Bad Grandpa: V8 swapped '87 S15 - S-10 Forum
 7Likes
post #1 of 102 Old 01-15-2017, 08:39 PM Thread Starter
gas4blood's Avatar
User is: gas4blood is offline
Time to jump back in to the forum! Some of you on here may remember me from a few years ago when I had my '91 S10 daily driver. Pic attached for memory's sake:
That truck was a 2.5/5 speed with A/C and around 58,000 original miles. I was really wanting to build a V8 S series but could not pull myself to take my '91 apart for the swap. I ended up selling that truck to a guy in Texas and then drifted away from the S10 scene for a couple of years. Fast forward to about 6 months ago. We are now living in Virginia and as most of us do, I was browsing craigslist looking for nothing in particular. A search of "S10|Sonoma" pulled up this 1987 S15 being sold about an hour from our house.
It looked clean and the price was right so I loaded the family in the Tahoe and made the drive to go check it out.
"Hey! Driving is a serious business. I ain't having no accidents just because of you!"
post #2 of 102 Old 01-15-2017, 08:47 PM Thread Starter
gas4blood's Avatar
Re: Bad Grandpa: V8 swapped '87 S15
The truck ended up being an abandoned project of the seller's teenage son. They had purchased the truck in stock form from their neighbor who also happened to be the original owner. Shortly after getting the truck, the 2.8 blew its guts and they began pulling things apart to prepare for a small block install.That's where things got put on the back burner and the truck ended up sitting for quite some time. In comes me!
We agreed on a price and 7 days later I was back with a trailer to take it off their hands.
Due to the fact that this truck was owned for most of its life by an elderly gentlemen, it was in phenomenal shape. The interior was one of the nicest that I have ever found. The dash alone was worth the asking price!
Stopped on the way home to blast off the years of mildew and moss that had accumulated onthe truck. I think by now you can tell where I came up with the "grandpa"part of my project name.
post #3 of 102 Old 01-15-2017, 08:59 PM Thread Starter
gas4blood's Avatar
Once I got the truck home, I decided to try out an old hot rodders trick to see if I could get rid of the rest of the nastiness that had built up on the truck. Comet to the rescue!
Now that it was looking fresh and clean, I started to tear in to the interior to see what I was dealing with.
Floors look pretty dang good! A little surface rust on the passenger floor but nothing that cant be easily taken care of.
post #4 of 102 Old 01-15-2017, 09:07 PM Thread Starter
gas4blood's Avatar
While I was waiting for our move to the new house, I started my search for some new parts that would be needed for this project. A call to a member of the facebook V8 S10 owners page that runs his own performance shop got me set up with my suspension. I am trying to build this truck on a budget so he hooked me up with what he thought would be my best combo. The rear setup is Western Chassis Supply 4" drop leafs with Lakewood traction bars. The front has 2" DJM drop spindles and 1"springs. I also picked up a new rear axle which I will explain shortly.
Right around this time, I happened to be talking with my neighbor about my new project and mentioned to him that I was in the market for a new rear axle for the V8 conversion. He said that he had some cousins that worked for the local Pick-a-Part and could get me hooked up with whatever I needed. The following Saturday, we went to the yard on the hunt for a 2wd 5 speed blazer with a 8.5" 10 bolt. After a morning of scouring the yard, we found this little Jimmy tucked back in the corner. I jumped under to confirm that it had what I needed and he had his cousin drag it out of the mud so that we could pull the axle. It was at this time that I should have paid closer attention to the wheels. They would have been a dead giveaway that this was going to be a bi twider than I thought.
post #5 of 102 Old 01-15-2017, 09:13 PM
ajp89's Avatar
User is: ajp89 is online now
Truck looks super clean! I would love to find a rust free 1st gen some day. Nice thread so far.
