Bodydropped 99 s-10/hombre
Go Back   S-10 Forum > Member Forums > Member Rides
Old 01-01-2009, 07:12 PM   #301
WERD
GET_LOW's Avatar
Re: Bodydropped 99 s-10/hombre
Man those firewall fillers look like ass. You knwo you coudl just cut them out ar redo them nice. Its liek the perfect time to sice you already got the carpet out and everything.
I love your truck
Old 01-02-2009, 11:40 PM   #302
Mustangs lowered at least
slonlow2000's Avatar
Yeah their not the prettiest, but I doubt I do that. Just tryin to clean up some wiring. Some point in time, i'll prolly re-tub the front for 20s so i'll clean it up then.
Old 01-10-2009, 02:01 PM   #303
That thing's cleaner than a gallon of Bleach! The front end shot's almost has a......(e.t.)Extra Terrestrial look sic man!!!
Old 01-14-2009, 11:11 PM   #304
Goin' Nowhere Fast
2.5FearFactory's Avatar
nice truck...very clean...me likey
Old 01-15-2009, 04:54 PM   #305
Thanks, not to many updates casue i'm still tryin to track down a 5 speed tilt column. I pulled out the old one, and the truck came with a tilt out of an auto extra. It had a blown bag, and a broken end shaft, then to find out it was collapsed or something, and pretty much ruined. I'll have some pics up in a little while.
Old 01-16-2009, 01:40 AM   #306
Column that came with the truck seperate, was from an auto that had been wrecked.
Heres the rod that had snapped
I know this part is removable, but the bolt had been push back to, when the column colapsed, which you can see in this pic.
Then the studs to mount it under the dash had been lost I guess and bolts were tacked onto the column. Which would lower it even more, kinda defeating the purpose.
And the wire has been all spliced up for something, guess its been swapped before.
Now here the non tilt column out of the truck.
The bolt that was pushed back in the column that was given to me, this is what it was supposed to look like.
My corner of the garage is growning
Old 01-18-2009, 01:10 AM   #307
"BUILT-NOT-BOUGHT"
mayhem247's Avatar
what size tires do you have on those stock 14" wheels?
Old 01-18-2009, 12:35 PM   #308
I'm not 100% sure, their just what came on the truck, i'll look and let ya know later this evening.
Old 01-19-2009, 09:40 AM   #309
WERD
GET_LOW's Avatar
Those going on the Hombre???
Old 01-19-2009, 12:46 PM   #310
Tuckin15's's Avatar
love this truck. i really like the color.
Old 01-20-2009, 12:28 AM   #311
I bolted them up on both the blazer and hombre, but on the hombre they rub on the tie rod end, so i'm guessing the drop spindles are causing that. So I guess they wont work on the hombre without spacers, which i'm not really interested in running on this. The 18's look retarded on the blazer at factory height so they prolly wont go on it either.
(No weight is on that jack)
Old 01-20-2009, 12:54 AM   #312
Registered Boozer
coloRADo_S10's Avatar
def doesn't look good on the blaze. But then im biased not a fan of the big flashy wheels. The look the hombre has already is bad ass. Keep it that way. just my $.02
Old 01-20-2009, 09:25 AM   #313
WERD
GET_LOW's Avatar
What size are those rims????
Cause if anythign those drops spindles should be helpin ya on clearence cause they push the wheel out another 1/2 inch or somthing like that.
Make em wokron the hombre, they look sick!
Old 01-20-2009, 12:37 PM   #314
Tuckin15's's Avatar
x2
Old 01-20-2009, 05:38 PM   #315
Those are 18's in both pics. I have a 18/20 combo that came with the hombre, thought why not, i'm always around people with s-10 lookin for wheels so I took them. Way back when I took the orignal 14's off the hombre I found one 1/4" spacer on the back wheels. I'm guessing they ran them all the way around and accidently left one on there. The tie rod ends have been ground down from the wheels so I know they were on there at one point in time. Not sure how wide they are.
They def aint goin on the blazer, I was just checkin that to see if they cleared on there, i'm thinking some 22's for the blazer in the future with a small drop.
Old 01-20-2009, 09:20 PM   #316
Back in CALI
SHROP's Avatar
how much for the 18s?
Old 01-20-2009, 11:18 PM   #317
I doubt I get rid of them, and i've only got 2 18's not a whole set. I'll prolly start another truck this summer from stock so I can say I did the work so i'll keep them around.
Old 01-20-2009, 11:24 PM   #318
WERD
GET_LOW's Avatar
hhmm. Well it sounds liek ya got too wide of a wheel for your diameter. Ya coudl run the 18s abotu back and the 20's up front???
Stil diggin the steelies with the moons. One of my altime favorite setups, and its cheap!!!!
