Corey's Freshly rebuilt lq4 6.0 s10 - S-10 Forum
post #1 of 26 Old 03-27-2011, 03:42 PM Thread Starter
I has s475
Tuckin15's's Avatar
User is: Tuckin15's is offline
Ok this is a good friend of mine's 1997 6.0 s10, we first swapped a 2005 escalade 6.0 in it last summer just a stock motor pretty much with a ls6 cam nothing to special but ended up running a 12.95 at the track on some ET streets so this winter he tore the truck back down and started rebuilding the motor and building more power. He started out by milling the heads with a valve job and a bunch of porting has a ls6 intake now with 60lb injectors upgraded fuel pump some other motor work im sure he will chime in and tell you everything. painted up a bunch of stuff cleaned up the wiring harness and cleaned the interior up a bunch. Ill let the pics speak for them selves.
Before first time swap
6.0 when he first got it cleaning it up.
cleaning it up again
notching for h3 oil pan
All welded up
98 dash swap
motor in
Ill get more pics of motor getting rebuilt and shit.
leaf spring sliders
post #2 of 26 Old 03-27-2011, 03:54 PM
you gonna leauurn today
bigpokie's Avatar
User is: bigpokie is offline
Re: Corey's Freshly rebuilt lq4 6.0 s10
Whats with the sliders? I dont understand why you would want them to move
OLD - 00 S10 , vicorty red , 2.2 , envoy swap , all shaved except the gate , Bagged , 3 linked , 18's
NEW - 04 Dodge 1500 QC , 5.7 , bright white , bagged , Z'd , 2-linked , 22's
Originally Posted by TED NUGENT View Post
IF GUNS KILL PEOPLE, ALL MINE MUST BE DEFECTIVE !
THE ABOVE POST HAD NOT BEEN SPELL CHECKED
I am not a English major, nor claim to be.
bigpokie is offline
post #3 of 26 Old 03-27-2011, 04:34 PM Thread Starter
I has s475
Tuckin15's's Avatar
Weight transfer squats more in the rear end and provides better traction, kinda prevents wheel hop too.
post #4 of 26 Old 03-27-2011, 04:38 PM
s-series #2?
greencactus3's Avatar
User is: greencactus3 is offline
it takes the place of the shackles
post #5 of 26 Old 03-27-2011, 04:51 PM Thread Starter
I has s475
Tuckin15's's Avatar
Word.
Im gonna be building almost the same truck just with a t56 and gloss black or pewter with centerline qualifiers.
http://centerlinewheels.com/wheel_de...vehicle&data=2
post #6 of 26 Old 03-27-2011, 05:12 PM
We Bend Stainless
JDrummond Service Inc.'s Avatar
User is: JDrummond Service Inc. is offline
Ahh you change your mind more than I change my undies! lol
post #7 of 26 Old 03-27-2011, 05:15 PM
Check your ground
556mm's Avatar
User is: 556mm is offline
Saw that truck on youtube. It's bad ass.
556mm is offline
post #8 of 26 Old 03-27-2011, 05:22 PM Thread Starter
I has s475
Tuckin15's's Avatar
Na always been set on a truck with a ls motor just didnt know when i wanted to start building it, im gonna buy the truck when i get to my unit in 5 months then lower it 5/6 with sliders drive it with the tutu till i get enough leave to drop in a motor.
post #9 of 26 Old 03-28-2011, 03:03 PM
red dragon's Avatar
User is: red dragon is offline
hey Ross thanks alot for putting this up i will have to get more pics up on here
the engine:
-ported and polished heads
-milled the heads.....by Baker Engineering
-new valves...by Baker Engineering
-complete valve job...by Baker Engineering
-new valve springs and seals...by Baker Engineering
-ls6 intake
-224/228 114 comp cam
-ls2 chain
-injectors
-new aeromotive in tank fuel pump
looks/ powder coated:
-valve covers
-timing cover
-crank pulley
-tensioner assembly
-heat/ac delete plate
-coil brackets
frame:
-spare tire cross-member removed
-box metal welded in
-new leaf spring sliders
-c-notched
trans:
-well all rebuilt again blew up another rebuilt trailblazer converter last summer sending aluminum through the trans thus total destruction...but all new and new torque converter..( true gm not rebuilt )
there is alot more but i don't have the time to type it all out lol
but all equals to one wicked ride
post #10 of 26 Old 03-28-2011, 04:32 PM
bartle doo
hrspwr454's Avatar
User is: hrspwr454 is offline
we need new vids!! this thing is bad.