1998 ext cab 2.2 5-speed (LS6 swap in the making)
ajp89 is online now
post #6 of 102 Old 01-15-2017, 09:21 PM Thread Starter
gas4blood's Avatar
I totally stripped the axle down, cleaned up the housing, and ordered a new 3.73 gear set and Eaton posi unit.
post #7 of 102 Old 01-15-2017, 09:28 PM Thread Starter
gas4blood's Avatar
Then the day finally came to move into our new place. I finally had a garage to work on this pig.
Then came the start of the tear down. First things first, that camper shell had to go. I was sick of all of the "mini Farm Truck" comments! haha.
Then I started to strip all of the unnecessary factory stuff that was in the way.
Good thing I was getting rid of the stock fuel tank!
post #8 of 102 Old 01-15-2017, 09:31 PM Thread Starter
gas4blood's Avatar
Pushed it out into the driveway and put it up on jack stands so that I could get the frame and underside all cleaned up.
Back in to the garage you go! Time to start tearing out the old suspension
post #9 of 102 Old 01-15-2017, 09:38 PM Thread Starter
gas4blood's Avatar
Started with the rear suspension/axle. Pulled out the whole assembly and gave it to a guy that was building a 1948 Chevy truck.
Cut the factory bump stops off. Got the rear half of the frame prepped and painted then slid all the new parts into place.
I'll wait until things are all in place and back on the ground to finish the trac bar install and order my shocks.
jplinville likes this.
post #10 of 102 Old 01-15-2017, 09:48 PM Thread Starter
gas4blood's Avatar
Then I moved on to the front. Stripped the suspension out, painted the frame and undercoated the wheel wells and bottom of the bed. All new parts up front to include rotors/pads. wheel bearings and seals, spindles, springs, control arms and bushings. I also took the time to swap the power steering box for a manual unit.
Out with the old:
All painted up:
In with the new:
New to memanual box as it was when I bought it:
And after some elbow grease and paint:
post #11 of 102 Old 01-15-2017, 09:52 PM Thread Starter
gas4blood's Avatar
Around this time, I was trying to order replacement axle shafts for my new housing.The shafts were measuring at 29" which was 4wd length. After some research I determined that I had a non-ZR2 4wd 8.5" 10 bolt. NOBODY carries off the shelf replacement shafts for this axle so a call to Dutchman Motorsports got me a pair of 30 spline replacements.
Got my best little buddy out into the garage with me to help rebuild the rear brakes.
post #12 of 102 Old 01-15-2017, 09:55 PM
heeter_33's Avatar
User is: heeter_33 is online now
Please say you're going to leave the body untouched!
1985 S10 2.8
2010 Cobalt SS
1972 Honda CB100
post #13 of 102 Old 01-15-2017, 09:58 PM Thread Starter
gas4blood's Avatar
I had previously picked up a set of Weld Prostars on craigslist. I had recoated them in semi gloss black and was super pumped to run them. Once I determined that my axle was about 4" wider than I had planned, they had to go! Way to much wheel sticking out past the bed sides.
I ended up selling those wheels and ordering a full set of the JEGS SSR racing wheels. 15x8 in the rear with 5.5" of backspacing. Fronts are 15x4's. I also ordered some Nitto Drag Radials and front runners.
Even with the increased backspacing of the new wheels, I was not happy with the amount of tire that stuck out past the bedside. I remembered seeing some pictures of 1st gens with the factory flares and remembered that they add about an inch of coverage over the rear tires. A trip to the local junk yard yielded a pair of rear flares. I snagged some front fender moldings as well and painted them all with some high quality black trim paint after a good scrub and scuff.
post #14 of 102 Old 01-15-2017, 10:02 PM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
I was going to ask about leaving the patina too. Do you have the rubber snubbers for those slapper bars?
Pull those bedsides. lol
TelAmeriCorp
post #15 of 102 Old 01-15-2017, 10:04 PM Thread Starter
gas4blood's Avatar
Got the brake system flushed out and replaced all of the soft lines plus the rear hard brake lines on the axle. Had my wife come out to the garage to help me get the brakes flushed and bled.
