Bodydropping my ex cab - S-10 Forum
Old 02-16-2011, 09:46 AM   #1
xmb63's Avatar
I might as well start a thread here everybody likes pictures of trucks getting cut up.
Here is the truck after I got it bagged I drove it around like this for the summer until the motor started giving me problems. Then I figured its time to body drop it and throw a 350 in there.
The cabs dropped I slid it back 3/4" to center the wheels and angled the fillers. The seat pans are also dropped to get back some head room. I will be using integra buckets the mounting for the seat rails are flat so this will make mounting them much easier.
I had to swap out the upper control arms to a set of SD arms I got in a trade. The stock pie cut upper were hitting the exhaust manifold and steering shaft layed out.
The motor is about ready to come out.
Here is how it sits.
Old 02-16-2011, 09:49 AM   #2
xmb63's Avatar
Re: Bodydropping my ex cab
I plan on keeping the heat and ac the heater box fits back in with the firewall welded up.
Old 02-16-2011, 01:00 PM   #3
v miss her
98layinframe's Avatar
lookin good man, where'd ya get the motor from? is that ryans one out of his old car.. vega i think?
OHh and I hate how fast you did this thing..but you already know that. :haha
Old 02-16-2011, 01:54 PM   #4
xmb63's Avatar
Yea the motor is out of the ventura. I still have to get it off of him.
Old 03-01-2011, 09:45 PM   #5
xmb63's Avatar
Frame horns dropped and plated.
Firewall seam sealed and painted.
jm5 booster looks like it will clear the tire
Old 03-01-2011, 09:55 PM   #6
2.2X-10's Avatar
keep it up
Old 03-03-2011, 01:02 PM   #7
v miss her
lookin good joe, did ya have to drop the frame horns a little more then the cab due to the frame?
also.. im interested to see if and how well the heater box fits back in my first gen too.. did you have the stock one in your old orange first gen truck?
Old 03-03-2011, 07:03 PM   #8
xmb63's Avatar
I dropped the frame horns an 1/8" more than the cab so if I need to shim it to get everything to line up I can. I didn't have heat in the first gen, I hated that. The windows would fog up I carried a towel with me to wipe the fog off. Everything I build from now on I'm gonna keep the climate control stuff.
Old 03-11-2011, 05:57 PM   #9
Professional fabricator
BlackCrossFab's Avatar
Looks good dude keep up the hard work!
Old 03-26-2011, 07:23 AM   #10
xmb63's Avatar
Test fitting the motor.
Old 03-26-2011, 09:11 AM   #11
v miss her
lookin good! what pulley setup is that, where they from? Liken them since they will clear the stock hood!
Old 03-26-2011, 04:48 PM   #12
xmb63's Avatar
They are march pulleys their ryans, he wants them back. Im gonna run the stock setup from the s10. The power steering pulley is close to the steering box but I still need to get the motor lined up.
Old 03-26-2011, 04:52 PM   #13
xmb63's Avatar
Heres the link to them on summit.
http://www.summitracing.com/parts/MCH-22021-09/
Old 04-23-2011, 08:33 PM   #14
xmb63's Avatar
Motor mounts are made and I got the motor mounted. It looks like the stock hood will clear.
Old 07-15-2011, 10:26 PM   #15
xmb63's Avatar
I started working on my truck again I have the motor in for the last time and bolted down. I started on my exhaust manifolds. My welder was acting up so the welds aren't the best but I think they will be fine.
Old 07-16-2011, 06:27 PM   #16
xmb63's Avatar
I got the other manifold made I still need to weld on the down tubes and flanges.
Old 07-20-2011, 07:44 AM   #17
xmb63's Avatar
I had my dad laser cut my flanges and drilled and tapped them for the studs.
Old 07-28-2011, 08:37 AM   #18
xmb63's Avatar
I have gotten a decent amount of work done on this the past week. All the accessories are on the motor ,I have gotten a belt for them but took the picture before I put it on. I got the drivers side exhaust done I still need to finish up the passenger side. I'm hoping by next weekend to at least hear the motor run.
Old 07-30-2011, 10:00 PM   #19
v miss her
lookin good joe, did you modify the frame or modify the oil pan to get the motor to sit so low? What tranny are you running?
Old 07-31-2011, 11:16 AM   #20
xmb63's Avatar
I sectioned the cross member. I'm running a nv3500 tranny I think I might need to trim like .5" off the bottom of the bell housing its gonna be close ill have to see when I get it back on the ground.