Bryce
v click v
1998 Blazer 2 door: fully bagged, 18" Ridler 645 wheels, custom paint, American Bass system
2008 Chevy HHR Panel: goldline 2"drop springs, powdercoated black 18" cobalt SS wheels, HID conversion
post #11 of 26 Old 03-28-2011, 08:14 PM Thread Starter
I has s475
Tuckin15's's Avatar
Word corey were are the videos...i have more pics also.
post #12 of 26 Old 03-28-2011, 08:56 PM Thread Starter
I has s475
Tuckin15's's Avatar
post #13 of 26 Old 04-02-2011, 01:13 PM
S10_QC's Avatar
User is: S10_QC is offline
do you have a complete build thread when you first dropped the lq4 in??
S10_QC is offline
post #14 of 26 Old 04-30-2011, 02:45 PM Thread Starter
I has s475
Tuckin15's's Avatar
videos.
http://www.facebook.com/video/video....04569849629902
http://www.facebook.com/video/video....04566939630193
burnout marks are from the truck.
post #15 of 26 Old 05-04-2011, 02:34 PM
DELETE MY ACCOUNT!
kennymbell1's Avatar
User is: kennymbell1 is offline
you tore that road up, haha, why does the speedo say error?
post #16 of 26 Old 05-05-2011, 07:57 AM Thread Starter
I has s475
Tuckin15's's Avatar
Cause the wireing harness is a pain in the ass lol.
post #17 of 26 Old 02-26-2012, 07:26 PM
User is: 04600rr is offline
where did you get the sliders?
04600rr is offline
post #18 of 26 Old 02-27-2012, 04:29 AM Thread Starter
I has s475
Tuckin15's's Avatar
There are actually several place's were you can pick them up from, you just need to make sure that they are the GM style eyelet leaf spring slider. Alot of dirt track shop's like speedway motor's and several other's have them in stock.
http://www.summitracing.com/parts/AFC-20236S/ keep in mind them are the Chrysler one's.
BTW update on this thing it spun a rod bearing this year and the motor is getting tore down to be rebuilt, also it's not going into the same truck he is picking up another Stan cab with a 3/4 and a 2.5 inch body drop. Keep an eye on this for updates!
post #19 of 26 Old 01-24-2013, 11:15 PM
wrenchin' for life
philiow313's Avatar
User is: philiow313 is offline
is there any kinda further info on the sliders? did they help handling any or just off the line traction?
WICKSIDE RACING
My '98 daily driven, weekend beaten, autox abused S10
2013 SCCA SFR FSP Class Champion
-QA1/UB Machine/Proforged/ZQ8/ES/Hankook/lots more-
Thank you sponsors - Prospect Historic Hotel, Western Sign Co, Napa Auto Parts - Fairfield
post #20 of 26 Old 01-24-2013, 11:38 PM
User is: Criticalbeatdown95s is offline
I think that the error on the speedo is an excellent touch.
post #21 of 26 Old 01-24-2013, 11:52 PM
needs a cheeseburger
tohoopty's Avatar
User is: tohoopty is offline
always loved this video
https://www.youtube.com/watch?v=l8kVkmgd3Nk
Originally Posted by The Griff View Post
I looked at my asshole in the mirror today. It blew my ****in' mind!
tohoopty is offline
post #22 of 26 Old 01-25-2013, 05:50 PM
no bags here
tretiak's Avatar
User is: tretiak is offline
just curious i know this hasnt been updated in awhile but what mounts are you running?
2001 Blazer Xtreme
project: clean and simple < getting bagged and ls swapped
exceeding limits nepa chapter president
Originally Posted by MotorNut123 View Post
I actually should've used concrete on my fender. That way i could decorate it like pottery
you can actually really weld aluminum to steel lol friction welding
tretiak is offline
post #23 of 26 Old 01-25-2013, 05:58 PM
We Bend Stainless
Originally Posted by tohoopty View Post
Hey you deleted me off FB dick! lol
aren't you guys diggin up a really really old thread here? That truck is still around but the guy who put up this thread is in the army and doesn't even own this truck.
post #24 of 26 Old 01-25-2013, 11:37 PM
tohoopty's Avatar
actually i deleted everyone like 6 months ago.took you long enough to notice lol
tohoopty is offline
post #25 of 26 Old 01-26-2013, 12:16 AM Thread Starter
I has s475
Tuckin15's's Avatar
^ correct. Truck is no longer around to my knowledge, Corey and I are no longer friends so idk what's going on with it.
Leaf spring sliders are installed in my Red s10 also, I think they ride great and still keep alot of handling characteristics.
post #26 of 26 Old 01-26-2013, 12:18 AM Thread Starter
I has s475
Tuckin15's's Avatar
2.8 mounts where installed. I also have 2.8 mounts in my red s10 and will be swtiching to current performance mounts due to the 2.8 bushings being too weak.
You may post new threads
You may post replies
