Bodydropped 78 Chevy LUV...
LinkBack (3) Thread Tools
Old 03-22-2005, 03:25 PM   #201
mytruckputsitsnutsonya
T Baggin S10's Avatar
Re: Bodydropped 78 Chevy LUV...
Quote: Originally Posted by BIGGERISBETTER
dood.. i want your patients... idda kicked a friggin hole in the side by now
I'm in no hurry to get it going because I still have no motor. I'm not flintstoning it around.
I have a Blazer that I drive daily so I bought this to spend time on so I had something to work on but didn't have to worry about doing small stuff to it so I could drive it as well.
Old 03-22-2005, 03:31 PM   #202
art thou leaking?
sdime98's Avatar
i may have missed out but what motor do you plan on runnin?
Old 03-22-2005, 03:50 PM   #203
LT. Morgan
miself's Avatar
i belive he mentioned running a new stock motor.
Old 03-22-2005, 03:51 PM   #204
Right now I plan to run the factory motor out of the truck I may get. If I don't get it then I have a few ideas. Not going to go back with what was in it that is for sure.
I'm concentrating on getting the body straight right now. The motor is not even on the to do list as of right now. I'll work on that after the body is further along unless I finally talk to the guy about the orange truck.
Old 03-22-2005, 03:56 PM   #205
Draggin Moderator
98layinframe's Avatar
why not the v8 that was in it? it looked nice in the pics... why not keep it in there for now?
Old 03-22-2005, 03:58 PM   #206
art thou leaking?
sdime98's Avatar
yea i heard that, i gotta get mine runnin right before i really dig into it too....i was thinkin of runnin a newer 4.3 with a nv3500? maybe, as a cruiser truck, nothin particularly quick
Old 03-22-2005, 04:16 PM   #207
Hardcore 1st Gen'r
jman's Avatar
i always liked the luv's. i admire the patience and effort you are making. i couldn't do it. already looks worlds better just sanding it down. can't wait to continue seeing the progress.
Old 03-22-2005, 04:21 PM   #208
art thou leaking?
sdime98's Avatar
is it me, or can nobody spell patience correct?
Old 03-22-2005, 04:30 PM   #209
I got the truck with no motor or trans. The motor mounts that were built are junk. I'm going to cut them off the frame sometime soon and grind it smooth.
I want to be able to drive it and get halfway decent gas mileage so I'll drive it more.
Old 03-22-2005, 04:31 PM   #210
Alot of people misspell words. I just read them as they are intended to be posted and move along.
Old 03-22-2005, 04:33 PM   #211
By the way. If you want to see a big list of the pics I have taken during the build, click the word LUV in my sig. I have not posted all of the pics I have taken so far.
Made it huge so everyone would see it.
Old 03-22-2005, 04:33 PM   #212
Hardcore 1st Gen'r
jman's Avatar
fixed. just be patiant. j/k i'm typing a little too fast. i rarely proofread so that doesn't help either.
Old 03-22-2005, 05:00 PM   #213
I Love Tools
rainingbullets's Avatar
Awesome. Keep up the good work. :thumbup:
Old 03-22-2005, 06:52 PM   #214
dimeless again!!!
Bullyspeedfreak's Avatar
your LUV looks sickkkk, i admire your hardwork and itll definetly be nutz when done. keep up the good work!!!
Old 03-22-2005, 06:59 PM   #215
xtremefour
xtremefour's Avatar
I wonder how much money he spent in bondo, also that thing will be light as hell now.
Old 03-23-2005, 01:41 AM   #216
Took a better pic of the bed. I got the rest of it down at the top after this was taken...
Before I started tearing into the side...
This probably looks really funny, but I did it on the other side and it worked well to tell me where the high/ low spots were. I Used a wide flathead that has a sharp point and a hammer and worked diagnal downward chipping the filler away to find the fossils underneath...
A couple of the bigger pieces I pulled off the bedside...
Showing the areas that came off really easy...
Yum...
Most of the bed down. It will be finished next time I work on it...
I decided to go with a wire wheel instead of a sanding disk on this side. It takes about the same amount of time to get it down and I dont have to come back and smooth it out afterwards...
The filler for the blinker on the back corner of the bed...
Old 03-23-2005, 09:20 AM   #217
sketchystreet's Avatar
it looks like someone took a golf club to most of that truck. how are you going to fix all them little dents with minimal bondo?
and i cant beelive he could drive that truck without the bed sides of bondo falling off.
