Post Your 1/4 Times Here!
Go Back   S-10 Forum > OT Forums > Racing
LinkBack (1) Thread Tools
Old 04-02-2004, 07:07 PM   #101
Akerfeldt
MINTSICK's Avatar
Re: Post Your 1/4 Times Here!
Quote: Originally Posted by Rhansen
Damn, I used to pull 2.25-2.30 60' times with an open diff. and 3.73's, just letting it spin. You should persuade your track to prep the launch pad or something.
Yeah no kidding, I was told that they put traction compound down on friday nights, but I've been there on a friday and never saw them prepping anything. Aside from that, I just need to find a better setup for traction, I must have been running the wrong tire pressures or something, but I know I need traction bars now. It's pretty sad that my best 60' is a 2.38 and I run 15.8's, I should be a lot quicker with a decent 60' , don't you think? Any tips for running street tires? By the way all my runs to date have been with a gov-lock 3.08 equipped rearend, I hope the eaton 3.42's will help out as well.
Old 04-02-2004, 07:32 PM   #102
footbraker
Rhansen's Avatar
I'm using 275/60-15 (28x10) Yokohama Avid ST's with a locking diff etc. and if the track isn't prepped my 60' will fall off to around 2.15. Just burn them enough to clean the tread and don't worry about tire pressure - the best 60' I ever got on street tires was with 35 psi in the tires. If you can get your 60' down to 2.18 then you should run around 15.60. BTW I am very satisfied with my SSM lift bars, but I can't say how much difference they made because I did too many things to my truck at one time.
Old 04-02-2004, 08:12 PM   #103
Akerfeldt
MINTSICK's Avatar
Thanks, I think I ran my tires at 25psi a couple times and usually did not burnout at all, this time I will just leave the tires alone to start and then go from there. I will probably only be getting a cheap set of lakewoods since I don't frequent the track more than 3-4 times a year to race, but they should help out some. I'm in the same boat, if my times get better I won't be able to tell for sure what attributed to it, but any increase is good.
Old 04-02-2004, 10:32 PM   #104
www.myspace.com/MINTSICK
jmwxtreme43's Avatar
i lowered my tire pressure and i gained a 10th
Old 04-02-2004, 10:35 PM   #105
CANADA SUCKS
WAREAGLE's Avatar
I can run a 1/4 in about 1/4 an hour. my truck sucks
Old 04-03-2004, 06:21 PM   #106
x01
Some of us don't have a 1/4 mile track. So what about a 1/8 mile list?
Old 04-03-2004, 07:27 PM   #107
Banned
97s-dime4.3's Avatar
1/8th mile = 8.5@84mph
edit: this is 97se-r posting at my friends house. those are the 1/8th mile times for the 200sx
Old 04-03-2004, 09:00 PM   #108
footbraker
Rhansen's Avatar
?Maybe we should set up a time slip database?
Old 04-04-2004, 12:26 AM   #109
sounds like a very good idea, some people may not have scanners though, but i guess a digi pic is just as good
Old 04-04-2004, 12:28 AM   #110
footbraker
Rhansen's Avatar
Can always go on the honor system but have to watch for BS. I throw away all my timeslips after I record them in my logbook. Of course I can always get more timeslips.
Old 04-04-2004, 06:12 PM   #111
Carmelo Gaudite's Avatar
Quote: Originally Posted by Navecm
Lately browsing not just this forum, but others...it seems that everybody has a wide range of 1/4 times, some seem outrageous with the mods that they had....and some are blatent pure lies.
So I ask for you to post your 2.2, 4.3, V8, any s-truck non lie, non myth times, feel free to link to slips or videos, but dont waste our time by posting what your camaro or whatever else you have runs, or posting your mind altered, or altitude corrected time.
When I had my CPI 4x4 with K&N (2dr blazer), and Flowmaster I ran a best of 16.955@79
No Times with the LT1 yet.
11.70 @ 117mph with 60' 1.60, I have a 91 Sonoma S-15 Xtended cab, have a 383 with a Vortech S-Trim blower , had two runs @ this time last Sept.,03 in Atco ,NJ, I had some lean condition on the mid to top range but I did not push it hard, being worked on now for a new fuel mgmt. system and I 'll keep you guys posted.
