weight difference between 1 and 2 gen
Go Back   S-10 Forum > OT Forums > Racing
Old 06-22-2009, 11:40 AM   #1
whats the weight difference between the first and 2nd generation s10's? i found alot of information on the first gen trucks but nothing on the 2nd generation...
im looking at single cab short box pickups in both models. 2wd. im looking at building a drag truck.
Old 06-22-2009, 12:16 PM   #2
NOBODY FUX WIT DA JESUS!
jeffs99dime's Avatar
Re: weight difference between 1 and 2 gen
need to know exact years for each gen and motor sizes
Old 06-22-2009, 12:48 PM   #3
either truck will be getting a LS1 and 4L60e
which year is lightest on each vehicle? they all look about the same to year by year.
Old 06-22-2009, 12:55 PM   #4
AWD V8's Avatar
My guess would be a 1st gen short box 2wd, with little to no options.
Old 06-22-2009, 01:14 PM   #5
on average, how much heavier would a 2nd gen s10 extreme single cab short bed stepside be over a first generation single cab short box?
just looking for a rough estimate. nothing exact. if its only a few hundred i would sacrifice that for the styling of the 2nd gen. its more my style.
here is my current truck
im wanting to take the drivetrain from this truck and stuff it into a s10. my current best in the 1/4 is a 11.65@117 from last weekend in texas heat. spun through 2nd gear.
thats my main reason for swapping it to a s10..lighter weight and better traction.
Old 06-24-2009, 02:36 PM   #6
XDime99's Avatar
Hey dude, wikipedia(SP?) them shits bro, i found out how much my X-cab X weighed on there, they have scales for the years and engine types, its a lotta reading, but you can learn a LOT about S-10's from it!
Old 06-30-2009, 03:25 AM   #7
i believe the first gen is around 400#s lighter
Old 07-01-2009, 08:51 AM   #8
You can't polish a turd.
devil boy's Avatar
Location: Hawaii - stationed in S. Korea - chillin' in the Philippines
My 2003 S-10 regular cab with a stepside weighs about 3050 lbs. I have a 50-70 lbs tonneus cover on the back, so you could probably subtract a bit from that total. Here's a simple diagram with the corner weights and info when I had it corner scaled.
I don't know what a 1st gen weighs, but I hope this helps give you some kind of comparison.
Old 07-04-2009, 02:44 PM   #9
The Eye is watching you!!
kamesama980's Avatar
'87, short cab, short bed, 2.5 4 cyl, 4 speed manual, 2wd, base as can be.
2700lbs empty
Old 07-08-2009, 09:48 PM   #10
rb25det inside :D
scottymizt's Avatar
my 99 standard cab short box weighs 3600 with out me in it but i do have about a 200lb box,20's, and a different engine. I will tell you that the frames are boxed farther down on the second gen vs the first gen. The crossmembers for the tranny are different too, the second gen is heavier built, imo i'd rather have the second gen for the extra support vs the first gen's lighter weight.
Old 08-20-2009, 03:44 PM   #11
dude, i know im late, but you ROCK!
thats the best answer ive seen through all of my searching. everything else says that the trucks are up around 4,000 lbs. i found a 2001 s10 xtreme for 1,500 that im going to look at today. no motor and no transmission. perfect for what im looking to do!
Old 08-21-2009, 04:21 PM   #12
montec's Avatar
My '83 with the front diff and all the axles out in front with me in it unloaded was about 2900lbs or so.
Old 08-22-2009, 05:30 PM   #13
meyers2211's Avatar
idk how u got urs to weigh 3000 unless its a 4banger.
my v6 turbo, with no ac component, CF hood, slicks and skinnies on drag wheels, step shavers, has never been under 3k lbs. When i got the truck it was 3850 w/driver. reg cab stepside
Old 08-23-2009, 01:48 PM   #14
montec's Avatar
No front diff or axles in the front. I have a/c delete and no power anyting. And yes it has the 2.8L v-6 with a 700r4. Running the 5spoke 4x4 rims and had lt235/75r15 tires. I had it basically all cleaned out nice no sub box and its a reg cab LB. And thats what the scale said @ the dump after my load of carpet and sheetrock that put my truck in @ 5600lbs going in.
Old 08-24-2009, 04:55 AM   #15
devil boy's Avatar
Just a thought, but it may be the type or calibration of the scales you were using. I wouldn't trust those scrap yard / big truck scales. The scales I used were the Longacre Racing digital scales that measure all four wheels and give you your corner weights and front and rear weight differential. I have more faith in those readings than any other scale that might be out there.
Old 08-24-2009, 10:53 AM   #16
montec's Avatar
Yeah but with a certified scale I can get my weight on my registration lowered so that I pay less for renewal. I pay the same as a 1ton truck since the DMV has the weight @ 6800lbs.
Old 08-25-2009, 01:02 AM   #17
The Blown Blazer's Avatar
My Xtreme reg cab with a SBC with iron heads, 700r4, 15" steel wheels, and a fuel cell weighed 3240 without me in it.
Old 08-26-2009, 12:55 AM   #18
drag racin > dragin frame
v8lonoma's Avatar
id say get a 2nd gen and make it lighter..
if its going to be a drag truck theres a lot of things you can do to reduce weight. take out the inner fenders, fiberglass hood, take out the HVAC system. aftermarket seats. suppose you could throw a light soft bed cover on it and cut the bed floor out.
btw my second gen was about 33-3400 with me in it.. and im no lightweight either. sbc, havnt removed the hvac or inners yet. stock gas tank. cant remember if that was with the 18s or drag rims either. ill be weighin it again soon with no hvac and no inners.
Page generated in 0.59958 seconds with 31 queries
[Output: 100.58 Kb. compressed to 93.29 Kb. by saving 7.29 Kb. (7.25%)]