Old 03-23-2005, 09:29 AM   #218
flat blue and layin frame
BIGGERISBETTER's Avatar
I dont think ive ever seen that much bondo on any vehicle ever... that must be one dented up sumbitch
Old 03-23-2005, 09:45 AM   #219
art thou leaking?
sdime98's Avatar
yea, i cannot get over all that bondo there....its rediculous
Old 03-23-2005, 10:07 AM   #220
I want one \/
s10n20s's Avatar
that guy must have stock in bondo
Old 03-23-2005, 11:06 AM   #221
awesome progress! and I have started working on mine again thanks to your inspiration... today im going to get my drille and a change of clothes on my lunch break so that right after work i can go straight to the shop and work on my truck for an hour or so before we play poker... wednesday night poker night
going to wire wheel some parts of the cab and start taking down the bondo on my right bed corner where it was once wrecked and fixed with pure bondo... goin to attempt to fix myself by using kitty hair/a lot stronger and then bondo/filler putty.... atleast enough to make me happy for this show season....
last night i block sanded more on teh cab and primed some spots where it was bare... block sanded on the doors and found a low on the driver side...
ill link you to some pictures tommorrow if i remember... working on a full size long bed = 5x more work
Old 03-23-2005, 11:52 AM   #222
I'm going to straighten the bedside with a dolly, hammer, and a pin gun. Hopefully I can get the big areas out enough to straighten them. I'm not just going to slap bondo back on it and call it done. There were up to 7-8 layers in some spots of primer, paint, filler, primer, filler , filler, filler, paint, glaze, primer, paint. I will go look for one of the pieces that has alot of layers. I wish I would have started the 5 gallon bucket filling with the big pieces when I started on the other side. It would have been filled by now.
Old 03-23-2005, 12:00 PM   #223
Glad to see that I inspired someone. That was my intention of posting soooo many pics and explaining pretty much everything I'm doing and why I'm doing it. i have always liked seeing people let you know everything they are doing on such a big build, so I figured I should go all out with pics and all.
I'm actually using a grinder and a flat wire wheel. A cup on a drill will not work as well because I'm using the side of the wheel most of the time to get the most use of it and not have it wear away at an angle. Did you see the pic of the last wheel I went through??? I have one before it that was not nearly that bad. I'm going to take a pic of a new one I have next to the two used ones to show just how much use I got out of them.
How bad is the dent on your corner that you are going to fix? Is there any way for you to pull it? It would be much better if you pulled it out at least some and tryed to get some of it's shape back before filling it.
After seeing how bad this was and attempting to startt blocking it at first I will most likely never just block sand and paint another used vehicle that I have no clue as to what is hiding underneath. I blocked the Blazer and sprayed it because it still had the factory paint, but I'm going to redo it as soon as the luv is ready for a break and is driveable.
Get me the links for the pics. I love seeing pics of peoples work.
Old 03-23-2005, 01:36 PM   #224
PPG sprayin' member
downtoearth's Avatar
i think I'm gonna go vomit...looks better every time I see it.
Old 03-23-2005, 01:47 PM   #225
I'm trying. This bed may not be used afterall. That is if I can get another one really cheap. I'm going to cut the taillight fillers out and try to find some factory taillights to see just how hard it will be to get them to fit again.
Old 03-23-2005, 04:57 PM   #226
Hardcore 1st Gen'r
jman's Avatar
that's just crazy. i think the other bed would be a great idea right now.
Old 03-23-2005, 04:59 PM   #227
Hardcore 1st Gen'r
jman's Avatar
its rediculous
now, now, you just knocked my spelling?
Old 03-23-2005, 06:43 PM   #228
What y'all watchin HOES!?
Crazygenius13's Avatar
This thread and Avtekk's thread should be sticky'd, it'll be a race, which takes longer? rebuilding a Peice with roughly 6 gallons of filler? or SFBD from scratch on who knows what the final product will be? I'm sure both of your guys' work is going to turn out superb! Have either of you had feature trucks? just curious.
Old 03-23-2005, 07:26 PM   #229
I'm stripping the entire truck down, redoing all of the suspension, body work, poaint reshaving everything, redoing all of the interior, redoing all of the bodydrop, and adding alot of metalwork into the rebuild. He will kick my ass on getting his done. There is no doubt about that. He is on a deadline, I'm not. I have no deadline for when mine will be done. I'm in no hurry to get it done, I'm just working on it when I can and as much as I can. After the body is done it should go by alot faster because what will take time on the rest will be planning not actually doing hands on work.
About having a feature truck...
No I have not ever had one, but I plan on having one by the time I feel like thi truck will get a break. I have a few plans for it, but going by the shape it is in I'm not going to make any major permanent plans for it because alot of things I am running into are unexpected.
