Her Name, is Circa. 5.3/t56 swap (56k warning)
LinkBack (6) Thread Tools
Old 04-10-2007, 10:50 PM   3 links from elsewhere to this Post. Click to view. #51
Re: Her Name, is Circa. 5.3/t56 swap (56k warning)
Hahaha, last to finish, man I started mid march and still ain't got the tranny mounted to the engine. Let my fuel line get here and i'll have an engine and tranny in within 24 hours.
Old 04-11-2007, 08:57 AM   #52
ɔıɹɔ&
circa's Avatar
Im still trying to negotiate a settlement with the insurance lady from when i got hit from a drunk driver
i need somewhat free money...working sucks!
Old 04-11-2007, 09:55 AM   #53
Sdimess84
Zerocool350's Avatar
Ill be the last one done probably. Im still hunting down a transmission. I havn't pulled the v6 yet. Im waiting til I get every part I can think of in before I start. And plus im putting a motor in my back up ride (1959 GMC stepside ).
Circa what are you doing intake and accessories wise?
Old 04-11-2007, 02:26 PM   #54
So-GT0071's Avatar
Quote: Originally Posted by Rompn
Also, I would think the 5.3 engine will drop the front at least an inch or so so consider that.
Nah, it won't. The front end on my truck sat higher with the LS1 in it then it did with the V6...the all iron V6's are heavy...
As for a 3 inch drop, why not just use 2 inch drop spindles and 1 inch drop springs. If you want coil overs up front, Spohn makes tubular lower A-arms that will fit QA1 coil overs in them or they can make them to accept the factory springs.
Cool project!
Old 04-11-2007, 02:31 PM   #55
INNOVATIVE FABRICATIONS
Rompn's Avatar
Arrow Re: Her Name, is Circa. 5.3/t56 swap (56k warning)
Well, he's swapping in a 5.3 not an LS1 so I think his front end will actually be heavier than with the V6 setup. The 5.3 is still an iron block.
I agree with the drop options mentioned above. However I would just run the 2" drop spindles so all of the geometery stays the same. If I'm correct about the 5.3's weight, the front should drop another 1" or so giving you the 3" your asking for.
Old 04-11-2007, 02:44 PM   #56
ɔıɹɔ&
circa's Avatar
Cool project!
I was looking at Spohn's setup last night its about 900 shipped give or take 20$
control arms with Qa1 coilovers
the v6 didnt seem that heavy maybe im just strong
the t56 is heavier then the nv3500 by i think 30-40 pounds dry
maybe could even it out
gotta work on my frame tonight, the sun is out
Old 04-11-2007, 02:52 PM   #57
So-GT0071's Avatar
Ya, the block is iron but the heads are aluminum. V6 is all iron. They will probably weigh about the same.
Old 04-11-2007, 04:06 PM   #58
Rompn's Avatar
Ya, I agree they are probably close in weight but I still think the 5.3 is going to be a little heavier. Maybe not enough to affect the ride height though. Don't know, guess there is only way to find out.
Old 04-11-2007, 07:40 PM   #59
ɔıɹɔ&
circa's Avatar
well my packing slip said 473 pounds which was the engine complete and the roughly 30-40 pound wood crate.... and the nearly 10 pounds of shrink wrap
just bought mounts and headers from current performance
i took a picture of the truck missing the engine on my cell, its the wallpaper and every time i open it...
Old 04-11-2007, 07:44 PM   #60
ɔıɹɔ&
circa's Avatar
90mm tb and the tubing i havent figured out...probably route it down by where the battery box use to be as i'll be moving it to the bed
accessories... no a/c and if everything fits then its just gravy
i will have to cover up the a/c box for room with the coil packs and probably a vette booster to help with clearance also
Old 04-12-2007, 11:18 PM   #61
BadS15v8's Avatar
So are you running the truck accessories?
I've seen how they fit in bucket's swap, but wouldn't the P/S Pump hit the gear box under hard torque or am I just tripping?
Old 04-13-2007, 01:31 AM   #62
ɔıɹɔ&
circa's Avatar
huh? P/S is no where near the gearbox its pretty much in the same location as the 4.3's
Old 04-13-2007, 02:55 AM   #63
So-GT0071's Avatar
Indeed!! Drop that sucker in there
Old 04-13-2007, 04:36 AM   #64
Call me Mario, Princess
AceHaag's Avatar
The enginge twists away from the steering box.
My engine ended up so low that i had to modify my ps bracket to get it in there.
Changing from a 2.2 to an iron 6.0 dropped the front of my truck 1in.
Old 04-13-2007, 06:29 AM   #65
takes 2 balls in our game
s10-den's Avatar
Your using headers?I dont know about the ls1 swap headers,but on the other small block headers you will need to do something about the clutch master.If the stock clutch line dont work,should be able to use one from a 2000 4 cyl s10.
