mytruckputsitsnutsonya
Bodydropped 78 Chevy LUV...
I bought this from a friend that bought it from a guy who bought it from the guy that built it.
I'm in the process of tearing it down to redo everything. I got it last weekend on Saturday February 12th. Here is what it looked like just before I got it. Nothing at all changed besides the motor and trans being pulled... ![]() ![]() ![]() ![]() ![]() Last edited by T Baggin S10 : 02-22-2005 at 12:46 AM. |
Re: Bodydropped 78 Chevy LUV...
Heres the console. The sides were cardboard covered in tweed, the top was thin pieces of aluminum...
![]() Heres the back of the cab wall. It was cut and dropped down, not welded at all, it has a few screws and pop rivets holding it in place and the same aluminum ducting tape as the floor holding it in place... ![]() Heres the interior fully gutted. I can't wait to grind on it and get ot ready to patch in the spots with rust holes... ![]() Another shot of the interior fully stripped... ![]() Heres a shot of the shock where it was rubbing on the bag... ![]() And where the upper ball joint nut was rubbing on the bag... ![]() Shot from the front of the interior stripped. ![]() |
Inspired Soundwave
decent. some work left, but it's a good start.
how did that bag not pop?
Heres the transmission tunnel. It was pieces of thin aluminum pop- rivited in...
![]() I started working on the wiring. I pulled all of the stereo wiring, and got alot of the rest sorted out. Heres a pic of the "fuse box" Notice the bolts in place of fuses??? ![]() I got all of the 1/4" thick body filler off and down to the metal on the drivers side and around the stereo surround. I cut my fingers and they started bleeding so I didn't take a pic of the dash where I stopped... ![]() |
I got the roof down to the metal minus a few spots. I used paint remover because it had two layers of black, a primer, maroon, blue, the origional white and a primer under that. I started working on the drivers side to see how ther rear was done. I decided to get most of the truck down to the metal to know exactly what I am dealing with so there are no surprises at all. I'm going to get all of the dash down to bare metal and weld up the holes in the top of it, smooth them out and go with straight paint on the dash with no dash pad. I like the shape of it and after scraping the body filler off the roof I found a hidden body line that matches the dash. I plan on grinding the floor down to bare metal to find exactly how much of it is rusted. There is alot of filler on the floor covering rust holes. I'm most likely going to patch in the front half of the cab flooer because most of it is trashed fron rust. The body is in pretty bad shape underneath the filler that ranges from 1/16"- 1/2" thick in some places. The drivers side gas door and taillight fillers need to be redone because they have no strenth to them and were not welded to the outside of the bed so there was about 3" of filler and dynaglass built up to make the shape on the back corner. and about 1/2" filling in the gas door. I have not got to the door yet,b ut I'm sure it is tacked in only a few places like the gas and taillight fillers. The body was pretty straight on the outside and the body work was done pretty good but the seams on the rear were starting to crack so I decided to see exactly what was done. I should have the roof done and laot of the drivers side of the bed and some of the rear of the bed done tomorrow to get ready to be welded up. I'm going to get the floor ready as well so alot of the welding can be done at one time. I'll post progress pics in the next couple days after I have something I want to show. Posting pics of big dips and poor patch jobs in the body is not something everyone wants to see.
Inspired Soundwave
shit, after looking at the rest of that, there's a LOT of work there. looks like some ghetto fab.
The dash...
![]() Here is how thick the filler was where the glove box was removed... ![]() Never did post a pic of the hacked up Radiatior support... ![]() Rear setup before... ![]() Fuel cell removed and bed floor showing once again. I traded the 3 gallon shown here for a 6 gallon today... ![]() |
slowly, but surely.
looks pretty cool man
Moderator
mm bodydropped luv.. mmm... looks like the same shifter i got.. and a couple of those gauges look the same as mine... gonna be bad ass when ur done!
wow that thing needs alot of work! but looks like your well on your way :thumbup: Im sure it will be real nice when your all done with it.
i <3 my truck
looks like you have a lot of work on your hands...good luck.
