Here I go again
Go Back   S-10 Forum > Member Forums > Member Rides
Old 03-24-2008, 07:45 PM   #101
wish I had a job
Zblue8's Avatar
Zblue8 is on a distinguished road
Re: Here I go again
did you have any rubbing problems with that drop and the stock wheels/tires?
i am probably doing a 2/3 on my zq8 with the stock wheels until i can afford 18's
Old 03-24-2008, 07:59 PM   #102
AKA DavidAndSomeNumbers
David12460's Avatar
David12460 is on a distinguished road
Re: Here I go again
They rubbed a little at almost full lock. Not bad...
Old 03-24-2008, 09:09 PM   #103
wish I had a job
Zblue8's Avatar
Re: Here I go again
is it any different with the new wheels/tires?
Old 03-24-2008, 09:21 PM   #104
David12460's Avatar
Re: Here I go again
Its about the same.
Old 03-24-2008, 09:22 PM   #105
wish I had a job
Zblue8's Avatar
Re: Here I go again
thanks
Old 03-24-2008, 09:33 PM   #106
David12460's Avatar
Re: Here I go again
No problem
Old 03-26-2008, 06:58 PM   #107
chrome bumpers suck!!
mels98s10's Avatar
mels98s10 is on a distinguished road
Re: Here I go again
damn your truck looks very nice, its coming along nicely and quickly too!
Old 03-26-2008, 07:46 PM   #108
David12460's Avatar
Re: Here I go again
thanks a lot man. I had a few bucks saved up for projects once I got a different truck. I have a little left and which will most likely going towards the bass portion of my car audio build. Ill do my components and amp a little later this spring.
I have a soft flush mount cover on order too right now. I hope to get it next week.
Im also going to go talk to a bodyshop near me to see what they would charge me to have my gate shaved, ss mirrors painted and portions of my grille painted also.
That will probably be completed early to mid summer.
Old 03-28-2008, 10:25 PM   #109
KYLE CRAIG's Avatar
KYLE CRAIG is on a distinguished road
Re: Here I go again
Im pretty sure i saw this truck at triangle park today. I must say it looks way lower in person and the irocs look damn good!
Old 03-29-2008, 01:22 AM   #110
David12460's Avatar
Re: Here I go again
Yeah I had it parked up there for most of the night. I actually think I saw you too at the stillwater RD and manning stop light at ABOUT 6:30? I was on my to WI in my buddies truck.
Thanks a lot.
Old 04-05-2008, 12:44 AM   #111
David12460's Avatar
Re: Here I go again
I got a new low profile soft bed cover. Ill get better pics up soon.
and yes I know I still need to debadge to gate. Im kinda procrastinating
Old 04-05-2008, 12:55 AM   #112
coffs03s10 is on a distinguished road
Re: Here I go again
nice, im gonna look into buyin one.
Old 04-05-2008, 01:01 AM   #113
David12460's Avatar
Re: Here I go again
yeah its not bad. If I did it again id consider going with a black one simply because I didn't think about this blue fading overtime. It may or may not be that bad, but we will see.
Old 04-05-2008, 02:21 AM   #114
I wonder how it tastes?
cpolaris502's Avatar
cpolaris502 is just really nicecpolaris502 is just really nicecpolaris502 is just really nicecpolaris502 is just really nice
Re: Here I go again
the bed cover is blue?
Old 04-05-2008, 10:54 AM   #115
csmizzlesxblizzle's Avatar
csmizzlesxblizzle is on a distinguished road
Re: Here I go again
looks great man
Old 04-06-2008, 03:17 PM   #116
David12460's Avatar
Re: Here I go again
Yeah its blue.
Old 04-07-2008, 11:05 PM   #117
David12460's Avatar
Re: Here I go again
What is that guy up to?
And the bowtie is not all the way in. Its hanging 3/4'' out so I can get good coverage.
And some better pics of the bed cover
Old 04-14-2008, 08:25 PM   #118
David12460's Avatar
Re: Here I go again
Got the grill shell all painted up. I scratched it pretty good on the bottom putting one of the turn signal lenses in. I might sand that back down and re- spray it. Overall I think It looks good.
Old 04-14-2008, 08:33 PM   #119
papa smurf
sexchangedisuzu's Avatar
sexchangedisuzu is on a distinguished road
Re: Here I go again
i have one of those covers on my truck and eh....im not a fan of it, i think i threw it away actually, but yours looks really nice, mine was kinda a piece cause i bought it used. only problem i had was with my shaved gate i had to leave the straps a little loose and when there would be a severe storm or real strong winds it would loosen up the straps from the puling and a couple times the cover flew off the truck lol. but yours definitely looks a lot more trustworthy than mine is haha
Old 04-14-2008, 08:39 PM   #120
David12460's Avatar
Re: Here I go again
Straps? Mine does not have any straps. It has two struts and to "lock" it down there are two little handle like things that turn under the bed rails. It wont go anywhere.
I do plan on shaving the gate (hopefully soon) and I will leave those handles unlocked and use tension from bunjee coards to hold the cover down secure. The struts do a good job keeping it down but the bunjee coards will be more for backup. This way I can lift it still and get to the handle, then disconnect the bunjee coards.
