#401 |
Hood Ride
Re: Upgrade
![]() boxing in the frame from gas tank to spare tire x member.. maybe this weekend if my back starts feeling better! |
#402 |
Get some
Re: Upgrade
I'm lost....NNBS IIRC...Explain pls.
#403 |
Calico 1st Gen
Re: Upgrade
NNBS = New new body style (08+) IIRC = If i recall correctly |
#404 |
Knows a lil' about a lil'
Re: Upgrade
#405 |
BUT I WONT PUT IT HERE
Re: Upgrade
why isn't NBS always the newest body style... thats kind of retarded if you ask me...
#406 |
Re: Upgrade
How thick of steel are you using, and what grade?
The proper way to name them is actually: 99-06: GMT-800 07 newer: GMT-900 |
#407 |
Hood Ride
Re: Upgrade
its 1/8" hot rolled carbon steel.
#408 |
Most Hated.
Re: Upgrade
have you seen that truck in league city running around it's the same body style as yours, crew cab but it's black, it's dropped low as hell on stockers with like 5% all the way around. there's a sticker on the back window that i think says "game over customs"
#409 |
Hood Ride
Re: Upgrade
sure its a crew cab? ive seen a black ext. cab.. have not seen it in a while.. last i saw IIRC he was pulled over in friendswood getting searched hardcore. gave him a dui test or whatever.. had to walk a line. lmao.
#410 |
Most Hated.
Re: Upgrade
yeah i'm postive it's a crew cab i tried to take a picture with my phone to post on here when i passed it but it was too blury
#411 |
GOT A NEW S10 WOO
Re: Upgrade
wow you would re blazer this thing
the lift then the drop and tint and horns and documenting everything lol |
#412 |
Hood Ride
Re: Upgrade
guess ill put my helper bag install in here too..
doing it different from how i see most the helper bag kits... i don't necessarily see this as being any better as both ways accomplish the same thing, this is just my way of wanting to do it. upper bracket/f9000 ![]() upperbracket/f9000 held up to frame ![]() lower bracket sitting on factory spring perch.. i will have two 3/8 bolts going through the bracket/spring perch to hold it in place ![]() with bag.. ![]() mocked up off truck ![]() lower bracket showing my how im doing it.. the two 3/8" bolt holes to hold it in place(bolts will be welded in place as i wont be able to reach them when lower bracket all welded up, and an oversized hole that i can fit a 9/16 socket on to access lower bolt. ![]() upper and lower bracket mocked up on truck. semi close to tire, but i dont see it being a problem. ![]() \and as long as my measurements are right, i will have 1/2" travel left in bag when truck is sitting on bump stops.. which i have never hit a bump hard enough that will make the truck bottom out. |
#413 |
V8 with bags
Re: Upgrade
looks good, you should send me those bags though lol
#414 |
Calico 1st Gen
Re: Upgrade
clean install
#415 |
Hood Ride
Re: Upgrade
crappy welds.. old welder started ****ing up..
![]() had to buy a new welder also.. ![]() Last edited by Wicked Mayhem : 07-27-2009 at 07:36 AM. |
#416 |
Calico 1st Gen
Re: Upgrade
Question for you,
Why the square tubing under the notch? |
#417 |
Hood Ride
Re: Upgrade
thats how the kit comes.. without it, my frame would only be like 1" tall right there.
#418 |
Calico 1st Gen
Re: Upgrade
Oh okay, thanks.
Bag install looks good. When do you get to test it out? |
#419 |
Hood Ride
Re: Upgrade
depending on how my back feels after work, im gonna try and run the wiring and 1/8" gauge line inside the truck, and my dads gonna help me bend the hard line up for it.. hard line owns me lmao.
#420 |
Calico 1st Gen
Re: Upgrade
what kinda line are you using? ive seen copper a few times before on here.
#421 |
Hood Ride
Re: Upgrade
Stainless hardline and swagelok fittings
#422 |
V8 with bags
Re: Upgrade
looks great. those new lincolns looks fancy. I sure do wish mine was a 220
#423 |
Hood Ride
Re: Upgrade
Yeah I love it so far. I wanna do more welding now lmao.
#424 |
Hood Ride
Re: Upgrade
#425 |
Most Hated.
Re: Upgrade
i have plenty for you to do (: |
#426 |
Hood Ride
Re: Upgrade
get me my blazer back for free and ill do all the work you need
#427 |
Most Hated.
Re: Upgrade
dude i saw austin driving it down 646 the other day.
it was my first time to see it in person it the daylight, that thing is clean! |
#428 |
Hood Ride
Re: Upgrade
dont remind me
#429 |
so fresh n so clean
Re: Upgrade
dont worry man this will be better
#430 |
Most Hated.
Re: Upgrade
don't get me wrong.
i'm really liking this fullsize. but the blazer, man. the color the wheels and the stance.... |
#431 |
Re: Upgrade
You running drop shocks? If not, pm me.
#432 |
Hood Ride
Re: Upgrade
i bought Gabriel heavy duty shocks.. not for silverados.. dunno what they are for. i searched part numbers for the length i wanted
dinner break.. old setup.. got all excited came home on lunch to put bed on so i dont look gay riding around.. ![]() ![]() ![]() then bam.. epic fail.. round 2! ![]() ![]() i dont see why this wont work??? |
#433 |
Senor motherfvckin Donut
Re: Upgrade
What happened?
#434 |
Re: Upgrade
I see you had to relocate the mounts, but where did the system fail?
#435 |
forum idiot
Re: Upgrade
what is that large copper fitting thing you have inline with the valves??
i like the hard line |
#436 |
Hood Ride
Re: Upgrade
where the mounts were, it was fine with no bed.. but with bed on fittings/line hit floor and i wasnt gona cut holes in floor for them..
brian.. its a check valve.. a big ugly check valve from a hardware store. i aired the back up, measured it, drained the tank, came out next morning and it didnt budge one bit.. done.. again.. hoping to have bed back on tomorrow. i hate no bed. looks so ****ing gay. ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#437 |
Re: Upgrade
No beds are awesome, all the cool kids are doing it. Sucks about having to re-locate the mounts, but should be well worth it in the end. Why no muffler?
#438 |
Hood Ride
Re: Upgrade
i have a muffler.. its a flowsound.. knock off flowmaster.. its even kinda welded on crooked
#439 |
Get some
Re: Upgrade
looking better.
#440 |
Hood Ride
Re: Upgrade
Thanks. Bed goes on in about an hour!! Wooo
#441 |
Hood Ride
Re: Upgrade
Yessss. Bed is on
#442 |
manual>automatic
Re: Upgrade
pics?
#443 |
Giggity Giggity
Re: Upgrade
i cant wait to see the pics.
#444 |
Hood Ride
Re: Upgrade
LookS the same lol...
#445 |
WILL WORK FOR PARTS
Re: Upgrade
your truck is GAY
#446 |
De-Xtremed
Re: Upgrade
#447 |
Hood Ride
Re: Upgrade
lift pics.. shocks max out or itd get a little more..
![]() ![]() and my dent fixer.. ![]() |
#448 |
V8 with bags
Re: Upgrade
woo, looks good, should make hauling crap or people a little nicer. And ive got those magnets on my fridge
#449 |
Get some
Re: Upgrade
Bet those bags help alot.
#450 |
so fresh n so clean
Re: Upgrade
howd you manage a dent ?>