Old 04-04-2004, 06:39 PM   #112
97LOWNOMA's Avatar
can someone update my time on the sheet i just ran the time listed in my signature
Old 04-04-2004, 07:10 PM   #113
footbraker
Rhansen's Avatar
Yeah, burned pistons suck.
Old 04-04-2004, 07:49 PM   #114
I'm BLOWN
n_v_my_noma's Avatar
17.2@80mph 2k noma ZQ8..it was my first time on a tree, and my r/t SUCKED ASS..1.33 the first run 1.18 the secong I gots a long way to go..but if you look at my slip..if i woulda had a decent r/t i probably woulda been 16.9xx but o well..i'll be practicin
Old 04-04-2004, 07:59 PM   #115
footbraker
Rhansen's Avatar
Reaction time has no bearing on your ET. The timer doesn't start until you cross the line. R/T is the time from when the light turns green until you cross the start line, it only matters when racing (you still have to cross the finish first, regardless of ET, to win, unless there is a red light or breakout.)
Old 04-04-2004, 08:33 PM   #116
14.9!? Wtf? You barely have anything done, come on tell us your other mods or lets actually see a proof video, tell me, what your stradegy is, what tire pressure your launching at. Is your local track nice, ours is notorious for no traction, did you do a burnout before each run, i personally find a 14.9 hard to believe with such minor modification outta these trucks. If HPP3, headers, Y-Pipe and EGR will give me .8 of a second off of my 15.7 i will be impressed.
Old 04-04-2004, 09:42 PM   #117
97LOWNOMA's Avatar
20 psi in the rear 45 in the fronts. track has crappy traction but i can get a good launch with a automatic. no waterbox, 2 dry hops just to clean the crap off my tires and heat em up a little. launch at 800-1000 rpms and easy into the throttle. if you dont believe me, jlaudio will be online later to back up my time. and i would be more than happy to get a video if your willing to send me a video camera in the mail to borrow for a couple days. i have no need to write false times that people like you will call bs on. the only reason i put my mods in my signature and make posts about how i got my truck to run faster is to help other people get there vechicles faster. if you had a good set of tires to go along with that 5 speed of yours (i think you said before that u had a 5 speed) you could easily get low 15's with your mods. i can't wait to get mach programming, 1.6 roller rockers, and some et streets, then you'll really be calling bs on my low 14 second pass. like i said i only make these posts so other people with s10's know what works and what doesnt work with modifying the 4.3.
Old 04-05-2004, 01:01 AM   #118
LT1 Powered
Navecm's Avatar
yeah a 14 second pass in a mildly modded s-truck does sound far-fetched (also sounds like you got pretty good traction), but if you say you did, then you did.
Old 04-05-2004, 01:41 AM   #119
20 psi seems really really low, good traction but might hurt the mph? You must have an awesome track cause here in New England NO ONE can get traction. I will try launching in the 800-1000rpm. I cant shift as fast i can w/out getting massive gear rubber, ( i know that must be hurting my time ) my additions to this time at the track will be, better stradegy, tire pressure, trying not to bake the gears, HPP3, Y-pipe, JBA headers and EGR mod. I dont know, im hoping for something good but have a feeling i will be dissapointed
Old 04-05-2004, 01:52 AM   #120
Black SS
97S10SS's Avatar
20 psi is nothing, I go 15 psi in my drag radials and I did with my street tires too. I believe his times, high high 14's is possible with a reg cab and a few mods. Hes probably running at a good track like mine thats near sea level. Also a few of my runs were made in temps lower than 50 degrees.
Old 04-05-2004, 03:09 AM   #121
FLAVOR FLAV!!!
JLAudio11's Avatar
Yes i witnessed 97Lownoma run 14.9's. He consistently gets 2.1 60's, today i mostly got 2.44 60's with some 16.2's last time i ran and got 16.2's i had 2.3 60's. Maybe our track isn't too bad, I'm constantly tryin to control wheelspin off the line and run 2.4 and 2.5 60's with a lot of wheel spin usually.
Old 04-05-2004, 02:40 PM   #122
Gear Banger
sixspeeddemon's Avatar
Before I Got My 9-inch In, The Stock One -legger Rear End On Some 275/60-15 Bfg Radials I Got A Best Of A 1.90 60 Foot, But I Had To Burn The Piss Out Of Them In The Box, A New Set Only Lasted A Month, And Only Made 12 Passes. Just Changing To The 9-inch W/4.11 Gears And A Full Spool Dropped My 60 Down To The 1.70's, Which Converted To .6 Off The Big End And Actually Added 2-3 Mph.
