#101 |
Re: Bodydropped 78 Chevy LUV...
oh man. i cant stop laughing at the gas tank filler
but wow you've made some major changes already. this things gonna be sic when its done! sad to see it so hacked right now though ![]() |
#102 |
alone i break
did you kill a cheeta lol looks good man
#103 |
slowly, but surely.
NEW PICS...!!! lol
#104 |
mytruckputsitsnutsonya
#105 |
#106 |
#107 |
Heres a pic of the parts truck I may get...
![]() Cut the fender support on the driver side to see how much room I will have for larger wheels, and so it will actually lay another inch or so in the front after I cut a little off of the trans. crossmember... ![]() This is a pic of it an inch from laying the front of the cab. I should have room for a narrow zero offset 18 with a 35-40 series tire... ![]() I got a better pic of the "taillight filler". It still does what you see in person no justice... ![]() Side marker light on the front fender was taped from the backside with aluminum ducting tape and filler was spread over the front side... ![]() Dash is down to the metal all most all the way. Minus a few corners, it went down nice and smooth with a wire wheel on a grinder... ![]() ![]() I cut the leaf hangers off the drivers side frame because they were keeping the truck from teetering on the transmission crossmember. The rear of the cab on the drivers side lays now. I'll cut the passenger side when I move it to the other side of hte garage and start on the passenger side... ![]() ![]() |
#108 |
dam that is a friendly truck...
#109 |
#110 |
hell if your buying that orange truck.... why not just use the bed off it? Dont look to be in all that bad of shape.. defiently better then the one on you truck now
#111 |
He means it waves at everyone...panels are wavy I have been watching since you first posted. Love what you are doing! Had quite a few duct tape and expanding foam trucks over the years. It is amazing what some people will cover with bondo. My favorites so far have been chicken wire and newspaper so far.Keep it up....we are watching..... ![]() |
#112 |
your work is lookin great man. in the first pics it looked like the frame was 1'' higher than the body.
keep up the good work. |
#113 |
whe ever did that bodydrop should have their hands cut off.
#114 |
LT. Morgan
the progress is lookin nice man....that bed is hella dented tho
#115 |
i think id just start all over with the orange one...
#116 |
Damn...still all I can say.
Making some progress and that's the important thing. Keep it up man, definately watching this thread. |
#117 |
flat blue and layin frame
One of the employee's at West Coast Customs mustve owned that truck before T baggin got it... cuz bondo fixes everything! and rust.. what rust? Isnt that what carpet is for? haha
#118 |
[ sic ]
As a person with no real understanding of cars, I have to say I respect you soo much! If that were mine... Id have everything done for me (If I had the money) or I'd have tried to sell it for more then I bought it...
Good job man! |
#119 |
364 Lq9 in the works..
Ben your the shiznick man
keep up the work i envey you |
#120 |
#121 |
built not bought
thats the biggest hack work i have ever seen . good luck getting her back to normal
#122 |
#123 |
let me guesss.... the leds are mounted in with bondo from behind... ?
#124 |
#125 |
I thought about not using the shocks on the doors, but this was something that was done pretty good, so I'm going to leave it but clean it up a little. The pic also shows how much of the filler was not welded to the floor...
![]() Pulled up a patch that was riveted to the floor and found two pretty big holes. The brake pedal was cut, the two pieces were stuck next to each other and welded, instead of sectioning it... ![]() Started on the cab floor and back wall, I got alot of the drivers side done. There was alot of surface rust, but it all came up with a little work. There is alot of rust from where the front of the seat was forward. I'm going to make a new floorboard to go over the existing one or cut it out and replace it with a new one... ![]() ![]() ![]() |
#126 |
LT. Morgan
awesome, its really cleaning up nicely
#127 |
hell man can i help?
i have nothing else better to do.....if your free on the weekends give me a call man "send me a private message" |
#128 |
#129 |
front end conversion?
#130 |
old school
wow! I started at the begining and was like, damn the frame is all rusted to hell, that's gonna be tough...but the resto is coming along great! I can't wait to see what it looks like finished
gives all rustbuckets everywhere some kind of hope ![]() |
#131 |
omfg!
a front end conversion on a luv lol thats would just be dope... ![]() |
#132 |
Rust buckets need lovin too!!! |
#133 |
#134 |
Got a little bit done today...
Pulled up the panel that had about 20 pop rivits holding it down, more of the tape, and some nasty white caulking that was used on alot of the seams. Underneath some of the metal was decent and came out decent with a wire wheel. A big portion of it was rusted and there are alot of big rust holes... ![]() You have to look at this pic for a little bit to take it all in. The floor is not welded in at all because it was rusted away and there was nothing to weld to. I'll be cutting alot more out of the passenger side than the driver side to replace with good metal... ![]() Got a little more done on the back wall... ![]() The back half of the floor is a little more than halfway done. I still need to go over most of it to get the small surface rust off... ![]() The dash is down and ready to have the top filled and grinded minus the fillers being cut out and grinded down on the front where the glovebox and two small patches on each side are... ![]() |
#135 |
LT. Morgan
nice
#136 |
Took a couple more pics of the truck I may get for parts...
![]() ![]() I know it is in really good condition and woule be a much better idea to just work on this one, but I want to be stupid and redo the nasty one. Hopefully the owner will call me or I will catch him outside sometime really soon so I know what is going on with it. I'm trying not to work on some stuff that will be replaced if I get this truck. |
#137 |
Mine's Longer than yours.
None of the pics work for me.
#138 |
Anybody got 20's?
They work for me
#139 |
Damn, that thing needs some work.
Here's hoping you get the orange one for parts. |
#140 |
#141 |
there is a stepside luv 2 doors down and across the street from me. look like its in pretty good shape too quality paint job but i really dont like the design. that guy always buys vehicles and does minimal to them to resell them for more. he said he wants like $2-2500 for it. i might be into it but id rather spend the money on my dime
#142 |
Time to finish
#143 |
But people who are will pay decent money for one in good shape. |
#144 |
i dont think i have ever seen a stepside luv...might have to do some research on it...just to see what it looks like it.............
your project makes me wish i kept my 79 ford courier... ![]() |
#145 |
4dr 4X4 Xtreme Blazer
looking good..
mark |
#146 |
im glad i never rode in that... i can see it now...
dude were doing 60 in 40... cool... drag it!!! okay... *87layinlow falls through floor and his ass drags more then the hacked up body drop* project is awesome though i check like every 5 hours to see if therse updated just because i love this kinda stuff ![]() |
#147 |
body dropped
Leave a note on the orange one and ask if it's for sale.
#148 |
Anybody got 20's?
#149 |
I'm going to leave a note on the truck next, then try to leave one on the door again. I had to buy a couple things for the Blazer today, so that set me back a little on the LUV. |
#150 |
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f30/bodydropped-78-chevy-luv-165517/
| LUVTruck.com :: View topic - Another Bagged Luv found on S10forum.com | This thread | Refback | 09-22-2007 10:04 AM | |
| LUVTruck.com :: View topic - Another Bagged Luv found on S10forum.com | This thread | Refback | 09-12-2007 01:41 AM | |
| LUVTruck.com :: View topic - Another Bagged Luv found on S10forum.com | This thread | Refback | 09-12-2007 01:33 AM | |
