37 PM   #30
More room for bigger wheels and better braking.
Old 11-12-2012, 11:42 PM   #31
Wasn't bad but yes I had dash out and ebrake assembly. I don't think you can do it if the ebrake is in there.
It's bad ass sitting in it and seeing a full back seat!
Old 11-13-2012, 07:33 AM   #32
have any pics of cutting the bed?
Old 11-16-2012, 10:19 PM   #33
no but i can tell you thats all i did for the moment lol! i hacked the front off the bed....i expect to see my truck in the most hacked thread in day now!
i need to cut the front panel out of the bed still and attach it and weld the new front bed mounts on. turns out there a lot of small differences in the cabs them selves for heater mounting provisions and the dash mounts are diff too so i kinda got around the dash difference. i have no heater in there now i roll with a squegee and rain-x lol. lookin at under dash units now or may try building out of my own
swooped up a super clean 1st gen bench seat to put in.
swaped in a blazer harness for the rear doors and turns out that gm made several changes in the harnesses so i will be re-pining most of the window harness and modifing it to work with mu stock harness.
Old 11-16-2012, 11:07 PM   #34
Looking good
Old 11-17-2012, 06:34 PM   #35
was it a later model crew cab like 03+
i wonder why there would be so much difference in the cab?
Old 11-17-2012, 09:17 PM   #36
Oasis Customs
NevurMind85's Avatar
bam bitches
love this shot, this will turn out awesome, i want want static just like it.
Old 11-22-2012, 12:59 PM   #37
well i rolled it to work last week and this week its so awesome having all the extra space lol...down side more room for shit to accumulate.
built my lexan rear vent windows till i find some legit ones and source real crew cab window seals
chilling at work
new seat got it for 50 bucks at work freshly redone super soft love it!
installed
modded the floor shifter and moved it forward and choped it down about 6 inches
can a mod please add crew cab conversion to thread title? "k^woods crew cab conversion"
Old 11-22-2012, 01:31 PM   #38
prupnurp's Avatar
This thing is badass! I want to see more pics!!
Old 11-22-2012, 01:34 PM   #39
mhilt13's Avatar
Looks bad ass. I think it looks better with the small bed
Old 11-22-2012, 02:05 PM   #40
AcrophobiA
STEN_(d_slammd_1)'s Avatar
I swear I just saw this on Portland CL not long ago. Before the crew cab.
Old 11-22-2012, 02:10 PM   #41
i would never sell it! j/k yeah it was on there all i got was low balls and honda kids lol. i didnt need to sell it so i figured i would see what was out there then got bit by the bug again.
Old 11-23-2012, 03:15 PM   #42
out draggin.. brb
Gimp's Avatar
love the bench seat man. just an FYI. youll get your title changed faster if you PM one of them. cant wait to see more updates
have any paint ideas in mind yet?
Old 12-08-2012, 11:29 AM   #43
im lookin to go with hot rod flats champagne gold metallic very close to my stock color with a satin finish.
picked up a 1st gen blazer tank to swap in the rear. also swooped up a 0411 pcm,hx35w,and some other goodies for it. snail wont be going on for a while. but the crew is in the shop started the tank in and going to redo the rear bag set up i think swap out the 2600 for some f9000's
Old 12-08-2012, 04:25 PM   #44
mockin the tank up
Old 12-09-2012, 02:32 AM   #45
out draggin.. brb
Gimp's Avatar
throw some SS8's out back youll love them! I know I do
Old 12-09-2012, 01:47 PM   #46
mhilt13's Avatar
i kinda wish i would of went with sleeve bags for the rear too. i think they ride the best when mounted over the axle, which is what they are designed for. bellowed bags are designed to be used in a leverage applications such as on a control arm or a bag on bar. they are much stiffer than a sleeve bag and make the ride a little rougher when mounted over the axle. i recently rear about it in minitruckin i think it was in the ask max part..
Old 12-09-2012, 02:18 PM   #47
mocked up hidden hitch
i got dom 26's in the back now and its stiff even with added weight of the crew cab
Old 12-11-2012, 11:07 PM   #48
mhilt13's Avatar
thats sucks i havent got my driveable yet but it would be a pain to switch to sleeves since they are so much taller when compressed. id have to re do my upper mounts
Old 01-31-2013, 12:57 AM   #49
5.74x4's Avatar
Just saw your build and I love it, can't wait to see more progress on it. I bought a crewcab theft recovery on the cheap and trying to decide what I want to build with it...lol.
Old 03-29-2013, 04:07 PM   #50
Lifted 2wd & Bodied 4x4
layinbody31's Avatar
Awesome build