Old 04-05-2004, 02:49 PM   #123
zY
I completely believe that time. I had essentially the same mods as him when I ran my 15.1@89, plus he's std cab, and had a better 60' than I had, I see no reason not to believe it.
Old 04-05-2004, 04:52 PM   #124
i believe it, just is a little shocking....hmm well i'll just see what i can get if it dont rain on friday.. 15 psi on street tires!? Man, i gotta drive home a little while so im not going any lower than like 20-25. Our track is only 90 feet above sea level. See what happens i guess
Old 04-05-2004, 06:18 PM   #125
first time out with high rpm fuel starvation and on 35 psi street tires.
60 ft. 2.195
1/8th e.t. 9.991
1/8th mph 70.42
we dont have a 1/4 mile track around here so all i have is 1/8th
Old 04-05-2004, 06:36 PM   #126
footbraker
Rhansen's Avatar
Calculator site from hell (including 1/8 to 1/4 mile conversion)
http://users.erols.com/srweiss/
Old 04-05-2004, 06:45 PM   #127
footbraker
Rhansen's Avatar
My bad - wrong link, www.edstephens.net/1_8_mile.htm is the correct link but it is down right now. Maybe it will be up later.
Old 04-06-2004, 12:26 AM   #128
Spark'n it Up
XtremelyLowRide's Avatar
anyone know where i could find some drag radials or other rims that i can use instead of my 18's? I think I could have ran better w/o the rims.
Old 04-06-2004, 07:04 PM   #129
Akerfeldt
MINTSICK's Avatar
summitracing, jegs, ebay, wantads?
Old 04-07-2004, 09:59 AM   #130
footbraker
Rhansen's Avatar
I just picked up a set of drag radials for $60 from a friend of mine that runs a reair shop/used car lot. Too good of a deal to pass up.
Old 04-07-2004, 11:51 AM   #131
LS2OMFG
Ralphie's Avatar
I'll trade my ZQ8 wheels/tires for your 18's
Old 04-07-2004, 01:44 PM   #132
LT1 Powered
Navecm's Avatar
an update...
Member.................. 1/4........................... Truck
n_v_my_noma........17.2@80.................00 Sonoma
Ralphie.................... 17.10@??.?.......... 99 S10 4.3 auto X Cab
JMW92s10...............17.03@79.5..........92 S10 2.8 5 Spd Reg Cab
Navecm................... 16.95@79.9..........94 Blazer 4.3 auto 4x4
03zq8....................... 16.90@82.2 ..........03 Sonoma 4.3 5 Spd
mrshaft696............. 16.5@83.0 ..........99 Sonoma 4.3 5 Spd X Cab
j_gor78.................... 16.4@82 ..........99 Sonoma 4.3 Auto X Cab
Green Monster 98.. 16.39@82.12 ..........98 Sonoma 4.3 Auto X Cab
JLAudio11................16.27@81.24......92 Sonoma 2.8 5 Spd
Yanosh.....................16.2@83.............98 S10 SS 4.3 Auto Reg
mister880................16.09@82 ..........98+ S10 4.3 auto X Cab
Fool182....................16.01@83.............00 S10 4.3 auto X Cab
BlackS10SS............16.0@83.................97 Sonoma 4.3 auto X Cab
MINTSICK................15.87@88.2 .......... 00 S10 4.3 5 Spd X Cab
XtremelyLowRide..15.80@87.0 ..........S10 4.3 X Cab
JMWXtreme43........15.76@87.2 ..........00 S10 4.3 5spd Reg Cab
WhiteNoma.............15.39@90.7 ..........02 Sonoma 4.3 auto X Cab
97s10ss..................15.15@88.5 .......... 97 S10 4.3 Auto Reg Cab
BlackS10SS............15.1@89................94 S10 4.3 auto Reg Cab
Zygote.......................15.1@89.............. ..01 S10 X Cab
97LOWNOMA..........14.9@90.37 ..........03 Sonoma 4.3 Auto Reg Cab
Typhoon...................14.20@95 ..........93 Typhoon 4.3 AWD Turbo
Rhansen..................14.05@97.5 ..........82 S10 350/350
ZZ4Blazer ................13.54@103.7 ..........92 Blazer ZZ4/T56
Sixspeeddemon.....13.0n/a, 12.7nos.......88 S10 350 6spd Reg Cab
Carmelo Gaudite....11.70@117................91 Sonoma Blown 383
RANDY406...............9.77@137.84...........82 S10 406
Member.................... 1/4................................ Nissan
97SE-R.....................13.177@105.38.............97 Nissan 200sx turbo 5spd
Old 04-07-2004, 02:42 PM   #133
LT1 Powered
Navecm's Avatar
a mod should make a new sticky of 1/4 mile times, a chart, Name: Year of Truck: Truck model: Engine: Tranny: Modded-yes or no and the 1/4 time...?
