86' s15 ext cab v8 corner carver, 56k beware - Page 10 - S-10 Forum
Old 04-16-2014, 10:33 PM   #451
9" strait pipes...
hi_im_sean's Avatar
Re: 86' s15 ext cab v8 corner carver, 56k beware
just a small update/heads up. i spoke to soon about the tie rods. i thought i had the pass wheel locked in place when i was reassembling it, but it moved (toed out) while i was putting the drivers side back together. to get to the point, they still toe out just a tad, so a little more needs to come off one of the tie rods. with the steering wheel centered one wheel toes in and one out, so one tie rod will end up being a little shorter than the other, which is how mosy s10s end up after and alignment anyway.
Old 04-17-2014, 11:48 AM   #452
Longbeds FTMFW
gunther19820's Avatar
Looks great Sean. I like that you are still doing work on this!
Old 04-17-2014, 12:02 PM   #453
9" strait pipes...
hi_im_sean's Avatar
slowly but surely. ill never stop, its just hard to find the time and money lately. kidz...
If you do not want to register, fill this field only and the name will be used as user name for your post.
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