Nice and tidy!
post #16 of 102 Old 01-15-2017, 10:11 PM Thread Starter
gas4blood's Avatar
Swapped the old mirrors for some off of a Blazer
And then the moment came that I had been waiting for for 2 months. Took it off the jack stands and wheeled it outside for some fresh air!
post #17 of 102 Old 01-15-2017, 10:15 PM Thread Starter
gas4blood's Avatar
A few shots of the squeaky clean undercarriage.
post #18 of 102 Old 01-15-2017, 10:21 PM Thread Starter
gas4blood's Avatar
A little comparison shot of the before and current
post #19 of 102 Old 01-15-2017, 10:28 PM Thread Starter
gas4blood's Avatar
Thank you sir!
The paint and body are going to be left alone for now.
Yes I do have the snubbers. That's what I was referring to when I said that I would finish up the install once the motor and trans are installed and the suspension squats. The flares actually do a great job of making up the extra width of the axle..
post #20 of 102 Old 01-15-2017, 10:53 PM
Say what?
bawb_ferabbles's Avatar
User is: bawb_ferabbles is offline
Good find! I like what you done so far.
'92 S10 Ext 350 TBI 5 spd 3/4 drop
post #21 of 102 Old 01-16-2017, 08:08 AM Thread Starter
gas4blood's Avatar
Thanks! I appreciate it.
post #22 of 102 Old 01-16-2017, 08:22 AM Thread Starter
gas4blood's Avatar
Santa brought me some parts for the project truck on Christmas day. My wife knows me well!!
Also found a trucks only junk yard about 5 minutes from our new house. The very first section that you come to after walking out the back door is the S10 section! It was meant to be.
post #23 of 102 Old 01-16-2017, 08:49 AM Thread Starter
gas4blood's Avatar
After a few months of searching for the right motor for this project, I finally tracked down a guy in Southern Maryland that runs a business buying and parting out Government surplus vehicles. He had a few 96-98 Suburbans in his inventory. After a few emails and texts, I was able to make a deal with him on a low mileage 5.7 Vortec long block. It will get refreshed and maybe some head/cam work pending the budgeted funds allowing for that.
Horrible picture but I will get more once its on the stand.....
Ordered up a new intake from JEGS. I am starting to accumulate enough JEGS stickers that I could probably wallpaper my garage with them.
My daughter gets just as excited to see a box from JEGS as I do!
post #24 of 102 Old 01-16-2017, 11:37 AM
nfamus10's Avatar
User is: nfamus10 is offline
Gonna watch this one. Awesome find on the mint truck. Good fix with the flares and new rims. Looks sharp.
$$$$$$$$$$$Project El Cheapo$$$$$$$$$$$$$$$
http://www.s10forum.com/forum/f30/ch...6-dime-500352/
It will get done when it gets done...
---body drop thread---
http://www.s10forum.com/forum/f143/black-dime-b-d-finally-245523/
Project LOST CAUSE. BD on 22s, 350/700R4.
http://www.s10forum.com/forum/f143/p...-cause-587265/
nfamus10 is offline
post #25 of 102 Old 01-16-2017, 12:06 PM
jplinville's Avatar
User is: jplinville is offline
I'm digging this build, and can't wait to see how it turns out.
1992 S-10 4.3L V6 Regular Cab 80,000 miles
1989 F250 4X4 5.0 Regular Cab 80,000 miles
1987 560SL Arctic White over Navy Blue 82,000 miles
2016 Jeep Compass True Blue Pearlcoat 4500 miles
post #26 of 102 Old 01-16-2017, 03:43 PM Thread Starter
gas4blood's Avatar
Hey thanks brotha! Much appreciated.
That makes two of us! haha. Thank you.
post #27 of 102 Old 01-16-2017, 04:57 PM
In charge of the big door
tajohns34's Avatar
User is: tajohns34 is online now
This is a cool old truck. Very clean underneath, you can tell a lot of work was done under there. The floor pans are very impressive.