Old 04-13-2007, 09:22 AM   #66
BadS15v8's Avatar
This is what I was talking about: (This is from Bucket's Swap)
http://i31.photobucket.com/albums/c3...Picture129.jpg
Old 04-13-2007, 09:26 AM   #67
BadS15v8's Avatar
Old 04-13-2007, 10:11 AM   #68
Rompn's Avatar
Now that I could see completely. That little 2.2L is tiny compared to the size and weight of a 6.0L.
Old 04-13-2007, 12:20 PM   #69
ɔıɹɔ&
circa's Avatar
it's close but it should be ok, bucket would say something im sure
I gotta buy a sand blasting gun and some abrasive tonight so i can remove front suspension and sand blast the rust away, give it a coating. Hopefully I recieve my steering from suicide doors, spohn lower a-arms w/ QA1 coilovers :>
redoing entire front suspension. I'm looking at the SC&C upper a arms that someone just posted but they are pretty spendy...along with new spindles and a big brake kit, brakes could wait awhile though
Old 04-19-2007, 11:58 PM   #70
ɔıɹɔ&
circa's Avatar
Still waiting on parts! Jared's headers were out of stock so he is having them shipped directly from Sanderson which is in california and im in washington..mounts are on their way though
spindles upper/lower arms are off along with the stubborn sway bar
no balljoint seperater, so I used a torch.
Nothing caught fire if any of you are wondering...
Old 04-23-2007, 09:44 PM   #71
ɔıɹɔ&
circa's Avatar
Remedies for stubborn lower control arm bolts?
spohn lower control arm's and QA1 coilover kit should be in by the end of the week (fingers crossed)
same with headers
buying steering linkage and upper a arm's from suicidedoors.com as we speak
spindles rotors and brakes from summit...still browsing
sway bar i think im getting the hook up from a friend at schucks...not sure though
Old 04-28-2007, 02:57 PM   #72
ɔıɹɔ&
circa's Avatar
havent posted pics in awhile... nothing "major" really done
got my mounts
waiting on lower control arms coilover kit upper control arms and entire steering linkages, havent ordered spindles or rotors from summit yet..they ship pretty quick anyways
Also, i've been sanding and blasting the frame...front only for now
probably going to prime it black...wouldnt mind leaveing a raw metal finish
on this pic you can see where it was welded when it was fixed from w/e accident it was in
Old 04-28-2007, 02:58 PM   #73
ɔıɹɔ&
circa's Avatar
ohhh it sucks doing this outside...im waiting for a good rain and it gets surface rust and i have to go over it all again
damn the northwest...damn!
Old 04-28-2007, 05:07 PM   #74
What to put here?
Looks good man. Do you happen to have a pick of the wiring harness? And how hard do think it is going to be to hook it up?.... ( Any thing you think you will have a prob with?) Thanks!
Old 05-08-2007, 10:28 PM   #75
ɔıɹɔ&
circa's Avatar
probably will have a problem with the harness but i'll be talking to jared about it
in the mean time...look what arrived im jumping and giggling like a school girl
start of interior work :>
still working the front frame a bit...finishing it about the same time al the other front suspension parts arrive
Old 05-08-2007, 10:51 PM   #76
Sdimess84
Looking good. Im starting mine this weekend! I Cant wait
Old 05-08-2007, 10:56 PM   #77
BadS15v8's Avatar
lookin good man, like the coil overs....
Old 05-08-2007, 11:05 PM   #78
ɔıɹɔ&
circa's Avatar
finest 1000$ i ever spent (including control arm)
thats a pretty big incentive to NOT quit this project :>
Old 05-09-2007, 02:45 PM   #79
willey878's Avatar
wher did you get the coil overs and the control arms?
should be awsome when its all dont im starting on mine in a week or 2
Old 05-10-2007, 10:52 AM   #80
ɔıɹɔ&
circa's Avatar
Spohn Performance, Inc.
pretty neat stuff...for a pretty penny :P
Old 05-10-2007, 02:26 PM   #81
Usted huele como un asno
mattryanmusic's Avatar
i see parts, i see a truck, but no parts in a truck?
Old 05-10-2007, 11:25 PM   #82
ɔıɹɔ&
circa's Avatar
lol yup!
workin on it though
need transmission...or atleast bellhousing to start test fitting/mounting
Old 05-19-2007, 02:05 PM   #83
More Go then Show
THEKING's Avatar
Hey i just noticed that you live near me, kinda cool to have other people living in your area that are doing an engine swaps too! Keep up the good work.
Old 05-20-2007, 03:21 AM   #84
Super Saiyan User
Dragonball98312's Avatar
I live in Washington too Wish i had the money to do an LSx style swap.
Old 05-20-2007, 04:23 AM   #85
update brotha?