Old 01-21-2009, 12:42 AM   #319
Yeah their def wide, they barely clear the fenders, and then with that 1/4" spacer my wheels would have to be perfectly straight to lower it even a little.
On another note, I think I tracked down a tilt column here on the forum in Jeff City.
Old 01-21-2009, 12:59 AM   #320
Registered Boozer
awesome! ya tilt steering!
Old 01-21-2009, 04:57 PM   #321
Yeah i'm more excited about being able to have space between my thigh and steering wheel
Old 01-22-2009, 06:16 AM   #322
dimeon15s's Avatar
WTF is this bro? Big shiny whels i think not. I havent been reading this alot lately but i see youve been very busy! If you dont use your stelies send the moons this way lol. Looks good looks like you have alot of work ahead of you.
Old 01-22-2009, 11:48 AM   #323
Yeah the big shiney ones arnt goin to fit so its all good, I they did I would only be able to get a piece of paper between them and the fender when at ride height, so on a drag strip I could run them haha
Old 01-25-2009, 04:16 PM   #324
Picked up the new column yesterday from 2.2x-10 here on the forum, next weekend hopfully i'll be swaping those out. Still lookin for how to get the ignition off, I only see one of the 3 torx screws that I read hold it on.
I see the one here right above the key, I guess I have to remove the wheel for the others?
If any of you can point them out that would be awesome.
Also the harness had been spliced into twice, i'm guessin a constant for a radio, but if you know what these 2 wires did post it up. I'll fix the yellow, but prolly just leave the crimp/splicer on the orange one.
Old 02-09-2009, 05:39 PM   #325
Alright, I havnt updated this much cause I havnt done to much. I had to search all over the place to figure out how to remove and swap the ignitions. So once I thought I knew what I was doin and had the tools I took my junk column apart. Then I finally went at it with the 2 good ones. I took pics of the tear down in case anyone in the future needs some, cause it would have helped me.
Heres the two I hadnt taken apart yet
Start by taking out the airbag, theres a how-to on this and the whole steering wheel here http://www.s10forum.com/forum/f200/h...emoval-295279/. Heres the whole to remove the air bag
The clip in the back of the airbag
This is what you should be left with
This remove the horn switch, by pushin down then twisting like a like socket.
Then remove the steering wheel nut
Install the steering wheel puller, and go like hell until the wheel comes loose.
Heres the package for the puller, picked it up at Auto Zone for $16.
Old 02-09-2009, 05:59 PM   #326
Then your left with the clock spring, which in above post you can see how not to take apart haha. Theres just one snap-ring in the middle to remove and the whole thing will come off together.
Heres the snap ring
Now your left with the locking plate.
Which has a snap ring, kinda a dark picture but you can see it
To remove the ring you'll need this, also at Auto Zone for another $16.
TADA! I used the snap ring plyers and a small screw driver to get it out, its a pain in the ass.
This is what the horn pluged into, it just slides off with the locking plate.
Now you can get the the torx screws for the turn signal switch, and the ignition.
Heres the 2 for the turn signal switch, mine were marked with baby blue paint.
Thens theres 3 in the ignition, which I didnt get a picture of, must have been to thrilled that I finally got to them and didnt think to take a picture. Take those 3 out, and your done. Just swap them onto your new tilt column.
Heres the ignition off the column
Then both the turn signal and igniton seperated
And my awesome work space durning the week, the un-used corner of my apartment haha
Now that i'm done with this I have to track down some new e-fans.
Old 02-09-2009, 07:28 PM   #327
WERD
GET_LOW's Avatar
That looks like a bitch. At least you put it back together right the first time hopefully.
Old 02-09-2009, 09:01 PM   #328
layin rocker
BaggedOn420s's Avatar
wow. i dont think i could pull that off without shootin myself in the knee cap
Old 02-10-2009, 12:14 AM   #329
Yeah I got it all back together, I put it in the truck the past weekend and hooked it up real quick, it started and ran fine. Just gotta find some fans now so I can get it drivable again.
Old 02-10-2009, 07:52 AM   #330
Registered Boozer
Wow! Good work man! Keep that shit up!
Old 02-10-2009, 11:23 AM   #331
Thanks, right nwo the cabs still stripped, and i'm tryin to remove all the old silicon thats over the weld so I can put in some seam sealer, and then maybe try and find some carpet if I can make it fit. All it needs to be driavable again is some fans.
Old 02-10-2009, 02:24 PM   #332
dimeon15s's Avatar
I bet your glad thats all over, looked like a mess.
Old 02-10-2009, 04:13 PM   #333
It wasnt really all that bad, but I had a junk one to practice on first. That helped a ton to see how its all together, the only thing I was unsure of was how the steering wheel locked, but that wasnt to complicated. Deff worth it if you have a body dropped truck with out tilt steering haha.