well to get back to you on that one, i made an excel chart today out of being pure rattlebrain bored that includes mods, just dont know where to put it.
Old 04-07-2004, 06:26 PM   #134
Akerfeldt
MINTSICK's Avatar
Screenshot it and post as an image?
Old 04-07-2004, 06:30 PM   #135
LT1 Powered
Navecm's Avatar
mintsick, good idea, ill do that in a minute
Old 04-07-2004, 06:32 PM   #136
LS2OMFG
Ralphie's Avatar
*waits in anticipation*
Old 04-07-2004, 06:36 PM   #137
LT1 Powered
Navecm's Avatar
Here it is....
Old 04-07-2004, 07:10 PM   #138
footbraker
Rhansen's Avatar
I think all the ones faster than me are BSing. They should be removed from the list.
Old 04-07-2004, 07:12 PM   #139
97SE-R's Avatar
you know, if you changed the "truck" column to "vehicle" You wouldnt have to make me on a separate list just an idea
Old 04-07-2004, 07:14 PM   #140
First Gens 0wn
CBZED101's Avatar
17.9 @ 76 MPH.
1991 4.3L TBI 4 door, K&N Filter, Flowmaster 40 series.
Old 04-07-2004, 07:16 PM   #141
Akerfeldt
MINTSICK's Avatar
True true, but you are in a different category!
Old 04-07-2004, 11:32 PM   #142
flamedx10's Avatar
And a little tip, that TB spacer you got is actually doing nothing but making a whistle noise. 96+ 4.3 vortech engines are already setup for it, it does jack shit, there are many threads on it
improved gas milage.
Old 04-07-2004, 11:51 PM   #143
Just Shoot it
ss95's Avatar
et in my sig.
Old 04-07-2004, 11:53 PM   #144
Just Shoot it
ss95's Avatar
my mph was 99.7
Old 04-08-2004, 10:34 AM   #145
Gear Banger
how about no, come to CO and we'll see who's bs'ing
Old 04-08-2004, 12:48 PM   #146
K.L.N. Performance
dragster's Avatar
mods are in my post best 12.71 @ 104.33mph
and it built from left over parts
Old 04-08-2004, 03:55 PM   #147
Tucker is mah name
-Tucker-'s Avatar
hmmm, It's not Fool182... just f o o 1 8 2 (just correcting in case these get dropping into a DB later)
Edit: And my mods are: Ractive intake, MAF descreen, TBspacer, TB plate mod, MSD 6A, HPP3, 160° powerstat, Dynomax Super Turbo exhaust...
Old 04-08-2004, 04:05 PM   #148
footbraker
Rhansen's Avatar
lol, I'll be right over.
Old 04-09-2004, 03:37 AM   #149
havok
iqukgmc's Avatar
ok ran tonoght in the 1/8 mile
9.9147 at 68.9mph
60' time 2.140
r/t .975
03 zq8 reg auto
aem cold air intake
jet chip
mach pulleys
Old 04-09-2004, 05:01 PM   #150
Chevy Layin Low's Avatar
9.9147 at 68.9mph
60' time 2.140
r/t .975
03 zq8 reg auto
aem cold air intake
jet chip
mach pulleys
What is that in the 1320? 15.7? 15.6?
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f29/post-your-1-4-times-here-99508/
Posted By For Type Date
drag racing 1 4 mile drag times This thread Refback 11-26-2007 09:02 AM
Page generated in 0.66165 seconds with 32 queries
[Output: 223.00 Kb. compressed to 203.91 Kb. by saving 19.09 Kb. (8.56%)]