Old 04-14-2008, 11:44 PM   #121
papa smurf
Re: Here I go again
ahh mine might be a different model, sorry my bad
Old 04-14-2008, 11:45 PM   #122
David12460's Avatar
Re: Here I go again
na thats cool
Old 04-15-2008, 01:14 AM   #123
'Bout to be BAGGED!
leroyme's Avatar
leroyme is on a distinguished road
Re: Here I go again
Truck looks good! I wish I had either set of wheels! I just got done with the carrier bearing cross member from SD last weekend, actually! My arms are sore as HELL! I need to start working out! lol It took me quite a while, as I hadn't done it before, but after I got rolling on it, it went very quickly! I got the raw version and painted it flat black. The hardest part BY FAR was removing the rivots from your old cross member. WOW! What a pain! I found that if you cut the old cross member off AS CLOSE AS POSSIBLE to the frame, then cut the hump itself off from under your frame, you can actually get a grinder (grinding wheel, or cutting wheel. I used the cutting wheel and cut lines all the way through the heads of the rivots maybe 5 or 6 times. That seemed to be the fastest and easiest for me) to all of the rivots except one tricky top one by the exhaust on the passenger side. Yours is probably different, as you have the 4.3. After cutting all of the rivots, I used an air chizzle to pry the mounting plate off the frame. From there, it's all gravy! Just make sure you support your drive shaft when you remove the old cross member. I supported mine with the jack, then had to raise the truck a little more, so I tried to support it with a box, but it wasn't tall enough. It dropped quite a bit. Not too bad to put back into place, but I wouldn't chance it. I don't have any pics of the finished product yet, but here's my before pic:
This weekend I'll snap some finished pics. Good luck with yours!
Old 04-15-2008, 03:55 AM   #124
Have a nice day!
ProTouring2.2's Avatar
ProTouring2.2 has a spectacular aura aboutProTouring2.2 has a spectacular aura aboutProTouring2.2 has a spectacular aura about
Re: Here I go again
Sing it with me!
Heeeere I goo agaaaain on my ooooooown!!!!!!
Goin' doown the only rooooad I've ever knooooown!!
Old 04-15-2008, 10:26 AM   #125
super high me
baggedsonoma22's Avatar
baggedsonoma22 is on a distinguished road
Re: Here I go again
That Looks Like Led Zeppelin To Me ^^^^^
Old 04-15-2008, 10:29 AM   #126
All up in your shit
jakethegriff's Avatar
jakethegriff has a brilliant futurejakethegriff has a brilliant futurejakethegriff has a brilliant futurejakethegriff has a brilliant futurejakethegriff has a brilliant futurejakethegriff has a brilliant futurejakethegriff has a brilliant futurejakethegriff has a brilliant futurejakethegriff has a brilliant futurejakethegriff has a brilliant futurejakethegriff has a brilliant future
Re: Here I go again
yeah that's robert plant not david coverdale.
nice try though.
trucks looking great man, The grill looks sweet!
Old 04-15-2008, 11:40 AM   #127
02_blue_dime's Avatar
02_blue_dime is on a distinguished road
Re: Here I go again
wow leroyme u must've taken the hardest approch EVER!!!! i just torched the old rivits so they were all mushy, usted a pick and just hammered out the old rivits, pry bared the old one out, then bolted the new one up....easy as pie if you ask me!
Old 04-15-2008, 12:18 PM   #128
It really does...
TubbD's Avatar
TubbD is a name known to allTubbD is a name known to allTubbD is a name known to allTubbD is a name known to allTubbD is a name known to allTubbD is a name known to all
Re: Here I go again
Quote: Originally Posted by greenflameS10
Sing it with me!
Like a drifter I was born to walk alone!
But I made up my mind!. I ain't wasting no more time. Here I go again!
Truck looks good Dave! Nice sticker
Old 04-15-2008, 12:39 PM   #129
i need parts!
redsdime's Avatar
redsdime is on a distinguished road
Re: Here I go again
looking good
Old 04-15-2008, 01:27 PM   #130
'Bout to be BAGGED!
leroyme's Avatar
Re: Here I go again
Wow. Didn't know the rivots would get mushy if heated... There are wires just above the driver's side ones and fuel lines as well! WTF? How'd you work around that? Cutting off the cross member was super easy with my new sawzall. It took maybe 30 seconds each side. Trying to grind or drill those damn thing was the only difficult part. I'll try the torch next time
Old 04-15-2008, 03:45 PM   #131
Re: Here I go again
lol anything get's mushy when heated, didn't u learn that in science class?? if u would've searched on this forum you would've found out to use a torch it's a hell of a lot quicker and easier
but anways i'll let the OP enjoy his thread and i'll stop whoring it up
Old 04-15-2008, 06:36 PM   #132
David12460's Avatar
Re: Here I go again
HAHA no problem with the whoring, I don't care.
Anyways thanks for the nice words.
Old 04-15-2008, 09:12 PM   #133
i need parts!
