4 Door Blazer Xtreme Conversion
Go Back   S-10 Forum > Member Forums > Member Rides
Old 12-05-2007, 08:31 PM   #51
Misses the vette
americasfuture2k is on a distinguished road
Re: 4 Door Blazer Xtreme Conversion
any updates? i am wanting to do close to the exact same thing. ive got a 98 LT. im gathering info, then it will be the parts. im going to leave mine auto. it has a brand new motor. ive got some one touch window kits im putting in all 4 doors. i plan on doing heated seats for every seat. im building up a carputer right now. just waiting on some jb weld to dry and for the dealer to fix what they broke last week. jack asses..... ive got a nice set of euro clear headlights with parts of the reflector assy painted black. doesnt really look good on my blazer. looks like it has black eyes. ok, sorry for stealing this and going on and on and on.....
Old 02-04-2008, 10:01 PM   #52
5 speed 4 door blazer
nycblazer96's Avatar
nycblazer96 is on a distinguished road
as of today my 2001 blazer is gonna be a 5 speed, i already added the pedals and the clutch master cylinder are installed.
now that i have the engine out i'm replacing all the gaskets, timing chain & cover, front and rear main seal before it goes in..
tranny is also getting a new centerforce dual friction clutch with a centerforce bearing also, and some new pennzoil manual tranny syncromesh oil.
more toooo come. gonna take some pics soon and post them
i was doing another project on my 99 blazer but its on hold til i get my engine harness
Old 02-04-2008, 10:12 PM   #53
I.G.'s FTW!
ZQ8 Blazer's Avatar
ZQ8 Blazer will become famous soon enough
If you're still looking at putting the fender flares on the back doors then you may want to get some cladding off of a bravada. I was at a junkyard last week and they have the molding and some flares built onto them, they're a little different from the xtremes, but you could graft them together.
Just an idea.
Old 02-04-2008, 10:16 PM   #54
THANKS I WAS LOOKING AT THAT, BUT I HAVE THE XTREME skirts for it already my autobody man said hes gonna cut them and mold it onto the rear doors so it can open but that not close to getting done yet. need lots of $$$$$$ to dothe whole truck over in paint
Old 02-04-2008, 10:21 PM   #55
Whood'a Thought
russell's Avatar
russell is on a distinguished road
Pics no worky for me
Old 02-04-2008, 10:29 PM   #56
I.G.'s FTW!
ZQ8 Blazer's Avatar
I didn't mean use the entire cladding, I meant you could use the part of the cladding that has the flare and screws to the door and goes from the fender to the door and then use the xtreme flare for the outside then glass them together. You'd really kinda have to be looking at it with me showing you to get what I'm talking about, but I think that'd be the easier route to go and when it's all done it'd look just like an xtreme still
Old 02-04-2008, 10:32 PM   #57
Misses the vette
what color? black is the only color i like for the xtreme and tallhoe limited
Old 02-06-2008, 10:25 AM   #58
ClubECM.com
TA^Guy's Avatar
TA^Guy is on a distinguished road
Why not just get extended cab Xtreme rocker extensions and mold them together?
Old 02-19-2008, 08:13 PM   #59
UPDATES
i got the the wrecked 2001 blazer xtreme engine and tranny in my 2001 4 door blazer everything is a go.
at first i had a hard time trying to start it, and it would not start because of the factory installed security system called passlock.
what i did after 3 hours of trying to start it. i reprogrammed all the codes. and it started right up. duh
what i did was put everything from the wrecked 2001 blazer xtreme into my 2001 4 door blazer
everything from the spoilers, grill, fog lights, engine, tranny, harness, ignition key, column wich i also made into a tilt column with cruise control too, ECM, BCM, fog light harness, guage cluster.
i also sent out the 2001 blazer xtreme title to be made a parts only title. this way i dont get into any trouble with the law lol. kiss my @$?
everything is working sunroof and power windows working, onstar also working.
as of now everything is done just need to get the console in wich fitted perfect and the seats back in, then i'll get it cleaned up and detailed
i dont have pics right now but as soon as it take some more i'll post them...
Old 03-03-2008, 09:26 PM   #60
more updates
after the 3 hours of trying to start the engine, i forgot to prime the engine for oil to lubricate, and guess what happened. almost all of the piston rod bearings got all messed up, no oil there. i guess that from the engine cranking on a starter it dosent make enougth oil pressure. when i got it started after a while i noticed some really bad internal vibrations coming from the engine.
ohhhh well i took the engine out last week, and now i have the original 156,000 mile engine in it wich was the original from this truck. i took of the old oil pump and replaced it wich a high volume oil pump, with a steel shaft and guide. new timing set, took off the flexplate added a new pilot bearing PN ct1081 installed the flywheel, clutch, and pressure plate, a few freeze out plugs replaced, new rear main seal, new radiator, new oil cooler lines,and a bunch of other new stuff i still havent received yet.
this baby has to last me years to come.
i'll post some pics of it tomorrow.
Old 03-07-2008, 11:37 PM   #61
i got it running and it runs nice now that its a 5 speed, ohh man i love this truck now. all i need is the side skirts and i have a 4 door blazer xtreme lol. now i need to lower it some its too high. i'll take some pics and post them up tomorrow
i found out what messed up my other 4.3l engine and it was the dam flywheel i sent it out to get resurfaced and they f it up.
so i went on summitracing bought a new centerforce flywheel and all the engine vibrations are gone now. amazing....