Old 05-20-2007, 04:07 PM   #86
ɔıɹɔ&
circa's Avatar
im slow work sucks and parts arrive slow
bought more suspension parts... rotors sway bar and other garbage be here wednesday
the a arms and steering linkages from suicidedoors.com i have NO idea when they will arrive which sucks :< because i want the wheels back on!
once its rolling again tranny and engine fitting will commence
Old 05-20-2007, 04:16 PM   #87
Did you get the uppers from SD? I ordered my lowers from them about a month ago and still haven't arrived, Not like they're going to get installed anytime soon.
Old 05-21-2007, 12:42 AM   #88
meyers2211's Avatar
nice project keep up the good work
Old 05-21-2007, 01:20 AM   #89
The photo terrorist
postal's Avatar
NIce man efi rocks I have been only doing efi swaps lateley .I would ditch the p/s and get a manual box .I also use sanderson for all my v8 swaps on a std v8 and usually use stock manifolds on ls swaps ...I would like to see how well the headers fit ,sanderson is my fav .I have one pair that im still using that I put in my truck 14 years ago that sanderson made for me.keep up the good work I wish I was closer and I would help out a brotha to get it rolling ,.,.
Old 05-23-2007, 10:36 PM   #90
ɔıɹɔ&
circa's Avatar
well sh*t that blows.
Old 05-23-2007, 10:45 PM   #91
ɔıɹɔ&
circa's Avatar
got some more parts
DJM 2" drop spindles
helwig swaybar 1-1/4"
summit extreme cross drilled / slotted rotors
SSBC caliper's Force 10's
body mount bushings and spring isolators
STILL NO UPPER A ARMS OR STEERING LINKAGE FROM SUICIDE DOORS YET
so i cant put my front suspension back together yet..
sucks :<
Old 05-23-2007, 10:47 PM   #92
ɔıɹɔ&
circa's Avatar
oh and i have a subpeona for june 7th for that shit about the drunk driver...sometime soon would be nice for a settlment.
Old 06-09-2007, 02:22 PM   #93
ɔıɹɔ&
circa's Avatar
Global West hooked me up with some uppers....for a very spendy price. 700$ for these bad boys...as seen here Drag Racing Control arms from Global West Suspension.
later today i should be picking up my steering links from Schucks which were ordered today should be in aorund 3 ish.. with wheels bears and stuff... hopefully will be on wheels tomorrow!
spent more on front suspension then the engine itself... oh im so gonna go broke from this, but its my baby so imma spoil it.
Old 06-09-2007, 04:14 PM   #94
BLAZIN1990's Avatar
That Project Of Yours Is Stellar. Keep Us In Formed
Old 06-09-2007, 06:05 PM   #95
More Go then Show
THEKING's Avatar
I usually just find some old WD40 and spray it on, let it sit for 10 minutes or till i finish my underage drinking. then spray with the hose
I work for a flooring/countertop distributor and we have cans of Formica degrease and adhesive solvent.... it's some powerful stuff, took the oil out like it was a marker
I'm watching your thread as well! three 5.3 swaps going on at once! each one is different which is cool. I'll be last to finish though
I think i will maby. I have bare frame...
Old 06-09-2007, 10:59 PM   #96
ɔıɹɔ&
circa's Avatar
getting pissed trying (keyword) to install my coilover springs... need a compressor or cut the inside lip of the frame ... probably compressor first
Old 06-10-2007, 01:22 AM   #97
Nitto1320 M O D
guhman2002's Avatar
that frame looks DAMN GOOD.... nice progress man.
Old 06-10-2007, 11:05 AM   #98
ɔıɹɔ&
circa's Avatar
lol as i was sleeping i thought of a way to install the coilovers... i should be on wheels today unless i run into more b*tches.
cant start untill my help wakes up either -_-
hate being a morning person.
Old 06-10-2007, 12:24 PM   #99
Lookin good! Find a T56 yet?
Old 06-10-2007, 12:30 PM   #100
XtremeRacer11's Avatar
Man this is looking good man...can't wait to see the finished product...keep the pics coming
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f30/her-name-is-circa-5-3-t56-swap-56k-warning-287380/
Posted By For Type Date
84 S10 conversion - LS1TECH This thread Refback 01-14-2008 06:49 PM
84 S10 conversion - LS1TECH This thread Refback 01-09-2008 02:17 PM
84 S10 conversion - LS1TECH This thread Refback 01-08-2008 06:29 PM
New England Motorsports - Came Accross A Deal I Couldnt Pass Up (5.3l) This thread Refback 06-09-2007 02:15 PM
New England Motorsports - Came Accross A Deal I Couldnt Pass Up (5.3l) This thread Refback 05-10-2007 11:08 AM
New England Motorsports - Came Accross A Deal I Couldnt Pass Up (5.3l) This thread Refback 05-10-2007 10:42 AM