UnDeR CoNsTrUcTiOn!!
omg someone definatly rigged that thing. Could someone do me a favor? If i ever put cheetah print on my dash, someone shoot me in the face please.
get to work. It can only get better from here. I wanna see some progress. |
The Beast
MPG is overrated
nice. how the hell do you get your doors open from the inside? a remote? i'm likin the interior. nice and clean
Primer Spots
someone apparently did not own a welder
King of the Swing
Man what a hack, but its good to see that someone that knows what they're doing is going to redo the thing.
PPG sprayin' member
Atleast it had a V8.
un banned
wow! what a pos! you got your work cut out for ya!! hope it didnt cost ya too much for the truck, cause it needs a whole lotta LUV! props to you for bringin it back to life, but man.. i hope ya got some serious freetime! :thumbup:
LUV = s10s father |
#24 |
#25 |
#26 |
on my way to pimpin
i love the radiator support... its totally ghetto gangster fabulous. i wonder if youll find the guys spinner tooth cap in the cab somewhere.
#27 |
Static Dropped Dime
im likin that truck bro keep it uop cant wait to see it finished
#28 |
Supa Fly
looks like fun
#29 |
I like MINE with NO shine
I love Luvs
#30 |
Time for pics of todays progress...
In the middle of removing the thick filler on the drivers side of the bed. And the door handle down to the metal... ![]() Front view of the same thing as above... ![]() The bedside most of the way down to the metal. Minus a few extremely low spots where it looks like someone took a ball pin hammer to it... ![]() bedside done pretty much and showing the taillight fillers that are 4-5 pieces of thin strips welded together instead of making real fillers... ![]() Roof down to bare metal... ![]() Showing the Radiator support where it was chopped up... ![]() Showing how thick the filler was on the back corner... ![]() This is how thick it was... ![]() |
#31 |
forum idiot
HOLY SHIT what the ****!
#32 |
holy hell thats a shit load of bondo
#33 |
Registered Asshole
Mann o man, What a fukin HACK whoever built that shit before.
Glad to see somebody who knows WTF they are doing got ahold of it. Good luck, and great pics. |
#34 |
wow that some work there but its a better start then most stuff but cant wate to see it looks bad ass
#35 |
forum idiot
i look at it again...looks like a 5 year old did that body work...lol...
#36 |
2legit2quit
good luck dude. glad to see someone is taking the time to save one of those trucks.
#37 |
#38 |
Jersey's lowest
thats awesome...good luck fixing it
#39 |
Primer Spots
wow was the truck in a wreck before or something.. did you expect to see all that shit when you took the paint off?
#40 |
Holy ****
#41 |
SK= Midwest's Elite
wow
#42 |
I'm a huge ass
ummm im thinking WOW is just about the only word to discribe how much work its gonna take to smooth all the out
#43 |
nascar fan
nice man, keep up the good work
#44 |
Wow.... Good Luck. Ha. Your gonna get pissed at that pos. But hopefully it will look good in the end.
#45 |
A pin gun and dolly and hammer will be used and abused on the bedside.
#46 |
Supa Fly
you know if you work out most of the large "shit" spots you can float a thin layer of duragalss over the deep spots...I just did that when i fixed my tailgate...that shit is stronger than metal and its water proof, so its ok if you have to fill over holes...just my .02 you have some work ahead of ya :thumbup:
#47 |
Wow.....I never never seen any vechile done as shade tree and half asked as that. You've certainly got some work ahead of you man.
Good luck! |
#48 |
#49 |
I gotta ask, what other filler products are there besides Bondo?
I've never looked at other ones. |
#50 |
Posts: n/a
Thats fuggin tight, keep us updated on all progress mang!
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f30/bodydropped-78-chevy-luv-165517/
| LUVTruck.com :: View topic - Another Bagged Luv found on S10forum.com | This thread | Refback | 09-22-2007 10:04 AM | |
| LUVTruck.com :: View topic - Another Bagged Luv found on S10forum.com | This thread | Refback | 09-12-2007 01:41 AM | |
| LUVTruck.com :: View topic - Another Bagged Luv found on S10forum.com | This thread | Refback | 09-12-2007 01:33 AM | |
