Time to jump back in to the forum! Some of you on here may remember me from a few years ago when I had my '91 S10 daily driver. Pic attached for memory's sake:
That truck was a 2.5/5 speed with A/C and around 58,000 original miles. I was really wanting to build a V8 S series but could not pull myself to take my '91 apart for the swap. I ended up selling that truck to a guy in Texas and then drifted away from the S10 scene for a couple of years. Fast forward to about 6 months ago. We are now living in Virginia and as most of us do, I was browsing craigslist looking for nothing in particular. A search of "S10|Sonoma" pulled up this 1987 S15 being sold about an hour from our house.
It looked clean and the price was right so I loaded the family in the Tahoe and made the drive to go check it out.
The truck ended up being an abandoned project of the seller's teenage son. They had purchased the truck in stock form from their neighbor who also happened to be the original owner. Shortly after getting the truck, the 2.8 blew its guts and they began pulling things apart to prepare for a small block install.That's where things got put on the back burner and the truck ended up sitting for quite some time. In comes me! :grin:
We agreed on a price and 7 days later I was back with a trailer to take it off their hands.
Due to the fact that this truck was owned for most of its life by an elderly gentlemen, it was in phenomenal shape. The interior was one of the nicest that I have ever found. The dash alone was worth the asking price!
Stopped on the way home to blast off the years of mildew and moss that had accumulated onthe truck. I think by now you can tell where I came up with the "grandpa"part of my project name.
Once I got the truck home, I decided to try out an old hot rodders trick to see if I could get rid of the rest of the nastiness that had built up on the truck. Comet to the rescue!
Now that it was looking fresh and clean, I started to tear in to the interior to see what I was dealing with.
Floors look pretty dang good! A little surface rust on the passenger floor but nothing that cant be easily taken care of.
While I was waiting for our move to the new house, I started my search for some new parts that would be needed for this project. A call to a member of the facebook V8 S10 owners page that runs his own performance shop got me set up with my suspension. I am trying to build this truck on a budget so he hooked me up with what he thought would be my best combo. The rear setup is Western Chassis Supply 4" drop leafs with Lakewood traction bars. The front has 2" DJM drop spindles and 1"springs. I also picked up a new rear axle which I will explain shortly.
Right around this time, I happened to be talking with my neighbor about my new project and mentioned to him that I was in the market for a new rear axle for the V8 conversion. He said that he had some cousins that worked for the local Pick-a-Part and could get me hooked up with whatever I needed. The following Saturday, we went to the yard on the hunt for a 2wd 5 speed blazer with a 8.5" 10 bolt. After a morning of scouring the yard, we found this little Jimmy tucked back in the corner. I jumped under to confirm that it had what I needed and he had his cousin drag it out of the mud so that we could pull the axle. It was at this time that I should have paid closer attention to the wheels. They would have been a dead giveaway that this was going to be a bi twider than I thought. :surprise:
Yes I do have the snubbers. That's what I was referring to when I said that I would finish up the install once the motor and trans are installed and the suspension squats. The flares actually do a great job of making up the extra width of the axle..:clap:
Then I moved on to the front. Stripped the suspension out, painted the frame and undercoated the wheel wells and bottom of the bed. All new parts up front to include rotors/pads. wheel bearings and seals, spindles, springs, control arms and bushings. I also took the time to swap the power steering box for a manual unit.
Around this time, I was trying to order replacement axle shafts for my new housing.The shafts were measuring at 29" which was 4wd length. After some research I determined that I had a non-ZR2 4wd 8.5" 10 bolt. NOBODY carries off the shelf replacement shafts for this axle so a call to Dutchman Motorsports got me a pair of 30 spline replacements.
Got my best little buddy out into the garage with me to help rebuild the rear brakes.
I had previously picked up a set of Weld Prostars on craigslist. I had recoated them in semi gloss black and was super pumped to run them. Once I determined that my axle was about 4" wider than I had planned, they had to go! Way to much wheel sticking out past the bed sides.
I ended up selling those wheels and ordering a full set of the JEGS SSR racing wheels. 15x8 in the rear with 5.5" of backspacing. Fronts are 15x4's. I also ordered some Nitto Drag Radials and front runners.
Even with the increased backspacing of the new wheels, I was not happy with the amount of tire that stuck out past the bedside. I remembered seeing some pictures of 1st gens with the factory flares and remembered that they add about an inch of coverage over the rear tires. A trip to the local junk yard yielded a pair of rear flares. I snagged some front fender moldings as well and painted them all with some high quality black trim paint after a good scrub and scuff.
Got the brake system flushed out and replaced all of the soft lines plus the rear hard brake lines on the axle. Had my wife come out to the garage to help me get the brakes flushed and bled.
Santa brought me some parts for the project truck on Christmas day. My wife knows me well!!
Also found a trucks only junk yard about 5 minutes from our new house. The very first section that you come to after walking out the back door is the S10 section! It was meant to be.
After a few months of searching for the right motor for this project, I finally tracked down a guy in Southern Maryland that runs a business buying and parting out Government surplus vehicles. He had a few 96-98 Suburbans in his inventory. After a few emails and texts, I was able to make a deal with him on a low mileage 5.7 Vortec long block. It will get refreshed and maybe some head/cam work pending the budgeted funds allowing for that.
Horrible picture but I will get more once its on the stand.....
Ordered up a new intake from JEGS. I am starting to accumulate enough JEGS stickers that I could probably wallpaper my garage with them.
My daughter gets just as excited to see a box from JEGS as I do! :grin:
Is this the guy that always has motors on Craigslist? If so I have talked to him a few times in the past and he has some low mileage motors for good prices for sure.
That's the guy! He is always posting in the Mechanicsville craigslist. This motor supposedly only has 55,000 miles on it. I figured that I couldn't go wrong for the price I paid. He said that his contract with the auction dealer he uses is that he wont buy anything with more than 90,000 miles on it. I will tear in to the motor soon to see what I am dealing with. :grin:
There are a handful of things that I want to accomplish before I begin the motor install. They are:
-Perform an absolute and complete A/C delete to include both inner and outer heater boxes, wiring, and switch panel from a heat only truck.
-Remove all unnecessary wiring from under the dash and in the engine compartment
-Swap the steering column for one out of a 5 speed truck
The best way to get all of these things done at once was to just tear the dash apart. I was super paranoid about damaging my mint condish dash pad but made it through the tear down unscathed.
Related Threads
S-10 Forum
8.8M posts
182.7K members
Since 2001