Old 03-23-2005, 09:11 PM   #230
Shit's Weak
JohnH's Avatar
my friend, you are doing the world a service by rescuing this truck from ghettodom. keep up the good work and updates.
Old 03-24-2005, 12:55 AM   #231
Thank you!
The bucket...
Old 03-24-2005, 01:21 AM   #232
Time to finish
LT250's Avatar
its sad when the bondo you pull off a truck can fill a bucket. Pretty good idea to put it all in a bucket it will give some perspective to how much you are pulling off.
Old 03-24-2005, 01:21 AM   #233
PPG sprayin' member
The bucket, thats great; "FILLER" up, hahaha, get it...get it!!!!
Old 03-24-2005, 07:29 AM   #234
LT. Morgan
miself's Avatar
lovely bucket, progress still lookin good man.
Old 03-24-2005, 07:39 AM   #235
G2 Racer's Avatar
Still in shock from the amount of filler on it, yikes.
Old 03-24-2005, 11:26 AM   #236
The bad thing is the filler is just from the area around the taillights, the "chevrolet" and where the plate box used to be, and some of the passenger bedside. The rest of it was shavings from using a wire wheel.
Old 03-24-2005, 12:36 PM   #237
I hope this isnt another project like a saw awhile ago when a fella on teh forum was re doing his first gen from the ground up... he put an assload of work and money in it just too end up parting it out after he had the rolling chassis due to getting tired of it. It would be a shame to see you fall under the same kind of thing..because youve got alot on your hands and alot of plans... Id love to see this thing done someday man.
Old 03-24-2005, 01:14 PM   #238
I'm only putting time into it so far. I have not spent much money at all on it.
I am not going to give up on it.
Old 03-24-2005, 01:44 PM   #239
Rollin 1st gen style
tommyk90's Avatar
Jebus, for all the money that guy spent on bondo he probably could've bought a different bed.
Some people are just idiots....
Old 03-24-2005, 02:30 PM   #240
Dead Project Truck
rivbluenoma's Avatar
Been watching this from the beginning, soon as my 2nd gen project is done Im going to look into getting a luv or similar year mazda to play with. Your making lots of good progress, keep up the good work. Id hit the guys up over at LUVtruck.com and see if maybe they have some info on where you could score some new bed sides for cheap. http://www.luvtruck.com/
Old 03-24-2005, 02:46 PM   #241
Been on there for a couple weeks. Wicked Mayhem told me about the site and I registered. There is a salvage yard about 6 miles away from me that has alot of luv's. I may just try to find one somewhere around here if the guy with the orange one does not come through.
Old 03-27-2005, 03:56 AM   #242
Putting a trans in the Blazer. I'll have another update Tuesday or Wednesday night.
Old 03-29-2005, 05:06 PM   #243
LT. Morgan
miself's Avatar
progress is still lookin good man, can't wait to see more
Old 03-29-2005, 05:30 PM   #244
yeah... that's STATIC
larstrak's Avatar
gahdamn, you CRAZY sob... and i thought redoing my 97 dime was a waste of time, lol.
but i am glad to see you doing it, the truck did look okay before, but seeing all the skankiness could make ANY custom truck buyer weary...
congrats, props, high fives, blow jobs, self appreciation, pride, trophies... whatever man, i hope you get what you deserve for doing this project.
Old 03-29-2005, 06:09 PM   #245
welding bum
dedication and time go hand in hand....good job....and i just realized that thing is a unibody....didn't know or for that matter didn't pay attention to it before i guess....should be cool when it's finished!
Old 03-29-2005, 10:10 PM   #246
I hope I deserve something for doing it.
Old 03-29-2005, 10:32 PM   #247
Time to finish
LT250's Avatar
if I was a pimp I'd give you a ho for free, for taking on a project this big, I'd give ya two when it was done to encourage you to work fast
Old 03-30-2005, 08:08 AM   #248
Dead Project Truck
Old 03-30-2005, 03:01 PM   #249
LT. Morgan
miself's Avatar
unibody?
Old 03-31-2005, 12:26 AM   #250
Thanks man.
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f30/bodydropped-78-chevy-luv-165517/
Posted By For Type Date
LUVTruck.com :: View topic - Another Bagged Luv found on S10forum.com This thread Refback 09-22-2007 09:04 AM
LUVTruck.com :: View topic - Another Bagged Luv found on S10forum.com This thread Refback 09-12-2007 12:41 AM
LUVTruck.com :: View topic - Another Bagged Luv found on S10forum.com This thread Refback 09-12-2007 12:33 AM