Q: How many people can you fit in one Honda?
A: Well, the Bible said that all 12 disciples were in one Accord.
>-----<My Build thread>-----<
post #28 of 102 Old 01-16-2017, 05:03 PM Thread Starter
gas4blood's Avatar
Thank you sir. I try to keep things looking clean.
post #29 of 102 Old 01-16-2017, 07:25 PM
User is: Blue Thunder is offline
Now that you are in Virginia you just keep off the NC Craigslist. I don't need competition!
Clean looking truck. I will be watching this as well!
bowtieguy96 likes this.
post #30 of 102 Old 01-16-2017, 08:31 PM
User is: rexmburns is online now
Is this the guy that always has motors on Craigslist? If so I have talked to him a few times in the past and he has some low mileage motors for good prices for sure.
post #31 of 102 Old 01-16-2017, 09:19 PM Thread Starter
gas4blood's Avatar
So I decided to get real ambitious last weekend.
There are a handful of things that I want to accomplish before I begin the motor install. They are:
-Perform an absolute and complete A/C delete to include both inner and outer heater boxes, wiring, and switch panel from a heat only truck.
-Remove all unnecessary wiring from under the dash and in the engine compartment
-Swap the steering column for one out of a 5 speed truck
The best way to get all of these things done at once was to just tear the dash apart. I was super paranoid about damaging my mint condish dash pad but made it through the tear down unscathed.
post #32 of 102 Old 01-16-2017, 09:24 PM Thread Starter
gas4blood's Avatar
No promises! haha. Thanks man.
That's the guy! He is always posting in the Mechanicsville craigslist. This motor supposedly only has 55,000 miles on it. I figured that I couldn't go wrong for the price I paid. He said that his contract with the auction dealer he uses is that he wont buy anything with more than 90,000 miles on it. I will tear in to the motor soon to see what I am dealing with.
post #33 of 102 Old 01-16-2017, 09:45 PM
Connor94's Avatar
User is: Connor94 is offline
Wow, those floors are immaculate. I doubt ill ever find a truck that clean up here in Canada.
Connor94 is offline
post #34 of 102 Old 01-16-2017, 10:42 PM
Returning Member
ncarlin260's Avatar
User is: ncarlin260 is offline
Truck looks good....you gonna keep that bench seat? Im looking for one in good condition
post #35 of 102 Old 01-17-2017, 07:52 AM Thread Starter
gas4blood's Avatar
I was seriously shocked to find one this clean in Virginia. Things are typically pretty rusty out here.
Thank you sir! Sorry, but the bench seat is going to stay for the time being.
I had another really clean one from my last S10 but just sold it about a month ago!
post #36 of 102 Old 01-17-2017, 09:56 AM
Terribletrux's Avatar
User is: Terribletrux is offline
Following! This build is going to be EPIC!
Subscribed.
•Phil•
83' S-10 Durango, 2.8 - Iron duke conversion, T5, Rotting away.
85' S-10 Hot Rod Project, 355, T56, TPI or HSR comming soon. Thred
99' S-10 Summer driver, 4.3, Auto, Xtreme rims. Thred
post #37 of 102 Old 01-17-2017, 10:46 AM
Twisted Toys Customs Club
Crabby's Avatar
User is: Crabby is offline
The project looks good man! Definitely will enjoy this one
95 s10 ex cab- 4.3- lowered 5" with belltech spindles, springs, leafs & blocks. Complete body shave minus door handles
89 K1500 reg. cab 4x4- 285/75-R16, Duratracs, Flowmaster Exhaust
Crabby is offline
post #38 of 102 Old 01-17-2017, 01:33 PM Thread Starter
gas4blood's Avatar
Subscribed.
I hope so man! Ill try to not disappoint.