Old 02-10-2009, 11:04 PM   #334
dimeon15s's Avatar
Hopefuly ill run into that problem soon. I feel a bd coming. Especialy with the 15s, dosnt tuck much at all.
Old 02-10-2009, 11:50 PM   #335
Yeah, just cant wait to get this thing back out on the road for spring.
Old 03-16-2009, 01:39 AM   #336
Alright a little update on this thing, no pics tho. From the last time I got the column in and working, but I had to take it back ou to hook up the steering shaft part, so thats in now, and I can turn again, even tho its on jackstands haha.
Ordered my fans from summit yesterday so they should ship monday and be in by next weekend so I can put them in.
Also I started sandin the floor, i'm gonna give it a coat of dupli-color roll on bedliner just to clean it up a bit after I seam seal the floor. I figured it will be a little while before I get carpet for it, and I figured a liner would make it look better, and maybe add some sound deadening.
And last, I have alot of the interior pieces up at school that i'm tryin to get painted before a small car show at school. So far on them i've shaved over the door locks, the airbag switch in the bezel, the seam in the knee guard, and the e-brake release handles spot. I'll get some pics of those this week along with the other parts i'm gonna paint. Should come together pretty quick.
Old 03-16-2009, 02:18 AM   #337
My self esteem is lower
get layed's Avatar
Rightious, can't wait for updated pics. What a badass mini truck! Keep it comin man!
Old 03-16-2009, 02:21 AM   #338
Will do, this wek will be mainly waitin since i'm on spring break i'll just be sittin in my apartment wishin I was working on it haha.
Old 03-18-2009, 11:15 AM   #339
Useless posting member
Wrkn prgs's Avatar
I had to come back to your thread and see you truck again.. I just found a mint Hombre sitting in a local scrap yard
Old 03-18-2009, 01:04 PM   #340
square body newbie
Derek1387's Avatar
i gotta come chekc this truck out man. Im with D.O. KC...
Old 03-18-2009, 02:52 PM   #341
Dude buy it and ship it to me
Old 03-18-2009, 02:58 PM   #342
Yeah I'll be out and about with it here this summer, if you see it out just ask around i'll be somewhere.
As far as updates I have a couple pics but their on my phone and I have to download some crap to this new comp to hook my phone so i'll try and get that done today.
Old 03-18-2009, 04:27 PM   #343
WERD
GET_LOW's Avatar
man, i love this truck. I foudn almost everything i need to switch it over locally.
seriously thinkin about doin it.
Old 03-18-2009, 05:57 PM   #344
Just get ready to answer 100?'s about why you put a ford ranger front end on your chevy, its tons on fun.
And some pic's, apparently I can blue tooth to my new comp its badass.
This is how its been sitting in my garage ever since I brought it home from school.
And the interior, still missing. I've got the floor taped off and did a little prep for the roll on bed liner.
EDIT: wow those interior shots looked alot better on my phone, sorry for the bad pics
Old 03-18-2009, 06:09 PM   #345
Heres what i'm planning on using on the floor of it, just to clean it up until I find some carpet.
And a sample of what it looks like
Heres some shots on my interior i'm workin on.
These need another coat of filler on them to keep sanding then I need to knock down the rest of the texture and get them ready for primer. Heres what i'm using as filler and to bond in the filler pieces.
And lastly my half ass attempt at a skull in my air brush class, its only and hour on tue and thur so we're not getting anywhere to quick, but still a cool credit.
Old 03-18-2009, 07:11 PM   #346
Registered Boozer
I don't see a skull. C'mon man! Don't slack!
whats the sheet metal s10 for?? Is it a SD keychain?
Old 03-19-2009, 12:19 AM   #347
Huh guess I forgot to paste that link in
The sheet metal s-10 is from some kid in machine tools last semester here, I seen he was making them and I ended up with one. He just added a cowl hood to SD's design it looks like, and made them bigger.
Old 03-19-2009, 12:44 AM   #348
Redd's Avatar
lol you bought way to many tools to take the steering wheel and clock spring stuff off.. I got my wheel off with out a puller, and used 2 pics for the snap rings.
Truck looks good man
Old 03-19-2009, 04:04 PM   #349
I'm in school for autobody, and I work on alot of stuff anyways. More tools is never a bad thing. Just wanted to get it done and I didnt have much to work with when my tools were locked up at school.
Be sure to vote for my truck, I want those chairs but doesnt look like its goin to happen haha.
http://www.s10forum.com/forum/f42/dime-voting-thread-4-a-393551/
Old 03-19-2009, 04:39 PM   #350
It's a Blue thing...
♠ M®. ßlυε ♠'s Avatar
You got my vote, good luck.