Old 07-31-2011, 11:23 AM   #21
xmb63's Avatar
I used 1/4" plate to box it back in.
Old 08-04-2011, 08:43 AM   #22
xmb63's Avatar
The exhaust is finished I used the stock y pipe for now I'm going to redo it with duals later on.
I built the new blower box.
Test fitting the blower box in the firewall it still needs a little trimming
Old 09-20-2011, 08:06 PM   #23
deadman's Avatar
any updates?
Old 09-21-2011, 01:19 PM   #24
xmb63's Avatar
Not really I've been busy with other projects. I bagged the front of my 54 and lowered the back, and fixed the clutch in my Nissan. Hopefully I can get back to work on this soon.
Old 09-24-2011, 08:09 AM   #25
xmb63's Avatar
I worked on it for a few hours last night. I got the dash back in and wired up, and got the blower box finished.
Old 11-28-2011, 05:39 PM   #26
LowerdXpectations's Avatar
looks good, I like how you did the floor of the cab.
Old 11-28-2011, 06:36 PM   #27
Get low
dualthrush2s's Avatar
that cad is tits
Old 11-29-2011, 08:28 AM   #28
v miss her
Love the blower box setup. I still need to figure something out for the first gen. Doh.
Old 11-29-2011, 10:58 AM   #29
SMURF
ridinlow's Avatar
Any more pics of how you did this? I like this idea.
Old 11-29-2011, 02:33 PM   #30
xmb63's Avatar
No, the pictures in the thread are the only ones I took. The trucks mostly back together now I'm hoping to have it running by the weekend.
Old 12-05-2011, 09:32 AM   #31
drag addicts prez
love that blower box good idea
Old 12-12-2011, 08:26 PM   #32
xmb63's Avatar
The water pump pulley is damn close to the fans. There was an 1/8" until I trimmed the fan housing. Dodge stratus fans fit perfect in the s10 radiator.
Im keeping the stock wiring for now Id like to swap a fuel injected motor in down the line but couldnt pass up the deal on this motor.
Old 01-22-2012, 08:29 PM   #33
xmb63's Avatar
I finally pulled the truck out of the garage. It feels good to see it outside after being in the garage for a year. It runs pretty good, absolutely no traction. I snapped a few pics they are dark ill have to take some when its light out.
Old 01-22-2012, 09:06 PM   #34
RQCustoms's Avatar
now all you have to do is get rid of those wheels and you're set.
Old 01-22-2012, 09:21 PM   #35
xmb63's Avatar
I like them they are staying for now. Next on the list is the body and paint.
Old 01-22-2012, 10:10 PM   #36
v miss her
looks good Joe, like how the bed is completely factory looking at first glance. So is the truck all done, or many things you still wanna / need to do?
Old 01-22-2012, 10:31 PM   #37
xmb63's Avatar
There are a few interior pieces that need put back in. I hate the 2 link I'm going to make it a 3 link. Then just bodywork and paint. Hopefully by then its spring and I can daily drive it.
Old 01-22-2012, 10:37 PM   #38
xmb63's Avatar
I also want to put a York edc on and get the ac working by summer.
Old 01-23-2012, 06:48 AM   #39
Mafia Customz
mafiacustomz's Avatar
them headers are not going to flow good at all
Old 01-23-2012, 07:38 AM   #40
xmb63's Avatar
I figure they should flow about the same as stock manifolds. I didn't have a lot of room to work with.
Old 01-23-2012, 07:55 AM   #41
xmb63's Avatar
This is the thread that gave me the idea for the headers.
http://www.s10forum.com/forum/f143/b...eaders-290705/
Old 01-23-2012, 09:45 AM   #42
v miss her
Yeah body drops and lowered motors equate to next to zero exhaust room on these trucks.
Old 01-23-2012, 11:57 AM   #43
Longbeds FTMFW
gunther19820's Avatar
I am confused with you lowering the motor. How far down did you lower it?
I have a SBC/Auto in my truck...I think I may only have a couple inches between the trans pan and the ground when I am laid out. And my aircleaner is touching my hood now (im not bodied yet)..
Old 01-23-2012, 12:09 PM   #44
xmb63's Avatar
I'm not sure how far its lowered but the oil pan is about an inch from the ground. I had to trim the bracing on the hood to clear the air filter. I'm not a fan of cowl hoods is rather do the extra work to keep the stock one.
Old 08-08-2012, 09:08 AM   #45
xmb63's Avatar
A little update to this thread, I finished up the body work and painted the truck for carlisle this past weekend here are a few pics my buddy took of it at the show.