Thanks man! Glad that I'm not the only one that likes it so far.
post #39 of 102 Old 01-20-2017, 08:11 AM Thread Starter
gas4blood's Avatar
Anyone need a mint condish AM/FM stereo?
post #40 of 102 Old 01-20-2017, 10:28 AM
keystone's Avatar
User is: keystone is offline
Shes looking great man. Cant wait to see the motor in.
Project purple nurple- 1999 sonoma zq8, 2.2 5 spd. Summer daily 2" blocks Cai billet grille roll pan. Plans 5.3 with texas speed cam, prc heads, ls6 intake and t56
Project Tetanus- 1996 s10 zr2 waiting for trans and d30
1998 blazer sold
keystone is offline
post #41 of 102 Old 01-20-2017, 11:51 AM
User is: Dime94 is offline
Finally somebody else from VA. And you aren't that far from me. Truck is looking good man. Is that Woodfin Auto?
Dime94 is offline
post #42 of 102 Old 01-20-2017, 05:54 PM
81G_81RD's Avatar
User is: 81G_81RD is offline
Awesome & inspiring work done here
81G_81RD is offline
post #43 of 102 Old 01-23-2017, 12:14 PM Thread Starter
gas4blood's Avatar
Hey thanks man! I am hoping to start work on the motor here shortly.
We need to have a Va S10 get together. I know there are more of us out here. Not sure what Woodfin Auto is so I guess that's a no. Is that a local shop?
Much appreciated sir!
post #44 of 102 Old 01-23-2017, 12:24 PM
Slownoma92's Avatar
User is: Slownoma92 is offline
Nice work. Can't wait to see it when it's done. I live in Hampton, Va.
Sent from my VS985 4G using Tapatalk
post #45 of 102 Old 01-23-2017, 12:26 PM Thread Starter
gas4blood's Avatar
Got some more work done over the weekend. It was one of those days where you finish up what you had in front of you and it still looks like you didn't do anything. haha.
Got all of the ducting and inner box from the A/C setup torn out. Cleaned up some stuff under the dash and then installed all of my parts from a "heat only" truck along with a brand new heater core.
Also got the outer heater box installed on the firewall after I got some things cleaned up. This will get painted along with the rest of the engine compartment.
post #46 of 102 Old 01-23-2017, 12:30 PM Thread Starter
gas4blood's Avatar
I had purchased the switch panel from a heat only truck a few months back. It was pretty nasty and faded so I took it all apart, pulled out what I needed, then swapped all of those parts over to the nice switch panel that I had from my truck that came with A/C.
Before:
After:
post #47 of 102 Old 01-23-2017, 12:32 PM Thread Starter
gas4blood's Avatar
Finally, and most important, I cleared off some space on my bench in preparation for the steering column tear down.
post #48 of 102 Old 01-23-2017, 12:36 PM Thread Starter
gas4blood's Avatar
Really? I wonder if we ever crossed paths? We lived in Hampton for a couple of years. We left there in 2014. Lived right off of East Mercury. I had my static dropped blue '91 back then.
post #49 of 102 Old 01-23-2017, 01:52 PM
Gaaoooooo
MINTSICK's Avatar
User is: MINTSICK is offline
Clean looking truck! Why the A/C delete and skinnies up front, dedicated race truck?
2004 Silverado Z71 ECSB - |Silver Birch Metallic|5.3|Custom Single Exhaust|Method Standards
1993 Mustang LX Hatchback - |Reef Blue|5.0 H.O.|5 Speed|MGW Short Shifter|70MM MAF|MAC Shorty Headers|Pypes O/R X|Spintech Pro Streets|3.55's|
1984 El Camino Conquista - |Black|5.0L|Comp XE262H|Holley 570|700r4 swap|2.41 open rear|
MINTSICK is offline
post #50 of 102 Old 01-23-2017, 01:54 PM
Woodfin is a junkyard on Genito rd. Looking at your pics and seeing that you were in the Midlothian area, it looked like thats what yard you were at. They are full of S series trucks and blazers.
Dime94 is offline