Old 03-07-2008, 11:43 PM   #62
Quote: Originally Posted by orangesonoma
make it a 5 speed...that would be sweet
now it is.. sweeeeeeet.
Old 03-07-2008, 11:56 PM   #63
Whood'a Thought
russell's Avatar
All these words and no pictures...
Old 03-08-2008, 12:00 AM   #64
i'm working on them right now
loading them to my album
give me a sec hehehehehe
Old 03-08-2008, 12:01 AM   #65
Old 03-08-2008, 12:09 AM   #66
NOW AIR RIDE EQUIPPED!
vortec97's Avatar
vortec97 is on a distinguished road
Quote: Originally Posted by greenflameS10
wings west > xenon
no no no its stock>wings west>xenon
Old 03-08-2008, 04:14 AM   #67
chrome bumpers suck!!
mels98s10's Avatar
mels98s10 is on a distinguished road
thats awesome, cant wait to see this thing done!
Old 03-08-2008, 02:48 PM   #68
MARS2878 is on a distinguished road
Looking Good
I Was Thinking Along The Same Idea, But With My '93 Bravada So I Can Have An Awd 4.3l W/5 Spd Tranny (haven't Seen That One Yet)
Keep Up The Good Work
Old 03-08-2008, 02:49 PM   #69
What?
cwd240z's Avatar
cwd240z is on a distinguished road
5 speed in a 4 door...very nice.
Old 03-08-2008, 05:05 PM   #70
Have a nice day!
ProTouring2.2's Avatar
ProTouring2.2 has a spectacular aura aboutProTouring2.2 has a spectacular aura aboutProTouring2.2 has a spectacular aura about
well yeah... but the xtreme blazers were all 2 door. The only side skirts that would fit are aftermarket, unless he wanted to graft 2 side skirts together or something
Old 03-08-2008, 05:14 PM   #71
Master's Apprentices
MINTSICK's Avatar
MINTSICK is on a distinguished road
Wow very cool, I remember seeing a 5 speed 2wd 4dr in another country...possibly bermuda but not sure but it looks stock now!
Old 03-08-2008, 05:20 PM   #72
csmizzlesxblizzle's Avatar
csmizzlesxblizzle is on a distinguished road
cant wait to see this done... looks like nice clean work so far
Old 03-08-2008, 09:21 PM   #73
I wonder how it tastes?
cpolaris502's Avatar
cpolaris502 is just really nicecpolaris502 is just really nicecpolaris502 is just really nicecpolaris502 is just really nice
5spd in a 4 door is awesome. what was it like mouting the clutch pedal and clutch master on the firewall? how'd that go?
Old 03-08-2008, 09:25 PM   #74
vortec97's Avatar
yea i wanted to know that as well...
Old 03-08-2008, 11:06 PM   #75
man if i tell you, you wont believe me.
all it took was alot of patience and alot of walking away from this project lol.
but nahh it aint take much since i had both trucks and they both where the same year.
i had to take the dash out, cut the hole in the firewall, install clutch master, install the footpedal for the clutch, put dash back on. remove engine harness and ecm from the automatic to swap the 5 speed engine harness with the 5 speed ecm, then do the passlock reset, thats only if your switching columns with i did also. it is alot of work. but now i know how to do it this time if i do it again it will be way much more easier. i think i can do this again in less than 2 weeks maybe 1 week if i get really dedicated.
this is my second 4 door blazer i've converted to a manual tranny, my other conversion is a 1999 4 door blazer getting a 2007 cadilac escalade 6.2L v8 engine with a brand new dodge viper t-56 6 speed tranny, and a nice 8.5 inch rear end posi. i went all out on this one. if you want to see the thread here's the link to it.
get your napkin ready your gonna drull on this one
http://www.s10forum.com/forum/f213/9...thread-333915/
Old 03-09-2008, 01:15 PM   #76
so the pedal mounting assembly is different and all of that?
Old 03-09-2008, 04:10 PM   #77
no the pedal mount is the same. all i did was take the 5 speed pedal mounts and put them on my 4 door blazer. its all the same. just that one has another pedal.
Old 03-15-2008, 12:09 AM   #78
Its a Blue thing.
Mr Blue's Avatar
Mr Blue has a spectacular aura aboutMr Blue has a spectacular aura about
If your not sure what to do for side skirts yet, the 4dr S10 Trail Blazer came stock with them.
Although they aren't like the xtremes side skirts they are skirts with come down even to with the front valance.
Here is the vin # of a 2000 4dr S10 Trail Blazer if you need.
1GNDT13W3Y2257613
Old 03-15-2008, 12:15 AM   #79
this is what it looks like today, tomorrow i'm gonna add 2 inch drop spindles and 3 inch blocks for the rear so its gonna be lower i hope
Old 03-16-2008, 12:25 PM   #80
Minnesota Man
black_blazer's Avatar
black_blazer is on a distinguished road
Nice work !!!
yes yes yes this is gonna be awesome baby ! Can't wait to see it with skirts and flares also
Old 03-16-2008, 01:55 PM   #81
before
after
  1. complete ZQ8 suspension front & rear Belltech 2 inch drop spindles front & 3 inch blocks rear
  2. xtreme kit except for the side skirts and fender flares for now
  3. 5 speed manual transmission
  4. MSD blaster coil
  5. air raid throttle spacer for a little more torque
  6. 20 inch rims
Old 03-17-2008, 12:12 PM   #82
i need parts!
redsdime's Avatar
